View Full Version : Evo General
- Is catch can need when upgrading to GT35R and does it matter which one?
- Some advise on buying an evo VIII
- JDM Bumper, How to mount rear plate?
- Perrin CC Question and Concerns
- Got rear ended, have some questions!
- Whos car is this....
- Did a VTA BOV ruin my Cat?
- Fuel problems
- 7 years since I bought my Evo VIII
- 06 MR Key Transponder Blank Question?
- Which radiator cap?
- untuned with mods
- The saddest day of my life
- Engine idle is revving high please help.
- Amber plastic in headlights
- Idle problems
- where would you buy your turbo kit from
- Can I use the stock TOB on an ACT clutch?
- titanium exhaust tip
- Sweet Smell but no white smoke
- need some advice ....should i keep or sell ?
- Thread Pattern for MR Shifter??
- Any atlernative for The Double Din kit?
- What's different between viii n ix turbo?
- Flying Rally Evo!
- do the subaru 2.5's spool turbos faster then 2.0 evo's?
- Question about Evo 8 service schedule/durability
- parking light question
- Whats wrong with my evo?? Excessive white smoke
- Can you put a X fuel pump in a IX?
- need some help and a little info ...
- The dream car. Is it even possible?
- Making the evo more fun at the track
- Do Luck Vendors?
- Need help guys. maf sensr, ecu
- How or Where to Buy / Fix Apex Silver SE lip????????????
- Someone Help PLEASE :(
- need Your Opinions
- Spolier Fading Dealer is the dealer sketchy
- What color is this?
- Interior Question
- What route should i go with my evo?
- touch up paint
- I need wire diagram or Ecu Pin info
- notchy 3rd grinding 5th???
- stock turbo , stock fmic ?!
- EVO 4, 5, 6, 6.5 USA owners
- ACD lights??
- Ebay 3" catback T-304 Stainless Steel
- Buschur downpipe bolts
- Where to buy evo 8 headlight lense
- Flickering clock and buzzing front ECU Help please!
- Best Gauge Pod and Place to Put!?
- MIVEC not working?
- Evo IX MR 6-Speed; Twin clutch????
- Progress on the Evo
- need stock manifold fitting turbo
- steering column broken???
- Trailer hitch SF bay area
- Any regrets going from an sti to evo?
- Fpred/stock motor/tuning question
- VDO gauges REALLY dim... Anyone else?
- possibly another evo, input please--
- Fender bender / OEM parts
- Evo VIII gas pedal question
- So the fun Begins....once you go black you'll never go back
- apr splitter:check greddylip:check
- delaware emissions testing
- fog light issue
- What BOV????
- Another Evo Newb Question...
- BBS Center Caps Stolen
- boost
- Hard chatter and soft pedal
- BOV Help
- Atenna Broke on my evo 9 mr
- help me with my after market gauges
- Steering wheel and dash vibration.
- JDM Rear Bumper Additions:
- Please help boost leak and cant figure it out
- what to do when you lose your wheel lock
- Badges?
- evo 4 RS
- pic of intake cam anyone?
- Front wheel wells
- Peakboost Lifetime warranty
- P0365 ruins my day.....everyday
- Mitsu Dealer Warranty
- Do you spreadsheet your build?
- No Spark!? CPS bad?
- HID Question
- What size coupler?
- Stock Clutch at the drag strip
- Car won't start...But it sounds close.
- knock sensor question
- F'ed up my cam
- Will the Evo be the next Supra??
- Quick rundown of my new Evo and a few questions
- at a cross roads with the car
- staggered tires????......
- Intercooler sprayer
- Key sometimes hard to turn
- Voltex full body Kit CF
- clutch noise
- Question between 1g and 2g
- idle fluctuation after resetting ecu.
- trunk wire?
- Dimming CD Player
- Clutch Break In Question
- Anyone currently using the AiM MXL?
- AFR Problem
- HKS 264in/272ex Cam Gears Best setting using Vishne Pullies
- Looking for a good tuner in Maryland..
- E85 or c16?
- Built or Rebuilt
- Mitsubishi why have the ACD?
- Help Please--What Runs #8 fuse Under Dash?
- Evo VIII backfiring
- Car depreciation after wreck?
- test pipe question
- Wingless
- EVO 8 or EVO 9?
- Can anyone make me a HVAC relocation?
