View Full Version : Evo General
- How to turn off the service light
- car dies after cruising
- hick up under boost
- What engine oil is needed
- throttle hang issue. need help
- Might sell the evo.
- 1000rwhp can be yours... in Evolutionary form..
- anyone know where to find a braided oil line?
- A/C compressor...
- EGT Probe Install ???
- July 30th DYNO DAY @ F.I.M in CT
- 2006 EVO IX overheating.
- Prosport EVO gauges??
- loud noise after 2k rpm
- Keep forge wastegate?
- Stolen evo's
- Best oil catch can/breather set up
- Car Won't Start!
- Help!!! Timing Belt
- Evo 5 transfer case and 8 interchangeable.
- Boosting15 psi and lots of boost cut.
- Are you f-ing kidding me?
- Need Help: Who knows about PSI3's ECU Data Monitor?
- front lip hardware??
- What LICP is this?
- Funky noise
- Walbro pump loud noise
- 4g64
- stroker engine built
- milltek UK made exhaust
- Questions
- What is your Evo used for?
- 3 pulls today : clutch problem + LOUD POP (not intercooler piping!)
- A/C Compressor making knocking noise
- Part number of the headlight bulb above the turn signal?
- ETS exhaust owners chime in
- Going to hit 250,000 Miles in my Evo.....
- Shifting
- Gruppe-S Gauge Panel
- Evo 8 or Evo 9??? 2.4L build...
- Dash gauge pod
- has anyone had this happen??
- Buschur exhaust
- Getting ready to take my car to buschur, any recommendations?
- Lana Goes 10.7 @ 132 stock turbo!!!
- Anyone have 1 RED Rays extended lug for sale? Lost one
- Looking at a used evo 9 (evo noob)
- Suspicious evo 8...
- Stock steering wheel getting rough spots? Maybe this will help.
- hallman pro, forge uno, or greddy profec b spec 2?
- rust cleaning
- Installing new seatbelts evo9 Q's
- is "thermoid" vacuum line any good?
- cant post in classifieds?
- PA Emissions - Cant scan my car???
- Carpet My Empty Trunk
- 6262 or 5857?
- EVO V - Same struts (towers, mounts, etc) as 1998 Mirage?
- OEM Ex Manifold Cover?
- What on your EVO shows the most wear and tear?
- buschur inline mbc install how to?
- Exhaust question
- EVO 9 MR Weaknesses
- Bleeder on brakes?
- synapse correctly install w/ injen intake
- electrical issues?
- Mellon Racing FTW!!!
- Show me your Headlights! Can't seem to find any!
- power achieving
- 4g64
- lowering springs question
- Buschur Racing Cover
- anyone ever take apart a forge wg please help!
- Has your EVO ever left you Stranded?
- UICP install, new tune?
- transmission hard or can't shift in gear. please help!
- Differemce betweem stock evo 8 wing and copy?
- problem, advice/help would be awesome
- idk need help!!!
- wont start
- change odo on cluster
- Question about bbs rims
- has anyone tried this advanced key - push start kit?
- what should I buy?
- help with cam id
- AEM oil press gauge
- South Yorkshire Police
- No blower motor ??
- The System of buying a used car
- OEM Spoiler
- 3 gauges
- max rpm cut for 4G63???
- New Member Proper Intro
- Anyone know how to check front o2 sensor with multimeter?
- Need replacement shift cable metal retainer clips.
- I need help PLEASE!
- e85 and o2 sensor
- Found 05 EVO 8
- Ti TiAL Flange
- Winning is winning!!!!!
- Evo 8 front bumper black diamond emblem
- Question about problem meth and want use ethanol..
- When/why do you need to get a boost controller?
- idle issue please assist
- Anyone w/ F & R tow hooks want to make some money?
- Are cops attracted to the average Evo or average Evo driver?
- Evo IX white mirrors and door handles
- Whats the deal with Fujita?
- Motor Mount
- Roof vinyl's
- Dreading the 120k Maint... need info
- What color is in highest demand?
- Evo 8 Hood Size
- all help welcome
- 06 evo 9 starting problem
- Pulling a jet ski with an EVO
- Jdm evo 8 power windows not closing correctly.
- Had an issue starting this morning
- oil pressure sender unit/sensor wont fit!
- Hard to Shift at High RPM's
- In a jam here
- ATTN: Vendors/Shops
- spacer question
- need help big time...alignment problem.
- Moving from CO, to CA. Sell car before the move??
