View Full Version : Evo General
- Sun auto hyperforce?
- Map rev2,3 Vs. Curt Brown porting for intake mani ( help me decide)
- Missing a few fuses
- Gauges 60mm to 52mm
- Seat options in the Evo
- Random starting troubles and need some advice
- Odd starter issue solved (I hope)
- Where to buy OEM front fender?
- Is there a weight sensor in the passenger seat in the Evo 9?
- is this infamous Death Whine?
- brand new! would like a estimation
- Built a boost leak tester today
- AMS turbo back exhaust for evo 7
- 03 Evo 8 Front Brake Problems
- Service Engine Soon Light! Help!
- Weird sound when going full throttle
- Bilstein set worth rebuild?
- 03 Evo 8 extremely loud clicking noise under hood
- Tune
- Aem Digital Boost gauge help
- Aux problem?
- Cold Start Issue
- Evo 8 bogging down only in 4th and 5th
- Just need a little help please.
- how much??
- evo with haltech
- FP white FAIL :(
- what is this coil pack wiring?
- Speedometer and odometer + trip dont work. help!
- Motor Rebuild
- EVO8 low compression on cylinder 1
- E85 injector question.
- Slim Fan...
- Help Fix, WG Flutter? [video inside]
- No more pretty AWD warning sticker from Speed Element
- 4 point harness
- Jacking points on Evo VII
- Torque app compatible with Evo VI....?
- tranny rebuild at FFTEC good *review*
- mivec head
- Infrared car pictures
- Driver side Mirror got smashed. Just want to vent.
- A few Quick questions on my clutch install
- Hks turbo
- Going to get a JDM rear bumper
- Retune?
- Any changes to fuel pump assembly with e85?
- Vinyl Window Trim
- 2003 Evo 8 headlamps replacement?
- Lower Radiator tube hits the clutch slave cylinder....
- Stock block setup Safe?
- power steering leaking, help!
- AEM Tru Boost help/experience???
- HID'S are SO complicated. (and expensive)
- Has anyone ever attempted?
- 2 random questions
- coilover question
- Air in fuel rail?
- Dim interior lights.
- How long does that celery smell last
- Fp red/black
- EVO 8 white faced gauge removal?
- Spacers
- Cams with bbk full
- wife + mods = bad gas mileage?
- LC1 Wideband Issue...Please Help!!!
- Where does this plug into? Need help!
- Small crash, need help with info!!!!!
- Stock Evo 8 performance in high RPM's
- Best accurate wideband??
- Best way to use first gear
- 2 questions..... Your opinion matters
- Upper radiator hard pipe
- Looking for someone to run Car history?
- Torque Solution Side mount problem
- Oil Leak at Hydraulic Tensioner 05 Evo
- Radiator cooling plate
- Lancer Alternator on Evo
- help gas station gave me wrong gas
- Evo ownership, since 2004
- WOT in 3rd
- Oil in throttle body.....help!!!
- *gauge update*
- Where is Tamer!? (4WS Tuning)
- Need help with evo9 mr engine mount
- SRS light
- Head messed up from blown motor!!!
- First time porting!
- P0300 issues....
- Wear and Tear at current mileage!
- Zeitronix 02 gauge issue
- idling problem
- Faulty COP Ignition or CDI Box?
- Smell of gas?
- Absolutely stunning Russian Evo8
- defi Bf buzzer
- Which sensor is it?
- steering wheel doesn't turn all the way sometimes?
- how do i pass smog?
- missing something
- What all will i need for new injectors???!
- starting problem please help
- Evo 9 won't start
- Greddy gauges?
- New Release! Tarzan G Box by Do Luck
- Evo 9 Headlight
- Tracking down oil leak or burning oil in exhaust
- Lost but now its found
- e85 drum ftmfw!
- Oil catch can help!!!
- Stock vaccum diagram
- What connectors are these?
- HELP lower control arm bolt.
- Octane Boost - Lifesaver or Seppuku?
- Gruppe-s gauge pod no longer exist?
- Forge Adjustable Wastegate Actuator
- How much brake fluid?
- Harness bars and harnesses.
- need help with updating my vacuum line setup
- BR double pumper help
- Fp Evo flow advancement Port cover
- Greddy TI-C or HKS carbon TI exhaust
- Evo IX Mirrors noisy when driving
- Use OEM hangers for TurboXS Exhaust?
- What's This Leak?
