- exhaust diameter advise needed
- Idle hunting, pretty annoying.
- FP Green HTA Collector Nuts and Bolts
- Any good?
- crush washer for ACD line in transfercase??
- I have a problem AYC
- Transfercase question
- --- Kelford 280 & BC Springs and Retainers ---
- Shep T/C rebuild
- Problem: right piping for unknown HKS fmic core?
- Maximum power with stock-like drivability?
- Cast Manifold
- --- Clutch Assistance ---
- Leaking Drain Plug [Fixed]
- sound like compressor surge to you?
- Hallman Pro Evolution Kit Instructions
- Ams balance shaft delete? Do I have one?
- ef4 turbo results? need a better spooling turbo
- Compression Test
- Act Clutch Disc with Comp Pressure plate?
- shifter bushing
- About building a 4g64
- Another clutch decision thread
- Chatter noise after build on tranny and clutch
- How much damage can be done on one TERRIBLE launch..
- Random Tip About Spark Plugs
- Odd vacuum issue? HELP!
- best forged pistons for 2.0 liter, and best compression ratio for bb fp black build
- PLEASE, PLEASE HELP GSC spring seats not seating properly with ARP Bolts! PICS inside
- Flow Numbers for stock heads???
- Exhaust Camshaft position sensing cylinder \ Exhaust cam angle sensor
- PTE 6766 Billet CEA Ball Bearing Turbo Info Thread **
- Need main bearings for input and output shaft
- 5th gear popping out on load?
- Question on oil change for 06 mr
- Another day another problem
- Few issues with my evo
- Boost Issue
- Evo 9 overheating
- Whose driveshaft is this??
- Can someone label gears in transmission
- Axle popped out during Coilover install and now.
- Exhaust volume - PoPo bustin my b....
- Not sure on which engine build to go for
- Racing Oil (Engine)- How long without changing?
- Evo IX MR Oil Drain Plug Crush washer
- breather valve?
- valve seals popped off??
- slave rod wont push in????**pic**
- mysterious whine?!? please help, ive searched
- Modding my Evo IX
- Which Clutch to Choose?
- Car stalled won't run
- Car temperature rising at higher speed
- RPM Spike
- 2.2LR Should Cams Be Advanced, Retard or 0?
- --- Buschur Exhaust ---
- fluctuating boost at WOT
- 132k miles on the original timing belt. Don't be scared.
- Need help with the rear diff....
- Thinking about upgrading to a FP 71HTA
- HPS silicone intake/turbo inlet?
- bbk and fp turbos
- Weird poping sound from diff
- 4G63 Exhaust in a CH Lancer?
- BF 272's Who is running them?
- 5 speed or 6 speed?
- Spark plug question for lots of highway driving
- Cut back spark plugs?
- Can some one please explain this ??
- ZOMG 5th gear grind!
- AMS downpipe, 02 donut gasket?
- most functional pcv setup for sd ?
- Turbo leaking air?
- Missing Trans pieces - 6 speed to 5 speed swap
- injector tuning help!
- Where these parts go?
- What is this whine?
- Little help please
- Aem wideband-random full lean
- I need a gasket for a divorced downpipe - I think
- Headstuds. MAP H11 vs ARP L19
- Aw geez! Mike@AWD
- Heater Core bad? Coolant leak/smell inside cabin
- FP Red vs 750R
- Best Place to O-Ring a CylinderHead
- What consist of the stroker kit
- driveshaft alignment
- I use conventional oil in my 790WHP Evo and I can prove that it works great.
- spark blowout or bad tune?
- Reading spark plug, coolant scent with pics
- 2003 Evo 8, Clutch won't disengage
- AEM wideband problem
- help with buying a used block
- evo 8 full boost no acceleration
- ACD Pump Question
- WGA Install question?
- Fp4r or s2 cam?
- Rev Limit after rebuild
- Atp Gt3076r vs Precision 6262?
- NO Boost after gt35r turbo Install!!
- New Clutch Breaking Point
- Looking for advice to replace my HKS 3037S turbo
- Turbo XS High perf. Dual Stage Boost Controller
- Evo tech knowlage nedded Please help ID this Tc
- starter for 2005 evo same fitment as 02-05???
- 5 bolt outlet minus 1
- Need help ASAP - Military daily driver
- 2.0 Longrod Build Compression Issues
- o2 housing question
- Actuator Recommendation?
- Best Single Clutch Disc for Launch and TrackDays
- Possible Boost Problem
- 02 housing Gasket
- Well there goes a cam...
- Help with installing FP oil feed line
- Starter Location in 05 evo?
- OS Giken Twin or Exedy Triple
- sprak plug and gap info please
- Power falls off bad around 720 HP
- Any Good mechanics in or around Cincinnati?
- Best Stock Frame Turbo
- HKS 264 cams..
