PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Timing Belt issue
  2. PR Exotic Roll Race (GTR vs Evo X)
  3. Car won't start :/
  4. Convert Evo8 tailights into Evo 7 tailights using VHT Nite Shades (Red)
  5. Evo 7 gear shift problem
  6. Where do I solicite shops on here to do a distance build/tune?
  7. Fuel inlet thead @ firewall?
  8. Speed density pass emissions and inspect in CA?
  9. Help with car
  10. OEM stereo / radio, how many attempts with the code?
  11. injectors question
  12. Is this evo worth it?
  13. Just bought myself an Evo
  14. Spark Tech COP is awesome! But one issue remains. (pics included)
  15. Help Digital Center pods
  16. selling a motor w/spun rod bearing advise
  17. Universal AC compressor shims?
  18. '96 Evo IV - First owner in Canada.
  19. Extreme Dimensions C-1 Duraflex bumper?
  20. Question about Tephra for Evo 9 USDM
  21. Are ALL Mitsubishi evolution transmissions 4-8 the same/compatible?
  22. What colour is your Evo 7 windscreen?
  23. Starting issue need help!!!
  24. Evo 8 and Evo 9, What parts are interchangeable if any
  25. Carbon fiber trim
  26. crap! suction pipe… :crap: (problem)
  27. best tuner for evo 9 in so cal
  28. problem with my evo today and i am stumped
  29. Hta 71 with stock 10.5 hotside
  30. Varis rear Diffuser on INGS Rear Bumper
  31. Car stalls when the blower for the ac or defrosters come on!
  32. Evo good first car?
  33. Where can I go to purchase an evo in the US or Canada?
  34. 2 windows and power door lock not working
  35. GSC S3's and stock valvesprings?
  36. Evo Help!!!
  37. Broke Rear Diff on Evo5GSR can Lancer GSR Cm5a rear diff work?
  38. Are the Evo 8 Door pillars wrapped with vinyl?
  39. Crank and Cam Angle Sensor
  40. Light bars for Evo 8
  41. Evo 9 SE MR Carbon Fiber Lip
  42. Turbo manifold opinions!!! 4 bolt vs v-band
  43. Which evo should I buy?
  44. A.C. Compressor broke off the block and i need help ASAP!
  45. Trunk interior coating (bed liner, etc)
  46. Where to find quality RA front lip?
  47. 70mm throttle body install
  48. Buying new bumper
  49. looking for somebody to customize ix car mats
  50. How to disable the AYC on EVO 9 ?
  51. OEM V band clamp part number
  52. do I need a tune?
  53. IS SSL package encoded in VIN
  54. Spun B/S Bearing, 2.0L Build.
  55. Rebuild gaskets
  56. rear wheel bearing help
  57. Engine rattle (rocker cover)
  58. JDM Headlight Projectors???
  59. over heating issues
  60. Where is the best place to buy new JDM 8 MR headlights?
  61. Shifter vibration @2k-3k rpms every gear
  62. daily driver set-up, am I on the right track?
  63. odd anti-lag question mainly just informative
  64. Issues after catch can install.
  65. Dodged a bullet today
  66. Some sort of turbo issue.
  67. Valve cover modification question
  68. Need help engine knocking!!
  69. what part # are 1200 rc injectors?
  70. Headlight Intake Duct
  71. exhaust upgrade
  72. Gauge Cluster Problem R-Turn...
  73. Evo 9 Timing belt MIVEC cam gear
  74. Why does my WGA look like this?
  75. Evo FS - Honest opinions appreciated...
  76. Did 2004 evos ever come with ACD?
  77. Engine RPM problem? :helpme:
  78. Questions about EVO HID Headlights.
  79. how much to pay for cam install and head studs?
  80. TB Boost Leak Question
  81. Evolution VI Build - Advise Please!!!!
  82. evo 8 a.c. compressor and serpentine belt help
  83. Engine help, please!
  84. Noobie Needs a Bit of Guidance
  85. Evo9 MR Help
  86. Turbo manifold replacement help
  87. Fuel Rail noise issue?
  88. evo 8 crank but no start. help!
  89. timing off??
  90. Been away from the game. My IX MR - what is it worth?
  91. Spark plugs
  92. Lancer trunk lid
  93. Trunk Cardboard Interchange Question
  94. Will adjusting the idle screw effect my tune?
  95. Looking for Driver Window reg&motor
  96. Led wideband display
  97. My Evo 8
  98. Turbo HELP!!!
  99. where to get rocker panel clips
  100. Wiring/MAF issue? Please HELP.
  101. Steering wheel shakes at freeway speeds - throwing money away on this
  102. AMS Intercooler Evo 9 front bumper??
  103. About to get my evo tuned on a dyno
  104. Confused on the FP BLACK site says 86mm wheel now
  105. need help
  106. Whiteline rear differential bushing hardness?
  107. Torque spec for dshaft carrier?
  108. radiator blew its top
  109. Where to buy amber tail light overlays
  110. AC service
  111. Epic "build"
  112. Tube frame front end EVO
  113. Info on my evo 7 please
  114. Anyone have experience with these carbon fenders?
  115. Rear Toe Arm Repair Question
  116. Looking for help on an Evo xiii
  117. P0300 code after installation of new trans.
  118. X seats in a IX?
  119. loss of power in 4th and 5th gear
  120. Trading IX MR in for 2015 STI?
  121. Another Death whine
  122. Weather Shield for EVO IX
  123. Stock Boost Control Solenoid Failure
  124. Major Lag during acceleration in all gears
  125. shock absorber question.
