PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 [66] 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Main Bearing Oil Clearance
  2. Wierd engine noise?
  3. just got my fp black!
  4. New ATP Ball Bearing Setup
  5. engine stalls
  6. Any idea how I can tell which turbo?
  7. 2 small questions, hopefully small answers
  8. Possiable leak
  9. Clutch Masters push style twin questions
  10. Exedy twin to triple conversion kit
  11. Brake pads freezing to brake rotors in sub-freezing weather?
  12. Romone Head shop
  13. Must-have tool if you own a 4b11t! Flexible 14mm socket
  14. turbo to lower pipe coupler
  15. would injector dynamic 1000's be enough for my setup
  16. Has anyone installed the FP 84mm compressor cover on a BBK?
  17. back to back test with FP's advanced flow port housing vs stock housing on IX turbo?
  18. Knock Sensor Location
  19. Halman 'pro' mbc??
  20. Im in need of help, anybody have the mivec wiring diagram/schematics for the evo 9?
  21. licp coupler problem
  22. After Cam install.. some ticking noise.
  23. To all the evom gurus
  24. HELP!!! po112, po113, po122 HELP
  25. Zero Compression On Cylinder 1
  26. Won't go into reverse. Loose end nut?
  27. Boost controller suggestions
  28. works short shifter for 6 speed
  29. bearing noise in my 6262/.82
  30. loud ticking
  31. Please help.. Weird noise after accident
  32. blown QM hydraulic release bearing?
  33. Engine question
  34. blew up my turbo ...
  35. Idling drops drastically once turn on head lamps.
  36. Evo 8 turbo problems!
  37. How much about to deck a head?!
  38. question on 4g64 swap
  39. GSC S3 Cam Card
  40. idle jumped up to 2500rpm ??
  41. Reverse Gear Lockout..any ideas?
  42. Evo 8 vs Evo 9 turbo
  43. relay ??
  44. Oil leak from head gasket
  45. Odd clutch engagement "whine".
  46. White cup looking thing on Transfer Case
  47. Urgent help! Fitment of front pipes
  48. Centric master cylinder
  49. stock turbo 11psi question Yes another
  50. just installed cams and....
  51. Evo 3 Cyl head serious probs
  52. 2.1L headgasket?
  53. EVO IV Boost cut fuel cut???
  54. Tune has gone almost 1 full point more lean?!
  55. Back up to stock.
  56. Neutral Clutch Engage=Creep Forward
  57. AMS F1-I install help plz
  58. Thoughts, Opinions...
  59. How hard to replace wastegate actuator?
  60. MAF Cleaning...CRC MAF Cleaner
  61. How to adjust cam gears?
  62. where to find omni 4 bar scaling for AEM EMS?
  63. Fuel Line fitting question
  64. cosworth head gasket over 40psi??
  65. BR double pumpers....
  66. Transmission removal
  67. Knock, Knock...Who's there? Your Engine mother******
  68. Need help
  69. Random Jump in Idle to 3k
  70. how much whp till double pumper is needed
  71. IM & TB removal
  72. is it worth the risk of buying a used twin disc to rebuild?
  73. Overboosted lifted head....
  74. EVO VIII or EVO IX gears?
  75. 2.1 or 2.4 long rod, looking for decent spool with streetable power
  76. lancer trans in evo
  77. What does a 6 Bolts & 7 Bolts on an Evo Mean?
  78. FIC injector seals
  79. Exedy Twin, Awful Drivetrain Noise (probably bad TOB). Video Inside.
  80. Help Request / AEM Intake Install / Pics
  81. Aftermarket center differential = ACD delete?
  82. Weird Noise.
  83. Quarter master twin owners
  84. mishimoto tstat + Rad = too cold engine
  85. Guru's Oil Help Please
  86. Bbk-b!
  87. Hydralic lifter pumps up after backfire?
  88. Supertech Valves for sale
  89. Sard r2d2
  90. Billet 6765 surging ?!?!
  91. Engine Smoking: Determining the culprit....
  92. Difference in the fp red
  93. WG spring question
  94. Is this a problem? Grease coming from rear axel
  95. Any difference between 03/04 wiring harness vs 05?
  96. Half radiator in summer??
  97. Water in Catch Can Normal?
  98. AC/Heat = Stalled Engine
  99. Evo 8-9 rear axles. Longer is passenger?
  100. Angled shifter extension: wtf
  101. Another Vibration Post
  102. Evo 9 Fueling Setup (~600-700awhp)
  103. Thinking of changing out my buschur exhaust
  104. Need advice on 02 dump???
  105. Evo 8 head porting
  106. can somebody help go shopping for me?
  107. exhaust manifold testing
  108. This looks wrong
  109. Problem with boost. 25 psi donw to 18 psi...
  110. Finally back together, ran fine, now runs lean. Why?
  111. build parts finally arrived
  112. What gauge is this? AF and boost on one gauge at the same time vid inside
  113. Aftermarket cam sensor
  114. PTE Injector Fitment ??
  115. Swapping an 03 (non-ACD) trans into a IX MR?
  116. throwout bearing failure question
  117. Need Specs: Long Rod 2.0 Build
  118. Oil surge on drag launch
  119. Need help deciding
  120. ID1000cc vs ID2000cc spray pattern diff?
  121. Evo 9 Overboosting Help
  122. Who's running the new HKS Cams 274 278
  123. strengthen trans case
  124. Older Evo Brake Master Cylinder Problem.
  125. late spool on a 50 trim (help)
  126. Evo ix mas
  127. clutch maybe going or normal?
