PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Please Help Me Find Previous Owner?
  2. Broken part behind steering column
  3. 05 evo rs need help.
  4. Help me find my old Evo!
  5. Damaged injector (with picture)
  6. coil pack & leads testing with meter acceptable Ohms range
  7. BR Double Pumper Whine < 1000 miles
  8. EVO IV idle problem(s)
  9. Evo 9 engine power loss ..... HELP!
  10. How many bulbs are in a 06 evo mr instrument cluster?
  11. Crazy light trunk skin
  12. RIP Evo
  13. Another Evo off the road :(
  14. WTB EVO 8 Rolling Chasis preferablly an RS but MR or GSR will do
  15. Evo Maf help
  16. Evo 7 intercooler colour
  17. Nurburgring 2016
  18. Timing belt install questions
  19. broken 02 dump
  20. New EVO Owner, Boost Issue & Cornering Judder
  21. Thinking of selling
  22. head noise ?
  23. Carbon Fiber hood
  24. So I removed my vortex generator today....
  25. Flow Tested and Cleaned Injectors... Now running lean at idle
  26. Evo Ix short block for sale eBay item # 322013342085
  27. ARF dips Rich during decel/off throttle
  28. Evo 8 diff blown - Help required
  29. Need help on smog, tactrix cable..
  30. evo 9 se low idle oil light flashes
  31. Buschur Front Undertray & Rear Diffuser Replacement Ideas
  32. Rear Wing Clear Coat Peeling
  33. And another evo hit....
  34. Best Shep trans 5 speed lube
  35. Unsure if tuning issue or not.
  36. Brake pads
  37. Evo 9 timing belt - Timing belt tension arm move freely moving
  38. Evo 8 downshifting problem
  39. Painted intercooler *help!*
  40. Starter wire blows fuse??????
  41. Hesitation start up please help
  42. VIII/IX turbo feed line I.D.?
  43. Tb question
  44. Would I need tune once putting stock parts in?
  45. how does 520 whp and 485 tq on a 2.3 sound
  46. Brembo pads. Correct part numbers?
  47. short shifter
  48. Oil Pressure! Help!
  49. Should I give up on my Evo dreams :(
  50. 03 heat adjuster .. i know i know
  51. Cusco widebody front fenders
  52. Evo wing removal
  53. Tial MVR wastegate help!
  54. LICP + Splash Pan
  55. Where to find replacement rear axles?
  56. For those driving SQS-E/SSS sequential shift converter on your evo..
  57. free: N1 coilovers evo 8/9
  58. Wicked White a single stage paint?
  59. Rallycross and airbags
  60. Trunk Support - Without Spare Tire
  61. AEM Infinity in the engine compartment :)
  62. Drivers side HID went out. New bulb didnt fix the issue.
  63. Windows go up/down extremely slowly?
  64. if you drive evo!! do not go to jiffy lube!!! cuz car could end up
  65. Erratic RPM problem,need help!
  66. Fuel Lines, pump, etc
  67. Ghkk
  68. This is my third evo ix purchase
  69. Recirculate piping plug
  70. Thinking of joining the club.
  71. Help!!! Trunk wont close
  72. ⛔★ p138 high secondary 02 voltage??
  73. Resonated test pipe
  74. Rear Lower Strut Bolt Size
  75. Blow off valve flutter.
  76. Map Sensor Evo 8 vs Evo 9 CEL Lights
  77. evo 8 wont start
  78. Front Mount License Plate Bracket
  79. looking for evo 8 interior floor carpet replacement.
  80. Lifters or Rod knock?
  81. Srs light on - which side sensor
  82. Knock sensor ohms reading
  83. D2 Coilver Dampening, Which way is which?
  84. Lean after clutch install :(
  85. Car "dying in flight" and some observations driving up a grade
  86. WTB: band manifold
  87. newb looking for advice/mod plans
  88. Intermittent Grind Noise on Evo IX
  89. "75" MPH tick on speedo
  90. Newb here
  91. painting motor parts
  92. OCD moment
  93. Anotha one...
  94. Enkei TS-10
  95. I need help car is haunted
  96. street slicks
  97. Should I buy this evo ix? Is it worth it?
  98. Hta35r exhaust mani bolts
  99. Aftermarket Sensors and Gaskets
  100. greddy boost controller, help needed!
  101. Engine sounds different
  102. Want to get back in the game, high mileage VIII?
  103. Fender Liner extenders
  104. Grease the Oil Seals?
  105. ★ Lc-1 logging through Openport 2 but without using rear o2 wiring?
  106. Accidentally shifted from 4th to 3rd....
  107. Help, Evo making screeching sound as clutch engages gear?? (Video upload)
  108. AWD to the rescue
  109. Spark plug cover bolts.
  110. Daily driver
  111. Exhaust manifold leak
  112. Steering wheel shake at highway speeds?
  113. ⛔★ Door chime dings with door open no key in ignition
  114. Another New Evo IX Owner Reporting for Duty!!
  115. Asking for advice from any DIY tuners here, thanks
  116. Evo 8 A/C Compressor spinning and cold lines, no cold air
  117. AEM UEGO logging help!
  118. Can the transmission fit in the trunk?
  119. Has anyone heard from Matt @ Spoolinup?
  120. Downpipe question.
  121. Number of X v Number of IX viewers
  122. Sourcing parts from auto stores.
  123. Help?? Fuel Cut problem!
  124. New 2005 Evo 8 owner!!
  125. Stolen Recaros. BOLO
  126. Anti-seize or grease on bolts?
  127. hard start whem warm only if jumped
  128. How thick are your Carbon Fiber Front Splitters?
  129. another clean wagon
  130. What does this sound like?
  131. New Owner checking in.
  132. Fuel Level
  133. need tuner!
