PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. First time working on the evo - fluids
  2. Battery Problem
  3. Carbon fiber.. Should I paint over it
  4. Conventional oil in Evo 8 ?
  5. Auto art Evo ix models
  6. Evo 5 transmission fluid pump located??
  7. Rough idle
  8. Built motor Compression test results
  9. Opinion Needed
  10. 70/80 mph vibration plus brake vibration need help
  11. Who here has removed blower motor
  12. How to install EGR?
  13. whats the proper way to launch?
  14. ACD/AYC Relay-Fuse location . Help Needed!
  15. JDM Headlights NON-HID bulb?
  16. What lip is this?
  17. pp02 for exedy triple, how to measure?
  18. Thoughts on purchasing an evo
  19. techie mod questions
  20. down shifting noise
  21. steering position sensor?
  22. Cf hood question
  23. turbo change
  24. After I changed the engine oil:(
  25. Exhaust Tip...
  26. Another no start thread...
  27. So I Did a Compression test... And well...
  28. quick question about stock recaros
  29. Where are these seats from??
  30. side effects of routing heater hose?
  31. evo 8 bogs out at 3000 rpms and 10 psi of boost help???
  32. lack of power and backfire
  33. need help buying an evo
  34. Front fender liner positioning
  35. How much blow by is too much blow by??
  36. Evo 8 5th gear misfire??
  37. Evo 8 radiator leaking coolant from top of fins.
  38. New A pillar needs color
  39. Has your Evo had an ACD problem?
  40. EVO9 fq340 450hp?
  41. Jumped timing...Bent valves?
  42. when to tune?
  43. exedy triple pin question
  44. Evo 9 seems to have cams but...
  45. Hood Damper Kit
  46. boost leak
  47. am i missing a plug somewhere?
  48. Good asking price?
  49. HID Headlight disassembly
  50. NEED HELP : EVO 9 stalls on 2nd gear shift after launch control
  51. rainy day concerns
  52. E85 fuel,getting codes
  53. Restriction from stock fuel filter.....
  54. Service (evo5)
  55. mpg?
  56. Evo x ayc/acd pump motor
  57. Evo ix wont go past 5500RPM at WOT - help?
  58. Remove Strut brace on engine bay?
  59. slipping clutch, need advice.
  60. Toxicfab!
  61. Evo 9 Turbo with Evo 8 9.8 Hotside
  62. ShepTrans shop for Clutch install?
  63. What RPM should I shift at?
  64. Loud "clunk" sound
  65. Does a Pre Turbo Leak make you lose power?
  66. Help High Idling issue Evo 9
  67. Heat soak/Oil pressure
  68. Axle won't slide out
  69. Looking for Evo 9 Shocks
  70. Need some experienced DYI'ers to check the labor bill..
  71. Problem with gates racing timing belt
  72. High compression on stock block block with s2's
  73. Weird Problem , AFR jam at 14.6 randomly
  74. About my evo5 turbo
  75. Oil Cooler Install Question
  76. evo 9 mr engine ticking noise normal or not?
  77. Online forum order = SCAM
  78. Throttle body :D
  79. Radiator Fan Issue
  80. Plug gap tight vs wide
  81. HTA71 for 600 brand new tempting
  82. Is my Ignition Coil missing the Cup the plugs to the Sparkplug?
  83. IX front bumper question
  84. Finally got me an AEM Infinity for the Evo
  85. How to: Apexi power fc
  86. do in my retrofit
  87. Official Blue By You Evo Thread
  88. Power steering pump pic IX
  89. Hyundai valve cover
  90. Evo IX RS...Should I trade for it?!
  91. How much can I sell my OEM/stock parts for?
  92. excessive footwell heat
  93. 3 vs 3.5 vs 4 inch downpipes
  94. 10.5 E8 Turbo limits
  95. Best way to glue PCV valve on Valve cover?
  96. 100 JDM Road Track & Rally Evo's... :-)
  97. Replica tail light sealing
  98. Best Cams for the Money
  99. Shoutout to Tom at Tscompusa
  100. Shifter stuck...Help
  101. Top 10 Turbo Charged Cars
  102. Front/Back windshield question.
  103. rhys millen racing question
  104. Exhaust Installed Happy Day, Boost Question involved
  105. boosting issues any ideas?
  106. EVO 7 AYC 3 lights - advice needed
  107. So my "nic-name" is BUD now? :/ lol
  108. Can anyone shed some light to my problem?
  109. anti lag
  110. What Front Lip is this?
  111. Reuse ARP Headstuds?
  112. Rough Idles
  113. 06 evolution idle problem
  114. EVO 9 Weight Loss
  115. bad timing belt tensioner?
