View Full Version : Evo General
- Evo V and VIII front O2 sensor differences
- PLX Boost/Vac Sensor Module
- Parts!!!!!!!
- Who makes carbon fiber headlight deletes?
- Just purchased a few mods for my evo, How much Gain should I expect? What do to next?
- Evo questions
- parachute and seat mounting
- Ets hfc
- Evo 5 Rear Side Window Replacement, Help Please
- evo 8 leaking oil need help
- Anyone interested in a SS cast manifold?
- evo 8 will not boost pass 20psi
- External wastegate & boost tap on evo 4
- Horriffic Vibration while engaging clutch
- fuel pump bad
- Help: Turbo needle bounces
- OMP WRC-R XL in Evo 8/9
- car wont start after intake install
- T3 turbo options
- Building evo from scratch
- evo 9 mr
- anyone use T4 Super99?
- Haven't Modded my Evo for 4 years... What's new since then?
- Evo 1-3 / Dsm FP RED / BLACK or BB76Hta
- Welding Crack Oil Filter Housing a bad idea??
- where to find new oem brake fluid reservoir to clutch master rubber hose?
- Motor sounds like rod knock. Evo 8
- Changed spark plugs and now car wont start
- 02 dump and rain?
- 05 Evo 8 Value?
- bov whoosh sound
- Tried to aim my headlights and it turned into an abortion
- bought an EVO a month ago fill me in guys
- Stolen 06 EVO IX MR Graphite Gray - Central FL
- EVO 8 no spark & no fuel
- 13 mr service transmission required?
- How much should spool improve with down pipe, 02 dump and test pipe
- Royal Origin x All That Low 日本 Daikoku Night Meet 19/09/2014
- Rear Diffuser for Evo 8 JDM Rear
- stock evo 9 rims
- Buschur stage 3 install then disaster
- OEM ECU - anyone know how high the cold start settings/rpm for OEM?
- Boost question
- check engine light came on today?
- Evo 8 winter driving
- Evo IX front bumper
- Weird starting issue
- Injector pigtail wiring?
- buying an evo VI GSR
- Intake pipe size and verifcation
- Evo IX Intercooler Piping Kit
- Isopropyl Alcohol as a Fuel Instead of Ethanol?
- question about belt tensioner.
- Nardi/personal
- what is the sensor called located on throttle body
- Ignition coil upgrade
- Anything I should do before I put my engine back together?
- Size of bolt for heat shield? NEED ASAP
- Evo 3 Front Lip
- Fuel Rail question
- Ets small battery kit relocate to trunk?
- 20 minutes for the tranny to warm up for shifts to feel smooth?
- ABS Problem
- Idle fluxuation
- Random question for trading a Evo 8 shell
- Boost problem
- Help, Evo throttle pulsing, can't drive
- Engine shippment
- Evo IV Dash Lamp
- car not starting
- Semi-weird issue. Engine braking
- anyone use this radiator pipe?
- BOV and wastegate?
- Just bought an Evo, not sure about whining sound
- Does lancer fuel pump housing the same/ work with evos
- On the verge of buying an EVO IX
- clutch/flywheel replacement
- EVO 8 car wont start untill i've to crank the car twice?
- Anyone own this lip?
- is now the time to sell your Evo IX?
- Snapped exhaust manifold heat shield bolt
- What hose is this?
- Whats my EVO9 worth?
- Evo 7 accelerating problem
- Newbie question
- Evo 8 vs Evo 10
- 04 EVO ecu in a 05 EVO.
- Head light issue ..
- wheel Offset that will clear brembo?
- Help finding OEM 300km/h cluster part number (non Ralliart)
- Just Curious what its worth
- Evo 8 EBay exhaust review
- Has anyone noticed a change in engine + Exhaust note by running E85?
- Request for a picture of valve cover
- a/c fan
- Greddy Ti fitment w/ USDM IX Bumper
- wheel stud spinning with lug nut still attached how do i get it off
- I done it again..shifts fine with car off, won't go into gear when running
- Random Questions
- Where to get GOOD vacuum caps?
- Exhaust rubs bumper cover
- SRS Codes meanings?
- Excessive water out of firewall drain tube?
- Help Urgent pls EVo 8
- Main Girdle Question
- new world record 8.225@169.17
- Cam sensor mivec IX troubleshooting
- looking for an evo 8 steering wheel with airbag
- Any early Evos with structural flex issues?
- MMinvestmentCars Portland OR
- My antenna broke....need questions answered
- Problem Accelerating...
- How to adjust idle screw and table?
- My car is starting to whine!
- gauge pod phone holder
- experience with quick release steering hubs?
- New to site, much needed input on an evo9 I'm interested in
- red line on both my cam gears .?
- What Clutch Should I Get?
- Ics motor question
- Need 100hp, but keep torque the same
- no flex on my 3" exhaust, is that good or bad?
- tuned??????
- Anyone selling duckbill spoiler carbon fiber?
