- evo8 turbo compressor wheel
- downpipe clearance question?
- what clutch
- pill for 27psi
- Odd smell from AC?
- Need help with powersteering hose removal
- CRACK!! What to do
- Rod Knock? Need help please!
- Clutch VIII Posted in wrong forum...
- Prototyping 8MR UICP: Looking for input
- New o2 sensor and still codes????????
- Tanabe Concept G Blue?
- Replacing o2 sensor
- The quest for more speed, further improvement of the aero.
- What Are the Drivetrain's TQ/HP Limits
- forge wastegate actuator boost problemsh HELP
- Lancer evo stock turbos
- Need help with a couple motor issues.
- REALLY HAPPY with my results.
- Rough Startup
- !!! Short Shifter & Bushings & Motormounts!!!
- Evo 8 no power?
- fuel pump question
- rear diff question
- act clutches
- 2.3L Info Thread... Any one with a 2.3 please chime in!!!
- MY 2.3L/3076R Build. (56k....haha)
- clutch makes loud growling metal spinning sound
- Piston choice
- FP Red =]
- P.R. GT35r presicion 628hp@ 35psi
- Out with the Green in w/the Red, Kelfords & porting! NEW VIDEO ADDED!!
- leak in differential sys.
- Calling all AWDmotorsports Manifolds....
- 9 & 10 Second cars --Drivetrain??'s
- Please help with brand new slipping clutch!!!
- Engine light is on after cam install
- FPred vs FPgreen on 91 octane
- resonator removal / test pipe fitment
- Front uniwersal 02 sensor wires
- help plzzz
- Ic pipe size question
- FP Evo Red 1st. Dyno Testing Done, numbers and pictures.
- transmission drop??!?!?!?!
- Transmission fluid Overflow Tube
- FIC injectors: Am I being paranoid?
- @ 60K what next:(
- Evo Green Dyno Results
- help with clutch line issue
- supporting mods need w 3076r turbo
- Looking for a licp, which one?
- Fuel filter?
- AMS does it again... 2.3RR 850R 560whp on 92oct!!!
- Need Help on MAP Sensor
- 9sec9/OKIX's EVO, Red build, racing and VIDEO
- Boost problems. Will not see past 0psi
- balance shaft
- slight hum on deceleration.
- Red fluid in my airbox????
- In-tank fuel pump options for evo's?
- Need help, Fuel Rail and Injectors
- ecu code on my evo p0170
- Help With start up issue
- Check Engine Light out of no where?! Please Help!
- green to red
- Stock return line please look.
- Weird humming/howling starting at 3k rpm's
- transfer case
- Help me finish my FP Red setup
- Clutch Line Thread Size
- Test pipe gains??
- Thank you!
- trust-greddy???
- Im Doing Cams and "Maintainence"...I got a few questions
- NEED HELP car problems
- How much power can i hit???
- vwjeffs big adventure with the 37R
- fp red vs gt30r
- What do the seatbelt bolts get torqued to?
- FP RED 93 vs 100oct
- still having weird boost problems, same thing for about 3 years.
- Which invidia testpipe?
- oil feed banjo bolt
- Deciding between the 35R and 37R
- wastegate problems??
- Perrin Ebc
- Suman's Revenge - Part II - PT62/62 - 679 whp on pump
- Stage IV Evo 8 with FP Red 408 Pump - 509 Race whp
- Oxygen Sensor ...OEM or Universal
- Can i hit 500awhp?
- Which cams/valvetrain is this?
- rough idle
- help o2 bolt size pitch can't search on phone
- Pin retainers... OH MY GOD!
- lookin for options
- What is the procedure for measuring exhaust sound (decibels)??
- future plans
- New Parts, Car wont start... Help
- built shep 5sp only goes 98-97 @ 7k in 4th?
- AFI on the car!!
- Exhaust Manifold Upgrade?
- [Problem] Louder turbo, and smell.
- DD AMS 42R? Is anyone doing this? ANY 42R.
- Tranny Experts needed, Wierd issue after track night?!?!
- Drag Racing 2nd gear lockout
- kelford 272s w/ stock springs?
- ACD repair
- EVO8 piston/rod specs
- Help Me Decide...
- tilton twin installed, noises normal??
- Turbo install how many hours did it take you?
- oil from downpipe after FP green install?
- stock clutch go bye bye
- boost flutter
- Full Bolton Evo 8, What am i missing?
- (BR37r) My Plans, but no idea where to start
- FP RED dispelling twin scroll myths.
- What manifold is this?
- 344whp and 368wtq on stock 8 turbo
- Hi everyone, first post.....radiator help!
- silver`s engine damper ???????????
- Evo 7 map sensor
- Weird thing happened today
- help! my evo's running terrible
- noob question, wastegate control
- FULL FUNCTION's first car to be tuned on E-85 / 40R / 2.1L
- Backpressure Ratios?
