View Full Version : Evo General
- Battery Relocation to trunk
- AutoWeek Compares Evo IX to new Lamborghini
- Ses light p0138? Now bad idle after batt remove
- Suspected vacuum leak. Need help finding it
- intake help
- carbon fiber roof?
- carb legal intake
- In car camera mount?
- coolant leak help!!!!!!!
- Evo Voltex Kit
- troubleshooting Evo V
- Oil, Battery, and brake lights come on on dash......weird, help
- jdm evo 7 8 rear bumper
- Getting some wierd noise and shaking from the back end
- Dies when letting out clutch even in neutral
- Aem Uego o2 sensor question
- AMS shifter base bushings
- Akuma fabricated battery tray/holder
- Some Videos From Sema
- Anyone has an idea how to fix a leaking headlight?
- Spec-Ops Motorsports "From Then, Until Now"
- where to buy body trim?
- weird RPM pulsing at cruising speeds
- where to buy this clip for hood vent panel?
- After 70,000 miles on a built engine..
- MAP sensor harness!!
- Shipping my drivetrain to AWD...
- Never buying another Mitsubishi Car
- Installed cams car won't start :(
- Prosport WB AFR
- snowboard roof rack
- Mudflaps for aggressive wheel set ups??
- O2 sensor Bad??? Help :S
- Just replaced Spark plugs, now Car wont start?!
- E85 Prices WTF!!!
- What to DO!
- Powdercoating wheels AGAIN?
- erratic idle!
- Jolting steering wheel and engine pulsating HELP!!
- O2 sensor upgrade?
- Got a FS635 kit few questions
- Dealer records check
- EVO 8 Service Manual...
- TPS problem??
- will 380whp on stock CAT be an issue?
- shifter linkage bracket????
- Looking for the owner of this Evo IX
- Defi gauge over 2 Bar??
- my new build thread
- How lond does it take you to mod your evo where you want it be?
- Downloading Mitsu Evo repair/maitainence manuals
- thoughts on cams
- Yea.. Hose blew off on the 5 fwy.
- Big thanks to VR Speed Factory!!!
- Car cranks, but won't start, .... adivce?
- Evo 4 synchro where can I buy them?
- Failed Dyno Run.. OUCH!
- speed density harness
- Need expert's help.
- fluctuating idle, blown IAC?
- Car stalled and won't start!
- WRC looking EVO 8
- BBS LM Replica
- Car died after short gear pull!!!
- Help finding sticker/decal
- Cusco Rear trunk power brace vs GT spec trunk cage
- Replaced ACD pump, feels like a totally diferent car.
- To tune or not to tune?
- one Trustz gauge overlay question !!
- possibly oil in radiator
- Evo8 MR versus Evo9 SE/MR Headlights
- Recall Issue due to mods???
- evo9 e85 fp green non hta
- whats the BEST way to clean a transmission
- Crazy to mod a 160k mile original motor?
- T3 Manifold?
- Lancer and Evo rear glass the same?
- Evo 9 Turbo o2 housing Vs Evo 8 turbo o2 housing
- Insurance screwing, how much for salvage?
- trade evo for cts-v
- No Reverse
- Tale of two Vendors STM Rocks!!!!
- Stock Evo IX MR Antenna
- Will Muse uicp fit ams fmic?
- Turbo timer/boost controler
- misfire/sputtering?
- Should I tell the car salesman to come get his new car?
- do evo 9's and 10's use the same front brake pads?
- Winter-proofing an Evo
- Started 2011 bad with my evo =[
- Just did 60k now bad oil leak?
- What's the difference?
- Looking for some pedals
- I HATE thieves!!! What a way to start 2011!!!
- Dont know what to do
- Car will not hit boost correctly. Need help. Ignition issue? (video inside)
- Fabric wearing out!!
- Gas pedal sticking when cold
- Intake Ideas Wanted!
- ex-AMS Performance EVO VIII in Dubai
- Door not unlocking???
- connecting rods
- Tial BOV & Stock Frame Turbo
- Boost creeping in 6th gear
- would like to know how long before i can post in for sale section
- Evo Bogging Down :(
- Transfer case oil?
- Start up help
- 5th gear grind
- Help, not sure about the whine
- Is it cheaper to replace engine or fix a rod knock?
- Blown fuse on positive battery terminal
- clutch issue... please help..
- Found new place to get transfer case ring and pinion gears!
- Greddy Ti exhaust...JDM or USDM???
- Request: Open dump vs Ported o2
- alignment question
- ebay find-Mishimoto intercooler!
