View Full Version : Evo General
- Where to buy
- Aftermarket ABS Sensor Replacements?
- wideband reading rich
- Need help with cams
- Low Compression, need suggestions
- Readiness issue
- Rear wiper, water leak?
- Valve springs for 900whp evo
- Brake lights won’t work correctly when car is running and I have lights on!
- Streetability
- Rear Caliper Pin holes oblong
- Jdm 9 banjo looking steel line that resides right above the exhaust manifold
- Best shops for full build.
- X Rear Seats in 8/9?
- Where to find Hood Vent Seal?
- EVO 6 intercooler options
- Help identifying this metal piece I found inside axle
- New Evo VII Owner: Oil weight question
- Evo IV Engine Swap - ECU Options?
- Turn signal hyper blink
- 1995 Lancer Evo 4
- Evo 8 oil filter housing plug
- New Billet Engine Mount Option
- My Evo is hurt, sourcing parts
- 2x 38mm wasegates or 1x 44mm?
- Evo 8 stalls plus burning rich
- What's the best dual pumper setup?
- Will DSM Struts Work On My Evo III?
- Those without original window sticker
- All weather floor mats?
- Oil leak
- Resonating sound - Evo 9
- Evo high output alternator 160AMP
- Spare tire mounting bracket removal ?
- Windshield cowl rubber seal, part number?
- Twin fuel pumps external check valve??
- Timing belt whine but tensioner set correctly
- Back in an Evo Soon
- Trunk drain for water in spare area
- Build 2.0l 4g63 vs 2.4l stroker built.
- Fuel smell in the passenger rear wheel well
- Evo IV misfire then ok then misfire and cylinders stop working
- Jdm rear bumper
- I just got an abandoned evo 9 mr for free (pics inside)
- Help to a newbie ! My Evo loses power after a while
- Service Engine Light Turns Off And On When Wants To.
- Evo 8mr
- Clutch fluid goes black
- VP X98 safe for FIC 2150cc injectors?
- AC on with heater question
- evo 8 clicking sound after wavetrac install!!
- Voltex double over fenders over stock quarter panel
- In need of Evolution GT-A Service manuals
- Engine wiring harness
- 03 Evo 8 STFT read 0
- anyone looking for a stolen TME?
- Evo IX Launch Control - not working
- Mitsubishi evolution 8 differential Cooler
- Why not buy LHD evo 5
- Anyone help ?? Trying to track down my old evo....have everything but a name
- Cluster bulbs
- GTR coils
- catch can
- Oil light.
- shocks and Springs
- RARE Evo 1-9 articles and content
- JDM Bumper Exhaust Fitment
- Low RPM ticking sound, only in gear when on throttle
- Pairing ETS wide tank IC with Injen full IC piping?
- Turbo manifold to turbo washers
- TurboXS DTEC GameBoy Boost Controller
- wing braket
- speed density
- Windshield wiper sprayer hose question
- fan control module
- Best Shops in the East Coast to work on Evos?
- front bumber
- Original owners still out there?
- timing belt failed prematurely
- Evo 9 oil cooler in evo 8
- Question for gauge in lancer spot on cluster
- Evo 4 with evo 8 transfer case
- Evo 7 GSR Hood vent options? OEM is no more.
- Can you remove a rear subframe with jack stands and a car jack?
- Rust converter behind rear subframe.
- Intake Manifold Bolt
- I am back, Evo V on the way !
- evo best crankshaft? callies crankshaft forged vs billet
- Car covers for Voltex evo?
- Evo 8 crank walk eagle crank ( failure)
- About to buy this Evo IX - Requesting Advice
- P0134
- Stolen Evo 9 VIN locations
- Belt tensioner broke
- Evo 8 with Mitsubishi Mirage aluminum radiator
- Evo 8 - FIC 950cc Injectors - Running Lean
- Flex fuel setups
- Looking for an 8/9 Spoiler
- Tire pressures for road racing?
- Evoscan won’t connect to ecu trying to log
- Are the battery tray studs removable/replaceable?
- Emissions... in 2023, what are folks doing?
- Best AWD?
- Cluster plastic
- Mitsubishi lancer evo 2 1994
- Weird sound on Evo 9
- Evo 5 idling issue
- crank to Flywheel dowel pin evo 8
- Thinking of selling...need help on realistic price
- New YouTube Video on Buschur's Project White
- 2003 Evo Vlll Build?
- Dealership OEM Short Block Availability
- new exedy twinplate clutch. CAR IS SLOWER
- AC not working when raining on highway
- Evo IX random no start issue
- Evo 5 no crank. Starter clicking fast
- Summer progress
- 2003 Outlander Rear disc break swap?
- Coolant hose kit?
- Cluster overlay
- Evo 8 startup log - won't fire up...
