- HELP! Rattle and Whine noise
- uicp issues..
- Top mount turbo with MAF sensor?
- My TC whine video
- please help
- Shockproof + Amsoil cocktail in 6-speed gearbox
- Redline Oil Vs. OEM
- Stock oil cooler?
- What supporting mod for running 35R kit w/ maf delete
- Will An OEM Evo 8 Timing Belt Fit An Evo 9?
- Read Differential of Tansfer Case?? Whining!
- Service Engine Light On
- David Buschur's BADBISH 9.6@151mph *VIDEO*
- bov problems????hepl!!
- help hks ti carbon ex.
- Is this ATS twin carbon any good?
- can sombody help me
- Timing Belt Replacement Price?
- Need Help ASAP!!!
- Invidia Turbo Outlet
- fluttering at part throttle sometimes
- DB gauge Innovate not accurate????
- LICP and FMIC compatibility
- My goal has been achieved......one very BADBISH
- I just reinstalled my intake and now my clutch is bad..
- EGR removal w/ aftermarket intake manifold
- ets intercooler fitment problems??
- What spring are you running on your Tial External Waste gate? Tial BOV?
- Serpentine belt replacement...how??
- poping sputter sounds (please read)
- Build!!! What else am I forgetting?
- T67 vs GT35R vs ETS turbo kit
- P0401
- ats or exedy
- Fidanza Cam Gears - Which direction +-
- HKS SSQV Ver. 3
- Weird noise, need HELP ASAP!!!
- transfer case when doing clutch
- i need help i cant get exhaust mani off to do turbo swap
- Serious Help w/ Timing Belt
- Clutch Problem
- Tranny Noises on my MR -- is it death whine?
- Who runs Open Dump Tube off of your external wastegate? Experiences?
- question about turbo
- Under hood shifter buashing help for MR ?
- Do HKS 280/272 cams require upgraded valvetrain?
- Erratic idle that will reset with ignition off/on, then go bad again
- Anyone ever use an ACT PP with stock disc?
- evomotos guide clutch swap need help!!!
- What's Next After You Outrun Your Walbro Drop-In??
- Car Feels incredibly slow - Can't hear Turbo Spool
- ecu cutting boost?
- Newbie ? - How to adjust Cam gear timing?
- Grinding noise when turn and slowing down
- best downpipe and turbo outlet?
- ets,ams,blitz
- TBE with test pipe only mod with no tune?
- Agency Power DP
- Drop-in replacement turbo options
- is it a 20G wheel? or a Green wheel?
- So un-decided on what I want next....
- Tranny sound at 75mph
- tranny code???
- Cams, Knocking, RPM, Oh my..
- buschur intake pipe and filter
- Grinding 2nd, some 3rd, and 5th gear.... at 13k miles
- Please help!!!Race Car)
- GT35R Spoolup Answers (part 2)
- loud noise car dies??
- ratchet shifter
- which on line shop for the 20g titanium turbo evo 9 bolt on?
- Your thoughts on this.
- greddy timing belts?
- clutch swap...
- problems
- jus frustrated about this clutch n need to vent
- gear oil spewing from some hole in tranny in left wheel well
- Anyone Running Vishnu Stage Subzero?
- 20G turbo not boosting more the 18 psi help???
- starting problem
- A discussion about fuel systems and limitations
- Over Boosting
- need new clutch soon
- trans remove
- VEI gauges?!? Anyone used these??
- EVO Green vs GT3071R
- Evo IX and BOV
- Engine break in article:
- I had a nice weekend. Here are some pics!
- HTA35R-700whp/646ft lbs......Buschur RS
- Question about acd
- anti-lag
- Threw a new code today: P0113 - Intake Air Temperature Circuit High Input
- Exedy stg1 and gruppe s flywheel review?
- just installed megan turboback
- GSC S1 cams dyno
- HKS VS. Sun Ignition modules.
- Fluids changed, now shuddering on left turns?
- Engine Startup Grind???
- down pipe on evo 9
- around What WHP am i at?
- Evo/GT35R/Stock engine?
- any experience with HBX intercoolers...
- base idle set screw (BISS)
- HTA35R drivablity
- forcefed catback exhaust?
- Are there any good electronic boost controllers?
- Okada Project Coil packs
- What are the best cam gears?
- Helix Parts
- Inconsistent shifting quality in 5-speed?
- Weird engine noise (chug-chug-chug)
- Misfire codes at idle - narrowing it down
- 20g evo9 turbo
- Apexi induction box modify
- Prostreet Cam gears - STAY AWAY -
- Buschur TBE off a VIII fit a IX????
- Anyone running a t3 stageV wheel?
- Cam Suggestions gt-35r stock 2.0
- Castrol Syntorque 75/85
- Is this clutch shot?
