PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 [205] 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Did I damage my axle??
  2. Stock injector question
  3. Evo Passive Boost Solenoid Emulator Install
  4. I need your advise on which clutch to get
  5. Mbc Or Ebc
  6. Act Clutch Help!!
  7. Anyone ever replace the knock sensor?
  8. Cams and cam gears?
  9. Where can I buy a HKS DLI2 and greddy oil adapter?
  10. hks 30anni cat back..
  11. How much boost
  12. Pressure reading is sometimes 0......on idle
  13. Stock Cutch!!
  14. ACT owners...Does your clutch Stink? literally?
  15. Can this be true and/or Safe?
  16. HELP, Engine cranks but won't Start
  17. Water Pump leaking????
  18. boost problem Please help
  19. Anyone cut out a "side-pipe" yet?
  20. boosting high for stock? i think i am
  21. How can I increase my torque?
  22. Cam Gear Dimension
  23. rough idling
  24. HKS R-Type Intercooler ..is it worth it ?
  25. help with apexi avcr!
  26. Installed Boost and Oil Pressure Gauges! Correct Readings?
  27. Evo VIII ECU Harness pinout
  28. help please
  29. Ok im about to give up!!!!
  30. Car stalls when giving slight gas on an incline..
  31. buschur cat leak
  32. How much on average to install Stroker kit?
  33. Buschur's MAS Intake Install Question.
  34. Fuel Regulators What Works?
  35. Still Stock Boost
  36. anybody know why my car is like this?
  37. My car just "QUIT" so did the A/C
  38. Is ALKY ok with stock Turbo?
  39. intercooler question
  40. Max boost conditions.
  41. Forgemotorsport Adj Actuator
  42. Transfer box interchangeability.
  43. Custom work going on at Buschur Racing....
  44. intakes and air filters?
  45. My dealership is full of ****!
  46. Looking For Turbo
  47. CEL Light still ON - HELP
  48. ive searched!! when will i need a BOV
  49. Profec B monunt help
  50. Anyone have a Clutchmasters Stage 3 on their Evo??
  51. question? highest boost.....
  52. disconnected ebc and got 20psi..is it normal?
  53. 300+whp
  54. Going to turbotrix for a dyno tune
  55. which intake?!
  56. how much boost am i running?
  57. Quick Question
  58. cel light came on
  59. valve springs and retainers???
  60. Ghetto Fab $1 shifter bushing
  61. What do i need with cams and gears?
  62. Do any aftermarket electronics (AEM, E-Mange, Etc.) display thru an aftermarket LCD?
  63. alcohol injection questions
  64. AMS exhaust question
  65. DIY Pressure Tester
  66. Boost Leak Test Question
  67. DNPerformance or Megan Racing turbo Manifold?
  68. Safc Ii
  69. which wire is the tach wire?
  70. Flywheel machined, interesting discovery.
  71. turbo question regarding dump tube?
  72. 122performance.com Phenolic spacer tested.
  73. 4G63 Question
  74. i was just thinking...my friend at school says this happened to him
  75. BOV opening at 6K rpms in 3rd gear???
  76. Odd cooling/coolant question
  77. ams intercooler or injen?
  78. Weird Clutch Failure
  79. Dyno Graph, Finally!
  80. Headgasket?
  81. Whats the difference with the stroker kits (AMS vs Jun vs Toda)
  82. adjustable fpr mounting pic
  83. Rear rotors and calipers needed for Buschur Racing...
  84. Is Fuel upgrade necessary?
  85. Buschur Racing: Any chance of a turbo kit Group Buy?
  86. Throwout bearing problem
  87. Help mating I/C pipe kit
  88. have you ever got your motor mounts replaced?
  89. New catback exhaust experiencing rubbing
  90. Borla turbo manifold
  91. HKS SSQV idle help...
  92. full-race GT35R kit or AMS GT35R
  93. engine gasket question
  94. got question..Crower racing valves.
  95. Waterless Coolant... Do you use it?
  96. Biggest Fuel Pump
  97. Clutchmasters stage 4 clutch? HELP!
  98. Oil pump sprocket timing mark off
  99. stock IC pipes > aftermarket IC pipes
  100. NEED Opinion ASAP
  101. Cams + Gears
  102. HKS 3037s Spool Up
  103. Any new info on the 21G from BR???
  104. Help Please... Torque specs. needed.
  105. Where to buy new rubber diaphragm for Greddy TypeS BOV?
  106. Upgrading from OEM --> ATS Twin Carbon
  107. how to install greddy gauges....help
  108. Turbosmart e-boost settings
  109. High Rpm Boost taper?
  110. Buschur Installation Instructions..
  111. Finally Installed My GSC Cams!!!!
  112. 2g lifters getting installed
  113. Problems with APS BOV
  114. where is the intercooler spray hose suppose to be?