- HKS EVC issue?
- cam gears worth it?
- Fuel problem!
- Can a bad tune cause misfire?
- HELP!!! Strange Noise
- Engine vibrations
- Exedy twin plate hybrid clutch...
- only boosting 12 psi?? help me out please..
- Exedy stage 2 hd failure in 1500 miles
- Weird Clutch Sound!
- Anyone running the JM Fabrications Tubular Exhaust Manifold?
- Evo 4g63 price
- Running Rich issue cant solve.
- head knock at certain rpm range?
- Drivetrain issue?
- Trying to help a fellow owner on a budget, advice needed
- My mild build
- AMSoil
- Small end bearing to gudgeon pin clearances
- Power difference between regular T3 housing and T3 GT housing?
- Looking for shop to balance my rods.
- Seating front axles?
- Evo 9 Front differential?
- Airtrek Turbo issue......
- Does Transfer Case Whine
- fp84 silicone intake on an acd equipped maf car
- If you're running a short route UICP, Boomba catch can for X fits perfectly for 8/9
- 06 Evo ix MR boost level
- Problem with engine work (low boost) and AYC error
- Poor cold start and juddering when comming off the throttle
- What kills spark plugs?
- Cam Advice Needed
- weird vibration!
- Electric Power Steering?
- Gearbox/Transfer Case Oil Change
- Intermediate shafts...
- identify my cams
- Need a new transmission ?
- STOCK injectors, what is their limit?
- Cylinder misfires
- bigger injectors
- Grimspeed 3 port: one-and-done boost control?
- Irregular Knock really worries me...
- Dealer Issue with ACD
- Koyo or Mishimoto Radiator?
- need some help
- 9 Sec 2.4LR Build Forefront - Opinions needed
- whats the highest boost i can run?
- Keep stock dv? Or upgrade to Tial Bov?
- Have three clutch discs and don't know if I should use them. (ACT, EXEDY, RPS)
- Can you identify this Mystery Turbo?
- Which clutch? Stock, ACT or Exedy?
- Mr bov stall!
- Bov
- Exhaust Leak @ Turbo WG Actuator seal
- Who sells factory trans fluid besides dealer?
- Evo IX copper plug alternative?
- EVO 7 Rebult Engine Problem
- some CBRD builds-
- EVO 8 4th gear
- Evo 8 - No Boost. help.
- Hydrolic TOB, anyone?
- noob question
- best transmission oil for evo 8 5 speed..
- stripped compressor cover bolt
- HKS vs GREDDY
- Shep trans & tcase questions (axle related)
- Just blew rear end (lol), best option to fix/uprade?
- Walbro 400LPH intank pump ? Anyone got any info
- Fuel Pressure Regulator Install Pictures?
- how bad is this turbo damage?
- Need a -8 oil pan turbo drain line fitting/flange, where to get?
- ATP Compressor Dishcharge Flange
- Best 02 housing for mi FP Black...help!
- hks hi power exhaust tip too big??
- EVO IV starter replacement
- Divided o2 housing gaskets
- Need HELP ASAP with Full Blown System! Step Inside
- Noise after timing belt replacement
- Odd issue, any help?
- Running Boost Gauge with EBC
- Cat's gone... now what?
- what is this turbo help!!!
- Ht86 vs pte6766
- HELP im OVER BOOSTING
- Best clutch for my power level
- Engine blown...help please
- 4g63 trans question
- another turbo and still smoking
- Greddy ti-c help!
- Flywheel bolts rounded!!!!
- Evo 9 GSR Oil/fluid Change
- OPTIONS: evo 8 with REd XTSS or used Twin with shep trans
- anyone seen this yet?
- Looking for advice on replacing clutch
- What is the final consensus on the Exedy Twin Disc?
- noise question
- mr bov help...
- compression test results
- Help diagnose a CEL
- Precision News Update: New CEA 66mm Turbine Wheel - 6266 / 6766
- Advice for my setup
- A few questions.
- 5 bolt downpipe?
- progressive whine noise ???
- Tilton 3 plate metallic
- need full motor, tranny, tcase, ect.
- Evo bov question
- help with oil light!..
- Recirculated O2 Housings: WG Flow vs. Outlet Diameter
- Clutch and transmission help!
- 4G64 based build...2.4 or 2.1?
- Follow up on previous thread about clutch fork
- spun rod bearings
- ACD pump out?
- good short shifter for evo ix??? Plz help
- Idle issues
- High knock counts after balance shaft delete
- port and polish EVO 8 head
- Lost 4-5 lbs of boost.
- My Baby Needs Help
- AMS RACE FUEL RAIL INSTALLn
- Springs on TOB are backwards...what to do?
- Clicking noise when i'm Driving!
- evo 8 cam install helpp?
- To bleed or not to bleed? (new lifters) Help please.
- Input shaft question
