- Overspray -- How do you get it off?
- Help with buying Tactrix & Evo Scan
- Need Help Deciding Whats Next
- How can I post in classifieds?
- Take a look at these logs, engine sputter with backfire/popping
- Best way to make 300 to 350whp with an evo 8?
- AMS fuel pump question
- looking for a boost/vacuum gauge with 35psi and peak/recall
- Rear bumper: JDM IX vs Bayson R Ebay Replica
- Evo 9 OEM radiator
- Evo 8/9 MAP Varex exhaust opinions?
- Hard to get my IX MR into first and reverse...clutch issue?
- Broken Timing Belt
- evo iv
- Valve cover vent tap
- Almost have my Evo ready for summer!
- RPM dip help
- Electric Blue Evo 9 Interview and Car Wash #WASHWEDNESDAY
- Evolution 1-3 gearbox
- Redline armrest
- EVO 9 spark plug issue?
- Is this CF hood repairable?
- Dumb Question
- No Oil Pressure Below 3k RPM
- 2.4LR build
- Throttle body shaft seals question
- radiator hoses.
- Swapping at Map Sensers!
- Any interest in pre-shootout Dyno day/test/tune near the track? Aug 17t
- Next modification suggestions
- New into Evo 8 Help to achieve 400-450RWHP
- AC compressor connectors
- Do you know where to get this headlights?
- Can you guys help my find a member
- grey evo owners
- Anyone care to give me an opinion?
- Evo 8 won't start
- I just bought an Evo VIII w/ 30k Miles and I have some questions...
- Considering buying an evo 8
- Need suggestions for a new BOV
- Double pumper install question
- July Featured Car Of The Month (FCOTM) Contest
- Photos of an evo 9 rear bar on an 8 or 8mr?
- No open loop?
- EVO V Rebuild?
- Evo 8 Depo rear taillight
- is it worth upgrading intercooler and piping kits?
- will this power brace fit my 8mr
- evo 8 starter "rebuild"
- Block: 4g63 Gst Eclipse vs 4g63T Evo 8
- Motor build thread.
- Help me revive the Phenix!
- How much gain can I expect from these mods
- Evoo8u
- Just Installed Side Exit :D - Video
- EVO 9 ACD Pump ATF Fluid Equivalent?
- Bought my new evo 8! Although comes with intermittent boost issues :(
- Help with clutch problem!
- Exterior design question
- ACT HD Street Clutch issue?
- how to diagnose shaking/bogging/hesitation on acceleration
- Evo 9 best intake
- Need opinions for my rear!
- Anybody know what these would be worth?
- Scratched Camshaft Cap
- Battery fuse block idea
- Drive Safe Guys
- Options for wrecked 05 Evo...
- Car cutting out/grounding issue
- Car won't start code P0107
- Grimspeed 3 port help.
- what sound system do you have?
- Evo 8 Leaking Oil Cooler Help
- Shifter cable bushings for JDM Evo 7
- Valve cover job gone wrong
- Mini EL327 blue tooth not talking to ECU, please help
- Will a JM fab o2 hood dump work with stock manifold?
- Car running hot
- Gas Tank repair
- Transmission Leak and Bolt Identifier
- Help pricing Evo IX
- Wiring Aem wideband: where to route the wires
- "Stock"
- P0138 90 degree bend
- blow off valve????
- Problem with wastegate solenoid. Help!
- Broke accessory belt tensioner bolt
- Evo wont start
- Undertray
- Need Help... Engine harness plug
- Shops in houston
- Strange pump-type whine (video)
- Plazaman vs Injen piping
- Help losing power while driving
- Polyurethane Exhaust Hangers: Good or Bad
- Walbro 255 question
- My first engine warning light :-/
- Rear Wiper Motor burnt out?
- PO300 random misfire help
- Run carfax for you
- New build EVO 8 MR 320
- evo 8 mr
- Thoughts on this s2k?
- Lost power on freeway
- Does anyone know this evo
- question with turbo noise
- Evo 9 rear bar with diffuser on my 8MR - thoughts
- Cannot Find a OEM Evo 7 front bumper and hood
- I need a body shop
- What is a low mileage 03 worth????
- Sputtering and Stuttering
- Can a axle leak trans fluid from boot?
- EVO shell
- Help!
- Evolution
- V band flange fitment help!
- Need help appraising.
- ⛔★ Evo 8 CEL not working, its not the bulb. Tephra v7 issue maybe?
- I need your advice
- Evolution
- Oil pump seal
- Bad OMNI Map sensor symptoms...
- Front Bumper Bolts Broke -- Help!
- Welcome. My Mitsubishi Space Wagon 2.4 GTI -99 Rear turn signal lights stopped workin
- Rough idle and lean AFR!
