PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. I mean seriously, 65K
  2. USAA insurance taxing
  3. Should've listen
  4. Sparkplugs Wet With Fuel
  5. Any one with torque solutions engine mounts???
  6. Weird leak coming from exhaust hangar
  7. 2017 NY Resolution - getting this damn Evo on the street again
  8. Average/fair labor cost for clutch job ?
  9. Best way to install motor/trans?
  10. Fuel management
  11. Front bumper air duct solution
  12. Reasonable budget for an evo?
  13. Twin plate clutch scraping noise when driving (pls help)
  14. Evo blue interior door panels!!!????
  15. Woodpecker noise coming from trans/transfer case area Help!! please
  16. oil pick up line Please help "Urgent"
  17. Is it necessary to break in twin plate clutch?
  18. Upper Intercooler piping
  19. Is this worth $15k?
  20. Best License plate bracket for evo ix?!
  21. Emissions testing an VIII that has been out of commission
  22. Boost leak test with smoke machine
  23. Intercooler hose to the left of the battery.
  24. Can I/Should I rebuild an engine myself?
  25. transmission fluids
  26. DSM'er looking to get into an EVO
  27. Help! Torque Specs ughhh
  28. "Crankshaft position sensor"
  29. Gt3776 turbo will work good on my evo 8?
  30. Idle drops very low. Bad tune?
  31. Removing plastic battery base
  32. fuel cut?
  33. ⛔★ Super cold weather car seems like it has a solid axle??
  34. ⛔★ Real bad MPGs, like 13mpg normal suburbs driving
  35. Imports
  36. replica Voltex widebody kit
  37. Anyone on here own my old car?
  38. Evo 9 with only 6k
  39. Twin disk vs single disk for a daily? And why?
  40. CEL code: P0134
  41. Tein coilover damper issue??
  42. Evo 8 cranks but no start
  43. Anyone see this gem for sale..
  44. New Guy
  45. Holiday Sales! - What have you ran across?
  46. ETS intercooler now has a screw on Bracket instead of weld?
  47. Are you a car slut?
  48. Back fog light JDM bumper
  49. Help identify GSC cams EVO9
  50. Questions about intercooler piping!
  51. Another ACD pump? Rant...
  52. Wisco piston question
  53. What is this Plug?
  54. Need help with some airtrek engine questions
  55. Cylinder 3 fouling plugs
  56. LOW Fluid!! HELP!!!
  57. evo not starting
  58. Vibration/Ticking sound after changing timing belt.
  59. Total noob that needs some guidance
  60. First time owning an evo 9
  61. The"I don't feel like doing that" clutch replacement method
  62. Evo IX cuts out and does not start for a few Minutes
  63. Compression Results & Question
  64. Cleaning the fuel tank
  65. RPM spikes when clutch is disengaged
  66. Will I need a new radiator?
  67. please help my evo..
  68. Sparco harness bar
  69. Do I need to upgraded fuel pump for a dyno tune?
  70. Evo VIII vs IX Block Identification
  71. Help Having Problem with startup
  72. 500 WHP Evo 8 to new Dodge Hellcat sedan?
  73. wideband in rear o2 spot, where to run cable?
  74. Unintended Acceleration
  75. Clogged fuel injectors again?
  76. I'm at a loss(no boost)
  77. Lean on e85, perfect on 93
  78. Musty Smell
  79. Re-Painting Bilsteins
  80. Evo 8 Passenger Side Axle
  81. CDI M&W pro 14 issue
  82. Evo 9 JDM Bumper
  83. Key stuck in ignition, steering column locked- HELP!
  84. rough idle but no cel
  85. Preparing my Evo for winter!
  86. Question about my turbosmart bov after switching to SD.
  87. Help, bolts cover diameter!
  88. weird stalling issue
  89. Info on building a 4g63 stroker: input and experience please!
  90. Speed density BOV question
  91. Bilstein B6 bump stop question (cross post)
  92. Evo 9 whining noise?? Pls help
  93. vband o2 housing
  94. New Member, New to the platform, not new to cars.
  95. weird noise..need help in solving it please!
  96. bee-R riv limiter on evo 8
  97. ⛔★ Clunk or thump when getting on the clutch, bushing?
  98. ACD pump sensor
  99. Where to route gauge wires?
  100. Evo 8 throttle body part number
  101. Car smoking- injector 3 dumping fuel need help with wiring
  102. 2.4 block question
  103. Question for my Evo 9 people
  104. I think i have a bad BOV spring
  105. Excess Water Drainage
  106. TSComp ACD ECU review
  107. Difficulties getting local dealership to perform crossmember recall.
  108. Timing belt rubbing/making a sound after changing it.
  109. Need help with seat belt anchor bolt size
  110. AN Fitting Measurement
  111. ATP Fuel pressure regulator (fpr) whos using one
  112. Coolant leak? Green fluid on top of tcase
  113. Front License Plate Bracket Garnish EVO 9
  114. I think it is time to move on from the evo
  115. dyno results full bolt ons
  116. Help: Power steering line routing
  117. O2 housing question
  118. Ecu reset & mbc question
  119. Enkei RPF1 wheels fitment issue
  120. Evo 9 Haltech Help
  121. New to Maryland: State Inspection
  122. Northern cali evo meets
  123. Trying to decide on my next car
  124. Where to get flywheel cut central NJ
  125. Tire Rubbing, wheel offset suggestions?
  126. TruBoost Only Reads Zero
  127. AEM custom gauge face plate
  128. Blistein shocks
  129. where this part goes? evo 5
  130. Speed Density in Colorado
  131. Evo 8 high idle issue
  132. 2003 evo 8, ticking problem
  133. O2 dump
  134. Need Opinions!
  135. Evo 6 upper rad hose
  136. Evo 4 very smokey all the time!
  137. Violent Jerk shifting 1st to 2nd under WOT
  138. Cusco front brace for stock Evo
  139. best transmission oil for evo 9??
