PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. The Wait is Finally Over
  2. injen intercooler piping
  3. injen intercooler piping
  4. Lubross? Anyone heard of it?
  5. EVO 10 Air Conditioning
  6. New Evo VIII Owner right here!!
  7. Evo 7 left taillight needed or can it be opened and sealed?
  8. How do I get 400whp?
  9. good deal on this evo8 mr?
  10. Drivetrain noise?
  11. Have any of you mounted a holster in your Evo?
  12. Battery predicament
  13. Determining car value
  14. Car won't start under 30 degrees
  15. tps sensor and throttle idle servo
  16. What COP is best for my Evo?
  17. Evo 6 TME RS LHD
  18. boost leak test compresor leaking
  19. what built motors are people running
  20. 06 GG Evo IX MR in SPRINGFIELD MO
  21. How long should it take a shop to install L19's?
  22. How do I remove this interior panel? (Wideband install)
  23. Looking For Parts
  24. lost some screws
  25. SES at EXACTLY 1500 miles
  26. 2003 Evo 8 Rear Caster issues. **URGENT HELP PLEASE**
  27. Evo crash takes out electric 20 homes
  28. Lancer Evolution Door Sill Plates
  29. First 1/8 Run in my Evo
  30. Three fuel pumps WHAT!!!
  31. trouble code reading
  32. Front fender mod gap btwn headlight and fender
  33. Evo HID
  34. evo VII idle sticking
  35. Carbon fiber trunk
  36. **HELP** weird whining noise? Evo 8
  37. Drove the Evo in snow for first time
  38. lifter tick? do you agree?
  39. Down pipe rubbing
  40. how to remove 8/9 door handles??
  41. Dreaded P0505 is Back...
  42. Balance shaft or bad clutch? Need some quick advice
  43. Evo VIII
  44. Looking to buy first evo
  45. Exploring options
  46. Front Passenger Wheel not centered in Wheel Well?
  47. evo 1 stalling when coming to a full stop
  48. air coming out driver crankcase vent
  49. Are your Ferodo DS2500 as noisy as mine? :(
  50. Brief/abrupt lose of power when in boost?
  51. Question About Valve Cover Breather Filter?
  52. New to evos but not cars
  53. Which Rear Diffuser is ths? Looks similar, but appears different to the regular Varis
  54. Weird rattle at idle (video)
  55. Can I tow my Evo with tranny out?
  56. 03 evo help please won't start
  57. two concerning questions
  58. Evo 8 not reading coil pack..
  59. EVO 9 GSR Price
  60. rear trailing/lateral arm bushings
  61. ISO Build list for 400-450hp
  62. Buying Evo 8 Engine
  63. custom number plate suggestions for an evoIX
  64. Mass Air Flow Sensor missing, is this ok?
  65. Evo 8/9 Greddy Ti-C
  66. Normal Idle for Evo 8
  67. Need help! Problems with the ETACS ECU?
  68. My Silver Knight hit a milestone
  69. I need to wire up the 3 small factory gauges (battery, boost, temp) in my evo 9
  70. Stutter and full lean @3K
  71. does anyone have a racing outfit?
  72. BP used evo cluster in advertisement
  73. On the hunt for an EVO VIII
  74. Building a rollcage and need a good starting point?
  75. Seriously Inconsistent Boost, Power and Acceleration
  76. High mileage chassis rigidity options without rollcage
  77. old rings in new pistons?
  78. HELP!!! No power when I turn the key to on!
  79. Evo8 won't idle on cold start with new IAC
  80. Just bought a N-05 MMCS but wondering..
  81. Temparture gauge went down (Evo 9)
  82. Question about heater core hoses
  83. Smoke after boost!
  84. What will fit?
  85. Every evo owner should have this
  86. Aem wideband reading lean
  87. Stalling out problem, and tachometer not working....
  88. New to Site
  89. where to buy parts for evo 8
  90. OEM Interior Parts
  91. Video: Evo 9 races threw trees and snow during winter.
  92. Where Can i Get Those Window Vents..???
  93. Fuel Pressure to high
  94. New Radiator Needed - Recommendations?
  95. What do leather door cards go for?
  96. Clutch will not disengague
  97. What year miata battery....
  98. Best Bank to use for loan? Who gives the most money for loan?
  99. Boost restrictor pill location
  100. 2 step harming car?
  101. boost wont pass 14 psi
  102. Quick help! Brembo rebuild kit
  103. What is a good price for used fp red
  104. LED gauge cluster bulbs?
  105. Evo V hesitation
  106. timing belt failure 2nd time, need advise.
  107. JSpec parts
  108. couldnt help myself......
  109. oil pressure light brefly
  110. o2 Dump on DD evo
  111. My Evolution Wont Start...
  112. transmisson noise normal?
