PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 [170] 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Need MAP sensor logs of a MBC
  2. 2.4 Brian Crower stroker with horsepower freaks 35rkit and 67mm wheel
  3. Gt32?
  4. Got fuel??
  5. Does Your Turbo Surge??
  6. Upgrade Front mount
  7. David Buschur's switch to the "big" turbo....
  8. Guess my AWHP (answer posted mid OCT)
  9. Do i torque down the spring bolts all the way on the DP ?
  10. Ceramic coat my header/exhaust manifold?
  11. Clutches for the $...
  12. evo8 5 speed gearbox - noises - what commonly fails ?
  13. 2005 MR 6 Speed and engine into 2003 EVOLUTION 8. drive train questions.
  14. cutout problem when boost builds????
  15. Blow-off Valve suggestions
  16. Cooler days and nights= more boost
  17. help!! I think i'm boosting too mucy.
  18. pssh sound when depressing clutch?
  19. How does our turbo vac system work?
  20. BMC Air Filter?
  21. 2.3 Evo IX mr
  22. HELP - Intake hose keeps popping off
  23. Exedy Twin cerametallic weight
  24. Methanol's affect on AFR readings
  25. IC pipes or sewer pipes? You decide!
  26. Accessory belt jumping a groove
  27. Inj. ID. Are these 560cc's?
  28. Spark plug question.
  29. Boost limits and failure rates
  30. Anyone has feedback on EVO IX WR turbo?
  31. BOV or what?
  32. Is a reflash needed for a bigger...
  33. quick ? need a reply asap!!! please.
  34. The notchy tranny feel
  35. Stripped Exhaust Manifold Studs...
  36. Thermal coated exhaust parts (pics)
  37. best evo IX MR exhaust
  38. left front tire coated with black substance
  39. What did you run your oil catch can lines too?
  40. Need some 101 class on 20gTME9
  41. Anyone have the exhaust port exit dimensions on their Evo VIII head?
  42. A little too much oil.
  43. Variable Clutch Engagement
  44. Lack of 6 speed short shifter in the market?
  45. Wiring Harness
  46. ACT Clutch and what happened..... :-/
  47. Had a spec stage 3 (6 puck disk) installed, will it get easier to drive?
  48. My new IX MPFab Front Mount - PICS
  49. 6 Exhaust Systems compared
  50. UR Testpipe problem.
  51. Cam install please help.....
  52. Cannot tell if I have cams.....Help
  53. I did a boost leak test...
  54. engine troubleshoot help
  55. EVO MR 6spd - 4th gear size
  56. GSC 272s best price?
  57. average clutch times?
  58. tial wastegate on stock turbo
  59. Official torque specs thread
  60. cam install q!!!
  61. Anyone use hks rs intake with bigger turbo
  62. IX Intake Cam more aggressive than VIII!
  63. ATP GT3076R - Impressions
  64. HKS Carbon-Ti T.B.E. Idle (video/sound)
  65. Had compression test done - numbers...
  66. SS Clutch Line Help.
  67. AMS 2.3 & 35R multi-gear spool-up data with Zeitronix
  68. buschur 35r with meth results
  69. Possible boost control solenoid problem?
  70. Numbers Too Low?
  71. Turbo Timer Help
  72. Anyone done headwork on the IX head Porting ect?
  73. New FMIC, boost spike is higher, redline boost is lower
  74. Valve cover torque specs??????
  75. Do I need to replace my exhaust manifold gasket????
  76. torque spec question
  77. Mbc Vs Elec Boost Control
  78. Noob Question, sorry but searching is getting me no where
  79. Since Revolver is taking FOREVER...what are the next best cams?
  80. T case fill and flush holes.
  81. help me out here!
  82. Check out my new cupholder
  83. Valvetrain to use with Tomei 280 procams?
  84. guru's i need help rebuilding
  85. junkyards for evo motors and trannys
  86. has anyone used apexi ps cat back exhaust???
  87. Please Diagnos - Power loss at WOT in high RPM's
  88. which hiflow cat?
  89. Who sells Evo IX TME turbo ?
  90. clutch problem
  91. Evo will not boost, and wants to cut out. Any ideas?
  92. Just installed the Green filters cone....
  93. Need CEL fix ASAP!
  94. Best Exedy Price
  95. HKS SSQV bov coming off intercooler pipe
  96. 2 weeks to make a decision/bolt on turbo/subject covered to death/help
  97. building a 2.3 or 2.4 stroker
  98. Oil Pressure Sensor Location?
  99. Evo 6.5 Air Flow Meter on Evo 1
  100. Which turbo????????????
  101. Magnus Vs Carillo
  102. Greddy RS BOV
  103. what clutch do you recommend
  104. prosport vs. autometer boost gauge!
  105. HKS RS intake tight fit?
  106. when should i get a tune??
  107. HKS RS Reloaded, Not holdin 1.5 bar, also mountin issues
  108. broken stud on fuel pump retaining black ring how to fix?
  109. EVO 9 Boost taper after MBC install
  110. Manifold / 02 Housing
  111. I need some stock pistons (evo 8-9)
  112. Going crazy!!!!!!
  113. Driveshaft hitting exhaust resonator
  114. My Evo Ix And Meth.
  115. Timing belt options
  116. My 42r kit being built by Peakboost
  117. whats the most reliable manifold that can last a nice 4 hours of racing hard?
  118. Clutch feels different after brake bedding
  119. camshaft crower 280/280
  120. Max boost on IX without tuning
  121. Custom Turbo kit plans. Opinions?
  122. boost getting stuck from 1.5 to 0.5, help!
