View Full Version : Evo General
- Wiring Up Fuel cell to work With Stock Fuel Gauge *HELP*
- do they make this?
- Oil Leaking Around Exhaust Manifold Stud???
- abs light on!
- shift light??
- Tuning Fuel Injectors
- what do you all think about this??
- Dent in door
- Prosport Premium gauge stuck at -30 PSI
- Lend me your ears... Need help with a light damaged evo body.
- I keep falling in love with my car
- How my Car Changed Throughout 1 Year and 4 Months of Ownership PICS
- (Help), Diagram of 04 Evo 8 Rs ECU Pinout
- 32 counts of knock at idle.
- Evo black box - Anyone ever find it?
- Not making more than 5psi boost, need help please
- Exedy clutch question
- A new EVO 8 for me
- What is this part ?
- How to open .hex files (fuel maps) on mac
- Breaking up while boosting after rain
- boost spike - all of a sudden.
- no e-85 stations in Maine?
- cruise control
- Car isn't firing.
- E85 Rocketbrand Race blend E85 vs E85 on Pump Station. Post your HP#s & 1/4 mil times
- Dome light and electric locks arent working! NEED HELP!!!!!
- car feels flat
- My Evo VIII featured in Auto Eclectic Magazine
- Car died while driving now it wont start!! HElp!!!
- Oil
- EVO 8 MR HID replacement
- Difficulty Starting Evo 8
- Soleniod
- Evo X vs IX fuel pump
- turo is shot ;[
- ***TF Evo 8 needs a transmission asap*** help
- seat height
- 91 oct a problem ??
- Transfer Case Problem
- Help??????????????
- Its been a while - after 2 evos, in an Sti - my review...
- Should I..
- Driving with P0420 code
- Recommended injectors for set up?
- Duraflex
- I got the bug!
- Weird nose during drive help!
- Help, Wiring up 300m Coil w/ Dynatek Arc-2 Cdi
- this.
- Dash lights
- running rich?
- Evo 8 Wiring Harness question
- wb02 sensor
- Evokid03's beast is almost ready!
- pt6262
- Stock Evo IX USDM ECU ROM
- I hate cleaning my car
- buying used mr at dealer need help
- car slow even at 20psi.
- Whats the cheapest u ever bought mobil1 for?
- does anyone have rpf1 on ww
- What to do to hit 400 whp on EVO viii
- SprintBoost
- CXracing intercooler?
- precision 58mm vs fp red on 93--help!
- evo HID in non HID headlight
- oil burn help
- minimum thinckness for the front rotors
- drive seat belt reel rattle
- rear differential bushing question
- car tips
- HID recommendations/advice
- Epm 02 dump
- Rear bumper question
- need some help!
- warranty cover my diff???
- clutch pedal vibrating
- Evo thermostat
- Color Vortex Gen. on WW
- What gap do I use on my plugs??????Please help
- external dump o2 housings
- Dyno tune today!!!
- Does anyone sell exhaust flange for the oem evo 8,9 muffler?
- Evo 3 fuel rail the same design as a 2gen eclipse
- Hit a deer and need advice
- Could anyone tell me the specs on the FQ400?
- needle bearing Pilot Bearing
- Steering ratio
- twin disc
- Brembo's on Evo IV
- Need opinions! car wont start
- ATTN: Ebay Buyers
- My Evo got stolen Last night...
- Someone save this brand new VII - PLEASE
- Anyone know the Color Code for this? (pic)
- what brands should i go with
- Tb trunk
- thoughts of selling your evo
- Question about the 2006 Evo MR
- Check this out ! really cheap real FQ400...
- size of stock evo8 steering wheel?
- left hand drive evo vii?
- Help! Car won't start after belt changes.
- evo 7 for 7600$- I dont think so
- Windows wont roll down!......need help..........
- spark plugs
- General Wiring Question
- how to adjust idle
- Need help ASAP!!! Having bad problems!!!
- best site to buy rims/tires
- Help with part numbers
- Checking Out Evo Tm
- Highbeams won't come on?? Where is the switch??
- How will you know?
- Opinions on parting out my Tommi Makinen
- Carbonetics clutch
- turn signal lights not working
- Best color rims on WW
- odds and ends needed
- key question
- ETS 3.5 or APS 3.5
- 9 RS ACD ECU serial no
- Forgot TDC before belt removal. HELP??
- Need advice ASAP: Is this a fair price for a stock IX MR SE with 2,400 miles on it?
- evo is not creating boost??? HELP!!
- Trouble after timing belt replacement?