- Cams and Turbo question
- electronic dump valve???
- 6 spd. Tranny Tech...Gurus Look
- ??boost??
- Problem Clocking Turbo
- valentine 1
- blinder laser
- tilton vs exedy vs cusco
- how long does your Clutch Masters clutch last
- Tranny Fluid Question
- Leaking Head Gasket
- Changing stock 9 turbo to 9.8 hotside
- 350whp with good driveability (Parts list inside)
- I know this has been discussed but I"M FED UP W/ MY ACT CLUTCH!
- Worst Experience Ever... Advice???
- cobb EVO access port
- 500 + HP daily driver
- Hp/Tq Capability with these mods?
- JMF Sheet Metal Intake Manifold
- 2.4 & HTA 35R - track time + boost graph
- new head gasket
- Gear Lockout?
- Need some turbo help
- Need help with clutch
- need help on cam install
- Does anyone regret having stroker?
- Evos acting wierd an i need help :( battery problems
- 4G64 block questions
- Fuel Cell???
- New Polished rail fuel...
- Ported, Coated exhaust manifold - Beads of melted Metal??
- car idling at 10.0????
- Brad Penn Oil
- Anyone have the FP Green In Stock?
- Buschur Mustache Bar installed!!!!
- what's Evo's stock boost pressure....
- Car wont start after motor went back in
- What Injectors For A 50 Trim
- Which 30r?
- Clicking noise from the engine?
- Clutch
- TBE, MBC, stock airbox on 91 dyno
- Domestic guy needs your help
- Exedy Twin question
- cam gears on stock cams?
- hks type r
- Evo 1 rear differential
- ATP turbo kit on an IX- impressions please
- HTA & Twin-Scroll
- Whining Noise w/ Video Clip
- '03 Transfer Case Disassembly Threads??
- evo8 vs. evo9 w/g actuator differences?
- Stock fuel pressure?
- Wierd noise after cam install........
- Stock Coil Pack Pictures any one??? I REALLY need this ASAP
- Single Puck/Dual Puck Turbo???
- Happy Turbo Day Everyone!!!
- Boost
- Boost right?
- Does anyone user Borg Warner?
- stock airbox vs aftermarket intake
- Loud Popping noise in my exhaust (Backfire?) NEED HELP!! I just installed parts
- Exedy Stage 2 Cerametallic Clutch Kit
- 20G O2 Housing
- Buschur vs AMS bushings
- Turbo XS type H34 recirc valve issues
- FP's W/G actuator setting link for fp-grn?
- Buschur's new tires/wheels, going for a new best ET/MPH
- gt35r motor internal build suggestions
- boost control question
- Motec ACD Controller = AWESOME
- The Phenomenon of Lifting the Head
- need your opinion on this
- Crank sprocket & pulley wear?
- FP Green vs FQ400
- Engine problem... Please read
- buschur fp3065
- Edge racing resonated Test pipe
- My idea for the "Red" turbo
- Weight of Cams
- Working with Extreme Turbo Systems and English Racing on my goals of 8s and 1100whp.
- DSM Experts - RWD Trans
- GSC S1's or Cosworth 272?
- meth kit installed under hood?
- ACT Street Disc
- ACT Street Disc
- Install Pics of 04' VIII RS w/ Buschur Parts
- turbo
- wheres the best place to get a BARE evo 9 block?
- ix turbo or fp green
- Misfire problem
- HELP:Swaping turbo will give me gains?(video inside 12.2 in 1/4mile)
- e-01... tbe... idc! im TURNING IT UP!
- Upgrade Thoughts
- Best stock turbo replacement?
- suitable inner cv joint boot replacement
- need fast answer on tranny fluid
- what kinda leak might this be?
- JVTR Intercooler?
- Once Again......avoid Valero Gas Stations......they Are Robbing Us.
- Agency Power 50-trim
- What next?
- 264/272 HKS cam timing for best emissions results
- How to store and use E85/Ethanol
- how to get E85 near you!
- Flow comparison
- Bosch 044 Noise
- Weird Misfire
- How much boost am i able to run?
- I installed cams and ARP head studs and now I have a big oil leak.. HELP PLEASE!!!
- Please help oil leak!!!!
- Engine and turbo build need opinions
- Titanium catback heatwrap
- okay car shut off
- Propeller Shaft noise under Decelaretion??
- Well, I'm pretty sure my Tilton is slipping.
- How to turn crank to TDC?
- EGR Valve
- Getting ready to add nitrous. Have a Q
- 6,7,8, & 9 transmission?
- something's not right...
- Unknown Aftermarket Gasket
- Monster style
- Stock Plug wires
- cams and smog
- Over Dimensions on Half Size Radiator anyone help me out.
- question on the 42r
- When is it time to get intercooler?
