View Full Version : Evo General
- Stalling Issues - BOV/Intake related
- Factory 8 and 9 Ignition Coils Interchangeable?
- The Good and the Bad...
- Has anyone else had this problem?
- Why do some OEM turbos have # stamped and other's dont?
- Boost taper solution
- Loose Screws under valve cover
- ID this ECU. Please?
- 5 speed, 6 speed trans and clutch parts interchangeable?
- Help...Open throttle around 4-5k RPM losing HP....?
- hoses on Turbo inlet
- Where is the EGR located?
- Not again ...
- It has begun...
- Inconclusive Boost Leak test results
- Stock sub location
- rear main seal help plz
- Prosport a/f error
- Evo 8 "false" CEL's?
- Do i need to remove the turbo to do engine rebuild?
- oil pump bolt
- cel help
- please help
- Any help will be thankfull
- What's wrong with this thing???
- silicone coolant hose
- Diff Problem?
- Six speed short shift
- All three ACD lights on when the car is hot?
- TOB question
- Rev Limit Question
- White Smoke after reverse stall
- Maf/bov
- Door Handles
- No cats=check engine light. How to fix this?
- Anybody use the seat lowering brackets in the SSL?
- what I found under my valve cover today
- Regular tune vs Tephra V7
- Warm engine after rebuild (in engine brake in)
- Evolution
- Fujitsubo Question
- Can I paint an intercooler?
- Need help! car dying on me
- Rexpeed still active?
- Evo 9, stock cam lift?
- Brake Caliper Paint
- quick question about forge wg adjustment or any wg actuator arm really.
- wastegate setting
- car wont start after rebuild.
- throttle body hose
- All 3 ACD Display Lights
- Paint Change
- Tomei Expreme TI with JDM/USDM Rear Bumper?
- need help with timing belt.
- Help with fog lights please...............L@@K
- Help Please?
- what spark plugs to get
- fic 850cc install question
- Driver's side wheel slighty sticks out towards the bottom, help.
- i got rip off by a member and need to salvage what i have
- water pipe differences?
- Car Stalling when downshift
- used EVO with MODS in it
- Quick question on evo 9 block
- fiberglass fender liners?
- Should I sell my evo 8 with 90k ?
- Confused About My 2 Step
- a/c not working
- Any fix for radiator
- Ignition Switch question
- having a problem
- Hood Dampers
- How hard is it to remove stock guage cluster
- 2 questions about this JDM HVAC controls
- 2.3L stroker kits
- Anyone put a X MR tranny in an 8 or 9??
- Evo 8 front emblem question!!!
- Hks 7460
- could use a little help
- Whats this Line!?!
- Can I do a Boost leak test like this?
- Just ordered Spoolinup COP Setup for my 8
- Help really quick please.
- Mysterious wind leak from passenger door
- My Engine blew tonight!
- If tuners use a "sniffer" during tuning...
- door open dash light stays on
- Is an evo 8 16g 10.5 hotside worth anything?
- ACD Pump question
- Reverse Issue?
- lucas in trans?
- HELP!!!!! % Sputtering
- side skirt extension help?
- ADVICE, 2.3l comp tbb turbo 67mm PSI?!?!
- Rough idle rough acceleration...just rough
- Need help with forge wga spring..
- JM Fabrication intake
- 04 evo 8 idle question!!!
- Identifying this Gauge controller
- Passed OBD-II emissions with S2 cams
- Making the jump to SD and have ?'s
- Double Pumper and Gauge problem
- Auto Tensioner Attacks
- Rear-ended: replace bumper myself?
- What to do, What to do...
- Evo member lost sunday afternoon
- Help! Loud vibration at high speed
- Rules for posting on EvoM
- Parting out an evo 9
- my new evo!
- curiosity... anyone running a dual set up
- Evo Buddy NEEDS HELP! Please spare a moment if your mechanically inclined! Reward!
- The Next big Step
- Cargo net hooks
- changing my flashed ecu back to stock for warranty work???
- are fuel stabilizer's ok?
- hard time restarting car if already warmed up
- Evo 8 Odometer?
- Underbrace bar
- Need new downpipe hardware, and hitting the oil pan
- Evo 8 idle issue
- Quietest Downpipe???
- Dyna Beads to balance wheels?
- Maybe getting back into a evo!!
