PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Electrical Questions for Stock Boost Control Solenoid
  2. Taillight wiring HELP!?
  3. Looking for a good fab shop in Delaware or Maryland
  4. Advice on 2006 Evo 9 MR
  5. My first time at the track with my Evo 9
  6. Vacuum/Boost Line Question
  7. Oil temp and oil pressure guages where to fit them?
  8. Exhaust for JDM rear bumper
  9. Car Died in Drive, No Crank, Just ticks
  10. 4g63 mivec camshaft caps
  11. Grade 10 bolts with lock washer skirt built in
  12. Hks turbo timer valve controller help plz
  13. Wheel hop, clunk + rough shutter on take off sometimes
  14. ETS short route kit compatible with oem?
  15. Paranoid or Possible TCase Whine?
  16. 4g64 oil pump
  17. Does Evo 8 Intake manifold fit Evo 6
  18. White plastic cap on top of the Transfer Case what does it do?
  19. Need advice onOil pressure sender install
  20. running very warm on evo 4
  21. evo 4 almost stall after high revs on idol
  22. Ayc failure in snow
  23. Would you buy a Car via an App?
  24. Front crossmember recall question
  25. FP Red HTZ JB supporting mods help
  26. Groaning Vibration from under drivers seat
  27. ACD Drag Launches
  28. Can leaking water pump cause damage to timing belt?
  29. *HELP* Will these weird injectors work for my evo 8??
  30. Building Evo 8 Block
  31. Noise around transmission
  32. Clutch burn in reverse?
  33. How fast is your Time Attack - Circuit Race Evo ?
  34. Switching From e85 to 91 Maps?
  35. Who else was at the westchester airport tonight?
  36. Anyone Near York PA
  37. Stock Evo VII GT-A mod/tune adventure
  38. Evo IX or X
  39. Power steering pump
  40. General question about fuel pressure dropping under boost
  41. Strange scratching/rattling sound coming from engine
  42. Evo 8 Overheating While Driving, Temp Goes Up Then Down
  43. HELP! Power steering problem
  44. +++I'm Looking for my 'OLD EVO9'++++++++
  45. Fair price for an Evo IX MR nowadays?
  46. Evo 8 hiccups
  47. Could some of you kind evo gods please help me
  48. Fuel Cut After Installing New Pump
  49. Won't Boost past 26PSI pte6766 turbo
  50. Daily Driving an Evo 9?
  51. Exhaust doesn't sit right
  52. Idle and bucking problem
  53. Car feels WEAK (E85 400whp/wtq 30 psi) - PLEASE HELP!!!
  54. Interchangeable fuel/gas tanks for Evos or regular lancers?
  55. Buying a salvage 9 MR
  56. In search of an LED that will fit Evo 7 Reverse light
  57. Grease nipples in ball joints anyone?
  58. Evo 6 stutters
  59. Looking for some ideas... car goes rich off throttle
  60. Evo 9 ACD pump
  61. Evo 4 Sprayer Switch
  62. Timing belt concerns
  63. Help, Deceleration noise rattle evo viii
  64. Do I have enough fuel?
  65. what happens when all 3 ACD lights are on?
  66. Rear Quarter panel availability
  67. Oil pan
  68. Motor break in tune
  69. Best short block on the market!
  70. Slave cylinder hardline leaking. Help!
  71. my latest VIII stumbles
  72. Pictures, how to.
  73. Anyone running torco or some sort of octane booster?
  74. Tomei Sparkplug Cover
  75. Remove CEL with ECUflash/EVOscan?
  76. Dead clutch spot
  77. Steering wheel parts
  78. Need advice for 650whp build
  79. Flat wheel towing a non acd evo?
  80. Noise when turning
  81. New on forum, Evo IV video!
  82. Walbro 255 is it just drop in ?
  83. Need Help lost bolts
  84. Error code with new exhaust
  85. Door handle interchange.
  86. Cheapest online place to buy OEM mitsubishi parts brand new?
  87. Body Shop Hiccup..
  88. Oem coil pack testing question (pic included)
  89. Evol 8 in Jersey
  90. USDM Amber Corner Lens - WTB
  91. About to buy an Evo 9 MR, what should I look out for?
  92. What's the going price for a ACD tcase and diff?
  93. Evo 9 MR2 help
  94. Replacement Keyfob - NorthCoast Keyless?
  95. Evo 9 stalls/jerks need help please
  96. Buddy needs help with his 03evo and i am at a loss
  97. Car spikes 10 AFR while cruising + p0134
  98. Should I Use a .020" oil restrictor to my BB Turbo
  99. Looking for a IX 5-speed, help please & ty?
  100. okay i need some help with 2byte load
  101. Is Facebook becoming the new online portal (Forums)?
  102. Evo 9 with evo X Dash???
  103. help with evo scan
  104. First EVO
  105. planning on getting 2006 evo as daily
  106. Changed spark plugs, now have boost problems
  107. Need some help here in Northern Cali
  108. I'm looking for a unicorn, can you help me?
  109. Wicked White JDM Bumper
  110. Sumo’s Evo 7 (Revival)
  111. Stock ECU record 8.77 @ 165 mph
  112. What is missing here?
  113. Front door swap: should hinges be this tough to bolt up?
  114. evo 3 thermostat housing
  115. low oil dash light will not turn on no matter what (yes I changed the bulb)
