- "Break-in" procedure/method for multiple new engine parts?
- JUN BL exhaust with downpipe?
- ARC intercooler info
- New Tomei Exhaust Manifold
- CAMS 264/272 or 272/272? help!!
- Boost Leak Test?
- Road Race Engineering RRE turbo kit Who has ONE???
- how much gains will i see?
- Is my motor good?
- Arizona Forced Induction 42r setup...Completed pics..
- Best Alky Kit For My IX:
- Anyone w/ a RNR GT35R Kit with more than 550 WHP?
- question about ams evo 9 package
- Help the Mechanically Disadvantaged - Acceleration Probs
- Tech question: Disk install backwards
- clutch adjustment?
- Differences in 1st and 2nd gen Magnus Intake Manifolds?
- evo 9 turbo installed in my '05 evo 8....
- megan racing dp fit ix
- Gruppe-S Prototype Manifold & 20G-6 Dyno
- Missed 2nd gear and 5th gear several times...
- popping from transmission
- Small hole in radiator fins any quick fixes?
- Boost leak question?
- slow boy stroker kit?
- Clutch failure or something else?
- Performance Guidance
- Every EVO shold have this two mods even you feel stock EVO is fast enough !
- Fuel Tank Setup
- DYNO results, can gurus chime in?
- which cams produce most power: HKS 280's VS Comp Cam 280's
- Need serious help please
- is it possible
- MBC problem help please
- 584whp/527wtq Stock ECU!
- Info on HKS Light Action Clutch
- The Purpose for ONLY having 91 Octane in certain states?
- Which Front LSD?
- Clutch mileage thread
- Perrin o2 eliminater?
- Can you apply a gt35r to a stock block?
- Need Help car wont start
- Which buschur muffler is this....
- Help-Dealer says using GL4 for entire drivetrain?
- Test Pipe Thread
- 280 cam install
- Dyno results. Evo9 Flash
- Tranny comparison DSM, EVO VIII, EVO IX and EVO MR
- GT30/GT 35r with ALKY where do you start injection?
- going to install DP spacer got ?'s
- Anyone looking to get the NEW SBR turbo kit 451awhp???
- EVO 9 ECUflash Results!!!
- Boost leak test
- Cosworth head
- For all of you that want 20G numbers...
- 3076 with .83 vs. 35r with .63
- Agency power Turbo kit tuned on EVO8
- noob spark?
- What should be next?
- MBC=Blown Engine?
- which cams for evo 8
- The latest Buschur Racing dyno test..........a wash.
- When are you guys changing out your stock plugs?
- Boost problem!!!Help!
- Suddenly my close to stock EVO runs rich...
- 2.3 Stroker!!! GT35 or gt3076????
- WHP on a 20G
- 42r's
- Wheel hop - How to eliminate it?
- Aem Random misfire
- great now what is my problem???
- Megan Testpipe flanges not alligned?
- another quick pic of my 2.1L
- clutch install problem
- Catless TBE installed w/o CEL Fix...how long is this ok for?
- What determins engine response besides rotating assembly weight?
- Exedy twin Carbon D-Core installed
- po 134 code and po 171
- What's a GOOD FMIC 'Intercooler' AIR TEMP??
- enging back mount removal?
- who's running the ss autochrome FMIC?
- Buschur Racing dyno testing brake rotors?
- GT30R .83 owners I have a question for you.
- need help fast
- Little problem..
- gm 3 bar map sensor
- Thread size/pitch question
- Timing belt.
- braking hard and clutch in ?
- Spark plugs
- Sound clips of JIC and Magnaflow TI?
- Am I running too Rich or Lean?
- Possible low/hi fuel pump relay faulty?
- AEM EMS, 50 Trim, 1000cc inj, M15 alky nozzle
- warped head, gasket what else?
- 100 octane IX boost setting
- Project CBRD MR, 2.3 liter JAM
- boost and power levels on stock motor and head
- Clutch selection?
- Need confirmation on IC/IC Pipe combination fitment.
- Please help with stalling issue
- Blew my motor!!! What to DO!!!
- tourque specs of pressure plate
- Anyone with Autometer boost guage.. Little HELP please....
- The Fuel System Thread: Stock to 1000+whp
- anyone using an exhaust cut-out on their evo IX's???
- About backpressure : intake pressure...
- So let's finally set it straight with aftermarket crank pulleys...
- Exhaust parts\info needed
- Engine Diagram Needed
- HKS vs Tial
- 27psi + BR3065 + Stock MAF = pic inside
- Turboxs FMIC installed on evo ix....
- Which Exhaust is louder?
- problem with hks tt
- Parts to rebuild Exedy Twin
- recent dyno,
- oil catch can cause engine oil leak???
- Aftermarket radiators?