- Anyone still using Borla manifolds or purchased them lately?
- Another overheating thread
- How much is my Evo worth?
- issues with radiator
- Anyone else have problems with their innovative wideband?
- radiator shroud For C-West Bumper
- Exhaust Extension
- HFC vs test pipe
- Evo IX with VIII front, badge question
- 5th gear issue
- TEHPRA MOD V7 help? CNJ area
- Winter Alignment Questions/ Suggestions
- Reinstalling Trunk Torsion Bars
- headlight advice (non HID)
- 03-04 Evo Awd Systems compared to the 05-06 ACD awd systems?
- Buying used Evo IX things to look for
- Is there a replacement for molykote 321
- Another Evo sold
- Clutch question...
- email tune
- Air intakes & exhausts
- knocking sound in first gear only
- ModularTurbo Evo pulls a Full size chevy truck out of a ditch
- Evo rx-8
- AEM Tru Boost Help (Did serach prior)
- AMS battery swelling?
- Transmission fluid alternative?
- Fuel Gauge Reading issue
- Buy Now or Wait?
- Shipping a Car
- Driver seat is coming undone
- Rear seat plastic cracked
- damn synchro help!
- Defi bf gauge help!
- Place to order ALL Oem parts?
- 2-Step Issue
- Low Boost
- Cheapest source for new oem hood?
- Crashed evo need quick advice
- General running costs of an Evo 7?
- Mishimito radiator install- Overheating
- 2.3L GT35R reBUILD - Almost done!
- mechanical VS electronic boost gauges. tested
- Is the Walbro universal?
- Police crash seized evo
- what do you think of my setup?
- cams require tune asap?
- Why so difficult
- Is it worth it? intercooler and pipes
- mona lisa dealers
- Need help in buying!
- Lana's back!
- very odd clutch problem
- Should I get injectors with this set up
- Anyone using manley 300m rods?
- Always gotta be somethin
- New Fogs!
- Problem breaking open taillights
- Fuel Pump Assembly Wiring Diagram
- New redline MT-85
- Need help on evo VIII issues
- Clutch problems? Or Tranny?
- evo radiator fan thickness
- Installing Gauges & Need Dimmer Wire on Radio or HVAC
- Wing or wingless???
- When should you upgrade your Fuel lines & Fuel Pressure Reg?
- Metal shavings....
- I Need advice on a catch can question please
- please help
- about to buy an evo! help pls
- Help: Rear Diff or TCase
- Cams Question
- Sun roof not working
- IX MR lip recomendations
- opinons needed..
- Daytime running lights
- Evo 8 Muffler on 2002 lancer oz rally
- Factory options different in newer years???
- Installation Kit
- Evo problems
- Front strut tower brace
- Prevent JDM Bumper From Melting
- evo ix mr question
- Which brand of fluids should I use?
- Solar Battery Tender?
- would a Blown Stock turbo cause stalling?
- Evo Problems Please Help
- Mbc????
- Diaqueen shelf life
- Guys refresh my memories!
- Annoying Throwout bearing noise
- evo VII
- walbro fuel pump
- Evo Situation
- My Day at the Dyno
- I need help with with evo 8 ecu
- Just purchased 05 MR..brakes SQUEEEEKING please help
- Are you the original owner?
- Place to buy EVO Parts
- Dimmer Problem After Radio Install
- Anybody know how to black out intercooler?
- oil burning? normal?
- Noob in the house
- Looking at Lightning Yellow 04 ssl 62k 14k .. New to forums .. Worth it?
- Electrical Problems. Help Needed ASAP
- Swapping Evo X seats into an Evo VIII
- Buying an Evo -- Differences between 04 and 05?
- Fair comparison between the viii turbo and ix turbo
- rear diff
- Evo 8 Tire Question...
- How many of you ?
- What to do?
- Just bought a EVO IX, noisy strut, please help!!!!!
- Evo 9 front bumper.
- Salvage Title Question
- Powder Coating MR Rims
- please hepl,tranny,diff oil change
- CBRD......i am so excited
- Where should I weld the 02 bung
- air duct question...
- Timing belt
- Headlight help
- 18th Annual DSM/Evo Shootout thread. An Evom review
- oil light flickering...
- Brakes help
- Is it harmful to drive my car without a muffler?
- Where is Bank 1 Sensor 2 located?
