- more issues
- Quick question for Stroker Owners
- hey guys .. help me pick my new parts :p
- 3.5 inch Flange Megan DP???!!!
- Wideband Cable
- Repo'd?
- Is E85 worth it.
- Possible leaking of fluids from unknown area.
- Full Blown Double Pumper help!
- Need help ASAP
- Ya, its story time
- Wideband question
- Evo 9 bumper front lip
- Evo boost/vacuum leak
- IACV Hook-up
- Small Batteries
- Help building evo 8
- How important is the bracket for the intake manifold
- new best time
- extremepsi.com?
- cold start issues
- Someone tried stealing my wheels
- Pt 6466
- AVCR overboosting & sensor is making a noice..
- Noise coming from car
- Need Help! My evo is acting up. =/
- my first feature
- Vrsf muse o2 dump Leak!
- Quick help before my E85 tune!
- Evo 8 4g63 vs,. 4g63T
- Engine Management Light
- Spoiler/Wing delete kit?
- Help with my front end Clunking/Popping noise
- Anyone ever replaced the engine in their Evo?
- Speed density: can i use the stock intake pipe
- Will driving in sand mess up ACD?
- Valve Cover HELP ASAP
- spoolinup
- Tommi Makinen Evo AYC light on... Jap Import!
- Oil Change
- 400awhp ??
- Front driver side wheel noise?
- whats the best avcr setup for 1bar boost on evo vi
- Help!!
- "clunk" sound when shifting from 1st gear to 2nd.. What can this be??
- Couple Questions including where to go for tuning
- why does my evo vi max out in 188-190 kmph??
- Any one from Poughkeepsie area wanna help me out??
- cooling issues
- Part Indentification : Mount inserts?
- PCV Valve on valve cover popped off
- 240sx?
- Anyone running a zeitronix Zr-2 multi guage (boost)
- Fp black on stock block set up
- Recaro warranty?
- Koyo radiator, what cap to use
- Carbon Fiber Vinyl for Spoiler
- Radiator Cap fitment
- Car still doesn't start right away?
- HELP!!Whining noise coming from the rear???
- Forge bov or stock evo 9 metal bov?
- Mivec solenoid on my Evo 9
- Bad clunk, something hitting the floor ?
- How important is the undertray?
- Gruppe-S Gauge Panel
- Keyless Entry Issues
- CBRD- last week- what was happenin'
- Happy 20th Birthday Mitsubishi Evolution
- 3.5 FMIC but Stock LICP
- Fuelpump hanger question
- running lean at idle
- ACD-Tuning Review
- need input from JDM headlight owners
- built block on CL
- MOD day 2012: July 14
- Spoolin COP... Undecided
- Gasket Gasket
- It's the little things that count
- strange find during spark plug install
- ticking from stock radio
- Need Help Finishing Build
- Week 2 an having issues, please help!!
- Looking for random parts who has them
- Stock Injectors 9 MR
- where to find hks intake couplers
- Help need a part number
- Rattle Noise
- oil
- Replacing hood latch cable
- Evo 3 bushings???
- Best MPG App (Android)
- Fuel issue HAVE PICS.
- Vsf tiago
- Weird "Clicking" noise after 2k RPM
- shifter thread size?
- I got Hit.. What should I look for? Listen for?
- radiator help
- Weird noise please help!
- No compression in cyclinder 2? WTH
- Snow Performance or AEM for Meth
- Posted in wrong area by mistake. Mods please delete it.Thanks!
- is this the right tranny fluid?
- Got Overboost???
- should i feel bad???
- ATF SP III leakage? PLEASE HELP!
- Removing check engine light from the Ecu?? Possible
- RC injectors
- salvage to rebuilt title
- AEM TruBoost Error code??!!!
- need help with takatas
- rear bumper retainer + taillight gap.
- Rebuilding evo advice?
- Starter Rebuild Kit???
- evo 8 oil pan part number ?
- ACT clutch problems..go figure.
- muse o2 dump
- Spark Blowout help
- Advice - What would you do?
- Gas mpgs
- Headlights
- Will I be fine without a tune?
- Whats the stock lugnut size on the evo9
- does anyone have black halo headlights?