  140. Evo 8 Mr spec
  141. 2003-2006 Evo engine build question
  142. ~~Howl/whistle noise at 60-74 mph (details inside)~~
  143. Anyone have photos of videos of the Evo in Production at the Factory?
  144. Next mods?
  145. evo 9 wont start p0335/p0340 huge story time line
  146. Evo blacks out under load?
  147. Will Dayco brand parts work fine?
  148. need help finding a video on youtube lol
  149. Stalling Issue, Possible CPS?
  150. Getting timing belt changed, do i need to replace tensioner as well?
  151. Spark Plug Discussion
  152. Idle Control valve issue EVO 8
  153. Rota Slipstreams 16x7 +35
  154. "rallytrack" trailer hitch owners...
  155. Transmission problem?? Pls help
  156. Longest running ownership of Evo
  157. Low compression unlike anything i've seen
  158. Do I need a tune for "boost tee" ?
  159. Purple Blue Mica Evo 8
  160. ⛔★ Evo 8 5sp, whats the door on the bottom on transmission for?
  161. evo 6 wont start
  162. RB26 in an EVO 8 - Not mine
  163. BOV - tial - open with small throttle
  164. Not another questions about oil again..
  165. Needing help with engine! (New around here)
  166. PCV valve replacement parts
  167. Broken Transferfcase
  168. Anybody ever make there own SD intake for a evo 8/9?
  169. Having loud ticking noise on my evo 8 (help)
  170. wing or no wing
  171. My very first evo ix purchase, assistance required please
  172. Odd Rexspeed JDM Rear Bumper Extensions
  173. Steel Braided Hoses
  174. respect
  175. undercoat
  176. Tps
  177. Question about jdm bumper diffuser color
  178. Looking to buy an evo 1 but have some questions?
  179. 2500-2600 lbs with full interior !
  180. Anyone have collector car insurance?
  181. Evo 9 not starting
  182. Evo 8 or Evo 9?
  183. Evo external part help
  184. What did I just find in the oil pan?
  185. idles at 2000 Rpm problem!!! evo 8
  186. Quick Edit: Evo V
  187. driving without under engine protector
  188. Need help with factory seat.
  189. Factory Recall ECU Flash 2006 evo IX
  190. A Chemical Guys car care kit for ridiculously cheap!
  191. Metal to metal sound when hitting certain bumps at highway speed. What could it be?
  192. Fluid help please!!!
  193. Anodized intercooler
  194. Can I import an Canadian Evo X into the U.S
  195. Safe Driver Monitor
  196. Rich Idle and Cruise - Data Log Attached
  197. Silver plugs
  198. Price check - 2003 Evolution
  199. Need BOV help (turbosmart dual port on a evo 8)
  200. Help with bolt size?
  201. Unsatisfied
  202. So how much of a pain is it to do the accessory belt
  203. What do you think of this no-drill license plate bracket?
  204. Best OEM Parts Supplier Online?
  205. Oil pump
  206. Help Me Diagnose a Sound (Videos)
  207. Timing belt factory install wrong? Need guidance
  208. Srs codes 22, 25 help!
  209. Button identification/ user manual 2006 evo
  210. Best place to buy used evo parts AUS?
  211. attention Hollywood CA evo owners, help identify this evo? look familiar?
  212. Spoiler Information
  213. 04 galant 2.4L Electrical issue
  214. Can someone give me some comment about this evo8?
  215. Running really rich when hitting it
  216. idle surging and dimming instrument cluster
  217. Shifting problems
  218. Evo 9 MR relay question
  219. Should i make this trade? Evo X for Evo 8?
  220. All 3 ACD Lights came on today--how long do I have?
  221. how to spot oem evo 3 kits from copies
  222. Engine vibrating Help
  223. brake booster delete
  224. Nothing but HOT AIR!!
  225. Low Fuel Pressure with Pedal Pressure
  226. HELP! Freshly Tuned Evo 9 Stalling and Cutting Out
  227. No heat from floor vents
  228. Evo 4 getting random beeping sounds.
  229. Need advice on cams
  230. Import Rules for a European Spec Evo 9 GSR
  231. My Modestly Modded Evo 9 (evovlog)
  232. Evo 8 power loss at low rpm's
  233. Moroso Oil Accumulator Setup
  234. Part speedo gauge light went out
  235. Can I run 225 40 18 tyres on 9" rims??
  236. Temp gauge stuck on hot
  237. Anyone recognize this sound
  238. HELP, want longer gears...wht to do
  239. Evo 9, AMS Brake Duct Inlets, License Plate Holder Mod [Large Pics]
  240. Potential Evo 8 Purchase - Seeking Input
  241. where in texas,can i get a tube frame made for my evo 8
  242. Evo 8 shocks n Springs on evo 4
  243. What to check before buying a JDM Evo8
  244. No start after new timing belt.
  245. Help - car acting up - rpm drop to zero
  246. Engine built
  247. Custom Dash Project - ACE LED question
  248. Swapping ignition questions.
  249. Weird bogging issue when hard shifting into 3rd?
  250. JDM Rear Bumper preping question