- Anyone have a pic of a Evo VIII with the HKS Intercooler piping kit?
- blue wire on a/c
- Gauge Fitment Issue
- starter fuse
- HKS intercooler piping, Good or Bad?
- Just got the evo!
- Evo GTA RPM Drop
- Rattling/noise @ 1500 RPM EVO 8
- Oxygen Sensor Wires Pulled
- oil pressure gauges
- tial sounds like a turkey
- bored today so painted rims/calipers...
- Plate Frame Ideas???
- Yet another problem with my evo8 after a rebuild.. lf advice.!
- throw out bearing fail
- Can I mount my HID hardware on NON HID headlights?
- Front o2 Sensor
- Finally paid off the beast!
- drivelinemotoring.com
- Under valve cover question
- Evo8 Rear Upper Control Arm (Toe) looking for options.
- can i use standard 2005 lancer body parts for EVO 8?
- All Evo's California Certified?
- what to do first
- boost flutter/surge after cam install
- oil Temp Senso Bad??? Replacement???
- Clicking noise from front driver side
- Windshield Rattle
- Rear Hub Knuckle
- Thinking of trading my GSR for MR
- DIY JDM Film Options
- Will a ebay test pipe fit on a turboxs TBE??
- aem oil pressure gauge
- daily driven hydraulic TOB clutches
- What you dont like about the Evo
- Need a good picture (MR)
- Stock turbo timer on Evo IX SE?
- Does anyone know where I can get a hood vent cover?
- LF: How to change clutch
- Evo 6 : SRS Fault codes help
- Warranty specifics on 2005 evo
- sti killer license plate
- rallyart style REAL carbon fiber mirrors
- Going to look at an evo tonight
- Anyone with a BR downpipe on an VIII?
- Ringing sound?
- evo 7 pistons
- Need Opinions on this Evo
- Wierd Problem....Please Help!
- double pumpers
- Cool F&F stuff i found online
- Broken Crossmember
- Looking at an EVO
- turbo drain cloged...
- Does this look like a good buy?
- During hot days, car feels sluggish
- How much hp will my car make??
- Black and grey Recaros?
- DC Sports Downpipe Gasket
- who has cam position sensor covers
- Whats a good price for an evo IX MR SE?
- What should i be producing?
- Father's Day Present
- Thew a CEL after blowing off intercooler hose, 4 readings.
- Should i buy this EVO?
- Turbo Removal for o2 Housing Replacement
- my visit at Top Level Performance
- Bumper help please!!!
- mini battery install help
- Stock looking intercooler but better performance and chrome?
- Evo Intercooler Piping Keeps Coming OFF!!!
- headlight question
- How Mitsubishi is your Evo?
- I'm really tired of seeing...
- weird squeaking noise from Coilover
- So I broke at the track.....help with diagnosis
- Which headlights came with HID and Fogs?
- Additional Key (Spare)
- Gauge wire routing
- Parking Light Help pl0x
- anyone have a perrin filter on an ets intake, help
- what size wastegate would you recommend
- aem serial gauge ??
- JDM IX attachment and fitment
- Is this considered knock?
- Why do people criticize the evo?
- whats your favorite Evo
- Steering wheel gauge pod
- Proper Clutch Adjustment?
- The bumper front lip is broken.. now what?
- If this was your EVO..what price would you put on it?
- Ground cable
- Motor needs to be fixed: Advice on what to do from here
- How to wash off exhaust carbon from bumper
- DBA 4000 series rotors
- Need advice for boost gauge
- P0122 (tps) issue
- strange boost leak
- "Is that a Real Evo?"
- Worse performance with new spark plugs?
- Convince my why I shouldnt sell my IX and get a BMW 335d???
- transmission install
- SRS Light
- evo meet in the IE
- fluids... all
- ets intake?
- Trunk Lip Options (other than Rexspeed)
- Looking for UICP that allows for a full size battery!!
- Cooling fan short cycling?
- 100-120 miles on a full tank of gas!!! WTH??
- Ebay short shifter
- Anyone know? Gas Cap Air Pressure Surge?
- Front Fender liner
- Mitsubishi Gauge Set - Boost/Volt/Temp
- Are the Evo Moto Camshaft Install Instructions wrong?
- Stock Boost Solenoid
- Sheared Off / Broken Downpipe Bolt
- o2 sensor help??????
- Is it just me or...
- Where and how to keep your evo safe if a Hurricane is coming?
- weird shifting problem
- Stock intake with K&N or HKS RS Intake?
