PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Question
  2. Evo 8 Clicking Noise
  3. Malfunction - MR / RS factory oil temp gauge
  4. EVO 6 Wont Start - Please help guys
  5. Car just turned 100k miles......
  6. ball joints?
  7. Prosport gauge issue
  8. Suspension next mod ?
  9. Image Request IPB of OilPan
  10. Dying in nuetral?
  11. anyone use a stock frame 6262 or 5848
  12. evo 8, Will APR splitter fit with lip?
  13. ideas on numbers and routes
  14. best place for an etune
  15. Stock headers evo9
  16. clutch stuck all the way down
  17. I might sell my evo :(
  18. antifreeze leak?
  19. Thinking about selling my evo.
  20. car died while driving
  21. Okada Plasma Direct vs Spoolinup COP
  22. Bolt size for mounting the Buschur Mustache Bar.?
  23. Lightweight DIY Trunk Plug
  24. Need some help / ideas here
  25. HELP!!!Evo problems
  26. evo v in Ontario?
  27. Steering pull question...
  28. Is it worth it? Tarmac black evo 9 with cf side spats?
  29. is tuning absolutely necessary?
  30. PLX wideband anyone able to help?
  31. It's official... the Evo is on it's way!
  32. This week at CBRD---
  33. Just got into an accident . what to do now?
  34. Boost Gauge Install
  35. really good watch
  36. Roller barrel manifold?
  37. Passenger front turn signal NOT working???
  38. 60K mile install questions / concerns
  39. Not sure what cams are in my car?
  40. jerking when at partial throttle... :(
  41. Planning on getting an intake and and exhaust soon. What brand should I get?
  42. Need help with exhaust!
  43. Evo 9 spark plugs
  44. How to adjust idler control valve
  45. What is the stock NGK number for my evo8
  46. prosports wideband
  47. can i live with out a tune if...
  48. can anyone tell me what wheels are on this STi?
  49. AEM Wideband install?
  50. finally back in the searching game
  51. Prosports oil pressure gauge issue
  52. Questions about evo 8 rear brakes????
  53. Buying an Evo 4
  54. the three lights
  55. clutch questions
  56. Anybody have a bell housing plate cover for the flywheel for sale????
  57. headlight housing info
  58. Intake manifold pressure gauge
  59. Radio Relocate harness question
  60. Spoolin up cop owners please.
  61. where to buy side extensions and jdm extensions???
  62. Anybody use the MAP licp??
  63. Dog box Transmission or stage 3 TRE/Shep/Jacks/Buschwaker for 9 sec street car?
  64. I'm back again
  65. test pipe on stock exhaust?
  66. Export France
  67. Mitsubishi Owners Day 2012???
  68. Did you buy a USED Evo?
  69. sell the car, or part out?
  70. Greddy BOV on Evo 9 questions, conerns?
  71. Starting problem, [update: ignition switch]
  72. Is 600 to much for a clutch replacement
  73. Thank you MISHIMOTO
  74. Clutch pedal clicking, possible fix?
  75. hole in block... odd question
  76. Take that, dynos.
  77. Bad Gas milage caused by cams?
  78. $750 to install cams and valve springs!?
  79. Cheaper Replacement Panel Clips and Removal Tip
  80. Tial QR or Turbo Smart BOV?
  81. Best kind of tranny fluid??
  82. Part number needed for struts bolts from and back ASAP
  83. Evo VIII/XI Anyone tried installing a rear dome light?
  84. Shortshifters in the evo.
  85. Help just bought an evo, and the car when decellerating makes a bird chirping noise.
  86. whats happening?
  87. New here help me :)
  88. Overheating ONLY on dyno
  89. "Rough" going to 3rd gear
  90. water temp issues
  91. megan racing gauges?
  92. Evo 9 MR Headlights
  93. Sunroof plug
  94. Small shifting issue
  95. HELP ecu fuse problem
  96. Tial Qr Adaptor
  97. Idle issue /w VIDEO
  98. car wont start after i stall it. dont know why
  99. For those who have/had JDM 8 MR headlights
  100. Anyone know what the brown wire (ECU connector pin 87) goes to?
  101. Evo 8 MOMO Steering wheel clips?
  102. selling my evo : (
  103. Stupid Effin Idle...
  104. P0172 code running rich?
  105. Installing Sparco Pro 2000 plus seats in an Evo 9
  106. HELLLLLPPPP!!!!! what do i do?
  107. need help identifying wiring colors for hid and non hid headlights
  108. weird car wont run correctly when battery is plugged
  109. Help! Cannot see my odometer lol
  110. Jdm rear bumper
  111. how can i reduce outside noise in the car???
  112. Where to buy used evo engines
  113. Evo IX headlights
  114. Its official: FFtec Tuning in a few weeks
  115. URGENT, warranty question for a dealer tech?
  116. Just got a 140k mile evo
  117. When was the 1st time your EVO scared the hell out of you?
  118. evolution 6 oil leak from head to inlet manifold
  119. info on hx40 build
  120. BBS wheel locks
  121. Roar of the ETS Exhaust on Evo IX.
  122. Quest for 200k+ miles...
  123. E85 or pump gas?
  124. I need help from someone who works at mitsu parts dept.
  125. friendly wager...