- Evo 9 mr tranny oil
- Help needed in identifying a whine
- I miss my Evo..
- Car can't be tune, and not making power. Reaching out to community for help
- Evo lacking power?
- AC question!
- Steering angle sensor calibration???
- so i launched for the first time in my evo 8
- Turbo question
- electric power steering pump convertion
- Fair trade?
- No power after Walbro 255 install
- My car was stolen last night!!!
- Are these the correct GSC S1 cams for an evo 8
- c-west bumper vs voltex type bumper.
- Evo 7 midpipe o2 sensor socket
- evo 4-9 enigine swap
- Steering Column Parts Help!!
- Why do i get 8-11 mpg on stock evo 8???
- The right tial spring, still fluttering.
- Cobb accessport
- What Part Is This??
- Fender Flares
- Installed uicp, weird gains.
- Original Fabric of the front seat
- Im i running rich? Help!
- Evo 7 getting through firewall
- Instrumental Lights on and car will not start
- If you had your transfer case rebuilt...
- Mini battery Catch can - group buy
- Evo 9 evo 10 shift knob
- Anyone help with a very rich AFR
- CBRD BBK Turbos
- Jack stand points 7-9
- Timing question, need help
- Evo 9 stock turbo glowing red
- Best fenders for running 285/30/18 +25
- Radiator Issue
- Heat Wrap Exhaust Manifold
- Bolt in Roll Cage Safety?
- Downpipe Rub on Sway Bar noise?
- Ets intercooler
- OEM Boost Line Location
- evo ignition timing
- 4B11 or 4G63 swap a converted Evo IV?
- Back to the Forums!
- Evo IX p0011 SES code and slight passenger side rattle thoughts for fixes?
- 2008 Evo MR
- 2008 Evo MR
- Inconsistent WOT AFR's
- Moving to Costa Rica what to do with the evo.
- Fourum noob
- Finally Modding My Evo IX! Any suggestion?
- Compression test evo 8 numbers good ?
- Complete 2005 Service Manual
- Turbo forged +300whp Lancer shaking badly at idle?
- Help Evo not starting!!
- Extreme tuners ...again
- Anyone know what turbo this is
- Funny afr at idle
- Blackops 1400cc latency?
- Need help identifying this bov
- Moving to Hawaii
- bnib oem evo 9 short block or 2.4 with h beam
- Help
- coil on cob
- My evo IV finally in 10 seconds!
- Exhaust or 2-step
- wideband going nuts?
- Cam, spring install. Clarifications
- Stock versus modified Evo 8 value
- Temp gauge reading engine temperature all the way in the H in the red area.
- Needs Oil Guide (Inside Transfer Case) TO finish my evo
- Best way to detail your engine compartment without water?
- Need help to Identify body kit
- Loud whine after changing rear diff bushings
- Quick question/answer stock 9 tails
- Confused regarding realistic performannce???
- Anyone a know what this is?
- Transfer case leaking??
- is this a boost leak
- Yay. Another speedometer issue thread
- trying too buy right parts for exhaust need help
- Evo 8 powered Porsche 911 video
- Help Diagnose bogging while cruising.
- Evo 4 w/ Evo 5 ECU - RICH!
- Width of JDM EVO 7/8/8MR seats compared to ADM or USDM seats?
- Evo 6 engine/ecu into Evo 4
- Vac leak?
- Issue with cylinders cutting out or something? Tuner and I are stumped.
- Best place to order parts from shipped to Canada
- Evo 8 battery light and brake light + missfire
- So dumb question about a MBC and tuning
- Evo IX minor accident
- Anyone use an Android Lolipop Device for Audio as well as data log via OBD2?
- Can a Failing EBC Solenoid Let You Make Less Than Wastegate Spring Pressure?
- PassThru Can Installation
- EVO powerband different than what I'm used to. Worried I'll miss my SRT-4. Thoughts?
- Looking at an Evo IX
- New member!
- Evo 8 Stock Piston Replacement
- P0170 shortly after tune
- Fuel pump problems
- how often do you change your oils when you track
- Officially part of the family!
- fuel problem issues
- buschur exhaust/muffler
- transfer case death whine!!
- Plusing grinding noise
- JDM bumper from cherryhillmitsubishi
- Racing Seat Help! Bride? Sparco? Cusco? Or Recaro Again?
- In need of a evo 8/9 oem hood
- Evo 8 TB coolant line fail..now no start
- Bleed the Brakes after Brake Booster?
- Tach is reading wrong?
- Diagnosis needed: ecu fuse keeps blowing
- Fuel pump or something else
- COP - Replacement Coil
- Fuel pressure issues
- Sensor.
- Wrenching & you - how did you start?
- Evo 8 no start
- crank voltage?
- part name and number needed
- Evo 8 Fuel system Modifications
