PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 [245] 246 247 248 249 250 251
  1. Tuning the S-afc II
  2. HKS TT type 1 turbo timer or Blitz DTT DC2?
  3. rmr intake, please look
  4. Differences between S-AFC and S-AFC II
  5. Odd Blitz DTT things
  6. Lancer Evo Oils
  7. Beefing up an Evo 8
  8. Toda Stroker Kit
  9. where to hide emanage in evo
  10. fuel system cleaners
  11. MBC vs EBC
  12. Engine Management Mounting Location
  13. Cusco diffs
  14. Buschur Exhaust recall!
  15. Power Steering Pump Whine?
  16. Please help! S-AFC II settings ......
  17. Adding more mods without dyno tuning?
  18. best intake for evo
  19. Would this fit our cars
  20. Twin disk clutch inertia
  21. how similiar are DSM clutch & flywheels to the EVO?
  22. are we stuck?
  23. Reputable repair experts
  24. Problems after installation. need advice
  25. intake high temp input code???
  26. blitz timer advise
  27. Amazing Engine Tech.. and it's real Check it Out!
  28. Forge Recr BOV w/ Filter
  29. changing clutch
  30. Tips on wire tapping?
  31. Easy Break-In of New Engine NOT a Good Idea?
  32. Clutch problems raise your hand!!!
  33. RMR 3" Air Intake system
  34. EGT gauge
  35. lambdalink & knocklink
  36. Turbo Timer ?
  37. Bigger intercooler on stock EVO
  38. Tranny Rebuild/Clutch Replacement
  39. works brain flash, throttle body, exhale
  40. Silicon vacuum hoses
  41. Buzzing/grinding noise on deceleration? PLEASE HELP?!
  42. SAFC2 - lets share knowledge
  43. Highest Boost on Stock Motor?
  44. lower stock bov hose
  45. boost controler for evo 8
  46. Possibility of electroplating my grounding kit???
  47. Recommended Intake for Evo 8
  48. Which one?
  49. upsetting problems wit my evo.. please read
  50. Profec EBC problem
  51. Windsheild washer not working
  52. Nitrous Intercooler Chiller
  53. usdm evo tranny same as jdm
  54. Hks Evc Install Help
  55. Turbo Timer
  56. Just some Filter and Intake info
  57. Check you wheel bearings
  58. JIC exhaust manifold and downpipe questions
  59. Need Help With S-AFC II
  60. Irratic idle on AFR, Which wire did YOU tap?
  61. washer fluid reservoir/burning rubber smell
  62. pictures of evo 4-7 pistons and rods
  63. Bolts unaligned in engine bay
  64. My evo feels slow
  65. apexi s-afc II and Blow off valve quetion
  66. Went to Dyno today -- AFR programmed
  67. Looking for a new exhaust
  68. Who Got A Clutch
  69. New Tranny/gearbox Noise
  70. Solution for Driverside whistling
  71. Is this a clutch problem
  72. Updated Forge Recirc Piston
  73. I need an exhaust that does not sound like a weedeater...
  74. Boost Control Solenoid restrictor
  75. rs-r Exhaust
  76. possible group buy on excedy twin disks
  77. Good Stand Alone Engine Management?
  78. Stupid Boost Controller Question...
  79. Evo newbie boost control question
  80. Titanium Retainers
  81. I need real tech on ALS. Only the most knowlegable please.
  82. Moving the intercooler fluid resevoir?
  83. Apexi and HKS
  84. AC questions, Stalling issues, and RPMs dropping problems, need feedback please read
  85. intercooler sprayer (Merged)
  86. anyone got pics of the HKS EVC V in their car?
  87. Turbo timers... hype or necessity?
  88. Evc Install
  89. Check Enginge Light
  90. AMS exhuast video clip...
  91. Wide Band Oxygen Sensor
  92. Question about Buschur Intake w/ MAS Piping?
  93. Stock Exhaust manifold and turbo
  94. Turbo timer, fans not running when key out
  95. Anyone know how 2 do this? (timer inst)
  96. Huge gains from Cat Deletion
  97. Toda racing
  98. Noise from underside of car
  99. buschur air filter........ works ecu flash
  100. Mod Challenge
  101. Heatshield touchup/rust
  102. 2nd Gear Grinding
  103. Does anyone know the inlet size for our stock mufflers?
  104. JDM Evo 8 6 speed gearbox recall
  105. Do i need to get the tuning kit
  106. Q about Buschur 3" MANDREL BENT SS CATBACK
  107. Major diff between BALL bearin and TWIN SCROLL
  108. HKS EVC V or Apexi AVC-R?
  109. Anyone running the Apexi AVC-R
  110. Installed RMR intake (Holy crap this is loud)
  111. will eclipse turbo 272 cams fit evo?
  112. Clutch Bearing
  113. Cost of USDM EVO 8 crate motor from dealer?
  114. USDM EVO 8 differentials upgradable?
  115. Evo VIII oil consumption problem?
  116. What are problems that people are having w/ new EVO?
  117. Borla EVO Works in Progress Header and Cat-Back
  118. exhaust vibrating?