  116. Tomei 02 housing with different exhaust
  117. Issue after issue with my Evo 8...honestly ruining me...what can I do?
  118. Jdm tommi makimen evo 6 for sale
  119. intake manifold
  120. My new evo
  121. Recommendation for IX front bumper purchasing
  122. Who sells hood dampers these days?
  123. going with a quiet exhaust
  124. Smell burning after trans fluid change....
  125. Going e85 probably next month
  126. Greddy TI-C and bushur DP install questions
  127. Spark plug problem
  128. zetronix AFR reader/E85
  129. The blood of your engine and how to ensure is top notch
  130. Cam advice for current my set up and goals
  131. UICP Bung
  132. s2R camshaft on non stroker engine
  133. Got JDM headlights with fog needing right size fog bulbs
  134. Cant choose snow/gravel/tarmac once im driving.
  135. door locks
  136. Anyone running a mini radiator?
  137. Best EBC??
  138. Hit the goal tonight!
  139. all 3 ACD lights on at the same time
  140. Evo 8 Injectors not firing fuel
  141. Thumps up!
  142. new paint... how long to wait?
  143. Need help on a used evo
  144. Popping/Backfire coming from Engine bay
  145. ARP head studs
  146. Evo 9 turbo with 9.8 hotside?
  147. ATE Super Blue Deemed Illegal for US Distribution
  148. Cbrd- news/pics/more!!!
  149. FRP Hood - Small dent/disruption in finish
  150. Proper boost leak test
  151. HVAC clip? Help!
  152. Squeaking noise when turning right!?
  153. Slim fan install without fan controller?
  154. Friend is giving me his ams knock off fmic is it better than stock?
  155. Anyone been to this shop?
  156. Annoying Heat Shield Rattle Fix?
  157. no start and ses light?
  158. erratic idling
  159. aem meth injection
  160. How to tell which FQ version?
  161. Fp red turbo upgrade questions
  162. MR sitting for over a year
  163. Retracting front license plate
  164. please help!!!!!
  165. lets play guess this sound (video)
  166. @#$Going Back to MBC. Leave EBC Plugged in?#$%
  167. profec spec2 boost controller
  168. Converting p/s rack to AN fittings.. ?s (pics, parts and lotta info)
  169. What is boost cut/fuel cut(evo 5)
  170. *HELP* unusual full boost stutter
  171. Fuel rail leak help
  172. Evo Tow Package.
  173. Passing emissions/readiness codes
  174. Help me hit 600hp!
  175. Well, I'm back...almost
  176. Anybody running a "grip royal" steering wheels
  177. Possible?
  178. Switched ecu's, car won't start
  179. Boost controller required?
  180. What type of turbo is this ??
  181. Will evo 6 boot lid fit on evo 5
  182. Friendly reminder, Don't speed
  183. Vortex gen help
  184. A/C causes car to overheat
  185. Is the brake pedal height/sensitivity adjustable?
  186. Ecu question???
  187. EVO 8 Starting problem
  188. Horrible sound during deceleration - Evo IX
  189. j&e built block?
  190. Accidently Removed pte bb oil feed restrictor fitting!
  191. who can build 2.0 block?
  192. Crossmember bolt sizes
  193. Evo rollover Value
  194. Does anyone on here know???
  195. Evo jo alignment pr 8.86 all boost
  196. Evo IX headlight part number?
  197. Evo 8 vs. Evo 9 Driveshaft
  198. Headlight corner stick out past bumper
  199. Fuel
  200. Trusted EVO shop in Philly area...
  201. Leaking tranny fluid from passenger side axle HELP
  202. A/C and Power Steering Delete Belt Size.
  203. Boost gauge help
  204. Help! Jdm rear stat!!
  205. Bye EvoM! Tactrix and Cam sensor FS
  206. evo IX power steering pump failure?
  207. Evo 8 different dashboard
  208. Street Import Fest V3 P.R. 9 Sec Evo's
  209. Evo x motor in evo 8
  210. Evo8 misfire under light load when cold
  211. Horsepower gain/lose
  212. New car warranty
  213. not cranking over
  214. Rear differential leaking
  215. Is this a good deal or not?
  216. What material hose for fuel feed/return?
  217. Dtc po243
  218. help! car rattles at 2000rpm!
  219. Evo 9 SE lip
  220. Powder Coating Thread
  221. whats next?
  222. Untuned mods
  223. What turbo should I use running 10:1 compression on pump gas
  224. Caravans to buschur shootout
  225. Fuse for the gauge cluster lights?
  226. Mirror very loose and HVAC Control took a crap
  227. Trying to find a DIY
  228. where can I get rubber liners for my gtworx springs ( making clanking noise )
  229. Difference between FP turbos?
  230. Stupid compression question
  231. 2006 Lancer Evolution Recall?
  232. Heel&Toe Question
  233. spark plugs
  234. JIC Magic Full Titanium Cat Back with type 2 muffler (oval) Review
  235. Evo wont start?
  236. *Warning - Only take your evo to an evo shop!*
  237. Cracked Piston/Engine build recommendation?
  238. Mystery hoses hanging around
  239. Evo 7 GTA
  240. Evo 9 Part out
  241. cylinder installation question
  242. IX front bumper parts
  243. Turbo outlet vac line.
  244. hks carbon ti exhaust
  245. Seminar or schooling for calibrating?
  246. Replace positive battery terminal cable
  247. Getting custom exhaust made, don't want deep sound
  248. front license plate bracket bolted underneath
  249. evo 9 turbo port?
  250. Exhaust quicky
