PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Turbo Upgrade
  2. Well. help me.
  3. AEM Wideband Full Lean at Idle after Turbo Install
  4. Factory Clutch question
  5. bov
  6. Transmission Q's
  7. evo 9 turbine wheel to 10.5 housing gap/?????
  8. Odd Compression Test Numbers
  9. GT Spec exhaust manifold cracked
  10. atp 044 holder
  11. 2 muffler catback?
  12. ACL Race Bearing Thrust Washer made from China?
  13. Which Precision Turbo should buy?
  14. 2.3 motor problem help please guys
  15. Wilson 90mm TB or Q45
  16. Ignition Options?
  17. Fresh motor eating bearings
  18. Water Pump Bolts?
  19. Question for people who did their own clutch...
  20. Timing belt noise after install
  21. PST Carbon Fiber 1 piece drive shaft installed.
  22. I need more power??
  23. Budget stroker motor
  24. Need some measurements
  25. Knock knock I need a new engine
  26. snorkel doesnt fit
  27. ARP 2000 head studs max power?
  28. evo 9 tranny!!
  29. 16G to 25G?
  30. 16g turbo upgrade
  31. Crower (not BC) cams question
  32. Proper timing marks? Evo 8
  33. evo iv catback
  34. Fuel Cell Installation Questions
  35. RPMs don't drop when clutch is in?
  36. Turbo upgrade?
  37. Turbo upgrade?
  38. Help! is my motor blown!
  39. EVO IX current set up
  40. Keep OEM exhaust valves? or go with inconel super alloy?
  41. Bad O2 sensor or ignition issue? Or something else?
  42. If you have installed a Carbonetic or ATS multi-plate clutch, come in.
  43. rich idle and cruise
  44. Quieting down my exhaust
  45. Leak down test
  46. Need some assistance with an issue
  47. Question for MAP Comp-gate40 O2 housing?
  48. Evo 8 Knocking sound
  49. TOB for Exedy triple plate HD
  50. Cams, values, springs, lifters... Oh my
  51. Which tial wastegate i should use?
  52. what PSI is the 2007' Mivec EVO IX factory boost?
  53. HKS GTII 7460R is finally done...
  54. Exedy stage 1 organic vs comp clutch stage 2
  55. HELP! Top End Ticking
  56. EVO IX Turbo
  57. Let's Talk About Rods, Shall We Boys?
  58. Starter and alternator wire routing
  59. Fp green Preload
  60. Another deceleration harmonic thread
  61. Exedy Triple...Clutch Adjustment Rod ?
  62. Oil pump modifications for big horsepower and high revs
  63. RC 1000 or FIC 1050, with FP red?
  64. Timing belt keeps skipping a tooth.
  65. Balance shaft belt timing help
  66. internal wastegate setup tip.
  67. Help, what's this sound?
  68. Can I run a tee off OFH for oil feed line/oilpressure
  69. Evo 8 IM work on Evo V-VI motor?
  70. Gear lock out
  71. Is this retaining ring on correctly?
  72. Car wont start after using wrong map?
  73. Quarter Master twin or Exedy Twin
  74. Upgrade my hks 272 or not worth it Fp Green
  75. Who makes O2 housing that won't crack?
  76. how strong is the OEM timingbelt
  77. Skunk2 pro cam gears
  78. How do I alleviate throttle lift bucking at 0-5 psi?
  79. Boost creep..12-20 psi..
  80. Can you guess what this is?
  81. Who has the best pricing on Tomei Expreme Ti for Evo IX?
  82. Evo V Intake piping
  83. switch M & W Pro 12 Ignition Module to high output mode (150 mj)
  84. Koyo Rad + FP Red = What Fan?
  85. Timing my evo 8
  86. Evo won't start :( PLEASE HELP
  87. EVO 9 Cluster fit Evo 8 non ACD?
  88. Hotside Evo 9
  89. Cure for loud external fuel pumps
  90. What are the best cams for a 1000hp setup?
  91. 4 port BCS - Anyone using one?
  92. Compression test
  93. Acd rebuild success!
  94. Good stock frame turbo
  95. Another low boost thread after installing MBC.. HELP!
  96. Actuator arm and creep issues
  97. radiator, intercooler question
  98. torque solutions
  99. GFB RESPONS VS SYNAPSE for EVO 8
  100. Fan Control module
  101. P0191
  102. 2.1L water pump?
  103. Iridium spark plugs
  104. 2 questions here regarding EVO IX Exhausts:
  105. Help! Injectors not firing
  106. New evo Servicing
  107. need big help! 64 block swap
  108. Incomplete Monitors? help
  109. 3" or 4" intake, going SD on HKS 7460 Stock Frame Turbo
  110. English Racing BUilt TX2K14 Evo w/ ETS PT7175 Turbo Kit
  111. Smoking Engine!!!!!!!!!!!!!!!!
  112. where to find a front diff?
  113. where to find a center diff?
  114. Fresh rebuild and car cuts out when in gear
  115. Acceptable inlet temp increase over a WOT pull.
  116. rod bearings 900whp evo
  117. Is the stock evo 9 worth porting?
  118. Trans fluid/transfer case suggestions
  119. How to fix a leaky V-band?
  120. WaveTrac fluid of choice
  121. Boost controller is vibrant!! Help!!
  122. Help!!!!Please
  123. which valve springs for high rev/boost
  124. serpentine belt issue
  125. Need clutch suggestions
  126. FP HTA 71 How much boost?
  127. Stock turbo working hard vs. larger turbo hardly working for reliability
  128. 6766 2.0 street car... .63ar?