- Anyone have experience with eBay Clutches?
- evo 8 overboosting,rough idle and dieing
- looking for a evodave or ruthless kit
- AEM Map sensor issue.
- Dialing in my car for a tune.
- Possible Tune Issues: A/F @ 17 , Car dies with heat on
- electrical problems
- Video: Car cranks, has fuel, spark, but does not start.
- help! sloppy suspension on evo 8, feels like a boat
- intro to forum and some questions.
- Evo Motor in Mobil 1 commercial
- Programming a key fob and key with EMS
- 25g kinugawa 500hp next week
- 3 in catback w/ stock cat, 3 inch gasket?
- Emmisions readiness help please
- Alternator issue? Please help
- Evo 3 door glass
- Plug c-01
- What is this connection?
- Evo VIII Tach Dims from Headlights
- Evo 9 MR Voltage gauge
- Gauge Pods under the radio In the Little Cubby
- Whats my STOCK 03 VIII worth
- Car won't crank.
- Car won't start, please help!!
- EF3 2900 lbs E6 vs EF4 3500 lbs E10 who should win
- evo 8 hood grill vs evo 9 hood grill
- No More "Diaqueen"?
- Easy tune injectors for 500hp
- Fathouse Fabs project / Head noise / exhaust leaks
- I owe some one money on the forums
- Evo hunting
- Weird clutch noise
- Dip stick tube affects oil pressure??
- Nitrous Intercooler Chilling kit. Pros/Cons
- How do I jump fuel pump?
- questions about tuning.
- EVO IX oil filter housing
- Easy injectors for 1650 advice
- Evo X (860whp+) VS 1100whp+ GTR
- evo 9 fuel tank measurements needed
- AC buttons
- driver side window
- md inspection
- How to tell/differentiate 63 crank from 64 crank
- Bushur double pumper question
- Evo 9 makes horrible Juddering
- Cel on but no dtc after new map
- Light weight race batteries, impractical...
- Weird boost/fuel cut at 0.7 BAR - EVO 4
- evo 8 intercooler colour
- help: t case, or transmission leak?
- Feedback on price 05 evo 12,600miles
- Fuel tank
- NEED HELP! Acd lights flashing anti lock flashing
- FP red ball bearing installed. Oil in turbo.
- Evo 9 mr front bumper.
- Innovate Motorsports SCG-1
- Dart sleeving Evo viii or ix block
- injector tuning 1650 FIC Bluemax
- Michigan Introduces Bill to Ban Most Aftermarket Exhaust Systems
- Identify Valves
- Help
- My Evo 9 Misfiring. sounding like it has cams.
- Zaklee clear cam cover + torque converter
- car not starting
- Weather stripping and molding are falling apart
- Jdm hvac
- I need block engine evo 8
- CEL not going with evoscan..need help.
- Aftermarket parts fitment help
- So this is what I stumbled upon today
- Quality of Bayson R 03-05 EVO 8 VIII Varis Front Bumper Lip (Urethane)
- TME seats
- Someone help please. Open/unconnected hard line.
- Evo 8 16G question, banjo sizes?
- uicp
- Paint codes
- car starts w remote start but not with key
- Fp vs Stock
- Engine break up at WOT
- a/c Help
- Godspeed Exhaust Manifold (ebay)
- Anyone have a evo clipart blac/white pic?
- Exploding spark plugs.
- Need help asap! Installing MAP o2 dump on evo 9
- Boost Cut Or Fule Cut
- UKDM MR badge
- evo overheating
- Evo VI Experts Chime In here, help...
- HID conversion kits for JDM headlights
- Severe knock issue under cruise idle
- weather sealant stripping failure
- how much can the stock evo 9 head and block handel?
- Need help installing GReddy Profec B Spec Boost Controller
- Evo won't start after emissions and ac removal
- Walbro 450 fuel pump
- Evo 9 CEL
- Lean AFR's up top.
- 600whp EVO reliability
- New setup options? Evo 9
- A couple pictures by request (in-dash monitor)
- Evo IV/V/VI - 5th Gen Mirage Sedan Headlamp compatability
- Dropping tools
- weird front end noise, please help
- Back in the Evo game.
- Issue with AVCR
- Rexpeed -- any chance of carbon dash kits again?
- Hi All new member
- looking for Evo vii front bumper
- Fuel Injector Clinic 1650cc high impedance injectors have arrived!
- rolling fenders on repainted evo?
- Evo X Envy....
- No electrical power, won't start, dash doesn't turn on, lights work, battery charged
- My Evo V "Eva"
- Misfire possible bad wiring harness?
- Buying a evo 1
- Apexi turbo timer
- Evo 9 compression numbers
- Front Case Install Help
- EVO 8 coil on plug
- Turbo Oil Feed Line Kit for fp green
- splitter
- Timing belt came apart in 100 miles
- Interested in buying an Evo roller.. TIPS needed
- WTF is this thing I found in my fuel tank?