- Changing Oil and Front Jacking Point
- Evo 9 Coil on plug system
- Need Help!! Lean spot 3.7k and bog during part throttle
- Wtb evo 9 usdm tail lights
- Brining Evo 8 back to Life - Need TS ideas/help
- What Is This Part Called? - Bought My First Evo Project
- The Hood won't close with hood shocks
- Replacement Alternator
- Evo OEM PCV Leak?
- Installing ETS battery kit - stupid question
- 2002 EVO 7 manual swap
- I Bought a 1947 Mile '05 Evo VIII!
- Speed density on Evo 7
- No power at ignition.... stumped
- Wheel bearing options
- Maintenance/ general information
- Buying an evo 6 tme
- FS - Evo 5 RS oem+
- Is this factory aero part worth anything?
- Window wind deflectors
- Grimmspeed Ebcs fitment Issues
- Oil pressure drop after oil cooler delete plugs
- Rota P1R Fitment
- Key FOB Not Programming
- extended exhaust hangers?
- 2 Step (clutch switch question)
- Iat Sensor Location?
- Aftermarket body panel companies
- Anyone use link pnp?
- Rear wiper motor thread broke off... Possible to fix or replace the unit?
- Evo-9, 200K mile club :-)
- After installation of cams issue
- Clock Alternatives
- Track and battery
- Where to buy this part
- Evolution engine noise when car warm up
- Replacement window visor clips
- Evo jdm rear bumper exhaust help
- Info about my 4g63 in Evo IV
- 2003 evo 8 rear window switches
- Evo 8 MR FQ300 front windscreen washer motor
- Coolant Leak under Timing Cover
- is my clutch smoked??
- still boost issues or atleast issue with boost reading
- Rust under windshield cowl
- Front bumper quick release fitment
- Help Needed! Rattling Sound when Accelerating - Mitsubishi Evo 6
- Recognize this intake manifold?
- HKS head gasket or OEM high boost
- 2.2L pistons/rods combo help please
- Bucking and hesitating
- Evo 9 Running Rich when hot?
- 2005 VIII MR Service MAnual
- Rear bumper brackets
- high boost valve springs
- Front caliper bolts stripped
- Clutch salve cylinder bracket
- steering wheel lock Evo 8
- Topline lifters or oem?
- 03 Evo 8 From Washington State
- How many keys can be programmed?
- Quartermaster twin vs exedy triple clutch
- Bought a used 5 speed and it's kinda trashed. What would you do?
- ARP 625 head studs torque specs
- Engine brackets evo 8
- Evo 8 specific inlet coolant pipe, discontinued MN143306
- Wobbly Power Steering Pump pulley
- Tomei Oil Slicing Baffle plate
- Need evo 8 longblock (local ish prefered)
- Looking for evo 8/9 rear end parts
- Serpentine belt idler pulley difference?
- Evo 8 usdm fuel tank filler neck pipe
- Ralliart Jackets for Sale
- EVO 7 radiator
- Ecu Tampering
- Looking for evo 8/9 parts
- Evo 8 tries to crank without key in ignition
- Walboro Whine Issue on Evo VIII
- Interior door handle
- Evo8 Ceramic Cat replacement
- Evo Shops left in Colorado
- 2 wasegates setup on single scroll turbo!
- I need help! Need a EVO 8 GSR Stock ROM (USDM Version)
- Original Evo articles and more
- Rear Window Frames - Rusted (IX)
- Vibrating clutch pedal
- tuners in south new jersey?
- Gsc racing balance shaft vs stub shaft
- Which Catch Can to do the Job I require
- 2003 Evo 8 new driver seat
- What would you do?
- o2 Sensors failing/P0134/afr/stumbling
- Remove coolant port?
- Rear diff upgrade
- Tracking All Evo Listings in The USA From Facebook Marketplace
- AEM x series 4 bar boost gauge question
- EVO 8 restoration update
- evo in hard right corners and oil pressure
- Any good speed shops in the North East, USA
- My Evo-8!
- My TME!
- Evo 6 Sunroof Weatherstrip Needs replacing
- Jegs 15x8 wheels and tires
- buying a project evo
- Boost issues
- Need help w/ harness bracket reinstall location
- Fuel pressure problem
- Broken fuel pump locking rings studs
- Manley piston ring gap
- New OEM serpentine belt tensioner pulley normal play?
- Gas Tank
- Idle rattle noise ?
- Unused Plugs In Engine Bay
- Valve guide replacement problem Crack
- Rust under top window molding
- Wheel Arch Repair
- Fibreglass Wings, Bonnets and Kevlar
- Evo 9 transfer case rebuild
- Evo 8 replacement key
- 15k Evo 9 MR 'Time Capsule' Build
- Smoke after a hard pull
- Low compression cylinder 3
- EVO VIII dashboard and door panels
- Aftermarket door cards?
- burning up starters
- Rear Chassis Leg Rust - Repaired
- Looking for advice on my Evo 3
- A Complete Guide to Replacing a USDM Evo 8/9 Bumper with a JDM Evo 9 Rear Bumper
- Looking for advice from a Evo IX professional
