PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Beat rush Evo 8-9 undertray DP clearance
  2. Need some modification suggestions
  3. Damaged Steering rack?
  4. Fuel Gauge not reading, need help
  5. Paint or Trade
  6. rebuilding the front end
  7. Connector plug beside IC sprayer plug
  8. Used Parts on the east coast
  9. Rough idle coming to a stop
  10. Spoolin Up cop diy kit issue
  11. Bov/uicp installation
  12. Exedy Twin Reverse Lockout ??
  13. How do I?
  14. Power Steering Pump Banjo Bolt
  15. Do I have aftermarket cams? You be the judge...(Video)
  16. e85 testing tube help
  17. independent inspections (i look like the bad guy)
  18. Is this a blown head gasket?
  19. Accelerator popped from 65mph and slowed to a stop and stalled
  20. 6an fuel line route in Evo8
  21. Bov position
  22. stalling and running rough after catch can install with deleted pcv
  23. Misfire on Cold Start?
  24. Ceramic Coating via Plasma Spray & Ceramic Paint Spray
  25. MAP EF3 Actuator
  26. exhaust
  27. Brad Penn Oil
  28. Does an 05 evo rs come with KYB struts?
  29. Evo VIII valve cover on a 1st gen Evo motor?
  30. Registration Event/Renewal Not Actual Miles Question
  31. clutch or slave?
  32. 2012 Census: Evo Owner Age
  33. Swift Plate?
  34. CBRD Upgrade to Ball Bearing
  35. RSB worth it?
  36. Tranny Questions
  37. Fluctuating idle with occasional stall
  38. MR BBS wheel set value
  39. Has anyone tried these?
  40. EVO 8 & 9 Front Bumpers Interchangeable?
  41. evo 8 brake lights
  42. Evo specialists in Seattle
  43. shifter bushings Need some input
  44. Evo VIII Wiring Harness help
  45. Mirage Tail light fitment for Evo IV
  46. Evo JDM Taillight Part Numbers?
  47. Attn: Parents w/evos. (Car seat question).
  48. So my rear glass decided to spontaneously combust tonight...
  49. just a feeler ?
  50. Anyone know the seat belt bolt size?
  51. I want a left steering rack for my evo 4 iv , can any one help me ?
  52. Evo 4 2.3 stroker kit with BC camshafts and big injectors and walbro fuel bump
  53. Power Sagging Under Load
  54. 4g63t 7 bolt engine stock boost and maximum boost at stock engine..
  55. Buschur TB Seals
  56. head gasket fix?
  57. Defi link BF vs Advanced BF
  58. Need help deciding which exhaust.
  59. Evo 6 : fitting a Evo 6.5 Tommi bumper
  60. blown headgasket?
  61. Anyone know this IX?
  62. Crossmember not lining up with subframe! Help!
  63. Leak in Steering rack
  64. Exhaust Measurements
  65. AMS mustache and bushing kit made clunk worse.
  66. synapse bov model???
  67. cams
  68. Clutch restrictor help
  69. What does it take to get a real sponsor?
  70. Looking for a shop does titanium exhaust
  71. What lowering springs does my car have?
  72. Serpentine Tensioner Question
  73. Evo 8 MBC issue
  74. HID fog light won't turn on
  75. Arm rest Lid removal question!!
  76. car feels slower after retune????
  77. Did I screw up?
  78. Stereo strange sound after installing AEM Wideband
  79. Spark Plug Boots and Timing
  80. Vacuum Lines???
  81. help me find a red radiator cooling plate pls
  82. Questions And Questions
  83. New throttle body ?
  84. Log stock evo rom help
  85. Transmission peeving me off
  86. Breaking up at top end only sometimes
  87. drivetrain help
  88. help with something...
  89. Still high idle, tried cleaning MAF/IAC...what's left?
  90. What made you choose an Evo over an other sports car. Specifically an STI
  91. Happy HalloweEvo!
  92. Is this serious? Possible causes? *Damage?*
  93. 10.5 hotside whereabouts
  94. headlight intake duct??
  95. Power source for gauges?
  96. Keep the ix or meet the x?
  97. Does Lancer radiator fit EVO?
  98. where to buy evo 8 10.5 hotside?
  99. '06 Evo Warranty Question
  100. crushing a 9 bov
  101. Fuel Cut/Rev Limiter - Educate me please
  102. Quick question!
  103. Intercooler water spray question
  104. Evo X Recaros in Evo 7/8/9
  105. Boost leak test leak coming out here? (throttle body)?
  106. Evo 4 intake?
  107. catch can compressing?
  108. Stock IX Seats for Shoulders
  109. A few boost questions
  110. anyone uses hks evc 5?
  111. Need advice
  112. Need clarification on transmission oil
  113. hi guys, please help me !
  114. EVO 4 Airbags Replacement
  115. upgrading whole fuel system
  116. No camshaft FP stock frame set up
  117. Poured fluid into the wrong tank...
  118. Engine "choking"?
  119. help electrical problem
  120. Evo 8 Mpg
  121. Car randomly died and won't start
  122. help id injectors please
  123. downgrading/upgrading turbo
  124. Hallman EVOLUTION in-cockpit boost controller
  125. steering wheel discussion
  126. Question about Redline oil
  127. For those who like to talk BS...
  128. idle creep
  129. Track car or Show car?
  130. passenger exterior door handle ripped out quick question
  131. OEM Paint
  132. Best reliability mods?
  133. should I retune?