- Fathouse Fabrication evo Vid inside
- Finally getting another Evo (its been way too long) :))
- clutch just dropped to the floor need help
- electric pump relay problem
- Able to pass smog with mods?
- overboosting problem help!
- 03 evo 40k need help
- Front end accident/ no start
- Timing belt issue... Need Help!
- Want to trade your old body kit? Extreme Dimensions: Aero Trader
- APS bov!
- A/c parts question
- Car is cutting out
- Tial bov question?
- HKS H-power exhaust
- Click or sharp thump
- VIII overheat / Fan testing.
- Anyone making a carbon rear seat delete panel?
- Mitsubishi Parts Catalog Download!
- Vacuum Questions
- where to get e85 55gal drum?
- catch can
- Hey wassup everyone my progress
- synapse
- Leaking Oil
- Car won't rev past 2k and rich idle
- vibrating question?
- What AEM is this ?
- valve cover question
- suspension woes
- Did Anyone Else Replace This?
- I give up, no speed shops in So.Italy
- spark plugs
- Soo... my hood latch cable broke
- The Return....
- EVO 8 Front Lip Screw Sizes
- Oil Pressure Issue
- Is it worth switching from t3 to vband?
- cam advice
- my afr are at 10 on idle
- Best place to get openport 1.3
- Battery Recommendation ?
- Oxygen Sensor
- need a good supplier for full racing roll cage
- p0135 with new o2? no second o2 but no codes for that?
- Varrstoens Wheels
- Loss in Power
- Exhaust mani heat paint/coating...from the store?
- Defi D (DF040) EGT Question!!
- EvoII vs new car?
- brembo wrap?
- Favorite Modifications done to your evo
- 2.3 Stroker/turbo combo
- My evo died when shifted into 2nd!
- Walbro 400lph info/story
- Radiator Removal question?
- Smog guy ran my evo on 2wd dyno. Any damage?
- Aem wideband readings..
- Evo 9 HID Kits Vendors around?
- Aem wideband walk-thru
- cutting gauge cluster for aem gauge
- So I got rear ended tonight
- dash kit
- Please Help
- EVO IX Lubricants in Europe.
- oil questions
- Grandpa Evo's timeline with parts list...
- Engine lost power on the freeway, now it won't start HELP!
- Quentin @ Evo Power Mods contact
- Where is the clutch slave cylinder?
- Bov suppose open a little when idleing??
- overboosting help
- nisei uicp install
- Coolant temp flucuating
- going to try this with my oil today.
- My timing belt snapped when i was driving my Evo.
- HKS 274/278 Cams
- Picking up new parts... suggestions Clutch and Suspension...
- New clutch
- Which Fluid do i Buy?
- Dropping a little weight
- When car turns on knock noise?
- Evo 9 turbo into a Evo 6
- Replacement GReddy boost solenoid.
- my new evo first time at the track
- Drivetrain Issue transfercase
- Modded head
- wiring question
- need help asap
- HORRIBLE gas mileage. Bogging under WOT
- Sloppy shifter??
- removing head bolts.
- engine check light
- how good is the stock pcv
- old gas = better gas mileage?
- Spec-D JDM Tail or DEPO JDM tail ?
- Evo 8 hood vent
- Prosport gauges quick Q
- What Vacuum Hose are YOU using?
- Spark Tech issues
- evo8 front license plate holder
- Why people shouldn't text and drive.
- bov and nesei uicp choices
- No start after rebuild
- Previous tune??
- Alternator %&^*!
- Bouncing idle, and metallic rattle
- What kind of drivetrain oils???
- Help plz!!
- I'm looking to buy a carbon fiber apr rear wing
- Evo8 front lip
- ssqv issues......
- need to replace my acd pump. help!
- need help asap plz
- EvoScan DTC and AYC codes??
- Disc brake jammed... HELP!
- Redbrick Racing in training for World Time Attack Challenge
- Carbon fiber center console?
- Coolant
- The New SIERRA MOTORSPORTS.... Please Read
- will this aftermarket blank transponder key work?
- Hose clamps on welds of Exhaust
- what do you think ?
- Bone Stock idle rpm?
- questions on fuel rails amd cam gears
- Speed bleeders
- ACD Transfer Case