  129. Hallman MBC problems
  130. Thoughts on ebay 35R turbo
  131. muse licp question
  132. Info on upgrades!!! Evo 7!!
  133. Evo in gear but doesn't move
  134. Exhaust options
  135. apologizing ahead of time
  136. Idle sometimes high or surging.
  137. Can the Perrin Intake work with the Muse Short UICP?!
  138. Wastegate seems to be malfunctioning
  139. Is this a 5858??
  140. Help me to choose the right turbo
  141. Mivec Cam gear broken - advice?
  142. boost
  143. RPM jump
  144. Built 2.0 or BR 2.3RPM ?
  145. Engine light ( code p0170)
  146. Transfer case locked up with no known fault
  147. replacement for Tomei h beam rods
  148. Which Brand Harmonic Damper is better for 2.3L Built
  149. Quarter master 8 leg DD friendly?
  150. boost??
  151. expensive accesory belt failure, a cuaitonary tale
  152. intercooler question
  153. Works Exhale Intermediate Pipe 3" RHD Clearance
  154. weird blt results along with another problem. related?
  155. Putting rear axles back in after diff swap
  156. Throttle-dependent whistling noise (with video)
  157. New clutch what grease should be used?
  158. Car will crank, but won't start
  159. Turned my type s into a fv.. Shh
  160. evo 7 5 speed issue after rebuild. please help
  161. evo 7 5 speed issue after rebuild. please help
  162. Oil feed line kit for PTE 6262
  163. ACD Pump Issue Solved
  164. atp gtx3076
  165. anyone run one of these? fuel dampener
  166. Which turbo for 2.0
  167. need advice.
  168. boost problem/ actuator not moving
  169. Proper street car setup
  170. Electrical short/thermostat problem?
  171. Alternator wire guage?
  172. HELP! Is my engine blown?
  173. What's making this noise?
  174. Rpm gauge
  175. another 2.4 timing question
  176. 4g64 2.2 destroker pistons
  177. FP Stainless Housing
  178. Engine turns over but won't start...
  179. Buschur 272 cams
  180. Evo engine number
  181. Going .060 over 86.5mm on 4G63
  182. hks downpipe not matching mounts any ideas why?
  183. bought a "rebuilt" 5 speed, what to inspect before install?
  184. 05 MR with horrible grinding noise coming from trans/need advice!!
  185. installing oil squirters in a built(fresh) block
  186. VC Baffle Removal/ installation new way?
  187. Evo 8 Exhaust Question
  188. Long story..even longer build questions
  189. do you need a Fluidampr ?
  190. built motor shelf life
  191. decided finally.. 2.2(4g63) at jackson automachine shop
  192. Curious, EVO IX 6 - SPEED clutch questions.
  193. clutch replacement opotions
  194. Oil leak in turbine side *help*
  195. act 6 puck best place to buy?
  196. re-use oil squirters on new build?
  197. new clutch hard to get in gear sometimes?? help??
  198. HELP No BOOST
  199. Evo 8,9 top mount mani
  200. 100mm OEM crankshaft questions
  201. Hesitation with heat range 8 plugs
  202. Motor is toast, going 2.3L, what else should I do?
  203. Splitting trans from motor help
  204. new exedy twin HD issue plz help
  205. Evo 4 vs evo 7 block
  206. wastegate
  207. Stock exhaust manifold bolts won't loosen
  208. ETS external wastegate in conjunction with stock internal?
  209. WTT ETS 3.5in Evo 9 intercooler for ETS 3.5in Evo 8 Intercooler
  210. Wrong pistons installed?
  211. Opinions from the Peanuts Gallery on Transmission
  212. Is this set up ok?
  213. possibly scorched engine what are my options
  214. Gearbox Help
  215. OEM crankshaft cracked
  216. stroker vs. turbo upgrade
  217. ACT 6 Puck Sprung?
  218. To stroke or not to stroke
  219. Kinugawa turbo
  220. S90 throttle body question
  221. Help with a coolant leak
  222. GSC S2 Cams, leaking valve seals
  223. rear diff issue
  224. 122k miles, rear diff servicing?
  225. Is there a pc680 sized battery that doesn't suck in winter?
  226. Engine noise whine
  227. initial response problem....
  228. white smoke from my exhaust
  229. Evo IX - Noise after timing belt/water pump
  230. Fluctuating boost at WOT
  231. T-case rebuilt + New clutch , any advice on break-in ?
  232. Lancer Evo VII RS2 Diff failure? help needed
  233. stock intake manifold limits?
  234. oil flow at OFH ports
  235. Evo 7-9 exhaust manifold and air intake fitment into an Evo 5?
  236. A few minor issues that needs some other insight with my Evo 8.
  237. Trouble starting when cold
  238. How much for built 2.4LR motor?
  239. building a 2.0 engine !! Please HELP !!!
  240. Differentials Questions
  241. 2008 EvoX final drive advice
  242. Another ACD bleeding question...Pressure bleeder?
  243. Evo 9 Turbo on Evo 8 - Crazy Spool?
  244. Tic catback
  245. whats next ?
  246. Transmission/Engine bolt locations
  247. thinking deuces
  248. Replacing driveshaft carrier bearing Qs
  249. basic turbo thread excuse me
  250. Help With Whining (Suspected T-Case)
