- Need help identifying Evos in my videos
- Evo 9 Tarmac Black Paint Code
- gearstick movement in first
- Intercooler questions
- Evo 4 questions
- Interior parts diagram?
- took off my door panels and look what i found
- Dash lights dim after Tt install
- Where to find an evo 9 brochure?
- Fuel line vapor lock causing hard start
- SE Lip extra parts needed
- Harley davidson exhaust stall my car??
- Starting problems????
- FF vs standard turbo setup
- Engine warm-up knock?
- getting shocked
- starting problems
- Broken Evo 8 cam gear!!?? WTH?
- AVC-R users
- Thanks evom members
- Doing the clutch. Ball joints. Damn you!
- 400hp goal
- Hyundai buying 2004-2006 Evos
- Which evo do I have
- Ac oil
- Cannot Find. 52mm digital mph gauge
- Passing emissions with force patch
- Going to be buying 05 or 06 Evo
- Evo VII vid in snow
- how to take off oil filter housing
- stuck on how to mount license plate on jdm rear
- Identifying piston size
- weire serpentine belt issue
- Weird vacuum issue. Please give me input!
- How much does a evo8 shell go for?
- Constantly Knocking...
- anyone interested in experimenting with this rear diffuser?
- stock evo 9 wastegate actuator
- L.E.Ds for rear license plate?
- Highest Horsepower Stock Block Evo8/9?
- Where to buy valve cover?
- Need exhaust help!
- Long term effects of using C-16?
- Average labor costs
- Not boosting correctly wtf!!!
- Annoying Seatbelt Noise
- Tactrix cable nova?
- after 7 years my radiator took a dump on me, need your help.
- Need advie, springs or coilovers
- OBD - Evaporative System: Not Ready
- West Coast Evo Shop
- S2 and s3 comparison on 2.3 motor?
- Overheating on idle and low speeds?
- EMERGENCY fuel system question
- PCV Valve Replacement Parts
- Zip hoodie bought from store....
- fitment issues?
- Emissions help
- Who wants to rebuild my trans?
- Home Depot front lip
- "All-Weather" mat solution.
- Where can a guy get a decent 3rd gear pull around here?
- O2 Sensor Replaced. Car runs way worse
- Black fmic
- please help
- Evo 5 disapointment continued lol
- Plug question
- removing stuck loctite plug
- WB Gauge vs. EvoScan
- Full race manifold
- What does this plug in to?
- Moving to Arizona
- Just Installed Zeal Function T custom ordered for my evo EVO 6
- Stock bolsters wearing out? Swap them, Left to Right
- ext. manifold port width measurement
- Engine knock
- oem oil return line compatible with 35R?
- Arp exhaust manifold studs
- Stock clutch limit
- evo 8 wing
- Evo 8 not reaching full boost
- Evos from nz pics
- A/C issue.
- No Boost
- Gauge Cluster Lighting
- Evo 5 Mags
- What is making this noise in my Evo IX ? (Video Inside)
- my plan fell through... now what to do?
- Clutch issues or something else?
- Boosting problems
- Evo 8 Starter Problem
- Perrin Turbo Intake Tube Quality
- Evo 8 Bellhousing Price?
- Whats it like to drive your evo off a cliff?
- Evo Ix exterior questions.
- S3 cam spool on 2.3 motor?
- Alaska drivers???
- Cluster lights inoperable
- Cheapest half-assed way to temporarily fix diamond black BBS curb rash?
- 8 Lip Options
- evo 9 trunk interior
- How many original owners are left?
- Evo 9 AC Climate Control Unit Helo!
- Please help http://www.upgrademotoring.com/
- Bought from private seller, car threw rod thru block. Anything I can do?
- (ADVANCED) differential equation for modeling gas milage in an EVO
- What's up everyone
- evo 8 lower arm bar bolts
- Acd fluid is milky pink?
- Extreme psi valve seals
- Notchy gears or grinding?
- trans blanket
- Starting problems.
- Anyone know what the wires on an AC compressor
- Road trip unhook intercooler pipe
- can I crank my boost up 1psi without a tune?
- windows wont go down fuse is not blown??
- Cosmo Dealership
- More issues with the Evo
- Evo 5 Disapointment
- How much did you spend this year?
- How far do you need to drive after swapping cat/CEL fix to reset ECU monitors?
