PDA
View Full Version : Evo General
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Rear diff upgrade
  2. Tracking All Evo Listings in The USA From Facebook Marketplace
  3. AEM x series 4 bar boost gauge question
  4. EVO 8 restoration update
  5. evo in hard right corners and oil pressure
  6. Any good speed shops in the North East, USA
  7. My Evo-8!
  8. My TME!
  9. Evo 6 Sunroof Weatherstrip Needs replacing
  10. Jegs 15x8 wheels and tires
  11. buying a project evo
  12. Boost issues
  13. Need help w/ harness bracket reinstall location
  14. Fuel pressure problem
  15. Broken fuel pump locking rings studs
  16. Manley piston ring gap
  17. New OEM serpentine belt tensioner pulley normal play?
  18. Gas Tank
  19. Idle rattle noise ?
  20. Unused Plugs In Engine Bay
  21. Valve guide replacement problem Crack
  22. Rust under top window molding
  23. Wheel Arch Repair
  24. Fibreglass Wings, Bonnets and Kevlar
  25. Evo 9 transfer case rebuild
  26. Evo 8 replacement key
  27. 15k Evo 9 MR 'Time Capsule' Build
  28. Smoke after a hard pull
  29. Low compression cylinder 3
  30. EVO VIII dashboard and door panels
  31. Aftermarket door cards?
  32. burning up starters
  33. Rear Chassis Leg Rust - Repaired
  34. Looking for advice on my Evo 3
  35. A Complete Guide to Replacing a USDM Evo 8/9 Bumper with a JDM Evo 9 Rear Bumper
  36. Looking for advice from a Evo IX professional
  37. Locksmith in London
  38. Can any headlight gurus help me out please?
  39. Squeak / Rattle - Please Help
  40. Hn 2023
  41. M/E Wagner Adjustable PCV Valve - any thoughts?
  42. Main Things to Look for When Buying an Evo 7-10
  43. Trans or Transfer Case Issue?
  44. Carbon pop shaft
  45. Evo 9 front differential Wavetrac or Stock LSD
  46. Does the bottom of your trunk floor creak when you press on it?
  47. Track setup questions/tips?
  48. Evo 9 Fuel Filler Neck - Replacement Options?
  49. 2.4L Build For Track
  50. Some pics and parts of my E9 FQ340
  51. Evo X Downpipe/ High flow Cat
  52. I need help EVO 8 ECU to EVO 5
  53. 2006 Evo Values
  54. Low Seat Base with Rails for Mitsubishi Colt CA0 1.8 GTI
  55. Evo 8 MR started and almost immediately died.
  56. Evo-9 200K mile club
  57. AFR Logging Help
  58. Strange lamp wiring harness
  59. Manley I beam vs carrillo pro h beams HELP
  60. complete electrical shutdown
  61. Car Show Board Design - which one
  62. evo x vs ix
  63. Stock car - wont pass CA emission - Federal Sticker?
  64. Will DSM engine mounts work on an evo 3????
  65. Evo 8 smoking on idle!
  66. Fuel gauge not reading at all. Help please
  67. Mustang GT to Evo IX?
  68. Location of the Immobolizer ECU? / Need the serial number
  69. Evo or Japanese specialist in USA Georgia
  70. Anybody here have NJ collectors insurance?
  71. Evo 9 seats rails and slider replacements?
  72. Is it possible to use a front wheel dolley to tow a non-running evo?
  73. Evo Sounds Like A Subaru
  74. Evo 8 AC wiring issue
  75. Evo 9 dos and donts thread
  76. Evo 7 front bumper grill/vents
  77. Evo8 "cammed" idle
  78. fuel level sender signal
  79. Evo 8/9 Recaro Car Seat Cover
  80. 4G63 shop recommendation
  81. Questions about when doing clutch replacement
  82. What bolt size are these?
  83. external fuel gauge
  84. Issue Making Power
  85. Where to buy replacement Recaro seat back?
  86. one fan not working
  87. Miss my IX RS. Loved my GT4. Now have C8. Want an EVO VIII or IX again.
  88. Weird Ac Sound
  89. Advice needed: Lancer ES 2005 to Evo VII
  90. Carisma Type 1 - 2 same as Evo 4 -6 ?
  91. Evo oil catch can smoking help!!
  92. Evo 9 Floor Vent has no air blow
  93. Labor for replacing Mivec Cam Gear
  94. Just Another Headlight Restoration Post
  95. Questions about AYC and its value
  96. Daylights/cigarette lighter
  97. battery voltages
  98. Need a V7 SD rom for an evo 8
  99. Turbo smart actuator questions, please help
  100. Scam or NOT for an 06 LANCER EVO MR
  101. Evo 8 or C5Z for spare toy
  102. What JDM rear bumper diffuser is this?
  103. keep breaking compressor pully
  104. Oil pan question
  105. Egr
  106. EVO 8 Coolant leak behind intake manifold???
  107. Help with value - Evo 8 RS that needs engine work
  108. ACD system trouble shooting/issue
  109. Evo 4 low power/response below 2k rpm
  110. Evo 9 dropping cylinders
  111. Evo 9 dies while driving
  112. Oil in engine bay, need help
  113. Evo IV MAF Replacement (No SD)
  114. LF My Old Car
  115. digital gauges fuel level
  116. Electronic noise from car
  117. 2005 SSL: Lean, Lean, Lean
  118. Evo8 No Start Condition
  119. 2003 Mitsubishi Evo VIII "Project"
