PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Actuator issues
  2. Inspection trouble
  3. Greddy Type S BOV or Evo 9 BOV?
  4. Tomei 02 housing what down pipe will it fit?
  5. Lancer Evolution 3 Front Lower Arm
  6. Evo VIII No Power to Sunroof?
  7. evo 8 tranny fit evo 9?
  8. Need to buy a test pipe. Recommendations? Resonated or not?
  9. First trip to the strip.
  10. BOV question
  11. Compression results
  12. Another help thread!! Front strut bar hardware.
  13. Anybody missing exhaust manifold screw or stud? How is/was the car running?
  14. Rebuilding ACD Pump DIY
  15. hmmmm cant get it to open, help?
  16. I want to install power locks on my Evo 8 RS! Help/Questions
  17. Possible Head Gasket Leak
  18. Summer time start up
  19. Motor mount bolt sizes
  20. PLEASE HELP! my evo wont rev!
  21. Evo fuel pump swap question.
  22. after-market modifications insurance coverage?
  23. Lets figure it out!
  24. Squeak while turning (usually right)
  25. check engine question
  26. OEM JDM IX Rear bumper. Do they exist anymore??
  27. idle issue
  28. figured out the boost cut issue
  29. Aftermarket serpentine belt tensioner
  30. Can Evo 8 intercooler, side grills and intercooler spray on evo 9 bumper?
  31. Future plans
  32. Recirc bov for 25g turbo 3" inlet
  33. Correcting for poorly maintained cars at a mildly build (5-600awhp) level DSM vs EVO
  34. US Mirage + Evo 8 = YAY OR NAY
  35. where can i get a battery insulation cover
  36. where can i get a battery insulation cover
  37. Left radio + AC on while changing my brakes.
  38. evo 8 license plate bracket
  39. Smoke coming from headers after install? OR what? Please help if anyone knows.
  40. Help buying beginner tools for EVO IX
  41. whiteline rear control arm bushings vs stock
  42. question about the price on evo9 turbo
  43. Stock 2003 VIII turbo issues
  44. High mileage 2003 evo 8 value?
  45. Hallman mbc issue
  46. any way to make these gauges work?
  47. Raceland coilovers & trip to Ruidoso with mod freaks of texas.
  48. o2 dump to recirculated o2
  49. Turbo or Bov Flutter
  50. Mitsubishi evolution VI seats
  51. any more precautions i should take???
  52. funky a/c smell
  53. Blown 8 turbo?
  54. 1/4 mile disappointment
  55. What turbo should I run?
  56. High mileage 03 value?
  57. Assembling turbo help
  58. Need a new tuner in about 4 months
  59. Went to Nürburgring today! Scary
  60. buying an evo4
  61. Time Attack UK - Oulton Park - Garage Tour....
  62. Covered dash and carbon
  63. Just finished custom gauge pod
  64. Tack rubber peg
  65. EVO I problems
  66. Evo 5 HELP!
  67. oil leak?? oil level full?
  68. HELP! Annoying clicking coming from drivers wheel
  69. Added a louvered rersonator and now boost is lower
  70. drivetrain fluids using same pump/hose ?
  71. boost problem in 5th gear
  72. Stock ECU launch control
  73. Typical Boost Response/Stock Turbo?
  74. my EVO IX acting up
  75. boost, air/fuel gauges
  76. Bought used Evo with JM Fab 02 Dump -- How to replace and with what?
  77. 2003 Evo 8 possible fuel pump problem?
  78. Evo Fuel cells i came across
  79. Which flange with ETS FP HTA Turbo kit ???
  80. roof spoiler
  81. Slow Knocking Sound at Idle
  82. IX falls on face after 2500 RPMS?
  83. Evo 8 coolant problem
  84. Need Help with my budget turbo set up
  85. Hey guys
  86. Techna Fit or stock brake lines?
  87. replacement rain guards
  88. What should I do? HELPFUL Advice.
  89. Changed actuator, car overboosting
  90. Is my maf dead?
  91. How much exhaust comes out of external wastegate?
  92. Diff/tranny fluid?
  93. performed some tests on the 9
  94. NGK BPR7EIX on Evo 6
  95. low speed clunking in stop & go traffic
  96. Favor: EVO guys in Japan, Philippines, Australia, New Zealand or Europe
  97. Need boost assistance
  98. Need help start my motor
  99. Downpipe question(Evo 8)
  100. Downpipe question(Evo 8)
  101. turn off anti/lock light after switching to nonabs??
  102. Tc install help
  103. Weird electrical issue
  104. The Greatest Evo's of All Time!
  105. ACD motor issue and possible wheel bearing
  106. Off the line launch ....
  107. Help identifying hose
  108. Points for post? Helppppp !!!!
  109. Gauge install solutions
  110. First trip to the 1/4...This normal??
  111. Afr problem
  112. Evo7.5 (GTA) wave spring HELP!
  113. Car falls on its face shifting gears
  114. Stock Wing Mod Question?
  115. The right set up for my evo ix
  116. Gauge cluster problem AGAIN!!!
  117. Megan Exhaust Manifold - Worth it?
  118. Help for a boyfriend's evo
  119. need help on my evo!
  120. where can i get my throttlebody rebuilt
  121. Mivec oil line to head
  122. Brake caliper install issues
  123. Help with stock airbox
  124. Throttle body coupler
  125. Carbon fiber hood heavier than stock? NO!
  126. can I use the existing hardware from my kyb's and swap onto bilstein HD?