- HKS DLI II Nightmare install HELP!
- Question for the guys running meth.......................
- SBR GT35R Kit - Anyone getting over 500bhp??
- Please confirm my decel noise is normal
- Boost leak help
- Tranny Problems
- Stock clutch finally done @ 51,995m
- Hks Vs. Vishnu
- ideas on twin fuel pumps????
- Rapid Boost drop cause?
- stumped on exhaust for my 9 mr
- Quick timing belt replacement Question....
- Evo Boost issue, please HELP! (i searched already)
- Agency Power Turbo Kit = AMS Kit????
- GT4088r Vs. GT4292r
- Questions for those with 2.4 motors
- tried Amsoil MTG in IX MR 6-speed
- oil squirters needed?
- Is my BOV in backwards; is it a big deal?
- Pennzoil Syncromesh
- Solutions: Broken fuel pump bolt?
- 4g92 turbo all people with knowlegede of this engine please read
- Six-Speed Short throw shifter update
- transfer case/tranny options...
- spark plugs for evo 9
- Downpipe
- Helpful Thoughs on 50trim
- 880cc with ecuflash
- ACD Problems...
- Anyone using HKS 272 cams?
- 05 clutch change
- Need some expert advise on cam timming
- Alternator problems anyone ???
- question on vacuum
- Another GT42r Evo...
- whitch turbo is better
- Peak Boost Manifold vs Full-Race Manifold...
- Stock Evo IX with intake and flash ... #'s?
- Where can I buy heat shielding?
- boost creep?
- evo ix with cams alky, front mount, etc
- Most WHP on Pump Gas 93/94 Octane
- gt35r + flash = ?
- Customised Works o2 Housing
- what manifold for pte 60 trim
- engine idle problem
- Aftermarket Intercooloer
- Anyone with Blitz SBC and Optional Harness?
- Injen Intake
- Good AFRs... Still possible to blow a motor?
- Where's all my antifreeze going??
- i need a clutch bad!!
- HKS EVC V Readings
- O2 sensor question
- Exedy Single or Stage 1 anyone?
- Stock turbo exhaust housing fitment
- How much WHP will HKS DL handle?
- build engine and gt42r for street use?
- 2 codes (need Help)
- Help please.. Car wont start after heavy rain..
- greddy profec boost problem
- out of all the EVO IX owners with upgraded FMIC, and/or LICP, who has BOOST leak?
- Any IX with JDM FMIC?
- Problem with HKS GD Pro clutch
- longer gears?
- Evo 8 Rear Mech. Diff and Axles
- Mis-Fire
- Recurculation???? (newbie)
- Broke the sensor...which is it?
- couple nitrous questions.
- IX MR exhaust manifold
- ebay store
- Greddy Type S leak
- Best engine dampener?
- weird clunk!!
- Tme-9 Rip?
- Stage II OBX Camshafts
- Fuel System
- exhaust gaskets - 3"
- broken turbo
- Quick oil pressure adaptor question
- Diverter valve tech.
- Taking off rear section only
- grinding when putting it in reverse
- mitsubishparts . net NEED HELP
- JUN b.l review
- intercooler pressure test question
- I have a problem with evo III
- turbo manifold for 4g92 for td04
- stock fluids help please
- Oil change ?
- Possible Rear Diff. Issue?
- pple with hi flow cat
- LC and bigger duration cam
- Clutch slipping again
- Question on Tanabe's Concept G Turboback
- 20g comparison
- HELP: hks resonator hitting the driveshaft
- Question about HPF 3.5 TBE.
- Blown Headgasket?
- Where to buy Diaqueen and BG synchroshift
- How Much Boost can my stock motor handle
- exedy twin not making noise anymore?
- Full boost at a higher altitude???
- hand brake center diff disconnect
- max psi for IX diverter valve
- 8 psi max on a stock ix!
- bolt-on GT35R turbo for Evo's...
- buddies bran new evo ix with "service engine light" with only 27 miles????
- Englishtown Summer Slam Race; 9.8 @148 in qualifing
- Speed Element / Full-Race GT35R 91 OCTANE DYNO
- Need Injector help FAST!
- MAF question
- Question about BOV!
- A stupid freakin question.
- Sputtering/Fuel Cut at 23PSI
- EVO 8 Repair Manual. (search down for me )
- 60,000 miles timing belt time! Advantages and Disadvantages to a OE belt?
- just installed new oem clutch...?....
- po11, oh man
- Cam Install... 2 quick questions
- Grounding Kit Results
- People in mass with upgraded turbos?
- Test pipe AFR
- Front 02 sensor shot?
- DSport Magazine Feature car search
- 03 owners, I could use some help
- Greddy Profec B Spec II Pressure Sensor Test
- mivec head on evo viii?
- Who's running Jun 272's?
