PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 [101] 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Best AMS turbo kit?????
  2. how can i replace my o2 with my plx wideband?
  3. The AMS Time Attack EVO “TA1” is back and ready to kick some butt!
  4. do i have everything
  5. I need some help in deciding on a turbo
  6. Help! Nasty sulfur-like smell in my cabin air system
  7. Lightest USDM EVO chasis?
  8. Does this Evo check out?
  9. Painted Headlights
  10. is this to much?
  11. Need Help Guage Relocate
  12. JDM Headlight for an IX RS
  13. Evolution Manual
  14. Oil Pressure Gauge problem
  15. Quick Question, Quick Answer
  16. Flywheel Bolts stuck
  17. invidia n1
  18. I'm sorry ahead of time...
  19. need some advice
  20. Defi Red Racer not performing closing mode
  21. Wheels & Tires
  22. Huge car meet in New Orleans
  23. maf problems
  24. fq 400 and other evos stolen
  25. dyno numbers???????????
  26. Raising Boost after Road Tune
  27. Hey Guys Need Help
  28. Installed my rally shift indicator
  29. get them to warranty it?
  30. Need help from you guys on buying my first EVO!
  31. Quick IX Question
  32. Warm Climate ?'s
  33. Modding Exhaust
  34. How much would my evo be worth with slight front end damage that has been repaired an
  35. Front lip clearance?
  36. Ready For Next Big Mod!!!!
  37. Help Please
  38. Boost leak????
  39. Installed LED tail light bulbs, now getting all 3 ACD lights lighting up solid.
  40. Widebands & evoscan
  41. How much is it to get a key made???
  42. Lower RPM after putting aftermarket BOV!!
  43. WW problems with Evo IX?
  44. Which gasket to use with aftermarket o2 housing?
  45. Headlight question
  46. quick question??
  47. used tru boost ok?
  48. Any advice on removing this part? (pics)
  49. $8000 evo
  50. Think you guys have warranty?? Look at this
  51. Bored, question stumping thread.
  52. transmission capacity
  53. did anyone get "on time" when they bought their car ?
  54. sorry need info
  55. Dyno And Reflash Results!
  56. ok. i took my car to the dealership they dont know whats wrong with it.
  57. Evo won't start!!!... HELP!
  58. 4G93GSR CM5A with 4WD stuffs from Evo 4
  59. Car is stalling Help please
  60. Engine Sound in Evo 8 and Evo 9
  61. Cams...too much??
  62. Evo Scam???:: Houston Texas:: 8k Evo
  63. Info card numbers
  64. 60mm air/fuel ratio gauge?
  65. Vendors: Aem Oil pressure gauge
  66. Is This Car Too Good To Be True?
  67. READ IMPORTANT FOR YOUR SAFETY : SRS Light - $1500+ part
  68. is a 50/50 bov bad?
  69. Adjust door gap?
  70. Another member taking money and not sending goods
  71. Tuningtechnologies on the front cover of Dsport magazine
  72. Borrowed?
  73. EvoDave?
  74. Front and rear oxygen sensor differences??
  75. Rims for evo
  76. Rims for evo
  77. What would you do?
  78. Upgrading to a REAL car
  79. Vishnu's Xflash or Tomei's Exhaust manifold+dwnpipe!? Need help!!
  80. HELP, Question about headlight
  81. Flow rates on PCV system
  82. Evo 9 MR SE How many are out there
  83. money for mods!!
  84. rim of the world????
  85. Non-evo drivers..
  86. Help removing Trunk Wire PLEASE
  87. what do you guys think? can this baby come back?
  88. Thank You For Saving My Life....
  89. Front windshield/roof trim...why can't it stick?
  90. Removed brake lines and blown airbags?
  91. Mechanical to ProSport Electronic Boost Gauge.. Problems?
  92. ANOTHER LF axle boot leak. WTF
  93. Live and Learn
  94. I've got a real bad problem! Help!!
  95. drawing a blank. maybe its a brain fart
  96. Greddy turbo timer
  97. Tried taking out pcv vavle...failure
  98. head off heres the damage
  99. Ets Or Injen
  100. Exhaust Issue
  101. Noise from right rear please help!!!!
  102. CBRD evo in Modified Magazine-
  103. Aem wideband question??
  104. Oil light
  105. Plx Dm-100 Gauge w/Lc-1 Wb??
  106. anyone know of a evo III bulid thread???
  107. need urgent help!! locked out!!
  108. Finally she is home
  109. should i get a mr?
  110. Video: my Evo @ Motorfest Mexico!
  111. Autometer question!!!
  112. boost leak tester?
  113. Spring project pics
  114. How to install shifter bushings?
  115. EVO Grease Monkeys???
  116. Found a Evolution IX MR
  117. Fuel Injectors Cleaner...Do they really work????????????
  118. High mileage Evos....ok to buy?
  119. Signal and Marker lamp blubs replacement?
  120. What should I ask for this 500HP race motor?
  121. 411.68 WHP Stock Turbo Race Gas w/QTP cutout
  122. Inner Rear Spash Guard Question???
  123. Intercooler are Intercooler Right?
  124. Evo IX with stock MR HIDs, want to change bulbs...
  125. Injector size question
  126. Question about Oil Catch Can
  127. plug wires?
