- OEM or Aftermarket Valves.
- Flywheel question
- Evo cutting out at high boost
- HTA 82 vs 6262 CEA DBB.
- Honeywell Dual Boost turbocharger
- Fuel Injectors/ Turbo
- TOB engagement issue
- While I'm in there :)
- Thoughts on Using a primary universal 02 Sensor.
- Help with identifying an LSD Manufacture
- Evo 9 blue smoke, oil on spark plugs!
- Can I use HKS DLi ll with my Spark Tech Non CDi COP?
- Wastegate vacuum line set up
- Main/rod bearing clearance?
- best place for an engine
- ATS Front Diffs
- Weisco pistons for 2.2 LR?
- 6466 or super 99
- 6466 Evo 8 Twin disc hd or triple?
- Piston rings
- Titek v1 02 housing diameter
- Transmission
- turbo question
- P0069 and Idle Issues on IX
- Flywheel Cover Bolts
- What plugs for stroket fp black?
- GSC vs MAP Valve Springs/Retainers set
- 2.4l butcher crank weight?
- oem evo8 piston weight?
- MAF issues plus symptoms
- Transfer Case Tail Shaft Leak? New seal, still leaking.
- 4" Speed Density intake for Stock Turbo?
- Evo 9 Mr Wont rev above 4k RPMS
- Lean idle
- idle issue with video
- Lean out issue at ~2300rpm. Ideas/experience required.
- Spotting fake Denso ignition coils for COPs
- Broke a valve Srpings, need some advice.
- evo9 mivec cams
- Which 4G64 block to use..?
- Melted No. 1 Piston Intake Side....Twice
- Orange gunk in thermostat housing
- P0335/P0340 codes.
- Trans & transfer case brace?
- bottom end build
- Evo Clutch Noise
- Help, i tried searching but all i found is a gates part #
- Transfer Case Tail Shaft Seal PN
- 2.3L Strocker on Stock turbo, hurting HP?
- Evo 8 MR rear diff ratio vs Evo 8 GSR
- Bee*R troubleshooting
- Fuel pump issues please help
- EGR Blockoff without tune?
- Front motor mount replacement
- raising redline to 8k on evo6
- Awkward Revving
- Rebuilding the exedy twin hd
- Rebuild Stock Evo IX Injectors
- stock block & cams 35R?
- another 4g64 timing question
- NSK bearing numbers pinion rear diff
- Weird fuel pressure drop
- avid motor mount help
- Driveline Binding
- Rebuild engine?
- Underdriven Oil pump gear
- mil-spec 65mm tb issue
- Am i in need of a Bigger FMIC
- Rebuilding an Exedy Twin HD
- What's this noise? With Video
- cncport.com head?
- Question about exhaust popping
- donut gasket for DP
- BR HTA35R vband turbo kit
- Calling all fault finders - Weird noise at idle
- Rough Idle?
- Injector Question
- Exedy Triple plate wearing out 450 hp evo??
- Turbo advice!
- Lightweight piston and rod setup
- WTK Differences in evo 4-7 head?
- $60 o2 housing
- Evo 9 idle dip clueless😑 (video inside)
- 10:1?
- Evo 5 speed part number???
- Clutch issues??
- 2005 MR over boost problem
- Walbro 255 Fuel Pump, When is it needed?
- half shaft circlip part #?
- New motor, will my valves hit my pistons?
- Intake manifold spacers?
- Modification of OEM Oilpan
- Tial bov springs
- Another whine thread video inside
- Evo IX Turbo Not Looking Well
- Remove radiator?
- evo 9 feeling sluggish when normal driving
- How does the oem EVO 8/9 fuel tank work?
- Tranny issues
- Does laminar airflow increase compressor efficiency?
- Whow has HTA35R?
- Blown head gasket diagnosis - Milky oil
- Evo overheating problem?! Please help!
- weight of the Exedy twinplate ?
- Sport Comp II Reading Extra Boost
- 70mm Throttle Body Seals
- Careful Buying ACD Rebuild Kits on Ebay
- Need a catch can
- Anyone try the exedy clutch master cylinder?
- Buschur 1/2 Radiator questions
- Oil return line question
- Misfire issues and boost problem
- Will an evo 8 cams fit directly to an evo 7?
- How is Sun Hyperforce with GT35R and stock coils, E85 33psi ?
- Do-Luck Torque Manager ACD evo
- EVO 8/9 Synchrotech Carbon Synchros
- FP 6466TZ... Thoughts?
- Does anyone other than STM make an aluminum ACD reservoir?
- Yayyyyy oil leak! But where?!
- Need opinion on compression test results!
- Strange Oill Leak coming from backside of Cylinder Head
- Petrol leak at engine bay area
- Intercooler upgrade
- Pep Boys told me it was the turbo?
