PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 [131] 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. leak found, need advice
  2. Full-Race twinscroll GT35R+Cosworth Heads and Shortblock+Cams.
  3. Aeromotive fuel pumps?
  4. Jun 272's, GSC S2's, or Revolvers for new setup??
  5. USA Pump Gas Dyno and Track #'s
  6. How much boost should I dial before Ecu tuning? Please reply, need advice
  7. Peakboost FTW kit with GT3076R
  8. Hydraulic TOB failure
  9. TRE drivetrain fluid recheck recommendation
  10. ? Best turbo for running e85
  11. Turbo not kicking in!
  12. What kind of press do I need to swap out motor mounts?
  13. need help deciding which clutch kit & flywheel
  14. Green + Meth + 2.3L?
  15. atp 35r numbers
  16. Injen UICP and LICP
  17. Shifting problems
  18. My AMS 2.3RR 37R Build
  19. Anyone running dry sump
  20. Time for a race head! BR, AMS or JAM?
  21. Idle issues after cams/tune
  22. battery/alternator problems
  23. Very low vacuum and terrible idle
  24. Evolution Ebay Front Mount Intercooler
  25. 1000cc or 850cc
  26. Tranny Question???
  27. Question about timing belt change. . .
  28. Water Pump Pulley
  29. Having a misfire issue between shifts, will HKS DLI fix this?
  30. PLEASE!!! ANY ONE using Supertech DUAL Springs and Retainers Chime in!
  31. Walbro 255lph fuel pump
  32. hks mivec 272 cams no rough idle
  33. Should I upgrade my valves?
  34. Which turbo should i get
  35. P0301 and P0300 Misfire Codes MR 6 Speed Specific Mitsu TSB!
  36. Specs for a 2.2ltr question
  37. Evo 9 Turbo Or FP Green??
  38. Alright. This 0300 (and related codes) is something that needs to be solved.
  39. Loss of shifting feel
  40. What brand fuel do you use to gas your evo?
  41. which cams?
  42. Transmission Help?!
  43. Gt3076 Hta
  44. What am I missing?
  45. Just got tuned by Ivey overboost?
  46. exhasut question about knock
  47. Head O-Ringing???
  48. Forged Recirculating BOV Boost Cut while Cruising
  49. Honest opinions on short shifters?
  50. 30K Service
  51. ams 35r or ets 57trim ??
  52. Throttle Body
  53. Dual Valve springs set question. Urgent!
  54. How to tell the difference in a 30R and a 35R compressor wheel?
  55. Greddy Racing Ti
  56. anybody runnin these plugs?
  57. Help Me Adjust Greddy Type S Bov!
  58. Anyone running Injen UICP with stock intake tube
  59. Another day of dyno testing with Buschur's RS.
  60. Looking to get into the 11's
  61. Engine Build questions?
  62. My Mysterious active differential problem
  63. Intake hard pipe question
  64. please help.. engine keeps dying
  65. Lower intercooler pipe gasket part number
  66. Part # for coolant overflow?
  67. Adding a "cherry bomb" to my AMS TBE??
  68. Eneos vs Amsoil
  69. ngk b8eix
  70. GT4088R on a 2.0L, searched..but haven't found much!
  71. Two great tastes that taste great together...
  72. How many people have made OVER 550whp WITH:
  73. Evo8 20g
  74. Borg Warner s256 VS. Precision 50 trim.....
  75. turbo xs fmic...
  76. Rear o2 Sensor (Cat/TP)
  77. mysterious active differential problem
  78. motor and trans back in...motor acting up..at idle and stops
  79. Damaged Transfer Case pictures
  80. Greddy Titanium Cat-Back For Stock Exhaust and $450
  81. Where Do I Start With Engine Mods????
  82. Aem Gauge Problem
  83. Help Installing Exhaust Manifold
  84. Evo IX Compression / Leak Down Problem - Need Advice (Long Post)
  85. what size to get?
  86. Which would be the better cam set for me?
  87. Financing?
  88. BorgWarner S256 Dyno Results!
  89. Borg Warner s256 NO COOLENT THROUGH TURBO????
  90. should i bother with UICP?
  91. Does Exedy Twin Hd really make a noise when you release it hafl wayf???????
  92. Head Studs really needed?
  93. what turbo for 500/500??
  94. Smoke out of intake
  95. Wanted: 05 & up front Diff
  96. New Turbos
  97. AMS VSR install (56k warning)
  98. anyone running the ets intake?
  99. EVO wont start?!??
  100. Inside the Brian Crower 2.6L stroker...
  101. Service engine Light?!!!
  102. Damn what to do next????
  103. Transfer case oil (sorry)
  104. 2qtrs of Oil but Oil level on dipstick is sky high!?
  105. Misfire!!!!
  106. Evo 8 Vs Evo 9 Block Differences?
  107. DSM 4g63 t3 headers Fit on evo 8 stock turbo???
  108. Shifter very hard to move.
  109. Buscher 35R Top Mount Kit?
  110. AEM Wideband
  111. Car sputters and bogs at higher RPM?
  112. hmm, weird oil leak.. help!!
  113. Measured backpressure on stock turbo
  114. Hta Fp3065
  115. Intercooler Pipe w/Magnus Intake
  116. To stroke or not to stroke PDF
  117. Need Help
  118. Mod help?
  119. 550-600WHP 1/4 Times
  120. Need pics of 9 and 8 hotside pics for project
  121. This has been bothering me for the longest time...
  122. Best drop in 85mm piston rod combo
  123. Sweet!
  124. Tensioner tool
  125. Low boost question..Help
  126. p0138 code
  127. lost power - where?
