PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Good or Bad setup for FP Red?
  2. What would you do?
  3. piston ring gap?
  4. turbo outlet
  5. Car Jerking
  6. Rattling...Downpipe?
  7. wategate IDK
  8. Intercooler piping
  9. Shifting problem-can't find reverse
  10. Help changed clutch and now weird noises
  11. odd problem
  12. Disadvantages of small battery
  13. Boost issue
  14. 9:1 pistons or 10:1???
  15. Soo, doing cams + cam gears tonite...
  16. Gain 50-75 hp????
  17. Looking at thick (long lasting) clutches for 300-350 wtq.
  18. evo 9 head
  19. AMS gt37R to 950R
  20. how to wire a double pumper to run all the time?
  21. 2nd gear issue when turning
  22. Seem to have some compressor surge w/FP Black turbo
  23. Stalling issues when hot
  24. Best MIVEC cam for FP Black
  25. mani cracked!
  26. POLL: Need help choosing a turbo for my build
  27. PWR intercooler fitment on IX?
  28. Need a good tune and mechanic
  29. 5 speed case and 6 speed the same?
  30. My build Buschur 2.0 =)
  31. precisions 6235 install ????
  32. car knocks bad over 23psi.
  33. smoking blue.. help please
  34. PPI LICP/o2 dump??
  35. Which o2 housing would fit in Works DP?
  36. fuel pump
  37. No 3rd gear!
  38. Solution for boost leak at injector insulators
  39. gt3076r questions
  40. soft clutch pedal feel
  41. Ready to put motor in (lots of pictures)
  42. Running Tial BOV with stock MAF
  43. peakboost exh manifold fittment issues ..HELP
  44. not gettin fuel
  45. FP Green issues
  46. FP upgrade question
  47. Noise when throttle is off
  48. New HKS GTII 7460R Turbo
  49. acd fluid leaking help
  50. timing belt tensioner ruined?
  51. My new boost leak tester
  52. Anybody have pics of their scattershield install?
  53. Need some help, puttering under boost...
  54. fpblack set up issues *need help*
  55. Is my EPM dump okay? (pics inside)
  56. fuel economy with bigger injectors...?
  57. HHHHEEEELLLPPP!!!!! Service engine flashes
  58. Help: Changed clutch to lightweight flywheel and Comp clutch carbon ceramic button
  59. balance shafts
  60. Innovate LC-1 Wideband problems
  61. 1.8bar + black = not enough pump
  62. New Toys and back to Ivey next week! ?
  63. evo and eclipse bearing
  64. high hp guys... O ring head or the block??
  65. EVO IX not starting after cam install, yet everything checks out.
  66. AMS exhaust silencer
  67. Evo 9 type turbo on an Evo 7: what do I need?
  68. aem vs sparktech
  69. HKS TT help!
  70. check engine light?
  71. Kiggly HLA Pressure regulator, worth doing?
  72. Valve cover question??
  73. Need help identifying some things..
  74. Car falling on face when accelerating
  75. ARC Box or HKS suction kit or K&N Typhoon
  76. Best fluid for tranny w/ plated front LSD??
  77. stock crank strength
  78. Looking for quality aftermaket stock manifold
  79. ACT HDG6 owners
  80. Is a Radiator fan needed for a Thicker Radiator?
  81. Evo engine numbers
  82. ACD Fluid in the Transfer Case
  83. Does anyone sell dipstick reroute kits?
  84. Swapping clutch discs....what do you think?
  85. Garrett 4 bolt gt flange .82 on a 6765
  86. Hks t51
  87. Buscher shifter bushings..
  88. Unique Overheating issue
  89. Does anyone know if this is flanged for the stock throttle body ?
  90. idle
  91. blocking off stock oil feed line how to?
  92. At what $$ amount should I replace instead of repair an 103K mile engine?
  93. Can i get away with a walbro 255 on a gt35r setup??
  94. Cam position sensor question
  95. 60K Service Question - Idler Pulley and Crankshaft Bolt Torque
  96. Does anyone run the billet 6765 in .63 a/r? results?
  97. Spark Plugs look OK?
  98. forge bov
  99. Stock EVO IX Interooler HP Rating
  100. 5 speed tranny fluid help needed!!!!!
  101. FP Red owners please respond!!!
  102. FP Red owners please respond!!!
  103. Injen intake and IC pipe ?
  104. tests on longblock
  105. forge wga too much boost.....
  106. Odd Deceleration Issue
  107. ACT clutch, new ACT T/O bearing or go OEM?
  108. Different Reverse Gear Issue
  109. Lsd Conversion
  110. Gsc s2 idle???
  111. Single 255 pump & 1200cc MAX HP #??
  112. AEM Digital Boost Gauge vs Autometer Analog Boost Gauge
  113. AFR went up randomly, any reason?
  114. 2.3+hta gt35r .63a/r (exhaust)=fast spool?
  115. crank sensor ...
  116. Agency Power BOV Leaking Help?
  117. Exedy Twin Concerns, Help!
  118. Searching for an Titek or megan O2 housing
  119. Stock frame turbo outlet pipe size?
  120. Braided Stainless Clutch Line
  121. cel misfire
  122. Every gear locked out. trans issue/warranty
  123. o2 dump Heat VS LICP temperature
  124. MAF or SD tune ?
  125. 84mm Compressor Cover for FP Red
  126. evo 8 or 9 intake manifold the same ?
  127. my 4th gear grind when i go fast!!!Why?