  134. Request
  135. What do you think should be done?
  136. Need some opinions... Too good to be true?
  137. NEW MEMBER NEW EVO 9 OWNER :) :cool:
  138. Retuning or better job of checking my work?
  139. Transmission Question/ HELP
  140. What is this (Newb Question)
  141. Want to sell items
  142. would this be a good OBD11 scanner from Bosch?
  143. How much is my Evo worth ??
  144. car is sputtering, need help to solve problem.
  145. How much to replace roof?
  146. New Electronic Boost Controller, do I need a retune ?
  147. Ralliart Upgrade
  148. Prosport Gauge blows.
  149. Recommend spark plugs for Evo 9 ?
  150. 2003 Evolution 8
  151. Clutch install - fluids?
  152. P0141 error question.
  153. Tial q BOV right spring??
  154. Black Vortex Generator suggestions
  155. Looking for a set of TE37's Bonze 18X9.5+15~22
  156. Lifter tick Evo 9
  157. half mile records
  158. Evo 8 restoration discussion
  159. Where are people getting amsoil nowadays?
  160. Opinions of the value of the EVO
  161. 2005 Evolution MR 27k miles
  162. ⛔★ Any way to cheap EVAP system to delete the ecu codes and pass emission?
  163. Window Deflectors
  164. Cable question.
  165. Crankcase evacuation
  166. Somebody help me with this ticking
  167. New guy in TX intro and ??'s
  168. new zealand
  169. Moving a evo ix without tc and rear diff
  170. What's this noise??
  171. No heat.
  172. Check engine light
  173. Split personality
  174. New to game, simple questions
  175. Mitsubishiparts.net
  176. Transporting a motor
  177. pression power fuel cutting..
  178. good pal
  179. Getting back into the game
  180. 4g63 reliable engine?
  181. crank, fuel and spark. no start
  182. Can't get into 3rd, 4th, or R
  183. For the love of white
  184. Evo 7 T-Case Wine Help ?
  185. Axle half drive shafts
  186. New IAC installed, rough idle and wideband does not read
  187. Help with power steering issue
  188. Evo 9 Steering rack clunk??
  189. HELP! Need Evo 7 Water Pump
  190. Ac compressor keeps seizing at wot or high rpm
  191. Want to see what happens when an Ilder Pulley fails?
  192. :( No More Evo...
  193. Progressively burning oil ??!?
  194. Hondas to Evos, oh boy
  195. Evo not starting
  196. Recommendation Needed: Cheap radiator and intercooler
  197. Looking for some input with codes p0340 and p0335
  198. Which Evo is best for me?
  199. Quick Guidance
  200. WTB evo 9 CF trunk
  201. Evo XI weighing on image: responsibility, practicality, maturity
  202. Voltex Style Diffuser With JDM Bumper??
  203. Who has JDM rear bumpers in stock..?
  204. Do Evo's make good DD's
  205. SpoolinUp COP Customer Service
  206. G4js head swap issue
  207. my plastidip experiment continues
  208. Gruppe-S Gauge style for OEM 44mm gauges?
  209. Looking for carbon body panels
  210. JDM Rear crash beam
  211. Next step... e85 or turbo. Opinions valued!
  212. What can i get for these
  213. Price for built evo 8 with engine issues?
  214. Creaking noise from passenger's side front, help
  215. Anyone have this issue?
  216. Shift bushings comparison with different manufacturers - same feel?
  217. 2016 evo ix build
  218. Help with Evo intake sound different like a loose clamp maybe?
  219. Wheel Wells salt and gravel
  220. Greddy FV - Stalling, Rich Idle
  221. Is this the correct fluid?
  222. temp fluctuation help...
  223. Help ID these set of cams
  224. EVO VIII's with 10K miles
  225. Just got my first evo
  226. New Evo Owner
  227. Selling the EVO for a BMW 135i?
  228. Evo diff questions
  229. Turbo back exhaust
  230. Can EGR delete be done with the head on?
  231. Evo X Positive terminal wiring diagram
  232. Evo 8 Jdm headlights
  233. New to the forums!
  234. anyone been denied an accident claim because you didn't have front/rear crash beams?
  235. Has any ever built a kit car in their garage?
  236. Insurance on a IX
  237. Half axle shaft
  238. Evo 9 AMS IC & Mishimoto Radiator Kit
  239. Humming noise going straight
  240. Evo 7 ACD/AYC solenoids
  241. Snow
  242. New injectors and preventative maintenance
  243. What would you pay for this evo 8?
  244. Call me old
  245. Factory beast
  246. ECU advice?
  247. Update on Evo 8 Rebuild
  248. LED high/low beam conversion
  249. Issue after ECU replaced
  250. Choosing Undercoating
