PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. evo 9 climate control bulb size
  2. Stripped manifold bolt
  3. clogged injectors or do i need a tune?
  4. catalytic converter bolts
  5. Weird idoling problem
  6. Custom shift boots anyone?
  7. Is it ok?
  8. Hood vent cover?
  9. Syncro??
  10. Evo 8 RS first gear whistle
  11. What is the best fuel setup for E85?
  12. exhaust manifold
  13. clutch?
  14. new tps and still got P0121 cel????....
  15. tein lowering springs?
  16. What it's worth? Your opinion
  17. Evo 8 stutter
  18. DSM RC 1000cc injectors in Evo 9?
  19. evo 8 and evo 9 white colors
  20. Car Diagnosis help
  21. shift knob question
  22. Recall... I need an honest dealer.
  23. Red red whiiine
  24. Evo VIII Wing deconstruction and repair
  25. injen uicp with stock intake tube
  26. cant seem to figure out what headlights and tailights go on what evo
  27. Does your Evo come with this?
  28. Looking of the amount of oil / R134a to refill an a/c system
  29. Mild build on Evo 9, Will I need injectors?
  30. boost leak test: do you plug the diverter valve outlet?
  31. Needs help/advice!
  32. Strange rich AFR issue - Any ideas?
  33. aps cold air
  34. New to evom
  35. What else to do????
  36. AMS vs Buschur
  37. Secondary Air valve
  38. Turbo??
  39. Bov
  40. just me or do these fog lights suck?
  41. Tial 44mm mvr issues...
  42. Affect of advanced timing on smog
  43. little problem
  44. will beatrush undertray clear mishimoto rad? searched
  45. TPS % wacky
  46. Advice for next mod to achieve goal...
  47. Will an aftermarket Boost gauge fit in the stock MR location?
  48. If you know cars, i need opinions asap!!!
  49. loose nut on 02 housing
  50. Driver side door is sagging.
  51. Which shift knob did i see?
  52. Exhaust leak
  53. Resonated or non resonated test pipe?
  54. My Evolution nightmare?
  55. This search sucks
  56. Evo 8 help
  57. RPMS rise high with ac on
  58. CWEST Font Bumper Install Question
  59. intermittent loss in power and response?
  60. Driver's Side Vent Not Working
  61. Bad Tranny.. Help
  62. Egr gasket placement
  63. hallman boost controller issues
  64. Quick Boosting Question
  65. Boost Issue
  66. Need some advice on choosing the right turbo!!!!!
  67. Upgrade to Block
  68. some reckless driver decided to ruin my baby!
  69. Slight problem
  70. Motor noise only at certain RPM
  71. Factory oil temperature gauge
  72. evo 8 swap to 9
  73. Break in for cylinder head?
  74. Ethanol question to all you chemists, engineers..
  75. Evo 8 vs Evo 9 slave cylinder...
  76. Autometer pyrometer egt exhaust temp gauge
  77. Evo 8 mr wanted mods, need advice
  78. Factory boost solenoid
  79. anyone have the ati dual pod
  80. Slipping Clutch?
  81. Gauge Cluster evo ix mr
  82. Head Unit Install Tips
  83. Evo X mudflaps on evo 8?
  84. Tape Airbag Light Illegal?
  85. RX7/240SX guy going EVO, Hello
  86. Where To Order Parts From
  87. Trading In My SRT-4 For An EVO...Help!
  88. which one looks better and has much good function...17 or 18" rims??
  89. MLR Sprint Series Promo Vid
  90. Are there any aftermarket part shops and drag strips in the Dallas area?
  91. Factory MR boost gauge
  92. Buying a new OEM short block
  93. Stock radio not working?
  94. Question on Evo 9 Wing
  95. Transmission (noob) questions
  96. Probe for EGT on downpipe...
  97. Exhaust leak at downpipe...
  98. Water, Fuel and Boost Sensors
  99. WOT Stutter
  100. Needing some advice
  101. Does anyone out there upgrade 9.8 Turbos?
  102. Evo 7 Factory Alarm
  103. Evo 7 Aircon
  104. CBRD FMIC and UICP fitment
  105. headlight question
  106. Should I?
  107. clutch pedal acting odd
  108. Best Single TANK of Gas
  109. 02 sensor part number
  110. Claiming city for damages.
  111. Tire change to rage!! SAM's Club
  112. Correct oil presure at turbo?
  113. Good deal?
  114. Color Selection [MERGE]
  115. misfire issue
  116. Quick question.
  117. I have a small oil leak
  118. Stock IC piping
  119. Under body squeal, not brakes
  120. Pic request: Bottom side of stock hood, around vents
  121. Tough Decision: Trade Evo VIII for R32 GTR
  122. Sabrina's Got Wood!!!
  123. Fuel issue
  124. Evo IX ate rod bearing -logs-rom *who done it?*
  125. Spooling up cop question
  126. got some cash
  127. was looking into some h.i.d's
  128. broken bolt sitting in my transmission? help
  129. 32psi on Stock long block -- looking for people who do it
  130. Evo 8 280 cam idle before and after
  131. R/ternie
  132. Low & Mid Trims stuck at 0
  133. ...i needed a new acd pump anyway
  134. Headlight Help
  135. Evo 7 ecu w/Evo 8 Rom
  136. take a look at this
  137. injector size for 400 whp on pump gas?