- Evo 8 to 9 turbo Swap Question
- gauge cluster problems
- Worth it?
- Hard Vibration when turning (help)
- snapped three head bolts
- light in prosport turbo gauge
- Turbo Housing Clamp
- what sequence do the head bolts need tightened
- Boost Leak question w/ pics
- weak battery = bad mpg?
- Hood problems
- Control Arm Bushing... Help!
- Help! UK Rear Badge (Ebay,other) review or where to find one?
- Why aren't my post going up?!
- quick question. tdc
- Front Hub Assembly
- Engine break- in Oil, high zinc
- AC does not work....
- Evo/S2000 Oil filter
- Good deal or no 500hp evo
- How to Properly Care for your FP Turbo, Info From Robert at FP
- turbo trouble
- Problem with Gauge Lighting
- clicking noise pass front side
- too rich during engine brake in???
- Wing shade
- evo airbag question
- 463 HP and 430lbs of TQ
- 150k + FP Green?
- HKS BOV leak on Boost leak test
- gauge cluster lights
- Built shep trans.
- best place to buy parts??
- Aeromotive 340L's keeps dying on me
- New discovery found after raining... LEAK!!
- My ECU is locked can someone help?
- 60K tune up
- nitrous intercooler sprayer bar
- Evo fluid maintence
- Perrin Oil Catch Can silicone hoses (Red)
- Please help
- Sensor.
- jingling sound noticeable at low speeds
- Broke my CF lip...
- help!! idlling issue after install
- Front bumper swap
- Brake lights stopped working
- Any bigger guys using the Sparco Sprint V?
- Quick release harness bar and harnesses from Buschur Racing
- Steering wheel, replace or get recovered
- Speedo troubles
- clunking sound when shifting into reverse?
- track day/autocross
- are you a racer if you own an evo?
- trading your evo 9? any regrets
- Will it hurt my evo?
- opinions needed!!! >_<
- stock IX dv flutter
- Help please! Blue power steering wire detatched? Cant find where it goes...
- is 18g to much for a rebuild tittle evo 9
- Lower bell housing cover.
- Boost Leak or what is this Noise
- Trunk having an issue...
- electrical problems
- Meth/Alky water injection vs. Straight Meth/Alky injection
- idle drop with AC on
- Towing car without transmission.....
- Stri DSD-SLMII boost guage just quit working??
- Bolt sizes
- need some help here about HKS DL II
- Install the injectors or wait?
- Strange gauge problem
- Would ask too much if i was to sell my car
- First Evo Purchase...Few Questions
- reverse trigger wire
- 1050cc injector question
- is this stock or did the owner before me do this?
- Lancer 4g63 swap
- jdm 3 bar map
- help..only getting 12-13psi of boost
- Need Suggestions: Car won't rev up.
- Hallman Manual boost controller
- DIY Screen Mesh: Front Bumper
- coby tablet as an engine scanner/tunner
- avoided disaster tonight.
- 4g64 oil starvation?
- Need your help fellow EVO OWNERS!!!
- what is this sensor?
- Crappy roads and an evo
- Buschur FMIC owners, chime in please
- Getting in contact with TRE??
- Boost Level Affect Coolant Pressure?
- Clutch help
- My $2,100 FP HTA Green
- GRRR! Local Mitsu dealer wants me to pay
- weird vibration
- Holy insurance batman!
- Selling an Evo... Do you agree?
- Idle surge
- Quite Evo Exhaust: Thread
- Buying an Evo with 90k Miles
- Evo 8 maintenance with 2000 miles need you advice
- aftermarket under body panels. anybody know where I can get some?
- Knocking sound top mount front suspension
- Boost solenoid vaccum problems
- Power steering pump whine Help
- what size tbolt clamp for the TB?
- 3" 3.5" or 4" exhaust
- carbon trunk
- EVO 8 to EVO 4 steering column swap
- transfer case fluid
- Need help diagnosing a problem..
- evo headlights
- help with lc1 and a few other things
- Any good spots up front to put battery jump terminals?
- Idle at 14.0-13.5! Tried Everything.. HELP!
- FP Green question
- Project rEVOlution
- evodave fender mod
- are these the same as the fic 2150s????
- re weld or have drilled out?
- A question on fuel efficiency
- Emissions wont pass
- Speedo troubles
- MR shift console to stock shift console
- Man.. Boost leak? or normal. Vid inside
