View Full Version : Evo General
- Evo 9 mr burning oil
- How does this happen..
- What T3 Manifold is this?
- Asking price of stock block
- Help!! evo isnt runnning right :/
- Looking for plug and play ecu!!
- Next Mods anyone?
- Where to buy a Radiator support?
- Sheptrans oops?
- 2.4LR Build Questions.
- Carbon fiber hood advice
- Timing Belt Install - Stumped
- Exhaust & header wraps
- Drip rails
- Best place to buy FIC 2150
- WHY does the oem IX lip not exist on the internet!?!?!?
- evoix front bumper cover
- Headlight bulb replacements on EVO IX
- exhaust manifold suggestions in $500-850 range
- 2011 Evo SSS - $22,000 CraigslistFind
- Fuel pump question
- Should I buy this evo?
- Evo ix rear bumper light
- Is my Evo's frame done? Body shop printout/pics (part 2)
- Wiring Harness Help! Went On A Depinning Rampage...
- Where to find OEM suspension hardware?
- My evo was stolen
- Map EF2.5 or EF3
- HOA vs grimspeed
- Missing pipe
- AC Clutch not engaging, diagnosed kind of.
- Evo VI (1999) Canadian Compliance
- Spun (Secondary/Counter) Balance Shaft Bearing - 2.4L/2.1L Questions.
- Evo got hit and pushed into a curb, body shop is iffy on frame.
- Tail of the Dragon
- ACD Code 65 Only!!
- Glad I own an Evo 8
- Anybody knows what the brand of this manifold is
- Evo ROM and Immobilizer?
- EVO IX MR 6-speed OEM Aluminium Gear knob.
- EVO IX Headlight Globe query
- Radiator or Not?????
- STM temporarily closed due to moving offices
- why not anti-sieze?
- Discussion thread about petition to keep evolution line alive...
- washington state
- Anyone ever seen this?? Mystery button?
- What are altezza tail lights?
- Insurance
- Has Mitsubishi stopped making Evo 8/9 parts?
- Autobody Shop
- Does this seem right to you guys this hp level
- Help!
- Buschur mustache bar (not about noise)
- Easy one hopefully..
- Did licp gains a lot?
- Evo 9 JDM headlight issue
- What is your favorite and/or most unusual mod you put on your Evo?
- Mechanic changed my clutch and destroyed my diff
- First Datalog, Some Concerns about Knock
- Metal sound when revving
- smog time
- 90 degree spacer with wb02
- id hate to know that I'm a broken record here… but regarding EVO IX fuel pump
- PCV Valve Part
- "Cast - steel"
- 4g64 head gasket question..
- General Evo 8 questions.
- Aftermarket trunk questions!
- Spark Tech average build time?
- Timing mark on the crank plate dipple
- Boost leaks?
- Evo 2, gsr common problems?
- lancer evo 6 diagnostic mode
- What can I expect to pay to respray rear bumper?
- Someone please help!!
- hey guys plz help my engine broke
- please help LANCER EVO 6
- FF turbo question
- what front lip is this ?
- what wear and tear parts should i stockpile
- Problems with AEM UEGO with Serial Cable (Evoscan)
- My 3rd Evo
- what do you think of your evo?
- Need an Evo 9 oem front bumper!
- Unusual noise
- Gas smell from exhaust.
- side skirts
- Evo head swap
- TW for a retrofit group buy
- Mystery bolt - Need Help
- new to the evo game. help please
- Boost leak test
- Evo 8 Shakes while braking no idea
- what the?… something stalled?
- Gearbox noise
- WANTED: EVO VII Taillights
- t4 TS gt3076 kit?
- Wideband?
- Evo 7 Built Motor idle issue...!!
- Leaking fuel at FPR?
- Fuel Pressure gauge pegged?
- Non HID oem headlight riddle
- Help with a few things please
- Interiror dress up questions
- Trying to get into EVO's
- 5 speed 5th gear failure?
- Soon to be Evo IX owner
- Why does my car stall when I turn on high beam or heater?
- Oil Smoke From Passenger side Near Firewall
- Another fun day gone wrong.........
- Oil coming out of cap
- Evo X Stolen - Looking to Purchase a 9 SE. What to look for?
- Wind tunnel results of various cars
- Evo 8 gas mileage on E85
- Matching Carbon Fiber
- Evo GTS 08 trans issue
- Must be an easy question; Washer fluid bottles… which one?
- "One-Touch" type oil filler caps
- Is it possible to get an evo 8 for $8k?
- Does rear diff = AYC?
- Quartermaster clutch
- newbie with evo1
- Amsoil Dominator racing 10w30 or Eneos 0w50?