- Not reading full boost...New gauge and same thing
- Headlight bulb size
- evo 4 tranny for evo 7-8..
- Recaro Speed-S seats rails
- starter compatibility.
- Fuel pump will not prime
- Water pump pulley grinding motor mount!
- Key fob
- Harness Bar Seatbelts
- Launch Control in Evo IV???
- Help with Code PO505
- Seat Covers?
- building my motor question?
- Does anyone rock no carpet in their Evo?
- P0300 Code
- Tach Motor Works says farewell to 2010 and hello to 2011!!!
- TC leaking gear oil?
- Greddy Turbo Timer Problem
- Evoscan Innovative LC-1
- Just a little snow.........
- Evo 8 / IX OEM downpipe
- Would you buy a built Evo?
- oomph labs hose candy hose connectors
- start up question - check engine light supposed to come on?
- for anyone with mudflaps help!
- FP Red approved oil from Mobli 1 advertised for motorcycles?
- 6 speed to 5 speed
- Xmas Evo Failure
- Help Walbro GSS342 will not fit!
- evo 8 sputtering?
- Can't Remove E-Brake Handle
- Radio Relocation Fail...
- Wrecked
- JDM Rear bumper for Evo IX. Good place to buy?
- greddy turbo timer issue
- SE lip question
- Clutch Plates
- MBC question
- Where to buy Real Jdm Rear
- Royal Purple= Loud engine??
- Evo IX Gauge pod
- evo 4 problems
- shifter base assembly
- HELP? No power accelerating forward from stop..
- Need some pro advice please!!!
- red manifold
- While the tranny is out...
- front end steering/ scraping?
- Surface rust on turbo kit....already??
- Boost fuel cut/rev limit at 5500rpm????HELP!
- Crashing Evo on a Dyno
- Trouble Starting... Looking for more ideas.
- Help identifying frame part
- timing belt
- Where is my power???
- Intercooler
- Need HELP
- Anyone tell me the difference between old school FP green and new HTA FP green??
- Evasive Motorsports Commerical 2011
- ETS Tubular Stock Replacement Manifold
- Hella Expensive Tower Bar?
- AMS exhaust users please chime in
- Service Engine Soon Light coming on and off...
- Stock Air Box part Number
- Black <> Black
- How much vacuum is your car making at idle especially with cams?
- Instrument/Gauge Cluster burned out
- STM Oil Cooler Kit Install (Pics)
- Feels like car hits a wall...
- Convince me to buy a black Evo...
- Transmission Housing Cleaning
- Best clutch opinion???
- Rip 2003 viii
- E85, Regulated? Questions on fuel quality.
- Grinding noise on cold start!
- Emissions w/o a Cat....I WIN!!
- On the road...again.
- Over boost problem?
- Newer hks 272/278
- Rev limiter
- cluster temp gauge & mitsu temp gauge both no wroking!!
- injector question
- How to Remove MR shift Knob
- Cam install
- EVO * issue :((( please help
- Coolant issue
- Length of AEM Wideband Cable????
- Evo key green control flashes?!
- Cusco Front Brace
- Here you go guys happy holidays!!!
- Is there a time limit on the servicing the timing belt?
- Exedy Twin blown up plates ?
- Zeitronix Zt-2 Kit
- hi , guys , need help
- Evo joe?
- Cleaning Injen air Filter
- Protect your Warranty!
- blitz sbc boost controller
- bittersweet ending
- PU do-luck front lip for evo 8.HURRY UP!!!!!!!
- Car rolls on cold start
- is my IX bumper missing something? (Pics)
- Turbo housing thread pitch
- Voltex front and rear fenders
- Center Console 3 Gauge Pod
- ACD question
- bank repo project
- Compression & Leakdown Test Result Help
- ams base flash question
- GT30r downpipe?
- Wipers turn on automatically and won't stop???
- Rich idle
- Voltex Diffuser turning white?!?!?!?
- Perrin Stealth exhaust?
- Cold Weather Idle Issues
- windows fogging up?
- Defi Boost Gauge Question
- Factory Windows
- Still having upstream O2 sensor issues
- Winter and YOU!!!
- Buschur Test Pipe
- Immobilizer malfunction issues!!! Help
- Evo Can't Be Tamed!
- weird misfire or fuel problem?
- DO NOT Support NJMP - they suk
- missing under load.... help?
- Question about FP Red setups
- Evo 6 speed trans issue NO REVERSE!
- Front bumper sag?
- Custom wheel center caps.
- Anyone have a do-luck type fiberglass trunk?
- Evo VIII MR falls off DYNO
