View Full Version : Evo General
- wiring harness question ?
- Iac
- What RPM should I see boost?
- Help!
- Double pumper options or something else?
- Running on cylinders 1&4 only, help!
- 05 VIII idle issues, random codes... frustrating
- Evo hurting and need some assistance
- Traded GG Evo IX at Warner Motors
- Blitz SBC-iD boost controller and Tial wastegates
- How to make her a little less noisy
- Anyones acd acts strange....
- AMS balance shaft delete install help
- Is the 6 speed better for road racing
- is this really an evo 8?
- press the brakes and the idle raises to 2k.....?
- twin disk help..
- how much would u pay for a evo 9 shell
- Gas leak...
- Long shot: Tracking down a '06 WW RS that was traded in
- T-Bolt clamp help for AMS Front Mount
- 03 BBY or 06 GG SE... opinions?
- What type of oil for my 04 Evolution VIII Rs??
- bb red and bb black
- Was just wondering
- Anybody know this car?
- Ams vs Brad Penn oil
- How did you guys learn?
- First Snow Day in NY
- evolution 7 radio wire diagram?
- TME with small issue
- Help with EVO VIII
- what does it take to run e98?
- Racing Harnesses for my evo
- 2006 Evo IX MR salvage title on craigslist, is it worth considering?
- Rear strut tower rust
- bleed screw pics
- Rexpeed Carbon Fiber HVAC Trim
- mivec and non mivec head differences
- bleeding screw
- hot off the press(I mean scanner), mitsubishi trounces the competition!
- Tomei parts made in China?
- It will never be all that you want it to be...
- what does this button do?!
- Fan Shroud for Evo 4/5/6 Mishimoto Radiator...is it needed for my Evo 8..?
- Evo's springing up in the winter
- Mounting points for Evo 8 motor onto Engine Stand..?
- Modified evo import to canada?
- help wanted
- A little help
- evo 9 ecu immobilizer
- Evo 5/6 RHD to LHD Conversion
- Car cutting of when headlight is switched on
- 3 port ECU based control?
- stock piston ring specs
- Where to buy exhaust tips?
- Idle problem.
- mixing brands.
- Tuning problem??
- Hey I am new and having bad issues!
- Sunroof problem with black plastic guides
- No power when the car is off, HELP!!
- Finally picked up a Litespec titanium exhaust!
- which oils should i change?
- question about test pipe and rear O2
- Winter....
- Will putting a bigger tank/body on the stock intake mani make more whp/TQ??
- Its official.... she's gone
- Question on Voltex Bumpers
- Reliable place to buy OEM parts?
- Can't find this part anywhere
- What mods to do next!
- HID Problem...NEED HELP!!!
- Worst offer you ever got for your evo?
- Auto gauge help
- Rear Ended - Bumper Alignment, Trunk Not Closing - Need Advice
- Evo 9 Mr 32,000k totaled!
- Tubular and heat?
- A Weird Problem!
- No two step???
- Evo 8 climate control clips
- Evo IX high flow cat
- I am Keeping My Evo Stock ! Despite all the temptations! :)
- Quick question
- Road Rallys like the gumball 3000
- Switching Evo 9 bumper for an 8 instead..
- Are there any gauge pods made to fit stock gauges?
- ecu help!?!?
- What would you do?
- Smell of fuel during start up
- Looking for a new ECU Evo 9
- 60k OEM timing belt kit
- Evo 6 Engine Questions
- is the 95 eclipse 7bolt gst 4g63 the same as the evo 8???
- Does anyone else's car jingle??
- Lower IC piping worth it?
- evo8 cluster swap to 02 lancer es tech q
- Mice Advice
- Evo 8 crank oil seal case bolt...?
- Evo 9 boost is higher than normal
- Shop/Personal Car - Should I sell???
- HELP identifying year of Evo 8 head!!!
- Car won't start, No crank or ignition...
- Help me install a A/F gauge
- 50 miles 1/2 tank?
- When to do oil change?
- Mini Add A Fuse
- Wider front fender options?
- Headlight housing question
- Boost Help?
- Thrust bearing crank pulley side gone?
- Weird angle into fuel tank
- forge DV question
- Gas cap cover spring
- gauge pillar
- ETS intercooler...
- changing to AMSoil need to drain acd pump
- EVO 8 TURBO LAGG? POSSIBLE bov
- AEM gauge troubleshooting
- 5 codes 335,340,365
- Want to buy a GT35r kit... help
- Air/Fuel % E85 vs 93 octain
- Quartermaster Clutch Issues - Any input?
