View Full Version : Evo Engine / Turbo / Drivetrain
- Very productive day :)
- GI: EVO Tubular Manifold
- Stupid Question inside
- boost leak?? or exhaust leak???
- TurboXS fmic gains???
- Going to try new oil
- How thick is stock Headgasket?
- "Magnaflow 3inch Resonator"
- What would you do with $8000
- Tubular dudes.....here's a header.
- turbo question
- AXel Back?
- Aluminum Driveshaft?
- BR stroker motor w/ race head package!!
- How much will a 1.5mm headgasket lower compression?
- New power with cams installed
- Lost Power On My Evo + Stock Bov Produce Sounds
- Basic Mods
- RS Front diff in a GSR
- cant get the boost right on MBC
- 264 intake/ 280 exhaust?
- What mod to do next?
- EBAY stuff
- Turbo Timers VS P0300
- BOV whistle
- is this worth spending money on?
- Opinion on Centerforce Clutch
- Hks 280 Cam Specs
- parts for acd!
- Engine No start after flash...
- Hose Sizes
- Kartboy Shifter Bushings Don't Fit MR
- Aeromotive fuelrail
- Shifter squeek and possible t-case problem?
- Oil Catch can hose... overkill?
- headstuds for boost or rpm?
- Weapon R Intake....Any one have it???
- 05' Goes in for diff probs again...
- Advice me on turbo kit
- The stock FMIC?
- FMIC and turbo kit choice
- Removal of Restrictor Pill..4th grinds??
- did u disconnect the battery to install your TBE?
- Valve springs and retainer install
- Weapon r oil catch
- ACT clutch installed, now noise?
- Ok I need help.
- Price of P0300 ECU reflash?
- Defi BF EGT -- strange reading
- 10.5 Hotside and stock exhaust manifold porting?
- Any way to tell if I have Aftermarket cams?
- who's got a datalogger? -> LTFT at idle
- a/f install help
- Limited Slips Explained
- ! Stock Boost Questions !
- To Those With Clutch Noises...
- Invidia Exhaust Group Buy
- Buschur Turboback Exhaust Parts?
- SES at 4600 miles
- EVO 8 exhaust movie/sounds
- to those w/ hks or other cam upgrades
- ARP head stud install
- APS 3.5in Race Turbo Back Exhaust
- fuel ?
- Anyone running the....
- ok people i need your help! 3" tbe and cop problem
- FMIC upgrades
- APS High Flow Intake Manifold
- Where to get clutch installed in raleigh NC area
- Any long term opinions on the Act MB7-HDSS?
- 19-20 psi on MBC safe with no tune?
- New EVO 8 product - Pro Street Lightweight Flywheel
- Airbox and filter
- Injector question
- EGT probe length?
- getting BOV flutter from greddy TypeS after intercooler install
- Is the flywheel worth it?
- big prob
- got a question about ecu flash
- HKS EVC 5 offset ?
- People using the Profec B Spec II
- Programming the EVO8 ECU...
- OK...Surging, maybe BOV?
- Anyone with ATP Turbo Experience?
- What cams should i get?
- Is it really an issue?
- how do you not slip the clutch at the track
- Fujitsubo RM-01A
- Do you have to change injectors for cams?
- The best way to store race gas?
- Is a Auto possible
- Rpm Drop Problem Help !!!!!
- Question about cams,gears,flash?
- Stainless steel/chrome upper radiator pipe
- 2 ecu's for one car?
- Evo Car Problem 8- ( !!!
- Pics of Injen Exhaust (56kers beware!)
- i have a cam question??
- WTF Am I surging?!?!
- GM Synchromesh Question
- Hallman installed....got some questions though..
- WORKS vs HKS
- need help!!
- RnR 3" TBE Exhaust - Good stuff :)
- Whats a bolt on turbo for Evo
- Peak boost @24.8?
- Is this bushing suppose to be loose like this?
- 280 Cams Installed !!!!!! Wow !!!
- Head Porting...What to Replace?
- i got my rnr turbo kit
- Methanol & Water percentage?
- Reusing Factory Sprayer with AEM and NX please help
- need help finding the best parts
- Slow Spooling
- leak
- leaking something
- Exedy>Cusco?
- Should i lower my boost????(merge)
- HELP!! some quick questions. need input!
- Max Boost around 12-15 ???
- Happier Than EVer With My EVO
- Holy Flutter!!! SSQV ???
- HKS Camshafts
- turbo manifold advice?
- are catch cans highly recommended?
- Boost Controller on Stock Exhaust
- HKS 280 cams
- At what horsepower level should you do engine work?