  128. new clutch?flywheel?rotors? your take
  129. Engine Troubles?
  130. Question on Buschur Turbo Kits
  131. Buschur 3065 cast manifold kit whos running it and what do you think of it?
  132. Why use other mods, if increasing boost can get the power you want...?
  133. HELP! Fused Throw out bearing
  134. Weird squeak I get when I shift fast...? **Video inside**
  135. FPGreen Dynos @ 452whp and 442ftlbs on VP MS 109 (unleaded)!
  136. Cam Timing Changes After Block/Head Work
  137. Where to buy a Stock Air Intake?
  138. Clutch Review I read
  139. E85 question
  140. can't decide
  141. can't decide
  142. Ebraking with ACD
  143. Serious Help Needed with 2.1L
  144. OS Clutch VS Exedy twin plates HD
  145. oil leak near intake manifold
  146. uber fluttering after IX DV install
  147. intake manifold
  148. Nuts/bolts for mounting propeller shaft
  149. Thermostat to hot?
  150. 2.3l + Gt3071r?
  151. New Engine Time But Not Sure Of What To order
  152. GM maf use and relocation possibility?
  153. Choice of Cam??
  154. what else do I need?
  155. Evo IX turbo worth the upgrade?
  156. purchase 3-3.5" blow thru?
  157. cosworth cams evo ix people
  158. Pic Request: Aftermarket o2 housings with stock heat shield
  159. New Transfer Case??
  160. project car
  161. Pics of installed intercooler piping
  162. best ehaust for evo 8?
  163. agency power turbo kits??????????
  164. New to Evo's- Please help
  165. stock evo 8. . . what are the 1st performance to buy for it
  166. hks blow off valve
  167. p0300
  168. 400WHP Clutch suggestion
  169. question about a downpipe
  170. Question about Intake Manifold!!!
  171. Tubular T3 exhaust manifolds
  172. anyone have HTA35 with cast manifold?
  173. Things to know about the diffrent Transmissons per year and model
  174. Going to bleed clutch, which brake fluid did you go with?
  175. Blow thru MAF?
  176. 272 or 280? And what injectors?
  177. new jam lifters
  178. idk what turbo to go for
  179. Downpipes (Mine's & Monster Sport)
  180. which electronic boost controller are you using
  181. 50 Trim 03 Evo
  182. replaced throttle body shaft seals, now throttle sticks.
  183. Opinion on Clutch
  184. Tanabe Exhaust Horsepower
  185. Upgrade Turbo question How more power can FP Green produce for me?
  186. I need a complete boost leak solution
  187. hey guys i got a SMOG question.
  188. boost controler question
  189. how to get over 400 hp
  190. clutch slipping?
  191. cams or upgrade to evo 9 turbo
  192. BR 37R HEADER COATED and BR COP INSTALLED!!!
  193. What Would You Do???
  194. stroker questions
  195. Has anyone toyed with the idea of dropping a 2jz in their Evo.
  196. need help for final step in rebuild!
  197. dp to o2 install
  198. which intercooler..
  199. ANY 1 have AMS FMIC ?
  200. How far will 780cc injectors take me?
  201. Confused about drive train
  202. Exhaust Manifold pics
  203. the fq-400
  204. Rear LSD Problem?
  205. injector stuck open
  206. 1st Gear Issue
  207. motor install almost done
  208. Condition of my 30K stock spark plug
  209. evo 9 turbo in evo 8 and evo 8 turbo in evo 9????
  210. Why people should heed the advice.....
  211. 2.3 IX, 37r, 600+ whp pump/meth
  212. Qucik injector question
  213. exhaust dynos
  214. Evo 9 MR oil drain plug crush washer question
  215. turbo question
  216. Where to look
  217. release bearing came apart?
  218. Pics of external wastegate on stock turbo?
  219. Dyno runs on Sharkbite2000's amazing AMS Evo IX
  220. EVO8 KAAZ rear LSD setting
  221. Ebay N1 Catback Exhaust Evo
  222. i cant decided on boost controller
  223. When Do I Need......??
  224. my custom built hybrid 6 puck
  225. Need part# for T-case bearings!! Help!!
  226. Two circle/dots - what is this in the trans?
  227. Questions about parts n such. Need some help
  228. Turbonetics GT-K turbo kit, is any one using this turbo?
  229. Is anyone making a turbo kit w/GT-K turbo from Turbonetics
  230. Exedy Triple HD
  231. i looked for my answeres and i couldnt find them, cam Qs
  232. seriously guys, last one about bovs, i swear,just answer my question honestly
  233. Buschur Racing..... Coil on plug ignition clarification
  234. My throttle cable has shifted itself? Pic inside
  235. Just upgraded to a BR3065, should I put the heavy RED spring in Forge Diverter?
  236. Transmission oil
  237. Spool on an a FP green DBB conversion
  238. Another new PUMP gas record, thanks Driven Innovations
  239. **Stock Manifold porting debate**
  240. HP level and drivetrain
  241. hks hi power 30th anniv
  242. Hi-flow 3" Cat By Perrin JDM compatibity
  243. Just the first of many new parts I'm building
  244. quick question
  245. o2 sensor help needed.
  246. My poor 35r
  247. ACT 6 puck sprung or unsprung?
  248. ACT HDSS Needs Adjustment?
  249. does anyone have any videos of there bovs, and i gota question
  250. Overboost problem