  126. Evo 8/9?
  127. best place to weld on 02 bung for wideband.
  128. Simple steering wheel question.
  129. does p0141 fail emission test?
  130. how to make my tailights look like this
  131. Highest PSI on stock Evo 8 turbo
  132. So check out my retarded turn signal (video)
  133. Would you consider an STI???
  134. GSC S1 vs S2 on 2005 turbo
  135. NO clutch hydro pressure... help
  136. JDM rear bumper Q
  137. Antilock and ACD trouble codes help?
  138. CF hood weight?
  139. How much can I add before I need to adjust ECU
  140. Faded Calipers
  141. Advice Needed
  142. Anyone tried 1400cc/min fiveo black ops
  143. Weird idle
  144. What about s90 throttle body?
  145. Sparco harness
  146. Detonation.... Help! suggestions?
  147. Car stalls at stop light. idle dip. Won't start without gas
  148. alignment help
  149. unofficial 91 oct +mods and dyno
  150. What don't you like about your car?
  151. Gauge/Radio wiring help
  152. retune???
  153. Hot parts with AFI manifold
  154. this can't be right, interesting oil consumption...
  155. My cars first feature!!!
  156. BOV recommendations
  157. is this too much $$$$$ for e85 conversion???
  158. Vent controls are hard to move
  159. Radio has no AM reception after installed Gauges??
  160. Apology
  161. Are these injectors??
  162. Serp belt keeps popping off under high RPM/load
  163. Loud screech, Wheel bearing or transfer case?
  164. What's the fastest full weight evo VIII on pump gas?
  165. Swops
  166. I just wants to say thanks to MODULAR WIRING SOLUTION
  167. any ideas to strengthen the driveability?
  168. Noobe with easy?? Cant find in Search
  169. Rims
  170. Iac question post-search
  171. Is this evo 8 worth it?
  172. I was just told my turbo bearing is going.
  173. What lip is this?
  174. Royal purple oil change special 35$
  175. Old and new buschur magnaflow
  176. 60k advice/ help
  177. no more dog box trannys?
  178. Greddy RS vs Tial 50mm Recirculating
  179. 05 evo wing
  180. Cleaning Maf help...
  181. Who is interested in swapping to the JDM/EUDM Electronic HVAC Controls?
  182. evo 8 or evo 10. help
  183. Car is Ridiculously Slow
  184. my car only hits 11psi?
  185. what price should i ask.
  186. are these pipes stock?
  187. E85 Mpg
  188. Help?
  189. whats the best way to get 11s on a 91 oct?
  190. Best price on 2x tial 44mm WG??
  191. Workshops and events in Florida to see Im from Australia
  192. Megan Racing catback
  193. Need input on issue
  194. Best Boost Controller?
  195. Fuel Pump/Injector Demand Web App
  196. Timing belt install question
  197. HELP! Whistling noise from under the hood
  198. Do not go to Mudpit Performance
  199. are these stock licp??
  200. Ign switch
  201. egr solenoid plug
  202. My evo 8 spit out white smoke
  203. high mileage
  204. Help please.
  205. Evo 8 roof rack
  206. Prosport boost gauge lighting problem
  207. Where can I find this cluster?
  208. 400HP from Stock Internals, Turbo, etc.. Possible? Safe?
  209. stock downpipe heat shield...?
  210. Murphys Law - P0300
  211. Cam install torque spec question
  212. JDM Password Engine Bolts
  213. Dangers Buying '03 viii w/only 8k miles?
  214. Need help locating a JDM or EUDM Evo IX Serive Manual or OEM Parts Supplier
  215. Short film
  216. evo 8.5 turbo to 9
  217. boost problem
  218. Finally looking to mod my bonestock IX MR
  219. What mods to get next?
  220. anyone have Tanabe EVO 8 Rear Lower Arm Bar
  221. Anyone make a front splitter/under tray?
  222. Rear trunk strut bar with stock sound pkg
  223. Kansai Air box Fitment
  224. Evo 9 transfercase rebuild
  225. SMOG test in California
  226. Sputtering @ WOT
  227. AEM intake and Muse UICP Fitment
  228. Idle Problem
  229. Boomba Fuel Rail question?
  230. Battery/Brake Light its not the Alternator
  231. 12V source only when engine is running
  232. Fuel pump weakness?
  233. How do you remove the side skirts?
  234. Erratic RPM at idle
  235. Tow Hooks
  236. My first Evo
  237. Roll Cages advice and Pictures Appreciated
  238. Play in driveshaft
  239. Stock rodbolt tq? help. engine doesnt turn over
  240. Is the power to all 4 wheels the same?
  241. Stripped Steering Wheel Allen Bolt
  242. What rear bumper is this?
  243. engine issue
  244. Awesome Fast and Furious Spoof - Yellow Evo
  245. Power steering help???
  246. Evo IX caught a cold? Please Help!
  247. e9 set up what power can i make
  248. One headlight turned pink tonight.
  249. Quick question
  250. just wondering if this was done before or if its possible
