- weird clutch/tranny problems?
- AFI are the hardest guys in the world to get up with.
- Oil Filter part # ?
- Hot Side Question
- need help on greddy profect b spec 2
- new help on greddy boost controller
- Kelford IX Cams
- how much boost
- Is this a photo of an FP "Green" Turbo?
- cam gear timing ??
- 5th Gear Grinding
- 348WHP EVO vs. 380WHP STI...
- Does anyone know the part #s for evo 8 3rd and 4th gear?
- 4g64 block
- exedy hyper single help! how much power?
- how to adjust clutch
- help on 5th gear scrape
- June 23/24 2007–Buschur Racing 3rd Annual Mitsubishi VS Subaru Showdown
- Fuel Rail fittings...
- Exedy twin disc clutch failure
- Evo Ix Mr Need More Power ?!?!
- need evo 9 S1 cams!!!!!!!!
- removed undertray = weird idle?
- acd pump hardline
- Cam Opening/Closing on Standard JDM 8MR cams
- LSD or Coil-over's? please help me decide
- Evo IX with BPU Stage I on 93 - "real world" boost level
- Odyssey mini- battery vs: Braille?
- OBD2 "readiness" status questions for 05 EVO
- Fuel line adapter for fuel pressure gauge or fuel side of nitrous
- Evo owners with/without a catalytic convertor
- espiler dp fitment?
- IC piping pops off @ 17-18 psi?
- tiny drops of oil in coolant overflow tank?
- No check engine light after test pipe install
- cylinder head specs and repair...got questions
- 2 Problems in less than 5 min!!
- Best place to get DEFI 60mm gauges?
- need help with TurboXS intercooler install
- ??? Downpipe Work With Greddy Ti-c & Ultimate Racing Tp??? Help!!!
- Which FMIC for Evo Green 20G-9LT ?
- Issues with Greddy Ti fitment...advice welcome
- Help me diagnose..
- TC cooler
- Turbochargers.com Evo 20g upgrade
- 76mm/3 in o2 housing?
- Installing TBE and larger O2 housing...Do I NEED a tune!?
- spark plugs?
- Does anyone know how to install monster sport intercooler pipe set
- Just picked up 06 MR, Looking for Suggestions
- Shepard Trans plain and simple FTW.
- Whining noise?
- Cant boost past 10 psi Need Help
- Bad Ass GT35 R Stage IV Evo with Reflash on Dyno - Video
- Any 4094R cars in the works?
- dp touching oil pan
- best launch = cracked tranfer case
- my car cuts out
- fuel filter
- Help Installing Exedy
- It Broke!
- witch wideband?
- how to remove starter
- evo 9 turbo in an s2000?
- looking for more power ...Sugestions?
- Will a IX downpipe fit a XIII?
- What spring for Forge Evo15 dv at 23psi?
- clutch problems guys
- this totally sucks. help guys
- Found out what the sound coming from my tranny...
- is any one running this AMS turbo KIT??
- Bypassing ACD any pointers?
- Breaking in an engine.....
- Single or duel vavle springs
- Tranny Problem!
- Spark plugs for Evogreen?
- IX spark plugs
- HELP PLEASE: Strange rubbing grinding noise coming from engine bay.
- no spark :(
- Get Walbro Fuel Pump in addition?
- Anyone considered/attempted ITB's
- Check Engine Light On ( Engine Over Boost)
- who has perrin cat back ??
- Installed TestPipe Now less Boost
- Here is my new turbo kit for my Evo 9
- Car Won't Idle When Cold Keeps Stalling
- Clutch longevity
- SS Autochrome Manifold & O2 Housing
- Wideband with audible warning?
- To coat or not to coat, that is the ?
- Throttle Position Sensor
- Post Your Hp And Mods
- what goes bang first????
- having problems with the TTP Engineering DP. Please Help!!!
- Which Injectors
- Boost Tapering Help
- MR Super Diaqueen is awesome in the 5-speed GSR tranny!!!
- 20glt supporting mods
- Exhaust question
- Jun 272 or Cosworth 272 for Evo IX
- Staight 112 octane plug?
- keep GSC 280/280 mivec cams or return and wait for the S2 series
- went to mitsu dealership for tranfer case
- What is the best manifold I could use with a atp gt35r kit?
- 272/264 who has them
- injector question
- Help, I cant get the tranny out of the car
- WTF cant boost past 25 psi HELP
- Another BR 9 second EVO, this one is impressive.....
- cat length
- GT30R Turbo Kit for an 2005 Evo Mr
- Strange Gear Problem
- I think I got ripped off! Help please!
- Works air filter - Fitment on IX
- Is my clutch gone?
- Whats the easiest way to change rear motor mount??
- are all 4g63 head bolts and cam gears interchangeable?
- Getting Loose in 3rd and 4th gear !
- How do i remove 02 sensor from 02 housing?
- fuel pump
- question on twin disc hd exedy
- Evo Stock wheel hp???
