PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 [97] 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Clutch going and flywheel warped effects
  2. Car Stalls When Started
  3. Turbo cant boost....RPM cant go beyond 4000rpm
  4. Anyone do a fuel injection flush or induction service on their Evo?
  5. Does any company make Titanium 3" Test Pipes?
  6. Stock 16G fit on 2005 WRX
  7. 16g turbo
  8. Help with new clutch please
  9. Slave Cylinder(spring inside) Problem HELP
  10. Not boosting past 21psi after O2 Dump installed
  11. Car wont boost...help!
  12. My Car Isnt Boosting past 4lbs...Help!
  13. few random questions
  14. hks 280's
  15. Trans Question Help Please
  16. stock turbo repair?
  17. Car is getting no power
  18. My Car lacks the oomph
  19. Help with cam choice!
  20. Knock Sensor Replacement
  21. Look what came! and what is this?
  22. Downpipe fitment on IX MR
  23. Problem with clutch engagement
  24. 2 questions
  25. Oil leak?
  26. Greddy SP2 Catback
  27. Airflow fluid dynamics
  28. Leaking o2 housing and burnt manifold
  29. 3rd and 4th gear lockout.
  30. Tensioner "special tool" stuck in engine
  31. EVO Exhaust with "widest" tip Diameter??
  32. The quest for 400/400
  33. 5th gear locked out?
  34. Question about intake
  35. HELP! Car Wont Start with New Clutch
  36. What would you change?
  37. what do you think??
  38. Need advise on my new clutch choice. Help!
  39. ACD pump relocation
  40. Tranny kicks shifter back in 1st
  41. Looking for specs on the older GSC 280's
  42. Greddy or HKS
  43. 2006 MR Cold Air Intake (CAI)
  44. Starting Issues (Fueling problem - Walboro?)
  45. Help Please...
  46. need help! evo6 max psi
  47. Over Rev on shifts, who's got the answer?
  48. HKS Hi-Power Possiable Issues.
  49. My Battery Relocation
  50. Gay boosting prob...need advice.
  51. Tranny Oil Options?
  52. Has anyone made 400whp on an Evo9 turbo on pump?
  53. Part selection choice?
  54. HELP! Tranny from Block:how?
  55. Anyone have Thermostat part # ?
  56. evo 9 ecu compatibility? hAlp!
  57. Stipped center exhaust manifold bolt...how bad is it?
  58. 2.0 rebuild question
  59. Buying new Thermostat...OEM or Mishimoto ?
  60. evo pulling mass timing?
  61. Anyone ever used OS Giken's Super Lock LSD Gear Oil 80W-250?
  62. The Physics of Multi-Plate Clutches
  63. HKS twin plate warps easily?
  64. Static ignition timing retarding by its self
  65. boost leak or faulty boost controller?
  66. Cost of coolant flush?
  67. Titanium Exhaust vs Stainless Steel
  68. FP red porting
  69. Bent crank angle sensing blade?
  70. Stock Alternator vs. Autozone Alt??
  71. Broken transmission and cracked exhaust manifold, what to do?
  72. Help!!!! Exedy Twin HD ?
  73. New FpRed vs old FpRed
  74. Oil pressure question....mounting
  75. need help did boost leak test and leaking from throttle body
  76. Turbo XS bov rfl evo IX
  77. Leak Down Test- Simple Explanation
  78. Crankcase catch can vs. Open breather
  79. does the vibrant maf adapter come with hardware?
  80. E3 Spark Plugs
  81. Evo 9 starter on evo 8??????
  82. Need quick suggestions before tomorrow on transmission warranty
  83. ams balance shaft delete install??
  84. Which alternator... F or D??
  85. crank pulley removal???
  86. Unbelivable blown clutch PICS INSIDE
  87. Stock Axles Max Power
  88. Limits on the stock valve train
  89. just bought redline oil...question
  90. Ottomatic's FP Red Install / e-85 build - Progress Pics
  91. Serious Problem EVO WONT GOOO
  92. JDM Evo 7/8/9 Transfercase compatibility
  93. What are the nessessay parts needed to convert evo8 gsr to evo 9 mr
  94. cams
  95. Random electrical problem, help
  96. Tranny Oil and TC ,Help Asap!
  97. Piston To Valve Clearance
  98. Where can you purchase the Driven Innovations Intake Manifold and Throttle Body?
  99. tranny lockout
  100. cam ?
  101. Intake Manifold Hose's
  102. Are some cams knockier than others?
  103. What is the metal thing behind the crank pulley called?
  104. Wheres the fuel pump relay?
  105. Need help with LICP for FP Green setup on 03 Evo..
  106. Titek version 2 o2 housing
  107. Hallman Pro Series Boost Controller boosting capacities
  108. Hallman Pro Series Boost Controller boosting capacities
  109. Need Help with LICP for FP Green setup on 03 Evo..
  110. Found 2 bolts broken... Now what?
  111. Help! Please run out to your evo to help me! Pic Needed
  112. p0138 problem
  113. Its so big!! Ams delrin shift knob!!
  114. Turbo Transfer
  115. blown clutch
  116. how to check tranny fork?
  117. Annoying whining noise....
  118. oil light
  119. Greddy full I/C pipes with stock I/C evo 9
  120. CCI stage 4 clutch kit with stock EVO 8
  121. Greddy Ti-C Turboback
  122. RPMs drop 500 during WOT in 4th and 5th, why?
  123. clutchmaster stage 2 clutchs and flywheels
  124. Help: A/C Questions
  125. compressor surge?!?