- Looking at Evo's
- please help
- About my evo5 (please help!!)
- Bushur testpipe/cat over all length?
- Maf post bov for better idle???
- ALS on Usdm Evo 9
- Double Din Orbital Kit
- What oil do I need to change to improve shifting? Evo V
- My new Baby
- wheel fitment question
- IC Piping blowing off TB?
- Weird AFR at idle…faulty 02 sensor?
- Bringing my Evo from Hawaii
- WANTED: USDM IX Tail lights/Head lights
- VRSF, Muse 02 dump, and Muse UICP review
- No Start. Turns out, TORN B/S BELT & POSSIBLE SPUN B/S BEARING
- Questions about an 05 mr
- Gas Tank Door
- import alliance spring meet Atlanta
- Intercooler piping
- Bit of knowledge required regarding EVO IX turbos, power etc.
- EVO IX FQ-400 specs & details
- High mileage solution
- Evo 8 hesitation at WOT.
- Front bumper tilting up normal??.
- Evo 4/5/6 Body Trim Compatability
- What is boost by gear??
- I need a straight up answer about cams EVO 9
- No Start.. Turns out, TORN B/S BELT & POSSIBLE SPUN B/S BEARING
- brrrrrr
- body trim restoration?
- Question about what part this is
- Evo V vendors in North America
- random question
- Help! EVO problems
- Evo 9 Front bumper Wanted
- Grounding kit?
- Is ther ewa spot on here to sell stock parts?
- Idle issues
- Changed battery, low oil pressure
- stock or 280cams ?
- Full Blown Throttle Body
- Ways to increase car performance
- Oil temp sensor for OEM MR gauges
- Aftermarket exhaust fasteners
- I got hard pipes but can't find a DIY thread or video....HELP!!!
- question, looking into fuel pump as next upgrade. Why is Walbro 255L so popular?
- Coupler sizes and degrees
- Just another Evo that won't start.
- Launch your evo they said. It will be fun they said
- is it a necessity to get arp head studs when boost 20+?
- Fuel Injector Markings, Need Help.
- Weird stalling issue?
- price on my evo9
- Question on ac condenser
- HELP, Gruppe M problems!
- Looking for this bolt
- Need assistance/ evo viii
- Thinking of putting 6.5 turbo into my Evo 5 GSR
- can't fuel up when temps around 30F
- Be smart when trading for a used car!
- missing bolt
- help with evo9
- evo9 parts
- how to fix a broken door mechanism in an evo 8
- North Alabama Area
- shifter bushes
- Fuel Press. gauge sender install...
- Leaking. pics
- Looking for Evo 4 front right window regulator!
- Varis Dry Carbon Shift Knob
- Torque Pro screen and hardware setups
- HELP NEEDED URGENT!Evo IV seriously pissing me off
- Evo time attack info
- Defi Gauge expert needed
- headlight relays
- Whats the worst string of luck you've have with your Evo?
- People these days
- Small battery kit from hell
- Where can I get this badge
- Stock Evo 8 safe daily boost
- Evo 8 taillights
- rear bumper?
- Anybody have TOMEI stickers or badges?
- Changing fluids in my Evo 5, need help!
- What you guys think about this evo… Worth it?
- Took a girl out on a date last night...
- Big Wing
- Brake Fluids??
- anyone know what the ss line is for?
- is this evo worth it
- Stock computer and passing inspection question
- Hallman heavy spring
- Car Sometimes Gets Hot While Stopped
- Omni bar 96531 rom P1400 HELP
- Post deleted?
- If you have experience chime in!
- Can you please help me with my idling issue?
- 4g64 timing marks question.
- Sold Evo… Problem already 1st day?
- Weird Idle problem
- Steering Wheel Shake at Highway Speeds.
- Please Help with high idle
- Help with a purchase
- USDM Ecu In JDM car?
- What color is the bottom portion of a jdm rear
- SSL Evo ix stock subwoofer
- Greddy Head Gaskets compressed thickness?
- fuel line length
- Yet another what oil should I use thread
- Review: MAP Universal 3" Inline Exhaust Damper
- What can I salvage from an OZ Ralliart that fits the evo?
- Rally potato edition
- Stock Block T3 Turbo Options
- Speed density converted!
- Fuel Pump Hanger Filter??
- Slight regret regarding my EVO IX. your opinion is required. (bit of typing).
- What would you do?
- Buschur stage 1 Trans review
- Buschur strage 1 bushwacker review
- Newbie Question Perrin Air Filter
- car paid off
- New Intercooler option coming for the 7/8/9
- Problem while putting my clutch in, need help! Pictures!
- Fuel Injector Clinic Dealers??