  138. Evo IX leaking water on hot track day normal?
  139. Evo IX MR Headlight aim?
  140. Strange noise
  141. How are my aftermarket parts?
  142. humming on right turns. help new owner
  143. Help with...."THE PLAN"
  144. Questions and such
  145. So what vendors have a non-ACD transfer case in stock to build?
  146. Where can i get purple seatbelt straps
  147. Evo IX
  148. Humming noise while braking
  149. Replaced o2 with wideband
  150. E85 Myths Debunked
  151. Acd - ayc
  152. weird evo... questions
  153. Simota Mushroom filter
  154. Max Pwr and Tq on 93 and methanol
  155. sti guy going to an evo, ideas on this buy
  156. opinions needed, evo VII or IX tail lights on White?
  157. Took off my valve cover on my evo9
  158. Help oil light comes on at stop lights
  159. anyone know where i can find Exedy twin Pressure plate in stock?
  160. Living with Evo 9 Everyday
  161. Boost Leak Test FAILED! HELP.
  162. Headlight replacement bulb help.
  163. Help!!! 03 bad evo!
  164. Do you use AMSOIL?
  165. Plan to buy AEM Meth kit. Need advice...
  166. updated (kind of) progress figuring out P0365
  167. Aem boost gauge
  168. Fuel pump relay.
  169. Anyone ever bought this? Trying to find the cheapest way to get jdm bumper
  170. Help....only 12psi
  171. Which Evo to build.
  172. clutch question for evo9 exedy hd twin disk
  173. Clunking vibration at highway speeds going straight, smooth during very hard turns.
  174. Smog help please
  175. E85 Setup
  176. Defi VSD Concept HUD Display
  177. Bolt Dimensions for boltz...
  178. Hesitation when cruising.
  179. What turbo kit do I have ?!
  180. 2005 Evo 9 GSR Turbo Pressure
  181. New Sponsorship with Evo Power Mods. Along with a one of a kind build for me :D
  182. when its a must to go electric water pump? need help guys
  183. AEM dryflow filter replacement size
  184. What causes the po300 code?
  185. Whats with the FP Black??
  186. Question about my GSC cams.
  187. evo 9 mr bbs se
  188. p0401
  189. views on evo in USA and UK
  190. Speedometer Not Working & Maintenance Required Light On
  191. Key issues
  192. Would you buy.....
  193. Panel Air Guide?
  194. Tial BOV Users..Info Help
  195. 05 Evo Map Senor code HELP
  196. Best TBE for VIII
  197. Just hit 200K in the IX, Suggestions?
  198. Water inlet pipe diagram.
  199. Getting Rattling can type noise on Decel..
  200. Rally/Dirt Setups?
  201. USDM amber corner on headlights? Pics
  202. 2006 evo ix or 2011 wrx?
  203. 2004 evo mr
  204. does this seem like a good deal
  205. Bad news for E85 users
  206. where you buy your carbon vortex
  207. Multiple PLX sensors wired to ECU for Evoscan?
  208. What would you do?
  209. How much power will stock axles hold
  210. decision decision! cf lip
  211. TT installed but car won't turn off
  212. Painting my stock VIII wheels glossy black need reccomendations
  213. 20g turbo
  214. MR597271 o2 -> downpipe bolt alternative
  215. No power to my ecu....
  216. Carbon Fiber
  217. Clutch Replacement
  218. 1 step colder plugs?
  219. 280 Cams
  220. Roll Call for MAP Proving Grounds June 25-26
  221. Has anyone got their gsc s2 cams yet!!!
  222. Why do EVO owners keep their cars with such low mileage?
  223. turning down my exhaust volume
  224. Max hp on Stock evo 8
  225. Advice on 3 Point Harness w/o Rollcage
  226. What to expect out of used short block. NO FS THREAD
  227. Oil Squirter Torque Specs?
  228. 6 speed Input shaft bearing
  229. anyone else with a vta dump have this prob?
  230. Recalls?
  231. Kelford cams need Valve springs?
  232. To the Previous Owner...
  233. Supra fuel pump on evo 8???
  234. Pump going bad in my Double Pumper?
  235. Small leak need advise
  236. has anyone tow a motorcycle with the evo??
  237. Good porting job???
  238. broken side view mirror lense, how to fix?
  239. rear 02 sencer question?
  240. evo / eclipse iac's
  241. evo questions
  242. Need your knowledge, help me out.
  243. Evo 8 Thermostat Missing?
  244. Proper way to break in a new clutch?
  245. Steering Wheel Column Lever Lock doesn't work
  246. Liner for back windshield fitted incorrect
  247. invidia manifold problem
  248. Beat rush undertray
  249. broke my evo :(
  250. Exedy twin: what is the maximum thickness of the intermediate plate?
