View Full Version : Evo General
- Power Steering leak
- Hi anybody knows what a STOCK E9 Wagon Auto boosting at?
- Clutch Install experience on an EVO IX MR
- PIC is this OEM evo slave cylinder?
- New intake
- Transfering for 8 Months! Need a little bit of info!
- DV help
- walbro 400
- Tactrix cable ?'s
- Head studs pattern
- Need help if anyone has advice!
- 400-450hp goal
- 400-450hp goal
- do I need to re-tune?
- evo wont boost past 10psi n engines bogs down with ac on
- expected hp with trap speed numbers
- Metal pieces in my hotside?
- AEM UEGO help
- Thinking of getting back into an Evo (#4 is a charm?)
- Got CEL P0122
- Can I swap my tuned evo 9 ecu for a stock ecu?
- Alternator Replacement Tip (Detailed)
- Whistle from passenger side while boosting
- BR lithium ion battery
- knock sensors are silly
- AEM Live Tech Real time log!?!?!?!
- Boost will not go over 23psi!!
- Boost issue help?
- Tirado Custom Coatings ??? Still alive??
- Start up issues
- Questions to hit power goal
- Will any aftermarket front bumpers fit with stock crash beam
- Looking for a BOV....
- spark plug cover
- Typical Evo issues.
- Issues with car, Please Help...
- Strange happenings...
- Throttle body shaft seal, Recommendations?
- First boost leak test atempt
- is this worth it?
- Surge???
- Bogging at wot on 1-2 shift.
- 06 Evo help please
- strange throttle issue when driving fast
- Shifter steel or stainless ?
- CBRD- news- new building- pics...
- Engine Build
- Evo 9 front?
- Buddy Club spec II exhaust
- Ongoing, intermittent problem, need help
- Bad E85 in Dickson,Tennessee
- Unknown Harmonic Vibration
- Engine question/concern for Gurus and Techs - Please READ!!!!
- Weird black build up in 3rd and 4th cylinders
- Need help with my TPS??????
- Evo8 Strange Idle, WOT, de-cel afr..
- 3/4 throttle ok WOT throttle not good!
- need help finding solution to rubbing issue with seats
- Will base lancer trunk interior pieces fit in Evo 8?
- evap canister hose
- Tough cam timing question
- Police vs. muffler
- broke cam stories
- AC compressor not kicking on/ wire cut
- are cuts throttle response at WOT
- Throttle Position Sensor
- slight clicking noise from front driver after axle change
- Please help. electric problems.
- Help with Check Engine?
- Inner CV axle broken bearing?
- The first time my Evo has let me down....
- boost wont raise over 21psi
- How do you roll the front guards
- RWD modern 4g63?
- MAF question
- General question (FP shipping times)
- OBD Question my car wont clear the O2, EGR, or Catalyst.....Help?
- Who bought slowboy racing's mike huml 2006 red evo ix ssl?
- Tommy Kaira Shift Knob - Evo 8/9
- motor oil capacity IX GSR
- knock on cold start
- Evo 9rs base car -question
- Anyone know what size is the Rear view mirror?
- Wife experiencing bog in 1st gear?
- Evo MR 05' Replacement Advice: Clutch Dead
- Source for harness connectors?
- Axle shaft cause violent wobble?
- Cams help??d
- Mitsubishi Evolution ad from 2003
- A Good ECU
- What is beside the injector resistor pack? Pic inside...
- Question about grinding?
- Evo V Twincharger..
- boost leak?bov leak?video attach plz help
- Evo X bov
- Over voltage issue, please help
- Evo FAIL AGAIN
- evo IV flickering/tickering noise :(
- how to tell if tob clip popped off?
- Hunt Valley cars and coffee
- does greddy fmic fit with injen icp
- Who is this EVO douche bag that ruined it for supercars?
- Fuel injector o-ring.. is this correct?
- Loud bang!
- Torque Solutions EGR plate
- Clutch help
- stock evo Viii got cought in "deathrace"
- Fog lights
- Coilover owners winter ride height
- Constant Vibration
- Is my internals damaged??
- When buying out-of-state :
- How much does a test pipe really help??
- Kitty cat cracked rear wing
- Crankshaft angle senor???
- recommendation for head gasket for evo 9
- all evo owners in la socal
- alternator bracket with phenolic im gasket
- So I just re-coated my Brembos...
- Brembo front calipers.....Help
- squeaking noise?
- 60k service kit
- For those of you who removed the spare from trunk.....