  120. Need Help - Missing Component on 06 Evo IX
  121. 4g64 oil squirters yes or no
  122. Evo 7 gta Weird idle on cold start
  123. Evo 4 won’t start pls need some help
  124. Any reputable machine shop in Illinois for 4g63?
  125. VIII Rear Chassis Legs ROTTED!
  126. Anyone here install an aftermarket fuel level gauge?
  127. Evo 7 Exhaust?
  128. Evo 8 incorrect turn signal?
  129. Rear bumper
  130. DBW from a 2005 CH Lancer
  131. Evo 7 no spark
  132. Evo 7 no spark
  133. How many 8-9 original owners are left
  134. Evo 7/8/9 a/c compressor suggestions?
  135. Need photos of gauges mounted ontop of the dash
  136. Evo IX RS unmodified auction.
  137. IAC Screws?
  138. 1mm over regrets
  139. Can I turn my 2007 lancer ES Sedan into a 2001 evo 7?
  140. Any Help
  141. Downstream/Rear O2 Voltage Low
  142. Evo IX MR BBS rim current value
  143. Evo8 idle control valve
  144. Brushing the dust off
  145. How to pull milage from unplugged gauge cluster
  146. I don't really know what needs to be replaced.
  147. What options are left for downpipes?
  148. Mitsubishi Lancer Evo I-X 1992-2008 Service and Repair Manuals
  149. CSF ultimate rad with fan thickness
  150. Evo 6.5 TME's at auction
  151. Launch Control Duration
  152. Link G4+ PnP Ecu help
  153. Failed Smog Readiness
  154. State inspection @ Houston
  155. 2003 Evo 8 Won’t run! HELP
  156. Exhaust E-vac For Sealed Catch Can For FF setup
  157. Mystery Bearing
  158. Lancer ES wagon question
  159. Dyno shop in Houston
  160. EVO 7 ecu question
  161. evo 9 with 4.3 final drive
  162. Evo guys what will you do when most of the evo parts get discontinued
  163. Evolution compression numbers
  164. Evo 7 SunRoof Parts needed!!!!
  165. The Alternator Problem
  166. Coolant disappearing, Headgasket?
  167. Evo 7 GT-A Vibration problem
  168. Oil temp gauge
  169. Evo 8 roller
  170. Disconnecting the battery?
  171. Pros and Cons of owning an Evo 4?
  172. Rattle noise, help please!
  173. Transmission Help, PLEASE!!
  174. High Evo 8 high idle problem / surge
  175. fuel leak front driver side
  176. S1 Cams
  177. ACR clutch
  178. Evo 9 fuel return help
  179. What's this part in evo7 engine?
  180. Help me: Evo ix mr transmission conversion
  181. 65mm ported intake manifold for evo 8
  182. Rattling issue - evo8MR please help
  183. Subsitute parts for Throttle body servicing an Evo 7
  184. Evo 8 replacement car
  185. My "baby" turns 19 soon, and went for a healthcheck...
  186. 4g64 with evo 8 head timing help.
  187. looking for EVO9 Rear Bumper, USDM
  188. Power steering High pressure line
  189. Ign-1a coils. stock ecu?
  190. Ac evaporator
  191. Kiggly 12T + AEM infinity spark timing way off, help!
  192. 2003 evo, HKS Cams and smog
  193. [QUESTION] 4G69 Parts Compatibility?
  194. Evo 8 freshly built 2.4lr no start issue
  195. Evo 9 etacs question
  196. Can't Figure Out High RPM Leaning Issue
  197. Evo 1-3 shifter same as later models? CAE shifter content.
  198. Evo 9 with 29k miles bought new battery but nothing is turning on still
  199. 3" to 3" with tapers will I need retune?
  200. Evo 9 oil low level light stay on when engine off.
  201. Evo 8 Troubleshooting
  202. Thinking about selling my 03 8
  203. Help me: EVO VIII MR information
  204. GSC beehive valve springs (5041) or Gsc conical High pressure
  205. Can anyone tell me what this piece is?
  206. Where should my AEM AFR sensor place to?? ( Pls Help)
  207. rich and high idle...
  208. Camaro totalled my evo.
  209. Evo 7 build help
  210. Evo 8 Build! NEED HELP!
  211. MaxxECU ?
  212. What oil are you using and why?
  213. Does hyundai G4JS cylinder head will fit evo 8 4g63 block?
  214. Lancer/Evo B Pillar
  215. the oil im using in my stock engine /minor modded evo 8
  216. Walbro 450 dead ?
  217. Egr delete vaccum questions
  218. can i make evo9's front bumper look like evo4 or 5
  219. HI i need help with definition id 52710007.xml for Lancer GTS 2008
  220. 2006 EVO 9 rear chassis leg replacement
  221. JDM Evo IX MR Trunk Badge Placement
  222. Just got a Evo 8, trouble shooting a few issues.
  223. kill all wipers
  224. Evo 8 GSC S3 or STM 650 cams
  225. 5w-30
  226. 2006 Evo rust question
  227. How do I purchase Tomei Jp when I'm located in US?
  228. Transfer Case drain plug threading
  229. GUAGE setup
  230. evo 7 no heat or ac blowing
  231. Fuel issue Help
  232. Please, need help finding rom!
  233. MAP sensor
  234. Cleaning around intake manifold
  235. Crud, that might have cost me 2k
  236. 400WHP Evo 8 Cali Smog
  237. Putting ECU back behind glove box
  238. 4G63 rebuild?
  239. Mitsubishi Evolution 7
  240. radiator question
  241. Is this motor mount attached right?
  242. What is Tephra V3???
  243. Evo x clutch recommendations
  244. Please delete thread
  245. Evo 7 chassis legs rust
  246. Evo 8/9 Values "?"
  247. NRG Cooling Plate (evo 8/9)
  248. Valves hitting valves
  249. Front Crossmember Corrosion - Recall #SR-16-003
  250. Another crashed Evo