- grinding in reverse
- Market for Twin Scroll/Integral gate GT30/35 Turbine housings ?
- so i put my buschur deluxe fmic on...CrOoKeD!!
- Need help. Broke something near radiator =gas and hissing noise
- CBRD and AMS Step 1: it arrives
- So i just got my Mivec S2 cams... or did i.....
- Hard shifting into 1st/2nd when my Evo is cold.
- Built 2.0
- Oil Pump
- 0 oil pressure @ idle in high altitude area
- Power Loss
- question about walbro 255 pumps
- Forced Performance Turbo
- new setup question
- Alky horror stories???
- WHY I Will Make 400awp on the EVO GREEN on PUMP!!!!!!!
- greddy type s with greddy type rs can it be done?
- thoughts on weapon R intake manifold?
- Opinions on Plastic BOV
- Check out how Nisei 1018 LICP is made in the USA
- exedy twin plate
- Target Goal 450 hp
- 4th gear gone
- oil chane up what grade?
- Tuning advice?
- Can I put the MR Super Diaqueen tranny oil in my IX GSR 5spd tranny???
- How to get the transfer case out.
- First Oil Change
- Trouble starting....help please.
- Downpipe Information Please ?!?!?!
- Max Boost IX intercooler?
- Is my Clutch Blown??
- Turbine Housing Porting?
- EVO Drivetrain Warranty Issues
- Atp kit with a dnp t3/t4 manifold?
- how to get 400whp with 20g?
- hp fuel pump vs. lp
- How's my 02 housing lookin'?
- meth before cams?
- oil light
- which clutch between 2 (look!)
- how to clean maf??????????
- Gt35r blown turbo?
- Pre-throttle body pressure for manual boost controller
- AEM EMS or electric Boost control?
- 10.5 on evo 8
- Anybody use the new FORGE piston-type WGA??
- Making a leak tester
- Evo VIII mods..
- Anyone using the new "piston-type" FORGE WGA on a IX???
- low oil pressure
- Megan racing EVO IX downpipe and turbo outlet question.
- Best turbo on PUMP GAS ?
- Help me with my Profec B Spec II!
- Ebay $300 TBE
- synchros $$$$$
- Lost clutch after 1 drag run! Need a new one!
- 2.1 stroker
- HKS 280's to GSC S1's for Evogreen
- Evo 7+ cams for Evo 6?
- transmission problem
- How to ID a FP Green
- REM ISF for transfercase?
- Cat O2 Bung Location and Where to Buy?
- Can't boost past 12 lbs! help!
- Buscher Modified Walbro Pump
- Boost issues from hell! IX still not boosting right
- My First Tune @ DSG
- what did you pay for your tcase upgrade?
- Possible to throw a code P0172 with just a Walboro FP?
- Compression problem
- 10" slim fan
- Is a catch can really necessary for the EVO?
- Problem with using continuosly an high flow pump ? (A1000)
- Problems installing Precision Injectors
- Are my 35R numbers right were they should be?
- 03 same transfer case problems as 05?
- ix mr idle.. noise?
- evo 9 intake manifold and tb same as evo 8?
- Just purchased new Evo, black exhaust fumes?
- cosworth cams not making power anymore?
- Check Out What We Got On The Dyno Today!!! Evo V +42r=nuts!!!!
- head gasket replacement costs please...
- Evo Tranny Question? Opponions please
- Where should the clutch bite?
- Specs of our stock clutch
- My new Turbo with the PPI treatment!
- bov for over 26psi
- 13.0 Afr
- Ebay O2 Boost Creep Fix!
- EvoIX w/ 03 xfercase???
- Weird feeling on my car
- Trubo XS FMIC
- buddyclub soundclip?
- ACT HDSS installed part II MORE PROBLEMS!!!
- Finally.. MPFab 35R Pump/Meth #s!
- Road Race setup???
- EGR Solenoid
- Looking for mod advice...
- green turbo upgrade
- hks gt037 turbo with which intercooler?
- Is there an easy way to tell if you have a fuel pump?
- Alright i need some help
- Clutch with soft pedal feel
- ETS behind the scenes - Our intercooler quality control process
- 2.3 liter IX running a Stock IX 16G Turbo Questions
- Need some help. What is this?
- How many of you keep your stock air box?
- 305awhp Evo shatters RS diff :(
- No Boost!!
- DP question?
- exhaust ???'s
- Problem with 2nd gear
- Put on Greddy Ti w/ stock bumper = melted
- reving to 8k safely
- im just gonna have to get a ride.....
- how long will a exedy twin last
- 4th gear issue
- Saturated Timing Belt
- vibration problem!need help!
- 50 trim Turbo only
- anyone running over 500whp with the Greddy Rspl?
- Need some serious help please....
- Oil on Plug need help!!
- Which Cams for my Setup???
- Any tricks for getting B-pipe nuts off at the stock cat??
- trouble getting into 3rd gear
- calling all destroked cars