- installing o2 housing
- Something is wrong with my 1/4 times and I need help.
- Let's show off our evos!
- Sound deadening removal after dry ice?
- Will cutout fit between dp and cat?
- Idle issue and stalling...please help :(
- Espelir downpipe any good?
- Mr. e85 and my Evo!
- Odd issues
- Wide powerband project, opinions/suggestions needed!!
- My apologies, but thank the meat head in the big truck
- CAR DOESNT START... sometimes...
- O2 sensor wiring
- Sequential Turn Signals for the rear
- diaqueen lsd oil ID
- Loudest Exhaust??
- Just how bad is the salty air around a beach for evo?
- obx twin scroll header with dump pipe ?
- Replacement Headlights
- Battery in trunk relocation question...
- HELP NEEDED to point me in right direction
- Loss of Power (Boost?) at High RPM
- Your opinion
- Which pin on ecu controls power to it?
- Waste Gate
- 906 whp Dyno at Mitsubishi Owners Day 2012
- Tranny, Clutch or both?
- bad alternator from serp belt
- Idle issue
- What track numbers to expect with a 2.4L with 525whp & 427tq? :)
- Im always on diets but should my evo be too?
- Someone school me on injectors!
- Annoying Vibration in floorboard
- Clutch Issues
- Invidia Exhaust
- Need Help on my A/C!!
- Felpro Donut Gasket Issue
- O2 and air fuel sensor relocate.
- Bumper duct question
- ?? ticking noise
- Modifications done and power you have accomplished
- oil question
- evo probs
- Turbo swap +80 mile drive+ no tune = ?!?!?!?
- evo dash gauges?
- Runroof vibration @ Highspeed?
- some issues i'm experiencing
- Question on boost, driving up steep hills and rpm range.
- Can I run leaner than 10:1 AFR on the pump?
- PPI website?
- Prosport air intake temperature gauge HELP!
- Reverse Light Issue
- Ontario drive clean 2013... LOOKS LIKE I WILL NEVER PASS AGAIN!!!!!!!! :(
- Power upgrade options?
- heaviest rs ever?
- How to clean out inter cooler?
- cat back exhaust questions
- Two catch cans....no oil collection??
- Exhaust Manifold
- Excessive White Exhaust Smoke?
- Torque solutions 2" aerial turning brown
- Evo 8 brake caliper question! Help
- Do you own a JDM Rear bumper or USDM Rear Bumper?
- Red grills???
- what next?
- what next?
- Ic sprayer delete question
- Megan Racing Parts?
- Evo Owners in Germany
- Towing Question???
- 30psi on stock? corporate car?? Hello!
- Fp Black vs Fp Red
- why can I not get my steering wheel centered?
- Better gas choice? 91 no ethanol or 93 with ethanol
- Think you're smart try this one out...
- HKS Turbo timer issue
- Quick question about A/C delete belt
- Hot weather owners, how's the AC
- Misfire
- self made dead pedal
- Any experience with the Black eBay downpipe?
- evo 8 build, opinions needed
- where to route postive cable thru firewall?
- injector pulse? EMS? Help!
- GSC s1 cam cold start stalling.
- evo mr 1/4 track time
- mr tranny wont shift into 5th gear at the track
- Do u actually gain any performance by adding a Grounding Earth Wire kit?
- Best Deal on JDM rear?
- OEM PCV Valve
- OverHeating
- Let's play indentify this stock framed fp turbo?
- exedy twin limits
- Shout out to ams
- What is your dream build?
- What sensor is this?
- cigarette lighter
- Need help modifying
- Someone stole my AMS shift knob at MOD '12
- STM customer service/ship times...
- Weird Engine Noise Help, audio included
- sunroof
- Evo VIII US-spec, 30 psi?
- Filter
- M.o.D Saturday morning
- Compression test numbers on a bulit motor??
- Oil return line gasket install
- Cosworth M2 272 Cams
- Need help!!!
- Evo sensor?
- need help identifying part
- questions: GSC S2 cams on stock valve springs
- is this a good deal?
- What're you riding on
- Classic car one day?
- evo ignition finicky
- evo 8/9 hoods
- Moving cross country.Shipping Evo: open/enclosed transport? Experiences/advice?
- turbo swap questions
- AC compressor wire location??????
- Ported intake manifold or gsc s2 cams?
- Radar for finding cops
- Can't Find 5th and reverse!!!!
- less boost
- Which setup should I use?
- Evo 4 windshield
- Best FMIC and piping
