- Cruise Control
- Aftermarket Steering Wheel
- front right rim/tire problem
- problem with ac controls
- Installed under glo light/ windows dont work
- Corner running light problem!!!!
- all my dash lights are dead??
- Help...my car wont start
- Somethings Wrong
- rather simple issue
- Rattle in door
- need RRM piggy back install instructions for manual
- Had a Problem Need Help
- Car running hot and idles weird
- B&M fuel pressure guage!!
- Put On R/B n Exhaust is hidden.
- CEL after unpluggin MAF sensor
- HELP Car won't start after piggyback install!
- Exhaust help
- Canadian Spec Lancer
- Braking noise
- Boost leak or broken compressor?? PLZ HELP
- Slight bumping feeling while stopped
- Service manuals for 2002 Lancer (should cover 2003 too?)
- my air conditioner is making weird noises HELP!!
- 1st gen apexi super afc
- Coil Pack not firing
- Help With Kamakazie Header
- Electrical problems after installing an SRI.
- Help!!! Trouble with intake...
- HOW TO INSTALL: kaminari body kit
- Another CAI mounting problem, Canadian version.
- shake and rattle only in drive
- my car is smoking is that normal?
- NEED HELP WITH FG Evo7 wing....?STABALIZE?
- Whining Noise
- floor mats???
- AC control lights
- strut bar help
- How much inner fender remove when installing AEM CAI?
- Does anyone know how to remove the side skirts and rear lip??
- My F***ing Exhaust!!
- after market tach
- Help with Gauges
- evo steering wheel installation
- MAF making zapping noises?
- help!!! steering problem
- car shakes at 2000 rpms
- Quick question
- exhaust smell
- idle shaking
- H1 Headlight= 1 Prong?
- Evo 8 Spoiler vibrating question
- SRI help
- piggyback problems, PLEASE help me RRM and evolved members..
- MIL Eliminator
- check engine light is on
- RRM Header
- US Wiring Diagram
- Installed my intake today, but theres one lil problem...
- For those of you with the so-called "Clutch rattle/tick"
- Buschur Highflow Cat install problem
- Automatic Transmission Jerk
- Electrical Issue. Stumped.
- post all STRANGE NOISE complaints here
- Post all RATTLE complaints here
- Post all SQUEAK complaints here
- Electric noise
- squeaking while driving...
- cedia headlight wiring...(not what you think)
- Part numbers?
- Did Search.....Need quick TIPS
- Burnt Fuse
- need help or service manual
- Throttle Body Set Screw
- hi-beam + low-beam headlights? possable?
- Sputtering.. some kind of misfire??
- Belt squeaking?
- Service Engine Soon Light.
- What's the name of this bulb?
- apex vafc or safc specs
- My Car is Up and Running again!!!
- No brake lights at all!
- Help!! engine probs
- Loose throtle cable
- Engine trouble - CAI + Rain???
- Clock Dimming (radio too) when HL's are turned on
- Removing Passenger Air Bag
- rrm rear swaybar
- Rattling noise from..then engine??
- Shimmy
- Test pipe help...
- engine noise at idle
- Antenna...
- Fans
- Throttle Body Cable...Help.
- cut ecu wires
- electrical problems help!
- acceleration noise
- steering column
- Is it supposed to be Jerky when I spin my Tires?
- RRM Gunmetals leaking
- Headlight electrical issues
- Squeeking coming from engine....pulleys?
- Cigarette Odor
- Do your stock tires go from under you on Rainy Days???
- Dome Light Problem
- dead battery from storing
- CEL light
- Noise in the steering column
- CEL light
- Engine ? Computer System ? i dont know
- Clicking Noise
- SO many problems, including rear bushings..
- SRI Installed/ Reset ECU?
- Low Idle Question
- headlight adjustment
- crap throttle response
- clicking from front driver side wheel
- clicking noise
- stock muffler removal
- lancer sidemarker replacement
- air fuel ratio correction?
- I think i messed up my gauges
- CAI question
- Help! ( car noises )
- axel back exhaust install problem
- turbo whine
- gasket sealant
- moisture in tail lights
- Power Line?
- electric trouble!
- strange noise
- help with service engine light
- Broken Buschur Filter
- damaged downpipe?
- calling all wiring and headlight experts
- Clutch
- weird problem turn signal on the cluster goes on when applying brakes
- rattling noise???
- MAS honeycomb question...
- The whole car is shaking
- Part # req. and brake question
- 03 Aem Cai Carb Eo #???
- front bumper damaged...need a little help
- 02/04 Lancer OZ
- Severe Rattle From Back of Car (Sounds Like Rear Windshield)
- Car dying as result of intake...
- jdm headlamps
- RRM Intake Part Missing
- Need Help Now Please!! Idling Problem
- CEL again
- Need Opinions Please!!!!!!
- SES light on..
- Reverse Style Guage Problems
- Rattling coming from trunk/ rear struts?
- Bodykit-blues
- Any ideas?
- Help Fast!!! O2 Sensor Prob
- RRM Header.. ??
- Where to find exhaust bushings?
- mas
- Noice On Driver Side...
- Intake HELP
- Testpipe bolt size?
- ///rrm
- A short in my headlights??
- Car Wont START!!! PLease HELP
- Door buzzer!!!
- Ignition Jammed
- Now turn signals won't work
- Noise when I turn it off
- wiper arm switch
- CEL came on today........
- please help? clicking noise
- your easy DIY = my hard DIY
- clunky lancer shifting
- Need a small part Please read and help
- 02 key?
- New Jersey's slowest Lancer
- my speed stops at 80!
- cattering noise
- My car is shaking .. steering wheel shakes, front wheels seem to shake?
- this sucks
- Front Bumper Removal
- rough idle/low idle
- Looking for a part
- Lights Out!?!?!?!?!
- clicking noise
- sway bar help
- Squeaking w/ AEM CAI
- Input needed............
- cant reach 4rpm
- Fuel Temp Sensor
- MAS sensor help
- Input needed - bucking
- Wiper blade
- Humming Sound
- test pipe trouble
- damn, my fuel econ blows
- New problems! (Idling this time)
- Problem with stock side skirts
- please help! car starts and dies
- I need help locating the fuse for my sunroof! Thx!
- a question to ppl who installed AEM CAI
- All around Greddy exhaust concerns thread (MERGE)
- Starter probs at 35000???
- serpentine belt going bad?
- Gas Mileage
- headlight keeps burning out
- problem with my shifter
- Mivec <<help>>
- Headlight Help!!!
- Trunk light, do we have one?
- noise in the rear of the car too!
- 80 miles already at half tank?!
- f*%$#!@ing squeek!
- Strut Bar Help!!!
- Gauges Dont Light up!!!!???
- AEM CAI install... SES LIGHT!
- complete dash removal
- safc to fix rough idle?
- cig lighter
- Service Engine Light????
- removal of muffler = exhaust hangage
- Injen CAI
- Replacing ugly orange bulbs...need help!!!
- helping a friend
- Cig lighter issue...
- HELP ME Comp. FRIED!!!
- whers the fuel filter
- help with intake
- intake problems
- Idling at 2 grand...
- What is this!!!?!?
- Possible boost leak
- AC Control Knob Not Working Right?!?!? Help
- airresearch turbo install HELP!!!!
- Unknown piece fell off!!
- okay new problem with misfire..
- gas pedal lag
- Please Help Me Now!!!
- auto tranny..
- new sound? what is it?
- LS to OZ gauge cluster
- why is my fuel pressure only @ 29 psi???
- Car stalling at low RPM! Help!
- spoiler holes?
- 3 Little Words/Questions
- Fuel Injection maybe???