- 350whp is what at the Flywheel?
- 55 gallon drum for e85?
- sell car or part it out?
- Keep the injectors?
- Silver mr tailights on a white evo 8
- The FIRM's rally promo video link
- Non-HID headlights
- installing a map sensor on a 2005 evo 8
- Ebay Gauge pod like Gruppe S
- One too many launches...
- 1st gear not stalling out.
- ceramic wheel bearing whp gain?
- E85
- Methanol Kit
- Would Evo 8 abs sensor work on Evo 9
- anybody on here from houston tx?
- starting issues
- Evo with +4 cylinders?
- Overboosting...29 Psi
- Where to get a new Mivec Allen bolt?
- Blocks in pieces.
- Evo 9 bumper bolt part #
- Speed brake wobble! Just installed new coilovers.
- Mitsubishiparts.net still good to buy from?????
- what's the part # for the rear camber bolts
- fog light question
- WW Evo IX MR from L.I ... Second post
- ARC Winglets (replica)
- alternator no charge WTF...
- Launching?
- Is this catch can setup ok?
- Silencing external walboro
- Installing horn
- Issues with synapse dv
- Oil Mise in the timing cover
- Dual voltage step down fuel pump
- Key question?/?
- motor dies when i plug maf evo 9
- square metal part next to 02 housing
- What mods next????
- Low idle vacuum?
- Attention painters! Are all evo 8s a single stage paint ?
- Gialla Front Bumper lip?
- oil temp help!!!!
- BOV Recirculating picture REQUEST
- What is up with STM?
- evo 8: car shut off while cruising
- Virginia Beach help!!
- Screw cover need anyone break evo 8 have one?
- Russel hose fitting thread sealant
- Help EVO 9 stuck injector need help (not your typical bad injector case)
- Part dimensions thread
- Vrsf Tiago!!!!!
- Boost Leak and Vacuum at idle? Help
- launch control device
- Car wont start after brake install
- Running with th p0304 code?
- Looking forward to adding another Mitsu to the game
- E98 vs e85
- What model EVO to get?
- front bumper in canada
- headlights got scratched!
- e85 evo?
- Sell Evo or Part out?
- anyone hear of z1auto.com?
- Exhaust can question
- Smoking after oil change
- How much power can i get from the stock VIII Turbo with Kelford 272's
- evo 8 steering wheel trim
- Endless brake pads
- Plasti dip trunk lid and roof
- Front end rails
- Does the Aussie Evo 9 have a fuel temp sensor?
- What fuse for double pumper? Need to know asap!
- Floormats?
- EVO Project Idea
- Grumbling noise just before idle?
- Radiator help?! Brands?
- Question about Works Downpipe
- Evo records/accomplishments
- Noise help
- steering feels sloppy and loose as if the car has no guts anymore.
- Metal piece under the shift knob?
- oem 8 front bumper middle grille?
- Issues with bov return hose(ETS)
- Turbo noise/ no boost pressure
- Acd lights(frustrated)
- Mini battery vs battery relocation?
- 02 simulator ? Are they still on the market?
- traction with high hp evo's.
- Passenger door key lock function question
- Exhaust help HKS Hi Power exhaust
- Vortex Generator engineering article
- Tomei 2.3 crate motor *ebay*
- Dirty walbro filter causing lean condition?
- any socal people know this car?
- Drip Moulding Clips
- Evo fuel gauge wiring
- Shifter bushing measurements
- opionions need: pros and cons of the JIC magic DE type 2
- Spoolin up contact info?
- boost creep worries
- Fmic
- slight grind going into 2nd
- JDM evo8 won"t start at all urgent !!
- full-blown hobs stock ecu
- plasti dip trunk
- Can't decide
- Quick plasti dip question
- What kind of oil?
- 06 MR - P0171 Too Lean Code
- COP Question
- Weird AFR Readings
- exhaust noise
- DEPO black door handles?
- BAD MAF? evo 7
- Need Help!
- damn intake
- Omni Power 7 bar Map sensor
- need to hold boost!!!!!!
- Car locking issue
- EVO IV Air flow meter
- 95 evo head removal?
- Wire gremlins NEED HELP
- reputable machine shop in PA?
- fuel pump swap now doesnt start help
- My easter gift lol
- harness predicament-what's the safe option?