  134. Swapping Aftermarket Parts
  135. oil from ac compressor?
  136. Bride Rails
  137. Need manual for HKS Twin Fire
  138. Bringing and AEM UEGO back to life???
  139. Any advice for a headliner squeak/snapping sound?
  140. 800 whp block
  141. clarify PCV VALVE PLEASE !
  142. Financing for a "lemon" title
  143. SSL stock radio din plug
  144. Oil leaking at oil plug?
  145. Raceland Coilovers opinions, good buy or cheap junk
  146. Power increase with Greddy O2 Housing?
  147. Rocker arms n Cam
  148. 4.5 FMIC overkill for E9 setup
  149. Super Stubby meth nozzle?
  150. Garrett BB turbo coolant banjo fittings extended?
  151. Evo 8 aftermarket fuel level sensor/fuel cell
  152. dsm graveyard?
  153. issues with engine oil
  154. Coolant temp gauge reads normal position @ cold start??
  155. How did you wire it up?
  156. evo 3 shifter
  157. tuning with stock catalyc converter
  158. front axle upgrade???
  159. Seibon Hood Fitment?
  160. Huge dent in frame rail?
  161. Bad tune? Map o2 housing HELP!
  162. Windshield washer res tank
  163. What is the size of the drainplug thread
  164. Mine's tuning
  165. evo idling issues
  166. evo 8 AYC pump repair manaul
  167. Twisted off the power cable bolt on the starter.. can I fix it? pics inside.
  168. headlights
  169. Rear Tubular Subframe (who has one?)
  170. Key stuck in the ignition... Please help!
  171. Bolt on advice
  172. yet another motor oil ?
  173. Huge problem!!! Serpintine Belt
  174. Screw Size
  175. seibon CF trunk fitment
  176. how to remove ac?
  177. Winter tire options in 18? evo 8-9
  178. What's an Evo VI Tommi Makinen Edition Worth?
  179. Considering buying another Evo - and selling the one I have now
  180. Finally getting back in the game
  181. Anyone know what size Injectors
  182. OEM fuel pump fail - I saw it before damage
  183. 2 bolt flange exhaust turn down?
  184. Engine starting problem
  185. Binary engineering seat lowering brackets installed.
  186. Help evo ix won't start
  187. BOV question
  188. 2 Q's Head Gasket related
  189. What is this pipe called?!
  190. uicp question
  191. Help needed please,white smoke and a funny smell
  192. how would you prep a VII or IX for actual rallying?
  193. CBRD 17,000 sq feet and more cars---
  194. New guy trying to find answers. sorry. Please point me in the right direction.
  195. Who knows HIDs and Foglights
  196. IC sprayer tank removal
  197. Neglected Evo. PC680 brought back to life.
  198. Evo 8 Front bumper license plate bracket?
  199. Install a Armrest in a RS?
  200. Catback vs Turboback
  201. How much horsepower
  202. How many times can a head be resurfaced and be ok???
  203. Front Lip Clips?
  204. test pipe rattling...
  205. Swapping Evo 9 parts to an Evo 6 TME
  206. Air bag module?
  207. Gutting stock hood
  208. Looking for details of EVO9 immobilizer
  209. ECU Power issue
  210. Need help! Tune issue or relay pump?
  211. my 800+ hp evo VIII (vid inside)
  212. Wheel Well Help
  213. No heat and winters a-coming
  214. AWD Tow Sticker for the X?
  215. DME strut tower brace
  216. Evo running rough when cold
  217. Looking for a high flow cat....
  218. SAS mode doesnt work. Idle doesnt adjust with BISS screw. I hate my car
  219. Evo VII Help - Uknown loose tubing
  220. Weird Afr Idle issue, please help
  221. oem filter?
  222. RS front LSD for 400+ whp?
  223. Identification question (stolen parts help)
  224. What site sells the cheapest JDM 9 bumper?
  225. Looking for an Aluminum Battery Box?
  226. duckbill-style trunk
  227. Hallman mbc
  228. What are the indents on the keys for?
  229. Steering Wheel Vibration Help
  230. What is normal Air Fuel ratio?
  231. Bride Seats / Seat Rail Questions
  232. Question of my chassis
  233. rebuild QM 8 leg twin disc
  234. Beatrush 05 evo undertray front
  235. Zero compression after one month of being garaged!
  236. Where can I buy a Miata\Civic\Group51 battery tray
  237. P0340. Advice needed
  238. annoying start up issue
  239. Idle surges even with SAS actuated
  240. Abs delete with acd
  241. TephraMod V7 question?
  242. oil pressure question
  243. Car running rich, need help plz
  244. 3in doughnut gasket
  245. Curious what roller cost
  246. AMS in chicago
  247. Vented oil caps for evo
  248. Swapping injectors without retune
  249. My exhaust tip fell off. Pretty funny but need some advice.
  250. fuel line options
