- Evo VIII Wastegate
- ticking/knocking sound at idle
- Hole in intercooler...help!!!
- Which is the ideal RPM to shift???
- broken rocker arms, does it mean bent valves ?
- installing oil pressure sending unit
- Mikey's DBB FP Black Build - New Spec-Ops Motorsports Drag Car
- Fuel pressure regulator problems
- Injector Resistor Removal
- Ceramic Coated Exhaust Problem
- Different maf types ?
- locked AYC diff and vibrations
- The hell is this hose??
- Have you deleted your oil cooler?
- One cylinder with low pressure
- Acd pump
- ACD lights on after clutch replace
- Halp removing plug from oil filter housing (not drain plug)
- cant rev over 4k bad misfire
- Who has run the Grodens and how long did they last?
- Need Help, Stock Evo 8 Clutch.
- Need help fast please! What OEM head gasket part number for 4g64 with Evo head?
- I need to put oil restrictor to my turbo
- Manley 156mm or 162mm TT Rods???
- Need help planning build
- AMS 900R (prescision 6262) turbo burning alot of oil, need some advice
- Possible dead fuel pump??
- New Exedy Twin - Strange Sounds
- need some advice... black or green?
- Cold Clutch Judder?
- AMSoil 75W-140
- Need Injector latency value's for NGi 2200's, anyone??
- my clutch reviews
- Mod advice for new turbo
- Most whp for stock fmic?
- Turbo smoke?
- Evo hitting 18psi standard??
- electronic boost controller ?
- Tubular front subframe
- Best combo for HDSS?
- 2.4 Strokers and Cam Covers
- Will there be BB 68 and or 71 HTA turbos ?
- Random line ? not connected to anything? help
- AEM Intake & Perrin Filter Compatibility (Evo 9)
- speed source 6speed under hood bushing issue
- 6 speed to 5 speed???? anyone know!!!!
- Greddy Ti Comp Downpipe hitting subframe
- Pic request - ETS or other slim fan install
- TB Shaft Seals and low TPS readings...
- Help trying to reach 400+Hp
- rebuild problems and questions!?!?
- Question on retune
- What spark plug are you running with your 450+hp evo
- clutch slipping
- Stock engine durability
- Lighter rods = lower torque?
- fp red or 35r??
- Flickering headlights?
- Fabricating manifold, where to buy pipes?
- LTFT Low and Mid off...
- MBC is maxxed out and Need moreee boost
- Replacing clutch, any other prevent. Maintenance items?
- Squeaky Clutch Pedal
- Help Identifying Car Problems
- removed balance shaft and low-frequency sound on 3.5-4.5k
- 2.4L DOHC intake manifold on a EVO
- Synapse Boost connect fittings?
- Difference between piston 2&3
- Is this a twin disc? HELP!
- HKS 4.11: what do I need to make it work?
- What should my compression be?
- Edit: Best place to buy Kelford 272's ??
- I need a new clutch for my evo VIII
- Forge Type RS Recirculating Evo 7/8/9 Blow Off Valve Sound Clip
- HELP! What valves to use for head rebuild...springs?
- Diff popping and clicking on turns under power
- 6 spd Sequential Shift
- HELP with identifying what went wrong, motor blown
- would you run an unported megan o2?
- wtb evo 9 turbo
- Found oil leak, need some advice.
- 50 mph transfercase whine
- Best place to buy GSC S2's? Is there a better cam for a 10.5 8 turbo?
- Do I need a new clutch?
- ams 750r v-band turbo kit?
- Magnus manifold, boomba tb and ets piping=fail :(
- nasty metal on metal noise at the front wheels during slow turns?
- Spun bearing?
- replacement axle
- CT9A year production issue, need information
- evo 8 mr atf sp lll container
- Ecu reflash.
- Where to get tools?
- Siemens Fuel Pump 300LPH
- Next mods for IX on 93
- Porting factory intake manifold - yield gains or losses?
- Buschur Exhaust Band Clamps?
- intake manifold design questions
- Dropping motor in...
- 4 inch intake..!
- Issues with stock ECU@40psi?
- help!!
- more boost?
- Help...2.4 L mivec cam gear adjust
- Viii and ix 5 speed trans interchangeable?
- issues with shifting, caused by adjusting clutch?
- What turbo kit is this?
- Comp stage 5 clutch review?
- turbo?
- Datalogging on AEM Wifi X
- Proper Fuel Pump Wiring / Safe Installation?
- What are my options?
- how to install 03 evo turbo
- HKS Sport Catback
- turbo setup
- Car bellowing smoke, cooolant on top of pistons, running out of ideas..
- 2 Hour timing belt change, yes it's possible
- Brand New Exedy Triple Cerametallic Slipping?
- Wastegate
- Cracked block on Evo 8
- 'tink'
- Can I have some opinion on this, please
- PT 6262 .63 a/r or FP black bb
- billet shafts?