  116. Evo 8 GRS to evo 8 Mr engine swap.
  117. EVO 9 grinds on 5th gear
  118. EVO 9 A/C compressor for sale ?!!
  119. Body shop messed up my paint
  120. My Introdution to EvoM
  121. Springs or coilovers?
  122. Overboosting after evo 9 turbo swap
  123. Just bought myself a Evo 9
  124. Sunglass holder hard to open
  125. Spoolinup Speed Density harness
  126. Guys I'm looking for an Evo and can't seem to find any available
  127. *SOLVED* Low Idle at Operating Temperature (300 - 500 rpm)
  128. Please help a noob
  129. Looking to buy IAC valve
  130. Greddy LS intercooler vs Stock
  131. Evolution IX UK trunk badges?
  132. New owner into
  133. Are these stock 2004 evo gauges ?
  134. Questions on AMS REMOTE OIL PRESSURE SENDING UNIT LINE
  135. Buying Evo 7,8,9 Healights
  136. Help with a certain part
  137. What is a good price to ask for evo 8 OEM rims
  138. 03' Evo wont stay running:-(
  139. Running 26psi safe?
  140. Evo-7-8-9 Fender Help
  141. EVO 8 Block with EVO V head?
  142. My Evo 9 stock turbo boost inconsistent
  143. Down pipe with o2 bung already welded on
  144. Purchasing 03 evo soon. First things to go out?
  145. Evo 9 value? And anyone coming from the E92 M3?
  146. Evo- no code no start issue
  147. Intake vacuum line not connected
  148. Need Help Finding lights
  149. Engine reroute panel fuse keeps blowing !
  150. Cheapest way to get Evo 8 Lights
  151. Evo 8 or 9?
  152. Recommended air filter intake kit? - Evo 6.5 TME
  153. Evo 8 front case help
  154. ASA OEM Aftermarket Parts Program
  155. Awd & ABS Help
  156. Handful of questions about replacing rear upper link
  157. Who makes a hood exit exhaust?
  158. New
  159. Evo 6.5 aftermarket steering wheel(OMP) installation?
  160. Can you disable the immobilizer chipped key with ecu flash ?
  161. Buschur double pumper question
  162. Evo 8 bad ignition? Need new key / ignition?
  163. Unicorn in Australia
  164. 4th Gear Grinding Issue
  165. How much to install AC Compressor ?
  166. Evo Shop Near Knoxville TN?
  167. Purposes of splash Shield??
  168. Hey LA Can I borrow evo8 OEM exhaust?
  169. Rear O2 sensor bad?
  170. Just curious what you think this would be worth
  171. Mitsubishi Owners day
  172. _-♣Bottom End Starting to go? Full Detail Write up♣-_
  173. genuine bosch injectors vs fic, id etc
  174. Thinking of selling...
  175. Raising Idle speed evo 8
  176. Need Help! New Evo Buyer!
  177. Stock TME - New exhaust setup?
  178. SoCal paint shops?
  179. Replace stock gauges?
  180. SoCal shops
  181. Evo 8 build or sell as is.??
  182. STM intercooler on IX bumper
  183. ARP Head Stud install - need to replace gasket??
  184. Boost doesn't come on
  185. Security/key fob??
  186. Replace stock mr gauges
  187. Car wont move. Clutch engages and moves but throttle input does not help move further
  188. ticking noise + high knock count
  189. evo 8 won't stay on
  190. Where to place RTV sealant on valve cover ?
  191. Evo 6 cold air intake?
  192. 02 sensor readiness monitor....
  193. Evo 9 MIVEC stops working after 4000rpms
  194. 10 second street car build
  195. Evo 6.(5) maintenance service schedule?
  196. "Warm" start issue after retune..
  197. heads up for gates racing timing belt owners
  198. Intercooler upgrade?
  199. Evo 9 Mivec Banjo bolt cracked
  200. ** Oil Leak** Check this out, Strange area (FOUND WITH PICS)
  201. Small Drivability Issue, Thinking TPS
  202. Evo TME performance exhaust setup?
  203. Evo IV foglights & covers
  204. Evo 9 Steering Column!!
  205. Pending recalls for K members
  206. Evo 3 service intervals
  207. Boost issue
  208. My gauge cluster lost all its lights ? Help please
  209. Inner transfer case seal direction
  210. T6 rotella hott weather
  211. No luck with this car whatsoever..
  212. Car meet in Poland
  213. Replace a v band with a v band
  214. Evo IX A/C Problems
  215. Beat rush license front license plate bracket
  216. Any help is appriciated, no start, fuel pump not priming after head re build
  217. UK partner wanted for an export business, I'm currently in Japan
  218. someone enlighten me on this issue
  219. Is -6 normal for idle vacuum?
  220. MR oil drain plug
  221. Works Croxx Plate 2
  222. Please help. Clutch not disengaging Evo 9.
  223. Recommended battery maintainer brand/model?
  224. How many of you have broken map "guaranteed unbreakable" rods
  225. Undertray
  226. power windows wont go up when all the way down, please help
  227. Evo IX vs X - Street Car
  228. What do you think?
  229. Multiple evo owner delima ???!!!!!
  230. EVO IX -Questions on making my car a bit....louder.
  231. Suggestions on new clutch and fly wheel
  232. right side axle seal problems
  233. Mistake on Japanese auction? Can the wagons come as MR edition ??
  234. New evo 8 owner
  235. Best Street tire/ Daily Driver Tires
  236. evo 8/9 IACV pinout description/diagram
  237. Weird clutch issues
  238. Scratched aluminum underpanel (Beatrush) after bottoming out, anything to protect it?
  239. Evo 7-8-9 RS VIN needed
  240. Possible jumped belt timing is off? Symtoms
  241. need help please evo won't start aem v1 😡
  242. Laughing 2.3 FP black
  243. New Evo what to do
  244. jdm bumper install issue
  245. ARP Main Studs NUTS AND WASHERS PART #
  246. Squeak from inside bell housing
  247. Oil light Flickers on taking of
  248. APS Twin Vent BOV for Speed Density
  249. Oil Pressure Flickering Idle
  250. Spark Plug Wires