- Full Blown Double pumper lean
- Have a question
- AC Possible with Forward Facing Turbo?
- Forged Racing Radiator?
- Aem uego stuck at 14.7
- wire problems HELP lol
- what does it take to get into the 12s
- Oil Change on 06 EVO MR
- GSP intercooler question.
- Heater only blows warm air. Thoughts?
- a vibration when i drive
- Evo owners with the SE lip: help!
- WTF!! is this about??? Pictures+Video
- 36 Knock Sum
- Lowering Seat Brackets Help
- fuel pump help please.
- Stalled auto Evo?
- Don't trust anyone with your car...sigh
- bleeding air from the diff
- FP Black price?
- Atmospheric bov??????
- Gates or AC Delco
- Engine rebuild specs?
- whats the name of this splitter
- Stock E7 running lean. Why??
- Evo 8 vs 01 Cobra
- Boosting issue
- Recaro seat rail/sliders
- On to bigger and faster things...
- Weird Tail Lights/Reverse Lights
- Double pumper and a FPR
- Something blew up
- clutch pedal problem
- Wandering about the ages of our evo owners
- acl bearing problems?
- Iacv and base idle set screw
- Thumping sound when shift, help!
- Intercooler help please
- help another evo 8 whine
- Exhaust, what is this pipe?
- Question about SpoolinUp C.O.P. Kit
- 2003 Evo GSR - HVAC Issues
- Difference between MN161463 and MN161464 for factory wingless trunk?
- Bumper hole plug
- Pulling to the left under acceleration
- Shorai LiFeP04 Lithium Iron Phosphate Battery -anyone use one?
- Where to get carbon fiber dash trim
- E85??????
- Where to buy 4 bolt housing...please help
- EvoII @ Solo2 ride along....
- Side skirt mounting tab
- Airflow meter mesh
- Starter Only Engages When Car is on an Incline...
- RPS Carbon Twin disc Rivet problems!!!!!!!
- oil help
- need advice!!
- Where do these go..?
- 2 different readings!
- Back in the Saddle Again...!
- Reverse issue on my 6 speed
- engine rattle
- Happy New Years!
- Evo Owner Paranoia
- Aluminum Roof Part Number?
- How much would you pay for an Evo depending on miles
- From BMW --> Evo 8/9?
- HIDs
- No heat please help.
- Throwing CEL P0031
- Some EVO VI questions..
- Exhaust manifold
- Headlight parts help
- keyless entry remote stolen, help
- beeping from fuse box area! help!
- Fuel pump on last limb?
- Best rust inhibitor primer?
- Boost... HKS EVC 6 Install...
- Intake Hoses Blowing Off...
- Immobilizer Question...
- Squeaking during idle [video]
- Idle Dip [vid]
- About to Pull my hair out! fuel problem!
- Squealling sound??
- VOLTAGE SPIKES and DROPS
- Car Broken Into Now all 3 ACD Lights are on
- 06 cluster for 03 evo??
- No Injector Pulse...
- Starter problems! Please help :/
- oil pressure sensor?
- Parts help needed (brake booster, nipple fitting)
- My Walbro 400 Stalls out!?
- Sunroof delete panel.
- A new sound??!?
- HELP!!!... Clutch Slip or Back Pressure???
- Upgrade cams or port intake/exhaust manifolds?
- Quick fuse box question...
- Vishnu performance?
- Is there a fuse for the map lights?
- Engine damper
- service engine soon
- Gas milage Good or bad
- Timing belt part numbers evo9 block evo8 head
- Can't get my 3 acd lights to stop coming on.
- Newb tuning question
- Insurance
- Got the car street tuned today....what's next?
- Evo running lean..need some help...
- CAR is slowly getting worse
- spark plug gap question.
- Evo 9 Turbo Shaft Play
- emission question
- What did you and your Evo get for christmas? [MERGE]
- AC clutch is not working??
- Evo IV in U.S. help please if you have any idea. (emission fail)
- A/F look normal at WOT and does this car sound cammed?
- Crank warp??
- Shift Knob?
- ECU Problem. Somebody Please Help Me...
- Tcase death whine, is it done?
- Prosport oil pressure sensor install help
- Should I buy for 2.5k?
- BOV Suggestions
- intake pipe length
- evo9 RHD to LHD swap?
- how to maintain a Evo? Oil and Fluid. 100% Newbie
- Electrical Issue
- What are these? (pic included)