  113. What should I do next? Help!
  114. Feeler what is my 2003 worth??
  115. Evo 7 (Yet Another) Won't Start
  116. 2003 Evo 8
  117. Got my Evo back from the bodyshop...fitment issues?
  118. EGR delete problems
  119. Which car?
  120. Big and tall
  121. aem digital boost gauge not reading boost
  122. Just 1 mod
  123. Check Engine light is a flashing rapidly help
  124. Evo 6 problem
  125. Jdm rear bumpers ?
  126. O2 sensor ?
  127. Help with bumper part identification, please!
  128. Very odd problem...
  129. Photo request for the backside of an evo 9 bumper with all of the oem grill mesh
  130. Evo 9 valve cover on evo 8
  131. Fuel sending unit -6 to stock fitting?
  132. EGR hose was disconnected....for 6 months :p
  133. Your opinion on HKS DLi2
  134. Need help tuning speed density please!!!
  135. 300-325awhp
  136. ETS intercooler mounting
  137. Apexi turbo timer
  138. P0300 help !!!!!!!!
  139. Fuel Pressure Regulator question
  140. Evo 8 accidentally towed on dolly? Help please
  141. Fuel return line location
  142. Photo Request! Pass Wheel Well!
  143. Cluster lights replacemnmet
  144. Gas in my oil !!!
  145. Egr block off head side
  146. Urgent! Fuel injectors MDL560 and MDL560P
  147. Front reinforcement bar
  148. Importing Special interest into NZ?
  149. Oil Pan Gasket
  150. Evo8 over heating
  151. bov hose
  152. Reno, Spraks, and Carson City
  153. Repairing cracked VC?
  154. Need socket/ wrench size for OEM banjo bolt for turbo water lines.
  155. Battery tray install
  156. Full Blown double pump setup
  157. Evo 7 boot/trunk lid
  158. Just Bought a 2005 SSL... help me piece together what I need:
  159. Evo 8 Turbo for DD GTX3582R or PTE 6262?
  160. Need a solenoid from AYC pump
  161. Evo 5 loses power, runs fine after re-starting.
  162. Evo 4 coil connector
  163. thoughts on the 2015 evo?
  164. Trying to find an old owner
  165. Where to find PAINTED JDM Rear bumper?
  166. Who wants to make my prom?
  167. Charging issue.
  168. a clunk when turning
  169. I just bought a 9 turbo for my 7. Do I need to upgrade my injecters?
  170. rich closed loop idle and idle surge on warm start
  171. [Advice] Pre-purchase Inspection
  172. evo 9 rear differential, options
  173. aem meth jet 1000cc/min
  174. Evo 5 Windshield
  175. bone stock + aem short ram intake = fluttering sound?
  176. help, radiator hose rubbing BOV issue
  177. No heat, and its gonna be -2 tomorrow!!!!
  178. Buying a used "race" motor
  179. Switchback LED's for turn signals?
  180. Size rivets for canards
  181. help! any advice on paint shops?
  182. EVOs in the wild
  183. Rebuilding high mileage Evo
  184. Need help on a price for evo 9
  185. EVO FLOODED A BIT :( need carpet
  186. thinking about trading in my evo VIII
  187. ACD Fluid question..
  188. Removing valve guides
  189. Looking for a wicked white driver door
  190. Want to trade my viii front bumper for a ix
  191. Car cranks but takes long to start help!
  192. Secondary Fuel Level Sensor bad?
  193. Any interest in a trailer hitch for the evo 8/9?
  194. New Colour
  195. Good clutch and website
  196. Which catback exhaust for evo VIII?
  197. 10k rpm tach
  198. Gruppe-s 52mm gauge pod (sign-up thread)
  199. info evo9
  200. Evo 8 stolen LONG ISLAND NY!!!!
  201. Bodywork....
  202. Slippery floor mat problem solved
  203. evo crank no start
  204. Good sites
  205. Tokyo Auto Salon 2015 (video shot today)
  206. Heat Deflecting Shield
  207. my mechanic didnt know what my evo was?
  208. Yet another "Emissions" thread
  209. How much is it worth
  210. New member need help
  211. Stupid ac question
  212. Tomei Spark Plug Cover with Spoolin up COP
  213. Evo 9 4th gear grind
  214. Flickering aftermarket gauges
  215. All of Sudden My Wiper Nozzels to not spray fluid
  216. Drip molding
  217. Evo on tv
  218. Could use some help finding exhaust!
  219. Stupid BOV flange measurement question
  220. camshaft & turbo opinions
  221. Evo 9 Pull and knock problem
  222. Evo 9 that's been sitting for a year. Help please
  223. Need Help! How to use search
  224. Where can I buy an evo 8 j-pipe?
  225. Need help identifying injectors
  226. evo
  227. engine swapped?
  228. Evo 5 idle problem
  229. Girodisc rotor problem help
  230. Evo 800whp+ VS GTR AMS Alpha12 1000whp+
  231. My Project for comparing cars
  232. Evo VII RS Stock Catalytic Converter/Exhaust
  233. Is it out of line to.....
  234. 6266 questions
  235. simple E-85 question
  236. 6266 vs 6466
  237. 1st gear + Low RPM = jerky / bumpy
  238. RPM drops too low/stall when clutch pressed
  239. evo keeps stalling help!!!
  240. Buschur DP in contact with front tie bar: Evo 8 GSR
  241. Takata Airbag Recall?
  242. SRS Airbag light after moving the sensor.
  243. Frontline Fabrication Oil Cap!
  244. Timing Mark Positions
  245. Pre-bent roll bar/cage, anyone install or see fitment? (links inside)
  246. cracked propellor shaft
  247. EVO V AC filter?
  248. Engine and tune questions
  249. Can't tell what kind of cams.
  250. FIRST! - 2015 Canyon Run