  128. Quest for 9's... Buschur Racing FTMFW!
  129. running 275s on 9.5
  130. 91 Octane
  131. Megan Track Coilovers Issue
  132. Is it possible to decrease our turning radius?
  133. So what would you do if this happened to your EVO?
  134. 'Click' under dash
  135. Arrrrg
  136. Big Turbo Up Grade Help
  137. you know you love your evo too much when...
  138. Brembo Brake Paint
  139. All evos queit at idle?
  140. OEM smell
  141. Are Evo8 wings under warranty or is the joke on me?
  142. weird noise coming to stops?
  143. Dash Light
  144. Will I be ok?
  145. Evo7 gets beat by a skateboarder....
  146. UGH! Another Steering Clunk
  147. Taillight out...not the bulbs. Anyone know whatsup?
  148. 400 Whp, Help Thanks Guys!
  149. Front Lip for EVO VIII
  150. insurance fraud
  151. just thought you'd like to know
  152. Very Disapointed!!!!
  153. Interest tester for FOG LIGHT CIRCUT BOARDS
  154. Couple of questions about warranties
  155. What should i do first Boost Gauge Or Drop the Car??
  156. Keyless entry
  157. JDM Headlight vs US Headlight
  158. Spark plugs Replaces at 13,000 miles
  159. evo twitchy at high speeds
  160. compression test = uh oh
  161. Hitting the good ole' 1320
  162. Outfitting EVO Interior for Charging Gadgets
  163. Rear driving light fuse keep popping???
  164. Evo Slow...
  165. Car Does Not Start Anymore....
  166. CEL fixer???
  167. Car is up and running... need someone to tune this beast now
  168. Evo Rally video
  169. I need a sunroof block off
  170. mmmm....upgrades
  171. Letter from Mitsubishi...
  172. Good Deal???
  173. A-Spec titanium manifold??
  174. No more tein green.
  175. Whats The Best Internal Wastegate For The Fp Green Turbo? Fp 18psi Or Forge Wga?
  176. A/C Doesn't Work
  177. Battery removal help, quick!
  178. evo interior help
  179. speedometer
  180. anybody knows this type of fuel?
  181. *** How often do you change your spark plugs?? ***
  182. Is it worth putting in an aftermarket intake?
  183. evo ix brembo peeling?
  184. Red Tint to my left HID??
  185. Clutch smell??
  186. Is it worth installing Injen LICP?
  187. Diferences betwen EVO 9 & EVO 9 MR
  188. NRG Seat bracket ???
  189. any members have 35r vids that they can post up
  190. aem wideband!
  191. Clutch clicking sound
  192. Evo 9 low mileage
  193. Evo Stock Xenon Light replament?
  194. Boost guages
  195. Chargespeed bottomline weave 1x1 or 2x2
  196. battery issues
  197. Gotta Love Us Evo Owners!!!
  198. Where can I buy this Window Visor?( pic inside)
  199. Painting The Front Lip
  200. Anyone?..
  201. cam gears
  202. hks dli ignition..
  203. Please Help Car Wont start after clutch pedal adjustment.
  204. Meth kit, or tires......lol
  205. boo dealerships suck
  206. question hks dli2
  207. I need a custom plate.... HELP
  208. Putting my evo turbo on a s2000?
  209. Mustang Dyno Question???
  210. Will adding an Intake system void d warranty?
  211. Cams or Air tools
  212. NY To Orlando
  213. painting the evo
  214. 3" piping question??
  215. o2 sensors the same from 03-06?
  216. Laser Iridium
  217. Evo VII on e-bay, anyone know about this car?
  218. @#$%*&$@# !!!! Icp
  219. fuel pump whine
  220. Good buy? Yes or no?
  221. Red
  222. small battery = hard starting?
  223. ? for people who have cf trunks...
  224. front bumper
  225. Gauge Cluster Swap
  226. Boost control solenoid HELP
  227. Air Intake 'Cover' Removal?
  228. Hello i need a SEAT!!
  229. Help! '06 Evo IX SE Price???
  230. Rear driver's side door lock problem
  231. Defi D Gauges
  232. Evo 4-6 Instrument cluster gauge pod fit evo 9?
  233. smoke and metal burnt smell after install o2
  234. Confused
  235. exedy 2 steppn
  236. But why evo!
  237. Evo tranmission origins?
  238. Question on warranty for modding
  239. Ferrari 360 vs Evo IX (not a kill story)
  240. Quick Question
  241. need input
  242. Anyone replaced the oil pressure switch/sensor on the EVO 8? help
  243. Anyone running NON-HID JDM IX Chrome Headlights?
  244. Evo to Mustang/Mustang to Evo?
  245. Du Luck Help needed from Vendors
  246. Squirley Tac
  247. who can tint tails?
  248. does anyone know how to fix oxidized wing!!
  249. Would this fit?
  250. tbe and oem cat?