  115. Idle problems
  116. gsc 272i/272e vs 264i/272e
  117. Flex Section For Downpipe?
  118. Which is the better turbo?
  119. ***power Question****
  120. Are you getting worse gas mileage with cams?
  121. Should i get cams or alchy injection?
  122. Boost hoses too long or too short
  123. no idle while AC is on, HELP
  124. Whats the best high flow cat that wont set off o2 engine light?
  125. Downpipe Question
  126. Injector noise is getting louder
  127. Hallman MBC...Help Please!
  128. E-Brake light flashes on and off while driving.
  129. Customer Update: Possible Pump Gas Record?
  130. Stock engine, just what is forged?
  131. Changing the Hotside...
  132. t bolt hose clamp size info
  133. EVO 6.5 RS TME Turbo
  134. What you guys use for Trans/Transfer case/Rear Diff Oil?
  135. Problem with front left after DE
  136. Feel like an idiot: is my boost controller set high enough?
  137. CEL after radiator install
  138. boom/need Tbolts and a way to clear SES light
  139. Torn CV Boot?
  140. Idle???
  141. hey guys i have a problem with injen
  142. Cam Install... Read this first.
  143. Inline fuel filter.......?
  144. Doesn't anyone have a manual???
  145. will ported cast iron crack like SS tubular manifolds?
  146. Boost not coming on tell 3rd gear?
  147. idle problems! *help! please!!!
  148. 264 in / 272 ex
  149. FLash for 93 or Flash for 100+
  150. Buschur turbo kit manifold question
  151. switching filters.. need retune??
  152. rnr intercooler piping?
  153. HelP! spotting a boost leak??!
  154. Hard shift into 2nd???
  155. ssautochrome intercooler
  156. Anyone ever have to "fake out" the Knock sensor?
  157. Ultimate Racing Turboback
  158. Atp turbo kit ?
  159. Exhaust and ECU
  160. HELP!!! ASAP! pressure test problem!
  161. Changed my TC Fluid yesterday...
  162. Anyone have experience with HKS EVC 5 Boost Controller?
  163. Blitz dc-ll, cant see display
  164. Rough Idle on 03, Typical Problem?
  165. To Jet Coat or Port and Polish
  166. How to read CEL's
  167. Intake Suggestions
  168. wtf transmission
  169. Looking for Test Pipe
  170. Where is the knock sensor?
  171. Blitz Boost Controller died
  172. Cold air intake for evo VIII
  173. Signs of a bad front diff?
  174. Weird Noise after Installing Intercooler Piping
  175. Can AEM ECU delete P0300?
  176. Can cams increase frequency of P0300?
  177. is this suppose to happen?
  178. Help. Overheating
  179. Damned transmission
  180. Those with EVC V
  181. big problem.. anyone with a service manual
  182. intercooler spray..
  183. Koyo radiator and no antifreeze
  184. $1000 Tuning What should I do?
  185. What is the Best Exhaust for the EVO VIII
  186. Just installed Buschur Exhaust......
  187. low idle, please help
  188. Greddy Upper Intercooler Pipe Question?
  189. New Clutch, New Problem
  190. HKS Racing BOV II
  191. Which performs worse: RFL or SSQ?
  192. 2nd gear!
  193. Team Rip Engineering transfer case service
  194. ATP3071 Dyno'd
  195. need help quick! boost guage installation!
  196. High pitched noise at idle
  197. Cams just installed....big problem.
  198. ARC or Greddy FMIC?
  199. need help w/ injen intake system..
  200. Help!!! Fuel Cut @ 1psi and 4K RPM
  201. Mid-West AWD DYNO IN!!
  202. 02 housing
  203. Help me figure out this taper issue
  204. Timing belt tensioner tool
  205. exhaust mani
  206. Will vaccum leak cause very bad idle?
  207. 4th gear synchro goes again
  208. Cams and cam gears.
  209. What would it be like running "open header" on Evo?
  210. please explain this fairly new exhaust concept...
  211. MBC or not
  212. Helix catback!!
  213. Maf delete
  214. Transfer Case Fluid Capacity Issue
  215. Radiator fan kicking on after cold start?
  216. Buschur FMIC/AMS Upper Pipe compatability?
  217. APS BOV adjustment
  218. Octane Booster...no good...questions
  219. What years share the same motor mounts as the Evo8?
  220. Can someone post sound clips of AVO exhaust?
  221. Alarm system install
  222. Cam gear settings..
  223. AMS 2.3L or RNR 2.4L stroker ?
  224. New exhaust upgrades? HP gains?
  225. Bov????
  226. Drivetrain Problems on my '05
  227. br front mount problems
  228. Upgrade ideas ?
  229. PD Tuning Goods Installed!!!
  230. What turbo mainfold is this?
  231. 10 psi when cold?
  232. Intake air flow problems? stumbling?
  233. Fuel Filter Replacement?
  234. just replaced my tranny drivetrain fluid last night
  235. sorry about asking: Turbo Outlet?
  236. HKS clutch = Exedy?
  237. Blow Transfer Case! Kinda Cool.
  238. 1.34 60 foot on stock axles
  239. Good basic mods list.
  240. Greddy r/s BoV
  241. Would u get 272 cams if your car is stalling?
  242. Any Evo's in the 10's on stock ECU?
  243. To convert the car to be dynoed help
  244. Is this viscous coupling ok?
  245. pd tuning/amzperformance manifold!!
  246. clutch install
  247. Difference in EVO Turbos 2005 V.S. 2006
  248. Ft/ LB to IN/ LB Conversion
  249. MR short shifter, has one been made?
  250. looking at differnet intercoolers...