  128. question about injectors
  129. Identifying a bad lifter.
  130. walbro 255lph hp or not high pressure
  131. Timing Belt Kit ?
  132. Megan FPR??
  133. Coolant leak!
  134. WTB a break...
  135. Stock Fuel Injector seal question
  136. Recomendations on spark plugs for my evo ix
  137. Max trq. made on stock muffler + midpipe
  138. Engine Swap Advise Needed
  139. h-beams and oem bearings handle big power?
  140. Compression Test today 100/120/117/118
  141. Mikey's LR2.4 MIVEC 10:1 Motor Build
  142. Rev Max
  143. evo 8 in car piston and rods install
  144. Cam testing on trouble build.
  145. some advice with FPred
  146. cam gears
  147. Problem with clutch or transmission
  148. Is this the right part I need to buy?
  149. Weird Engine problem
  150. snow meth kit
  151. Finally Found the Leak
  152. Buschur LICP to ETS 3.5" FMIC?
  153. What Air Filter are you using with your FP 84MM Intake Pipe?
  154. need to find out which wastegate actuator to run
  155. Thoughts on Used cams?
  156. Oil Change Fail?
  157. T/C oil drain pipe flange gaskets
  158. How 1 WRONG Part of a COMBINATION can RUIN the Setup!!!
  159. HKS EVC-S need help
  160. Clutch/ tranny problem
  161. Stumped on my misfire issues..
  162. 3"-3.5" ex
  163. Trany - Shifter issue - HELP
  164. Am I crazy? Mil Spec TB questions
  165. TPS uses what size bolt? Thread/pitch?
  166. Swaping internals NEED advise thanks
  167. which axle is long and which is short ??
  168. 2.4 Reliability
  169. Evo IX with FP HTA Green and GSC S2s on E85 Numbers and Video inside
  170. transmission oil
  171. For those that got MAP O2 Eliminator dump DP
  172. Has Anyone Found Replacement Driveshaft U-Joints?
  173. evo FQ meaning
  174. Stock turbo inlet size
  175. walbro fuel pump question
  176. Exedy triple disc question
  177. BBK Full + E85 = need double pumper?
  178. If you have an 02 dump off stock frame turbo please look here
  179. Can you do this??
  180. Evo9 headgasket on an evo8
  181. results from compression test and problems
  182. HeadGames max Rev?
  183. need quick advice: Tomei PonCam vs Cosworth M2
  184. Reverse grinding (unique situation though)
  185. Pics of eBay uicp please...little puzzled!
  186. 4.111 Final Drive
  187. Cometic or Oem HG??
  188. Evo 8 Clutch/Transmission Issue! Help Needed!
  189. RPM high at 2K and Slow start in the mornings
  190. Just installed the fp green hta and...
  191. AEM Oil Preasure Gauge Help
  192. Gates Timing Belt issue
  193. Serious clutch issues. Any insight or advice?
  194. Clutch type front LSD's?? Pro's & con's
  195. help! boost keep increasing after 5k+ rpm
  196. gsc s2 or kelford 272????
  197. Putting Engine In
  198. Kelford 272 and FP RED
  199. Stock Gauge (Boost,Oil Pressure,Volt) Hook Ups
  200. Building a 2.0l
  201. what spring to run in BOV??
  202. Clutchmasters Hydrolic TOB Failure
  203. Switching from HKS 272's to GSC S2's ???
  204. 5th gear grind
  205. HTA3582 Help! What Hotside????
  206. 10.88 stock engine, stock turbo mod list
  207. Power loss at high RPM
  208. Cams - 84k on the engine?
  209. fuel pump o-ring and spacer
  210. Ported Head or better cams?
  211. Just Bought Kelford 272s for my Evo IX! - Should I get Springs & Retainers?
  212. Evolution Motor/Power Issue
  213. FP Black oil filter line question
  214. Wich Turbo?
  215. Spark plug color different?
  216. clutch help
  217. clutch and launching problems???
  218. Education on Comp turbos
  219. Fuel pressure regulator, fuel rail
  220. Need advice with my front differential in transfer case
  221. Evo7 GSR Newbie here
  222. What's this engine sound? (NOW WITH VIDEO!)
  223. Electric Power steering
  224. Cosworth M2 IX cams. pass CA smog?
  225. Anyone know the PP clamping force of the Tilton Carbon??
  226. Thinking of going back to pump
  227. Twin Scroll Turbos?? Monster Spool.. FACT or FICTION???
  228. Limt of stock Intake manifold / Throttle Body and 3" TBE
  229. boomba t-body review (60mm stock adapter)
  230. aem ems/ buschur cop cdi/ no spark
  231. jdm sensor reads different than gauge
  232. EVO VII exhaust vs EVO VIII
  233. How a combustion chamber takes shape at HeadGames
  234. injectors for IX turbo
  235. Installed synapse bpv, loss of boost?
  236. 2003 e8 drivetrain question
  237. Power steering delete guys?
  238. fuel pump harness - wiring question
  239. Weirdest noise in boost
  240. Possibly heading to Cali, need some advice.
  241. oil cooler delete HELP !!
  242. need advise with transfer case
  243. Thanks to APM
  244. ACT has struck again!!!
  245. maxxed out fp red
  246. Fastest way to check timing?
  247. need input on clutches
  248. Car Jerks at WOT
  249. Ams or Buschur exhaust?
  250. transfer case is shot... Should I forget about doing mods w/rebuild?. Advice?