  126. Weird Rattle EVO 9
  127. Evo Cake!
  128. Car detailing, what do they use after they wash?
  129. New Tanabe Guages for 2014
  130. Mishimoto Is Giving Away a Free 2001-2007 Mitsubishi Lancer Evolution 7/8/9 Half-Rad!
  131. How hard is it finding a lightly modified Evo 8?
  132. Driver side window rolls works the rest don't
  133. Help identifying rear wing
  134. EVO 1-6.5 Custom Gauges
  135. Evo 9 Body parts
  136. Help on Cams... Stock or not?
  137. '03 Evo 8 - A/C Compressor Issue - Not Working
  138. Has anyone heard of Fluid Motorunion?
  139. AEM EMS series 2 Wiring harness help
  140. For those with mishimoto rad
  141. Poly Bushings for Buschur Mustache Bar
  142. Climate control only works on 4, but not 1,2, or 3
  143. handmade wood gear knob
  144. Ok guys lets hear your road rage stories
  145. looking for Cobb accessport for evo 9
  146. The boltiest of boltons
  147. Article on MSN
  148. Need help! Evo not running correctly!
  149. overheating
  150. Any evos in newhamphire?
  151. WTB: Knock sensor plug
  152. Ecu trouble
  153. Wont get past 16psi of boost. WHY?
  154. Where is Tom from tscompusa
  155. bad gas or problem?
  156. The hunt for an Evo begins...advice?
  157. Dashboard Issue with my 2006 Evo IX MR
  158. clutch line
  159. Popping under WOT and no power...
  160. Rear differential torque spec
  161. Smell of gas in Oil
  162. Affordable serpentine belt option FS
  163. Questions About Voltex Hoods...(CT9A)
  164. Diaqueen ATF J3 or SPIII?
  165. Tokyo car scene pics - tatsumi & daikoku PA
  166. Trying to come up with Evo 8 build plan...
  167. Advice on engine components
  168. Evo 8 ssl seats what are they worth if I sold them
  169. Looking to get some mods soon
  170. Trunk carpet - plugs?
  171. What mods are you MOST pleased with?
  172. coolant leak
  173. Just Failed Emissions Testing. Please Help
  174. Is this the head gasket leak? (PICS)
  175. Only boosting 10 psi?
  176. what injector adapter to buy?
  177. Front end link bracket bolts
  178. Idle lean after catback
  179. Remove dash & instrument panel?
  180. CBRD- what the heck is going on ;)
  181. IX Idle Issues Please help
  182. 6 owners in 2 years should I be worried buying
  183. Mileage
  184. Used a 25G from Turbolab
  185. How many MILES/KM you have on your EVO?
  186. gauge cluster help
  187. Tactrix Openport 2.0 better option for tuning
  188. Best in tank single E85 pump??
  189. evo 8 mr roof rack!!!!!
  190. Questions on carsponsors.com
  191. I'm stranded, evo died while driving cranks but wont start
  192. Where to get real Alcantara
  193. Unmolested 2004 VIII GSR - help with pricing...
  194. Need help adjusting an off center steering wheel
  195. Would you buy this Evo 8...? Fine example but crashed and repaired...
  196. My VIII has an evo IV front clip?!
  197. Evo 8 Fog Lights
  198. Battery Power
  199. Towing
  200. BOV outlet size?????? 1 or 1.25????
  201. Stainless m10 1.25 30mm
  202. Grille/Mesh for EVO ix
  203. AMS remote oil pressure sending unit lower quality now?
  204. Auto IC sprayer not working!! Used to switch maps. Please help ASAP
  205. Mod advice please!
  206. Condenser replaced
  207. 3D printing Headlight lens
  208. distribution block setup
  209. AIT Bung Plug?
  210. my evo semi build
  211. Oil puddle on top and under intake manifold
  212. aem uego help!!!
  213. Blown Fuse
  214. Gas Door Cap
  215. Bloched Evo Front Lip
  216. Buschur dp and stm testpipe, exhaust leak
  217. Evo as a first car? Good or bad idea?
  218. Injector o ring to intake manifold oily?
  219. Agency power exhaust?
  220. Vta bov to hold boost
  221. No start after winter storage
  222. Engine Bay Crud from strut towers
  223. Oil consumption on track?
  224. evo rebuild
  225. Fuel filter query
  226. How many studs does an evo IX turbo have?
  227. Inline fuse on the cigarette lighter, aka "why doesn't my cigarette lighter work"
  228. How to remove injectors for dummies?
  229. Should I replace my 02 housing heat shield?
  230. MLR Sprint Series Round 1 - Promo video
  231. Turbo ratings and specs thread
  232. Stock Tcase vs Shep question
  233. idle dip fix?
  234. Recommendable Evo shops in/near Port Arthur, Texas??
  235. Missfire after carwash
  236. Manifold input
  237. Buying Evo 7
  238. Looking to buy Evo 7
  239. Evo 8 Next Mods**** Please Look
  240. Buying a high mileage evo
  241. questions about cf trunks
  242. alternator Flucuations??
  243. So my Evo was towed away today....
  244. Need Help!!
  245. Help with front fenders on Evo 9
  246. What's supposed to mount here?
  247. Interior headlinder questions
  248. Possible Coolant loss? EVO IX (time to panic?)
  249. Help me find good pump gas
  250. Previous owner