- Input shaft bearing
- Thrust Bearing Failure
- New guy to the Evo world.
- Torque on main studs
- Bent shaft on 71hta
- Wheel of Misfortune.
- Fx 300 clutch?
- Please help me find out what I broke in my drivetrain!
- Torque spec please. Factory manual discrepancy
- crankcase ventilation idea.....
- Ac delete and idler pulley
- running in a not so new engine
- ID2000's (high impedence) WITH resistor pack...runs great...?
- exedy twin to triple or QM race 8leg
- It seems to be never eneding (oil light)
- EGR Removal and codes...
- clutch will not disengage
- Help...
- off throttle noise! ,p
- clutch tremble?
- MAF Sensor Honeycomb Replacement
- Oil consumption issue?
- IX Invidia DP install question
- Evo IX MR Downpipe
- Help choosing clutch for 03 evo 8
- Timing Belt Problem
- Evo Rear diff bearing number?
- 2.1L vs 2.4L vs 2.3 Stroker
- Intake manifold?
- New Royal Purple HPS oil
- Wiseco 85.5mm rings with 85.04mm bore??
- Toxicfab vs fullrace exhaust manifold
- lsd fluid help
- what turbo for built motor
- Where to get t3 twin scroll manifold
- Hesitation & Coughing?
- Axle seal leaking badly
- Ti dumpipe
- HKS/DENSO 1000cc injector
- shep trans down shift problems, need opinions?
- Grinding Noise "help"
- Plan on revving my motor to 8k+
- Is it bad on the drivetrain to get sideways?
- Need help identifying injectors
- Engine break up under boost?!?!?
- Evo engine problems help!
- Turned up the boost but now making less boost
- Does the wedge collar come with the pressure plate?
- Sloppy Driveline/Jerking and Bouncing
- Something in the Drivetrain is toast
- Is it worth going from BC 272's to a GSC S2? 10:1 2.0L GT35R
- Which evo 8 cylinder should I get?
- New AEM Ignition Coils - CDI performance!
- Taping????
- Engine Gasket ?
- 4G64 Oil Galley port work - lots of pictures
- clutch slave broke off tranny
- Well I figured out my ACD problem..!
- adjusted timing and belt is loose
- engine hesitates then shuts down. cranks but won't turn over
- Rear Diff fluid?
- lancer evo 5 upgrade
- VENT plug in tranny blow out and pissing fluid?
- Please help! Car is building no boost and making funny whirrring sound...
- Rear main seal?
- dc sports downpipe
- help me choose between these catbacks
- Stock Evo VII / VIII turbo spool info?
- Max rev limit for a Jackson short block
- AWD Motorsports Bastard Evo is BACK!!! HTA 71, Haltech, Stock Motor!!!
- FIC 2150cc VS ID2000cc
- Hks Timing belt & BLE TIMING BELT TENSIONER
- Clutch problems
- Probable missing part on shifter.
- Good discussion about prolonging race motors
- ATP 3071R vs HKS 7460R vs HTA Green 76
- Kelford 272 and HKS cam gear settings
- HTA Green DBB testing at English Racing
- Need Help!
- No injector pulse!!!
- Evo 5 Engine won't idle
- Wich valve components to choose with Kelfords 272?
- See if you can solve my diff question
- 2.75 to 3.0 inch dp
- Tial Bov spring
- Selling Evo because of clutch
- no fluid in acd pump reservoir
- Front and Rear LSD?
- idle issue , E7
- Anybody mount there MSD/ignition box under there seats?
- Strange stutter at WOT - No DTC/CEL
- Tatting noise from engine bay
- What downpipe
- carbonetics blade clutch
- 85w140 Royal Purple in TCase/Diff
- about to tune my evo with bolt on's + cams, need some help
- FINALLY!! FP dual bb Black
- what cams should i buy? i wanna be able to pass smog in Cali
- Boost creep on the hta green? No o2 dump
- Evo4 with evo8 engine has very strange engine work
- MD: WTT exhaust
- Weird Noise.. PLEASE Help!
- Picking the right valves
- Nitrous 50 shot!!!
- cam deg./timing
- AFR Rich on Boost
- Kelford 264 or 272?
- map sensor-inlet manifold hole size
- STM or Mil.Spec TB shaft seals?
- help please!
- Rough Idle and Misfire after FIC 1050s Installed
- big injectors without a new pump?
- Ryu's built motor thread (Sponsored by MAPerformance)
- What the heck is high rpm lockout?
- Quick Question about exhaust limitations
- OS Giken Twin PLate...
- Best place to buy /and brand evo 5 style radiator
- Hydraulic Release Bearing Help...
- Transmission help
- Big Build Need Opinions
- Built Evo still running lean.
- need help with boost soleniod vacuum hoses
- need some help drive train..
- Searched already, chatter is louder and constant at idle.
- Aps bov flutter!?
- GSC S1 Cam Specs (IVO/IVC, EVO/EVC)