  128. Question on the ACD Tranny ecu
  129. Trans help!
  130. evo sat for 3 years
  131. Double Pumper Impressions and ?'s
  132. My Set up and goals.. advice please?
  133. In Cabin MBC help/question.
  134. checking the head on a blown motor
  135. MAPerformance one piece o2/downpipe qstn
  136. How to idenify stock mivec cams
  137. Tomei Expreme 02 and downpipe - gains over stock
  138. speed sensor
  139. Tranny issue, high rpm lock out
  140. fullrace manifold with non hta 35r.86
  141. Boost leak or controller problem ?
  142. Carbonetics Twin, who runs it? AMS Push Exedy?
  143. quick question! transfer case drain plug gasket
  144. MIVEC versus non-MIVEC dyno charts (stock/mild mods)?
  145. evo9 only running on cyl1
  146. i have big lumps on my sticks!
  147. New BOV sound
  148. Another "what is this sound" thread
  149. Forge wastegate a worthy upgrade?
  150. Noticed theres two coolant holes in the oem head gasket that arent drilled out??
  151. Loosing power. What's wrong?
  152. 2.1 L gasket kit?
  153. engine ticking after warmup
  154. where to buy throw out bearing, part number
  155. how many people are still making over 500whp on the stock block??
  156. +Winter Project+ Best Way To Spend 4-6k?
  157. Rattling noise after cold start?
  158. A choice of two clutches
  159. 500 whp FP Black setup -- upgrade intake man or exhaust man next?
  160. MAP-o2-housing question
  161. FP-Black and stock 6-Spd......will it blend?
  162. 6262 build help please
  163. brake booster vaccume line help
  164. Completed built 2.0 long rod but having problem
  165. Comparison thread for HTA 3586 w/.63 ar and HTA 3586 w/.82 ar
  166. Fuel rail and regulator?
  167. What might happened to my Turbosmart Dual-Port BOV???
  168. where is the ACD fluid resevoir on an 06 mr
  169. Humming noise between 70 and 80 mph
  170. Random knocking problem...for 2 years :(
  171. AWD Computer
  172. Need some advice on my balance/timing belt tention
  173. dear vendors.....
  174. Am I missing anything?
  175. need timing belt help quick question
  176. Buschur/Ebay o2 housing
  177. Engine 8.5:1 compared to 9.0:1
  178. ETS Limited Edition Titanium Short Route Piping Kit!
  179. 7 bolts 4g63... all the same?
  180. Squeaking clutch?
  181. Strange temperature issues after thermostat change
  182. EFR match bot
  183. Coolant thermostats/housings CP9A vs CT9A .
  184. Stock Frame Turbo Owners.. Step up and NAME your Turbo!!!!
  185. Wiseco, Manley, CP pistons?
  186. ETS T3 manifold, Holset HX35, Tial 38mm wastegate - Will part out
  187. Looking to get back into the game
  188. Is This a Good Port Job?
  189. no power to coilpacks...no bad fuses
  190. bad crankshaft position sensor?
  191. ECU swap VIII to III
  192. Another clutch quest.....
  193. What injector duty cycles are you guys seeing with fic 1450cc on 93 pump only at 650
  194. Blowing Radiator Cap?
  195. please help!
  196. Turbo coolant line help
  197. Evo 4 Crank Walk victim...Opinions
  198. Turbo Spooling VERY slow.
  199. engine misfire
  200. Engine teardown and rebuild help
  201. Crankshaft position sensor question
  202. How to destroy an MR 6-speed (video inside)
  203. Just installed a bigger FMIC and IC Pipes and now the car is slower :(
  204. Change Rear Axle Boot
  205. GTII 7460 on 100 Octane Fuel
  206. NGK BR8EIX Iridium - gap
  207. clipping stock turbo? ? ?
  208. Odd temp issue
  209. best/fastest Intake Air Sensor?
  210. Where to buy throw out bearing
  211. Help with Identifying Noise!!! ***Video***
  212. Are all 3" downpipes the same???
  213. Fuel options
  214. Mivec related
  215. Need ideas, car won't run right
  216. fp black turbo
  217. Evo 8 best clutch kit
  218. what's the best oil for race engine?
  219. hks evc 6
  220. blown turbo or engine ???
  221. O2 Housing with No Divider wall. Better?
  222. Stock rebuild or built?
  223. what to change along with timing belt ??
  224. head gasket or something else?
  225. cracked head, block , or bad head gasket?
  226. evo7 engine replacement
  227. ams rebuild kits?
  228. Anyone seen/used this anti surge evo 9 turbo?
  229. My car needs a Diet
  230. I just ordered a 2.1l oil question?
  231. Which Clutch/flywheel combo would you guys recommend?
  232. cam install south chicagoland area?
  233. bolt on
  234. Evo wont start
  235. fuel issue
  236. WG flutter...(video)
  237. Where to buy wedge collar???
  238. metal vs. silicone intake tubes?
  239. Car stalls after omni 4 bar install
  240. Lots of Uh-Oh noises from rear end
  241. Exhaust baffles
  242. Which better e85 or Aquamist HFS-5?
  243. Engine wiring harness disassembly
  244. Fidanza 4.3 question
  245. ignition question
  246. whats pistons and rods should i get for a 2.0 built?
  247. White residue in intake
  248. play in power steering pump
  249. Exedy Triple Disc Clutch
  250. Evosick2332 2011 "Junk Box" Build in Effect!!