  127. List of concerning concerns...
  128. Consistent Misfire after FIC 1250 installation
  129. Help from the UK guys
  130. Bought used Boost Gauge! Need Extra Parts Help!
  131. Please help newbie with aftermarket bov
  132. Headlight issue
  133. Tbolt Clamps
  134. Any reason this IACV wouldn't work with an 06 IX MR?
  135. Cylinder head not getting oil??
  136. car boosting 21psi
  137. What is this? (Side view mirror)
  138. Various noises i'm trying to diagnose
  139. Evo 5 -7 owners Tactrix needs your help in redesigning our Mitsubishi reflash adapter
  140. Where to get M16x1.5 in SS?
  141. VehicLogics: Android Car App
  142. Buzzing/Clicking On Accel/Decel
  143. Evo 9 MR Obd2 white box missing
  144. Evo 9 cat on an evo 8
  145. heat soak or another issue
  146. Cams without building valvetrain?
  147. PLX Boost/Vac Sensor Module
  148. Evo IX USDM HID to JDM HID headlights
  149. Vibration in steering wheel above 60mph
  150. Help with bumper bolt
  151. Thinking about plasti dipping car
  152. gram lights 57xtreme velvet in stock?
  153. Acd bleeding?
  154. Tomei shift knob
  155. Evo practically done... For now
  156. Retrofitting Evos
  157. A/C conundrum
  158. Name that part
  159. eBay Full Carbon Fiber Wing (supposedly)
  160. Help removing inner shaft
  161. Driving 200 miles without tune?
  162. Help/Advice
  163. Engine has stalled while driving/low idle?
  164. Evo Dead?
  165. garnish ring
  166. tune questions
  167. Wtf McPherson strut bolt fell out
  168. looking trunk parts
  169. PTuning in manassas?
  170. Engine Vibration at 2K-2800rpms NOT balance shafts
  171. Evo VIII aftermarket headlights
  172. Popping/Misfire At idle after rebuild
  173. stock evo 8 at strip
  174. evo meets around DE?
  175. what to use to clean head valves?
  176. how to repaint brembos?
  177. Need your guys opinion on 2.3 13:1 CR build
  178. nlts question
  179. Drive / Serpentine Belt Tensioner Arm Broke Help
  180. Evo Owner's In Korea?
  181. Question for those with over 650whp.
  182. Replaced Wheel Stud, found this rattling around....
  183. Another plug question
  184. Oil leak, stock motor...quick fix?
  185. Brake & battery lights on
  186. JMF UICP problem!
  187. Cant find a how to....
  188. Any "How to" on hood restoration?
  189. Steering wheel Shimmy from 65 mph +
  190. lancer evo 9 plugs for my mods what kind do i need?
  191. Suppose a thief switches out your ECU with a stock one
  192. Differences between Evo 7 engine and Evo 4 engine
  193. Tell tale signs of knock?
  194. NRG harness bar
  195. ecu codes, help
  196. Toni Bueler EVO VI SC&TC
  197. Help! aircon makes engine jerk/stutter while driving
  198. temp rises when a/c is on full blast Help!!!!!!
  199. Evo 8 wing... what are they worth?
  200. My experience: Lancershop / RHDJapan
  201. Lip question
  202. AEM Wideband staying at 14.7/8
  203. high psi ic
  204. Looking to install gauges, few ?
  205. Help removing pass. axle from tranny
  206. Dsm graveyard reviews?
  207. 25g kinugawa Turbo install
  208. 06 Evo 9 MR oem bilsteins
  209. Suspicious Evo
  210. mounting block to engine stand help
  211. replacing the spare tire with something else
  212. Steady throttle misfire
  213. Evo front bumper
  214. Will base lancer seat belts fit in my evo8?
  215. Help with speedo!
  216. Can i stick with 2.5 inch pipe?
  217. Farewell to my noble steed.
  218. Alternator Plug replacement
  219. Evo VIII A/C Condenser Punctured
  220. apexi power fc edu
  221. Will Evo 8 HID Projectors fit in Evo 9 non HID housing?
  222. Noise when turning left
  223. Fuel leak
  224. Need some advice on Evo IX tail lights
  225. oil dip stick keeps popping off..
  226. What's the Fastest LR 2.4 Evo?
  227. has anybody moved their fuel gauge???
  228. 2.0 long rod vs 2.4 long rod
  229. gsc s1 and s2 cams?
  230. which o2 housing/dump will fit with a/c?
  231. I need an 05/06 FSM
  232. could I bother someone for a measurement
  233. Are sway bar bushings important??
  234. Starting build on heavy mileage
  235. It is possible put evo 8 HID hardware on evo 9 HID housing?
  236. FP black/red/green/white builds
  237. Should I be worried or just paranoid?
  238. Aquamist availability
  239. 1998 evo 5 carbon fibre bonnet
  240. Spotted! in the Orange County Area (Lake Forest)
  241. Evo 9 runs bad at WOT--HELP!!
  242. Help guy's
  243. Opinions on door handles
  244. Moroso Spiral Flow Resonator?
  245. Shifting issue, need ideas
  246. Review: Muse Dump, UICP, VRSF FMIC
  247. New Greddy BOV... Thoughts?
  248. How long did it take you to find your Evo
  249. Rebuilt Evo Value?
  250. Quiet fully 3" catback exhaust