- Transmission won't engage
- best drag motor
- timing belt
- Dump aka 02 housings aka turbo outlet (lol) - sizing
- Stock turbo suction pipe on IX worth replacing?
- Tomei h beam rods Max power
- Any updates to acd pro ( dccd pro / spiider)?
- Lets talk Intercooler pipe bends
- Evo IX - Hole in Intake Manifold?
- What's a good intake??
- F/S ODYSSEY PC925MJ-A battery
- Evo 9 GSR Turbo leaking oil from vband clamp ?
- BBK-3B vs. HKS 7460 GTII
- Clutch issue
- What size ACL race bearing in built 4g64?
- FP HTA86 compressor quality issue
- Need help!
- *please assist* drive train issuse
- 6466 or efr 9180
- How G-Force affects the oil in your pan.
- bluish smoke on start up,need help!
- titanium compressor wheel
- Revved up to 4krpm heard a loud bang....
- Evo 9 tansmission wanted!!!
- SpeedSport Single Carbon-Carbon Clutch
- Next Step
- Help with 2.0LR build
- Best piston/rods
- lean condition , rough idle
- Building a destroker - help needed
- buying a new turbo
- Help Car violently vibrates on acceleration.
- ATP GTX3076R vs CBRD BBK-B BB
- baffled oil pan or crank scraper?
- top mount 6266 2.0 cam question
- will Manley 156mm rods and stroker pistons fit?!
- GTX3582r Compressorwheel
- Noise after clutch install
- 06 evo 9 gearing????? It revvs 3800 at 65mph
- intalled new OEM thermostat - lowered coolant temps by 5-6 deg F
- EVO VI clutch part # cross-reference
- 2.3 build
- Evo 9 operating temp question
- Power vs. Reliability
- Need Help Troubleshooting failed evo 9 ACD pump
- T4 6466 drain line having issues
- Twin plate clutches, for every day driving… good idea?
- Evo 8 new tranny rebuild, first gear noise on decel
- Best Intake that makes power.
- AEM ecu questions, help needed!
- how to baffle an oil pan, anyone have pics?
- Evo 8 Turbo kit Help
- Which FP Green do I have?
- switching clutches
- What FMIC did I just buy?
- evop fmic
- 2005 evo 8 turbo blowing oil
- camshafts rotated 180 deg on cam gears but engine running fine. why?
- evo 9 turbo installation.
- Oil choices and E85
- I fear ive blown my headgasket
- Evo 4 gearbox to Evo 5 engine
- evo9 maf sensor
- Power steering problem
- MAP Sensor Recommendation
- problem with t4/t3 6262 please..!
- Evo IX 6 speed Broken Bellhousing by workshop / please help.
- Looking for this bolt
- spun a bearing ? plz help
- How to get to TDC for Leak down test??
- 2005 Mitsubishi evo 8 idle problems
- Cheapest place to buy EBC Solenoids (Link inside)
- UICP with Tial Q bov and stock battery?
- Evo V intercooler piping
- Evo4 short block need
- Afrs tipping lean
- Red Circle? Makers Mark?
- Upgrade Turbo Help Please
- Boost Limit?
- Tomei ARMS turbo max boost and spool question
- Setting competition clutch twin disc bracket
- Oil residue around filler cap
- Evo IX, GSC S1 - oil pressure drop on high RPM
- How to Bolt On Slip Fit Exhaust?
- help analyse my head fault plz
- QM 8 Leg install, HRB, did I leave this out?
- Gates Timing Belt And Tensioner Evo 8MR
- Eagle stroker engine advice?
- Evo 4 CRANKWALKED
- Has anyone used a Ford exhaust air supply pump for venting the crankcase?
- Acceleration cut out
- Fuel return line fitting @ hanger
- Cam install
- injector question
- Spark Plugs????
- Port Stock Exhaust Mani or Fix JMF Twinscroll
- Turbo upgrade path suggestions please
- Evo 8 head question. G6ew 1 vs. g6ew 2
- Turbo bellmouth/flow stack butt dyno impressions
- Need advise or info.
- Ported head
- Rear diff lock
- waste gate external actuator
- Have anyone buy a rebuild kit for their QM 6-leg twin dics v-drive clutch????
- Ooops
- Is there really a difference ?
- Trouble getting into gears when car is moving?
- Best drag tire
- Thoughts on my Summer 2014 setup.
- this is stupid and backwards
- to much crank case pressure
- Help Urgently needed EVO IV PISSING ME OFF BADLY
- Evo vibrating and shaking
- ABS Codes: 13, 14 & 23
- Output shaft circlip
- Some help please
- Blew Up 6spd Need Help Choosing 5spd
- Daily Drive without PS?
- 2.3 Stroker build gasket thickness
- Help on Fuel setup
- Little ACD help
- Really rich idle
- 150mm rods in 4g64??
- Evo 8 non acd t case in evo 6
- Running Lean after Turbo Install
- Engine valve cover