- add 5-7* timing = no difference?
- AMS 2.3RR GT850R CNC Race head Test!!!
- What Piping?
- Spanish 4G63 tuner!!
- 2.3 850r Pump Gas 530whp/462ftlbs
- HELP!!! OIL Leak
- greddy Ti and DC downpipe issue...
- 4G63T MIVEC Race Engine Build
- Help diagnosing issue
- CBRD/Kreionic/ETS
- badly in need of help. please read
- Question??? Help!
- 2.4 4g64
- VIII and IX axles
- help Help Help
- Anyone Running EvoRed + 2.3L Stroker?
- just got my car tune but the everytime boost 26 my service light starts blinking??
- need someones opinion
- FP Green on a 2.2 Stroker
- FP Green vs FP Red Dyno Results and Review (from my perspective)
- The World's Fastest EVO 221 MPH in-car video
- Engine Oil Analysis
- Synapse BOV install problem in stock Evo9
- How Can I Get More Power Without a Turbo Upgrade???
- Are the under-the-hood shifter bushing and the center console ones the same?
- evo 7 manifold
- What octane would you run at 26psi?
- evo green spark plugs
- no boost after hallman install, help plz!
- Clutch slipping
- Suggestion on my final mods list and build up
- Knock at 2step?
- Who's running BF 272's in a stroker?
- Another Bad Misfire Thread!! Please Help
- Help urgent! Car makes really wierd noise.
- turbo + water lines
- Kelford 272's - Evo 8
- Lightened Flywheel Info
- Open Exhaust
- Need suggestions on these mods
- Broken 2nd gear comfirmation.
- Stock Radiator Cooling Fan
- Cobb turbo back installed! (pics)
- same OEM flywheel on 5 and 6 speed?
- Are Evo 8 & 9 rear diffs interchangeable?
- Mitsubishi Turbo Nomenclature
- wierd clicking noise...help!
- something is wrong
- Do I really need a tune?
- Red on 03 50k few mods
- Why is SBR stroker kit so cheap?
- What are the stock IX cams good for? 50 trim?
- Help me please slipping clutch problem!!!
- cylinder missfire
- 3076 turbo kit
- Exedy twin plate?
- Oil light and temperature
- ams dnp buschur manifold with A/C
- Less than 5 miles on a new rebuilt tranny and look what comes out!
- Head rattle/tap help
- Timing Curves for 30psi on pump
- Leak from between t-cas and trans
- Are HKS Cams stamped with HKS lettering?
- AMS UICP And Mini Battery Questions
- i need a turbo!!
- o2 bolts
- E85 budget track motor build
- P0300 on Evo IX after HKS 272 intake cam install.
- sudden loss of boost
- whats going on with my plugs?
- Am I the first to buy a USED evoRED??
- Front Fender Splash Shield Clips? Where to buy?
- how do you remove the philips head clip
- Need advice on mods
- 610awhp@32psi.. E-85
- I'm Giving Up! Help!
- NOS Anyone?
- Should I turn my boost down?
- Green Turbo install tip
- What should be next.
- Switching BOV's
- need help i think i blew up ?
- HVAC problems....
- boost .... help plz
- overheating issue
- After reinstall TPS sensor, it reads 98.823 at WOT. Need help
- 6 speed 4th gear grind
- 637whp @ 30 PSI (video inside!)
- FP Red installed and running!
- Fuel/air ratio
- help plz
- HELP!Wont Hit 1 PSI of boost
- Help!wont hit 1 PSI of boost
- Help removing HKS BoV from UICP
- Exhaust, test pipe, and downpipe... safe AFR's???/
- Is my car underpowered?
- wierd place for boost leak or no?
- TPS is at 98.823 under WOT???
- Car Won't Start!
- Wierd issue With CEL
- Mike Reichen clinched new standing mile records for Maxton
- Quartermaster Twin Clutch Information Please?
- I know this has been asked... Greddy Type RS
- transmission problem....need help
- fuel pressure gauge question
- any one try this act clutch? i just got it and its getting put on wed
- Need engine diagnosis help.
- Broken timing belt tool... EMERGENCY!!!!
- AFI Twin Scroll 3076 Dyno part 1
- URGENT HELP!! quartermaster twin disk
- transmission warranty voided by FMIC?
- Please look at pics. 35r bent turbine fin (barely)
- Intercooler End Tank Design/Theory
- Intercooler, Piping...
- Two issues, please help!
- Building my shortblock.
- Need exhaust help
- Prosport oil pressure sender leeaks!?! HELP :-(
- best way to drive with no tune?
- o2 housing causing severe boost taper?
- Stock intake hose flying off all the time!!!@!@!*@7!*@
- spun main bearings what to do