- Does your Evo IX have this? HELP! USDM rear owners only!!!
- Typical cost for fluid change?
- Need input on good quality hood dampeners
- OEM NGK vs NGK #7,8 or 9
- Help me decide on what color to powdercoat my Le28n's..
- Another ac issue
- I want some graphics on my evo...
- clutch?
- AC stops working randomly
- Downstream o2 sensor
- P0300 code? What to do?
- Best Oil options/brands?
- Idle Problem? Electrical? Help!
- gaskets and flanges
- Anyway to make the Rear Seats fold down?
- Key not Working
- Can't find the ultimate rattle thread
- 1/8 mile run
- Evo 9 red headliner/door/seat inserts
- new summer new turbo
- get meth injection or upgrade to ETS 3.5?
- How can I tell if my gauge is wideband?
- Lucas e85 Fuel Conditioner
- Help..Blinking CEL under boost!?
- I am looking for stock boost lines.
- Trying to find ashtray guage pod mount!!
- Evo VIII recalls
- Effects of fuel system cleaners on EGT temps...?
- Thoughts of infidelity... *STi owner content*
- Throwing codes 401 & 234
- This much smoke normal? (video inside)
- BOV Flutter after Perrin Intake Install
- Fuel pump started whining REALLY loud today
- Anyone use this? Spooinup.com
- P0171 code with minimal mods, large cams the problem?
- Evo IX Water pump help
- Is this too much for a stock bottom end? Evo 8, 32psi, etc
- Stock launch control
- Car stop accelerating.
- S&W Race Cars 10pt Cage
- Drove my evo 4,000 miles in 4 1/2 days....
- Fuel door wont open
- Options for NON-maf intake pipe?
- major problem or simple fix
- Help!! im stranded outside a bar- my car wont start!!
- a/c causes vibrations?
- starter problem ; [
- walboro fuel pump question
- 2.5" exhaust causing lower boost peak ?
- Will it fit??????????
- could not change oil filter! *help* :<
- Best Air Intake ?
- A/C clutch not fully engaging, seeking advice
- Issues with keyless entry
- maf what to do with it
- Water damaged evo 8 ?
- New Evo and new parts
- speedo light
- Looking to buy a creader
- ATTN: Douglas Autoworks
- Evo 4-7 swap in evo 8 chassis
- 1050cc injector question
- "LANA" Spotted in NJ
- People running perrin intakes
- Wire broke off at connector. Options?
- speedo not working
- Keeping Engine bay heat away!
- high knock count
- Diaqueen LSD Gear Oil
- running to rich need advice
- Tire Suggestions
- external water pump?
- can someone please help identify my FMIC setup?
- door locks dont work after...
- Aem Wideband stuck on 14.8
- ACD problem
- Rebuilt transmission help
- Am I getting way too in over my head?
- Update from my Car Accident!
- acd clutch pack
- Disabling an Evo
- HELP w/ keyless remote ???'s
- 5th gear grind HELP!
- 110,000 miles on my IX MR
- Loud Roar
- never do business with this person
- Buying a used 9MR. Just checked compression... thoughts?
- Idle problem
- Legal exhaust... 3inch end
- evo x turbo
- Evo 9 Stock fuel pump question!
- tire went out on me while driving on turnpike
- Evo leaning out at high rpms
- WTB: 06 Evo Ix 5sp 50k miles and below cash paid!
- buschur licp no nipple
- Which section for DIY tune?
- Anyone know the part #'s for the oil pick up tube and windage tray for the Evo IX?
- Boosting problem :(
- Why so little WORKS talk?
- Mod 2011
- First trip to the drag in my less than stock EVO IX
- MOD 2011 -- Pics
- After a while.. My Evo back alive!
- Full oil change?
- Pics: Cleaned up the engine bay wiring for relocated battery.
- my compression test, thoughts/opinions?
- Mods That Need IMMEDIATE Retune
- How often does your Radiator fan turn ON/OFF?
- Evo IV = my 1st manual. Questions!
- spoolinup diy cop
- 02 housing
- evo 8 electrical problem
- Help pls!
- Original/Last Owner
- any other places like....cincity designs??
- "tight/tough" gear help?
- Thanks Guys
- fuel systems ams1000hp vs full blown on evo 8
- AWD Motorsports
- need more information
- turbosmart dual stage
- Anyone put dogs in their EVO?
- Help! Ticking at idle and acceleration
- Accessport used for Evoscan?