  126. Ball joint removal
  127. throw out bearing question
  128. Sard FPR and Guage
  129. Need an Explanation :S !!!!!!!
  130. Evo 8.5 starts, then dies after 5 seconds
  131. Stock block/pump power?
  132. slight slight flutter from tial bov
  133. no spark check list.. help!!
  134. Can I use this turbo?
  135. Can anyone confirm piston clearance for me?
  136. extend the clip to the ignition????
  137. Evolution 8 MR AYC Prob
  138. 1st gear/Reverse vibration?
  139. AGP Intercooler
  140. boost leak test oil cap leaking?
  141. suddenly car wont go into gear!?
  142. Where can I find a decent rear differential for a decent price.
  143. light smoke
  144. How long for lifters to pump back up after bleeding
  145. Injen intake is lifting my greedy pipes and wont let my hood close.....
  146. 5000rpm misfire.
  147. Finally started my built
  148. Ihi vf37 ?!?!?!
  149. 04 Lancer WRC engine bay
  150. Whine/vibration on fast decel shift
  151. dynotune gauges?
  152. Fuel injector problem
  153. Cams and Emissions
  154. Evo IX piston to wall clearance. HELP!
  155. Opinions on DD on cams?
  156. Lookin' to build a leak tester...
  157. Spark Plug ?'s
  158. another ACD issue. am i killing my car? searched.. NO solid answers. HELP!
  159. CAT Hitting my driveshaft. why?
  160. Drag guys......What power diff running without AC and PS?
  161. Upgrade clutch, or wait till stock dies?
  162. need brains 4 boostgauge hookup ...
  163. clutch completly blown, SUCKS
  164. WOT Heard POP no Electric for 1/2 second, then all fine WTF?
  165. What IC pipings will fit?
  166. HELP! Detonation in only one cylinder!
  167. when to change timming belt?balance shaft?
  168. Blow off valve stuck closed
  169. Engine cut out at high rpm
  170. HELP Identify this Injector Plz (Pics)
  171. Ceramic Bearings
  172. I got it!! I got it!!
  173. Mini battery love -
  174. Carrillo Rods, Wiseco Pistons Weights etc (New build)
  175. New Competition Twin TOB
  176. where to buy extended vacuum line?
  177. Spark Plugs - To gap or not to gap?
  178. Help, someone rescue me
  179. simple evo ?
  180. o2 dump vs recirculating o2 housing.
  181. o2 dump vs recirculating o2 housing.
  182. FP Red 80mm inlet Flow Advancement Port
  183. False Knocking ISSUE! NEED HELP!
  184. axial clearance rods.
  185. boost controller question
  186. Starter location
  187. Shifter Sux
  188. Need help, won't boost over 5 PSI
  189. Bad tranny, front diff, or Ring/pinion?
  190. ARP L19 head studs 1+1... what to TQ???
  191. having trouble finding the alt plug?
  192. What do I look for in a BOV??
  193. Does this sound like an ignition issue?
  194. Dealer Rec's TB Cleaning & Injector Flush - $200 + Tax
  195. clutch/tranny BLEW today
  196. kelford cam install problem
  197. Spacers do they really damage the transfer case.....?
  198. How many shims for a quarter Master Clutch on average?
  199. Where can i find this part.
  200. 1-2 Shift on hard accel
  201. Can I use stock head gasket with 86mm bore?
  202. Bad First Gear Noise HELP!!!!
  203. Turbo Question
  204. Silly intercooler couplers
  205. kiggly beehives springs/tool
  206. Clutch Blew out Tonight
  207. I can only get 1/2 lb.
  208. Car won't start from time to time
  209. Leak Help!
  210. Help! DRAINING coolant
  211. TOB problems, CLUTCH, PLEASE PLEASE HELP HELP
  212. FP Red or HTAG35R
  213. Loud Ticking from throttle body
  214. Vacuum line placement on tial 46mm gate
  215. Evo 7 Piston Burnt
  216. serp belt install probs
  217. e85 and gas mileage
  218. Tob help help!!!!
  219. Retuned after 60K?
  220. Cat life?
  221. What is the best oil filter sandwich adapter for EVO?
  222. Driven Innovations is King?
  223. tried everything! out of ideas! please help
  224. painting intercooler good or bad?
  225. Oil Flow Rate(s) for EVO8 ?
  226. Anyone have this manifold?
  227. Driveline fluid change complete
  228. e85 considering
  229. paracitic draw
  230. Anyone Using A Precision Sc 6176?
  231. Will AMS UICP fit Greddy R-Spec FMIC??
  232. oil Pump replaement
  233. gearbox pics/info
  234. hks super sequential blow off valve need help
  235. Ummm...am I missing something? (exhaust install)
  236. Boost Gauge Problem
  237. Need some help from fellow troubleshooters
  238. Serious Idle Issues
  239. Turbo Question
  240. Whistling noise while driving.
  241. rattling when going into 1st gear low rpms
  242. redline package
  243. Bushur Racing Quiet Exhaust?
  244. just got tranny rebuilt from jacks.. help!
  245. okay to run car with ACD fuse removed??
  246. ABS ring question. RR axle. missing teeth? can i replace?
  247. New Timing belt questions
  248. non water cooled turbo question
  249. Best way to store a block w/o it rusting?
  250. drop in pistons help