  123. 3.5" Exhaust/Mufflers, choices?
  124. alchy max boost
  125. Hooked up Hallman Pro RX and Boost gauge, then EVO Scaned!
  126. Need to bleed clutch again!???
  127. Coolent boiling????
  128. Cam install issue
  129. evo 9 trans in a evo 8???
  130. stock evo 8 turbo
  131. Cost of shortblock
  132. bov
  133. Doing your own Tranny rebuild...
  134. Where to flow test an intercooler?
  135. UICP Hitting Fan
  136. Tracking down a noise
  137. electronic cutout?
  138. Koyo racing radiator: where did you mount fan controller?
  139. Serious Problem,,,please help
  140. Question about stock IX turbo?
  141. Redline lightweight shockproof ok for tranny ?
  142. T04 3" Discharge Gasket
  143. URGENT HELP NEEDED: Transmission Compatibility question...
  144. Weird sound coming from pulley and belts
  145. Benchmark This Settup Vs. The 1/4 Mile Time So Far Achieved
  146. Question About ( Boost Levels )
  147. Down pipe install?
  148. Have you replaced your coil on plug boots?
  149. Funny Rattling Noise
  150. intake without tune safe?
  151. Evo9 hard pipe kits
  152. Buschur Injector reliability
  153. HELP!!..Forge Unos MBC
  154. aem uego in test pipe bung?
  155. High idle
  156. Need Help before install
  157. tore an o-ring! (what size to replace)
  158. Shearer Turbo kit??
  159. 60k Mile Service, some questions
  160. Pause in 3rd gear. Clutch?
  161. ATP 3071R and supporting mods for 400whp
  162. how many using the ATI Super Damper??
  163. clunck noise when down shifting
  164. Fluidampr balancer
  165. 3076R turbo 780cc injectors
  166. Hallman Pro RX install & test VS Forge
  167. adjusting tilton clutch
  168. Help Needed Strange Sound.
  169. Does the gt35r or the 37 kit fit the evo 9?
  170. I searched, UICP make BOV loud?
  171. where can i find a 9 WGA?
  172. put stock airbox back in now car wont boost past 12 psi
  173. Motor mount vs. torque damper review
  174. Full Race gt37 turbo kit... Our install
  175. 720cc injectors, how much whp?
  176. Cam comparison, highest hp yeilding/ better spool?!
  177. Act Clutch Problem
  178. 5 speed vs. 6 speed
  179. Whats wrong with my car?
  180. Revolver cam gear settings???
  181. Question About This Turbo Pic...
  182. Can Boost Change on its own
  183. car runs with no keys???
  184. GM blow-through & UICP - where can I get one?!?!?!?
  185. bb oil feed vs standard bearing oil feed???
  186. Intake manifold explosion! Alcohol possible cause?
  187. exedy twin users...
  188. High frequency vibration post timing belt/ balancer belt/ cam gear install
  189. Raise the fuel pressure
  190. Clicking noise from driveline at very light throttle.
  191. Which turbo kit will you buy??
  192. map sensor w/bov to atmosphere
  193. Drive Belt Tensioner Movemnt?
  194. 2nd gear trouble
  195. Question about ( Hp&Tq ) On Stock Motor
  196. tranny leaking at driver side axle after clutch install....
  197. Most WHP out of a 3076R?
  198. exedy twin issues ??
  199. Installing O2 housing
  200. Problems, needs answers please
  201. Installed a catback...
  202. Electronic boost controller questions
  203. Weird Voltage Fluctuation Under Boost?
  204. EVO won't start, wiring harness issues...
  205. Question about boost comtroller
  206. HKS cams changing shape?
  207. JDM Evo 8 vs JDM evo8 MR Turbo??
  208. installed a 10.5 hotside from gruppe-s today and had a strange problem
  209. What's wrong with my car??
  210. boost on stock turbo
  211. INjen LICP?? about the coupler
  212. GSC Cams: How many IX owners plan to purchase?
  213. Dual fuel rail and 8 injectors ?
  214. Shifter/Slave cylinder mod **WOW**
  215. Tranni internals???
  216. Tranny noise or am I just paranoid?
  217. T3/T4 turbo setups
  218. NEED HELP (cam question)
  219. Help Figuring Out a Possible Problem
  220. Tons of oil smoke after boost! Blown Turbo??
  221. Help: Engine Light on because of BOV
  222. HKS 272 cam timing
  223. my DIY Ebay O2 housing bracket
  224. coated turbine housing
  225. Boost shuts down on highway
  226. GT35 ... Antisurge Housing? Questions
  227. boost question?
  228. cat back: Magnaflow vs. Apexi NOIR
  229. The "Clunk" in the "tunnel", my observations/troubles.
  230. Stainless steel clutchline- any reason to buy an expensive one?
  231. What direction should I take now??
  232. will mitsu void this...
  233. 35r boost tester?
  234. cold air intake question
  235. NEED HELP (msd)
  236. Overheating / AC issues
  237. 04 Evo rs 10.5 hotside yes or no
  238. Adjustable Wastegate
  239. What is this part called?
  240. Whistling Sound?
  241. revolvers on just a flash?
  242. So Pretty! + A question...
  243. Evo 9 clutch question
  244. Some help please
  245. P0335 and not cranking.
  246. valve question
  247. JUN Cams and the stock valvetrain
  248. !!!Slipping clutch!!!!!
  249. con shape air filter without changing stock inlet hose
  250. Tuneing The Exhuast Cut Out!