- lug nuts evo
- Turbo help
- Engine tapping / knocking noise (E8)
- Cop coils wiring
- Cel today
- Click when trying to start
- Need help in identifying right brakepads
- rattling noise from under the car
- OEM Strut Rebuild
- Weird Thunking Noise - Just starrted
- Mishimoto radiator
- Prosport and aem boost gauge
- replica vii tail question
- Engine dress up Power Steering Reservoir
- Ignition Power Issues
- Put a picture to the profile?
- Which turbo timer?
- Warranty concerns with ACD pump failure
- eBay JDM Style Evo 9 Taillights
- Hks 272 cam
- Rusting Normal?
- Battery relocation
- (Problem) To achieve 1.10bar boost have to put 85% Duty %
- Balance shaft, keep or get rid of it?
- E85 vs fp green
- Evo fail....
- noob question
- where's the cheapest place to buy fuel system parts
- Buschur magnaflow exhaust or HKS sport exhaust
- WeatherTech Floormats
- 10k revving engine questions?
- Engine shut off problem...HELP
- rear bumper removal
- So, EVO Motor Swaps?
- P0420 Code??!!
- Sudden increase in mileage...sure it's a good thing but WTF?
- #1 engine fuse issue conflicting with igntion
- Walbro 400LPH vs BR Double Pumper
- Drivers side window won't go up??
- Blow valve
- evo hood latch has play
- Review: DC sports downpipe w/ cat deleted
- Evo 9 MR - Bad starter or other issue??
- car sounds horrid
- Wrecked Evo, Stupid deer...
- HVAC : A/C and recirculation buttons...
- Speed Bleeder
- Vacuum block off caps
- Throttle body coolant hoses
- installed cams now running rich
- Greddy BOV/Open O2 Flutter issue
- Evo shudders under sudden high boost... ideas?
- Trunk lid
- Odd hvac issue
- Oem oil filter
- What is this part called?
- Blox magnetic drain plug
- Somebody Tried to Steal My Evo!
- clutch issue... thoughts ?
- Trunk Picture Request
- virtual dyno tip
- half tank hustle
- My first trip down the quarter mile
- turbo to fmic to intake mani flow question
- p0132
- EGR remove or no?
- dual gauge mount a pillar ?
- Bad luck
- Cleaning mag and throttle body sensor
- Will insurance cover all of this random damage? Tons of pics
- Evo 9 mivec swap engine in a Evo 8 FQ320 ACD lights on
- HVAC Color change?
- New intercooler
- Aftermarket HID kit choices...?
- stalling/idle dip problem
- My 8.4lb Turbo back exhaust.
- Shifter Extenders, anyone here using them?
- newb here.. not much power at WOT
- Front bumper black plastic clips
- aftermarket FPR
- AMS vs. Buschur Motors
- Evo IX MR Factory Front Lip Help
- driver side window loose
- Best way to mount voltex side skirts?
- Evo VI TME JDM flares - anyone got one?
- Operating oil temperature
- grounding kit skeptics, read this:
- Random Parts
- kansai airbox +koyo rad + fp84 mm + stm uicp
- Solidworks drawing needed. Coolant bracket?
- Which Shift Knob?
- How much should an Evo 6 or 7 cost?
- heat blocking powder coating or ceramic coating info??
- AMS Shift knob
- shotty labor
- small battery
- Parts mileage
- Want to know about carcare one card
- fuel pump wiring
- will this knob fit??
- Could i use a 0.125" (3.175mm) copper gasket for turbo inlet?
- Maf for SD intake pipe?
- White Smoke in Exhaust using e85
- Who never needs to fix his car?
- Help needed, P0120
- Trip to NC. Suggestions?
- Popping Noise From Engine Once I Put The Foot Down
- Seibon CW-style carbon fiber hood
- Help: ACD light blinking and Anti-lock is on while driving.
- Car Running Sluggish
- well i got rear ended today but need some input from you guys
- Torque Solution Short Shifter Help
- instrument panel lights help
- Rear-Ended, need some advice on how to handle the situation!
- First time at a drag strip :(
- Tempurature Gauge Issue
- Sudden lean AFR's at Idle and cruse only !
- Ordered a new AEM air filter today..
- Aeromotive 340lph stealth in-tank fuel pump
- 2006 Evo 9 MR
- stupid clutch!
- My Birthday cake
- help electrical issue
- banks that give loans on salvaged titles?