  119. Gearbox Fitting
  120. ECU change on the fly?
  121. Would this really work?
  122. Anyone use 94 Octane?
  123. AC vent
  124. Merged: JDM EVO8 6 speed transmission 4,622 cars been recalled
  125. Cams
  126. AMS EVO8 GT Turbo kit
  127. nOObie turbo question
  128. Got my AMS exhaust today...
  129. EVO air intake question
  130. Can't believe this:HELP1
  131. Forge Dump Valve cause Engine Check Light
  132. Whistle at 2500rpm
  133. Exhaust Manifold to Turbo Gasket
  134. installing a boost gauge
  135. Holly mother of cow!!!
  136. HKS Kansai Intake duct
  137. Worth It?
  138. Installed my UR TB...OMG
  139. RENN-ART grounding KIT
  140. Hesitation at 4500 rpm
  141. How many built-in sensors in EVO?
  142. another cat question
  143. The BEST clutch
  144. engine shutoff noise
  145. Spare ECU for reflash?
  146. 3" exhaust vs. stock 2.5" exhaust
  147. Whoosh!
  148. Turnkey Boost/Engine Management
  149. How is everyone's boost guage working?
  150. Data logging
  151. OBDII observations
  152. 2 bulges on the stock exhaust
  153. Replace tranny and diff fluid
  154. Stock Evo Boost Gauge reads low?
  155. Ecu Reflash & Keys Microchip
  156. Those who have boost guages that read in "BAR"
  157. Update! More News About Stalling Issues....
  158. Confused on stock hp numbers???
  159. Which exhuast would be louder
  160. Where did you install your Turbo Timer??
  161. acceleration vs. RPM
  162. Transmission and Differential Fluid Change
  163. Ayc?
  164. will the standard ECU self learn based on MAS reading?
  165. NEW EVO8 Smells...
  166. Oponions on Turbo Upgrades
  167. Need HELP QUICK> PLEASE ASAP
  168. How do you get the stock air box out.
  169. HID Headlight Height Adjustment
  170. complete exhausts
  171. Installed: RMR catback exhaust + DP
  172. Evo Gas Guage Broken?
  173. Bad clutch topic.....
  174. Will a 95-99 Eclipse Filter fit on my car!
  175. shiv - why the variance in stock hp?
  176. How similar is the HKS and Greddy harness for TT's?
  177. Easiest way to make 300bhp
  178. EVO Dyno testing (Mustang)
  179. Evo7 + 8 Muffler Flow rating
  180. Question about boost gauge?
  181. Vacuum restrictor size at turbo
  182. Quick question about HKS 2.65" DP!
  183. What's the best Turbo Timer
  184. turbo on evo
  185. First oil change check list
  186. N20 on evolution 8
  187. Weird noise after Forge BOV?
  188. Boost problem after taken out profec b
  189. SBC ID vs EVC
  190. Got my T-back from UR
  191. Instlled HKS Type 1 TT now its not working?
  192. Mitsu Gauges
  193. cooling fan on/off/on/off/on/offon/off
  194. Took my Evo to dealer today for STalling issues, everyone please read.....
  195. u need 2 settings for AFC?
  196. 3" Downpipe + catback exhaust.
  197. Shifter
  198. Clutch issue again?
  199. Max Boost on Stock EVO
  200. rmr Clutch
  201. turbo timer
  202. Problems Shifting Into 2nd @ Redline
  203. Forge Recic BOV & RMR Intake
  204. Help, running too rich!
  205. HKS Type 1 install (need help with 12 volt points)
  206. Anyone with HKS S-AFR..
  207. my evo bucks is this normal
  208. Evo VTA BOV without Stall and irratic Idle
  209. Shift Light (only)
  210. stock exhaust pipe large enough?
  211. 15w-50
  212. Shaking and minor noise idling?
  213. boost gauge parts
  214. Cat Delete Pipe
  215. Some Questions About JUN 2.2L Stroker
  216. noisy gear box??
  217. JIC EVO Exhaust
  218. Help!!!!!
  219. Older blitz SBC boost controller
  220. XEDE vs HKS EVC V & APEXI SAFC II
  221. hid adjustment
  222. Did Mitsu screw up on the clutch
  223. Question for Forge DV owners
  224. Question on CA 91 octane and Detonation
  225. upgraded turbo?? 500hp dyno...sounds funny??
  226. Need EVO8 ECU PIN DIAGRAM, tried search
  227. mitsu tech website prices
  228. White Evo and exhaust
  229. New Fuel System
  230. Does VTA BOV MAKES CAR SLOWER
  231. timers/cooling
  232. 9.77 AMS EVO video
  233. anyone actually use that inter-cooler spray?
  234. Do you have a Greddy Type-S BOV?
  235. BOV questions
  236. q's for those with boost gauge
  237. only 15-17psi of boost???
  238. Buschur AFC Setting
  239. Works reflash + Pruven axle back + MBC ??
  240. Are octane boosters bad?
  241. stand alone or piggy back ecu?
  242. tranny metal shavings question
  243. Confused...
  244. grounding/earthing mod = placebo?
  245. Help. my SAFC-II will not work
  246. Wiring question for SAFC-II
  247. grounding kit bolts?
  248. Texas Dyno Day - Results
  249. Autometer Boost Guage Not Reading Zero
  250. Difference in JDM/USDM engine config.