- freebie mod, that is if you have the time to do it
- Intake and bov help needed.
- TME turbo and manifold
- megan racing DP issues
- Problem with Greddy Type S?
- Head gasket problem
- High RPM studder question
- Greddy BOV
- Muffler hanger problem anyeone?
- Whats this whole "20g turbo" ?
- Clutch not disengaging enough! HELP!
- Read This!!!!!!very Important To All Evo Owners
- Need some advice on my blown motor.
- Anyone have a FLow Chart for our Twin Scroll 16G Turbo
- Fuel line size?
- ACT HDSS clutch installed
- HKS 280 Degree cams
- Hks Cam Combinations 264/272, 272/280???
- Need help/input on exhaust, BOV & intake
- Possible turbo problems on a '05 GSR
- Clutch Change..
- bad turbo problems?????????
- Alcohol and 05 evos
- Whos have Blown Engines?
- Anyone Have The ATR Cat-back Installed?
- Change in boost durng engine break-in?
- RNR or RRM turbo
- Gt35r--i Need A Bigger One
- Cams and fuel pump...neccesary?
- Safe boost level on MBC w/o tune
- Best Upgrade Turbo for stock Man. Super 20G or 18G?
- why is BOV bad?
- Clutch retaining clip
- stock bov question
- downpipe rubbing on subframe?
- Ferrea Valve Springs & Retainers
- backfire (popping sound)
- question for Al, or those w/"stock" tune
- Got BEASTED by an M5 TOP END
- clutch still sounds and feels like>>
- turning off engine with downpipe
- e-bay header?
- Filter Test: MUST SEE
- IC Piping Diameter
- 15psi in 1st and 2nd... 20psi in 3rd-5th? What gives?
- So you wanted to know how heavy is the AC
- Turboback W/out Tune?
- Help? Can someone help explain?
- stock clutch... an exedy?
- Nitrous Anyone?
- Which next mod will give me best power
- Whining Noise When I Let Up The Clutch???
- Tranny limits ?
- Arc Fmic
- which turbo timer?
- AC out on my GSR
- ARP Head stud install... (yes i've done a search)
- intake adaptors connecting to MAF
- Best upper I/C pipe
- Black Soot from tail pipe since day 1...?
- Tech. stuff on exhausts
- VENDORS: Any Motul oil dealers here?
- "How To Lie With a Dyno"
- Using DIY tester for boost leaks
- injectors?? OK to install??
- Exedy twin plate clutch disk?
- Drilling holes in the firewall...
- Tranny gear oil / Bushings
- Looking for clip of loudest exhaust..
- Difference between headers/manifolds?
- EVO as daily driver
- Resolve CEL Issue
- what cams are these?
- What Gives?: Twin Disc Systems by the numbers
- How do you know when a maf is dying?
- what you guys think...
- Tuners, Al, Buschur, anyone, please help???
- Whining sound on diff!
- Strange Garrett turbo...
- white smoke wont stop
- Installed Megan Racing short shifter... Too stiff!
- Japanese ECU Install
- stroke length/redline vs turbos
- how do I tell whta HKS cams I have
- exhaust choices
- do i need to upgrade the valve train
- boost problem -- any guesses?
- GT35R Turbo Kit
- cam gear question
- confused with upper ic pipe with bov
- Downpipe ?
- Muffler delete vs. catback?
- Oil catch can?
- upgrading manifold on stock turbo
- Performance Gains with Buschur Cat Back
- Evo battery relocation
- Down Pipe Question?
- Pulse Converter Manifold?
- Stock boost solenoid help
- intake without tune=less power?
- cam gears?
- Car is bucking? HELP
- Dyno Correction Factors (SAE/STD/STP/ETC) Explained
- Pulling Timing Error
- Everything you ever wanted to know about Alky/H2O injection kits
- Opinions - GT3040R?
- Check out my dyno pull, let me know what you think
- Stock Map sensor and Intake Manifold?
- Air/Fuel questions-ATP Turbo kit...HELP!
- Rear diff making sounds?
- Detonation + Head Gasket = Freeze Plug??
- Boost cut then "service engine" light.
- Tob?
- When Rebuilding The Engine Who Recommends Replacing The Oil Pump?
- got question regarding Apexi intake kit
- just installed dp and test pipe
- who has the Helix IC piping kit?
- what to look for in a FMIC
- wtf look at this anti lag
- Pics of HKS RS intake installation
- Will an evo 8 clutch fit my evo 6 flywheel?
- PROBLEM, stumble at high speeds
