PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 [167] 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. gasket?
  2. engine oil
  3. clutch slipping???
  4. forge rs problem?
  5. how much power you get on stock turbo?
  6. Transmission Question
  7. HKS intake is bad?
  8. Revolver Question
  9. Trouble engaging reverse
  10. Full-Race ProStock Turbo Manifold
  11. Your thoughts on Nitrous & Meth
  12. Least restrictive and most durable high flow cat????
  13. Fuel cut when I mounted Mongoose exhaust on my EVO 6 TME
  14. BUILT motor question
  15. What flange for a 50 trim?
  16. Tranny question
  17. billet coil cover
  18. Hello again - HKS 2604-RM002-applicaiton?
  19. Those with Invidia O2 housing...questions
  20. Hello again - HKS 2604-Rm002-applicaiton?
  21. Exedy mm022sbl - what the application?
  22. ams o2 housing???
  23. list of stock turbo replacements
  24. Cold Air Box for Injen Air intake
  25. anyone run 1000cc inj w/out ems?
  26. Question about AEM EMS + Tial BOV
  27. Fast Oil Filter
  28. Anyone with buschur stage 3 shortblock and head
  29. Clutch Installed, Is my car having problems?
  30. what to watch out for when removing 10.5 hotside??
  31. what exhaust system gets the most WHP gains?
  32. Duty Cycle of stock fuel injectors?
  33. Helppppp
  34. Need Help Putting The Trans Back In!!!!
  35. Any one using Ganador Titanium exhaust??
  36. 16g flange, where to buy???
  37. Alternate Comp options on GT3582R ?
  38. use stock gaskets????
  39. EVO IX Cosworth Cams - The 1st Round of Results are Here!!!
  40. car wont start, HELPPPPPPP
  41. big cam vids
  42. Average costs of machine work to build a 4g64
  43. full buschur parts ........
  44. Check Engine Fix
  45. Dynojet Setup
  46. Anyone running a cosworth crate motor
  47. Evo IX MR / RS OEM Blow Off Valve: is it ok?
  48. Where to buy an Idle Speed Control Sensor?
  49. Clutch Suggestion for Buschur Stage 5
  50. Could have this been affecting power?
  51. reliability of WB sensors
  52. Gear whine question...search is too broad (i tried though!)
  53. Piston design quench zone
  54. Guys with 2.3's Chime in please.
  55. Clutch expert, please help!!!
  56. Cams and tune VS bolt-ons and tune
  57. Old vs. New?
  58. Any benifit to a 3.5" exhaust over a 3" ?
  59. Aftermarket clutch and 2-step
  60. IX Turbo, VIII Evo, 2 Dynos, Big Post
  61. does BG Synchro Shift II bottles come with a seal
  62. Motec Center Diff Controller
  63. Evo IX performance upgrades?
  64. 3" dp with stock exhaust question
  65. RRE's - Type-RS BOV Kit – or - WORKS - Diverter Valve
  66. headstud question
  67. How much boost on a GT35R (GT3567R)?
  68. Napa part # for accessory belt with no A.C
  69. BOV issues
  70. MBC installed. Having trouble now. Help please.
  71. Some help please from the ex DSM peeps
  72. Is Revolver out of business?
  73. do you need an upgraded ECM to run cams
  74. Evo IX compression check #'s
  75. Evo Problems. Attempting To Self Fix.!!!
  76. Clutch pedal adjustment
  77. Installed K&N drop in w/o drying it.
  78. VIII cam gears fit IX?
  79. A/Fs before and after a fuel pump...questions
  80. zeitronix meter.............
  81. Need advice Please help!
  82. Boost Guage
  83. 02 housing on EVO IX??
  84. Little Help
  85. Downpipe Difference? HKS 2.65" VS. 3"???
  86. Average life of Braile/Odessy Batter
  87. Cosworth Cams Myth
  88. Loud exhaust pops in between shifts?
  89. Exedy Twin Disc Question
  90. Threw a couple of codes...
  91. Ignition amplifiers
  92. Boost problem!!
  93. Anyone bleed lifters w/cams still in?
  94. clutch hits floor
  95. knock count
  96. Is there any intake does not require a tune?
  97. Low Trap Speed
  98. boost problem
  99. Head gasket install?
  100. confused about tranny leak from driver's side axle
  101. Extension Rod with Exedy Twin Plate
  102. 03 to 05 transfer case
  103. ping noise after oil change
  104. rebuilding motor, need parts list
  105. Pictures of my fixed head (ported) huge pictures. 56k nono
  106. Banjo Bolt
  107. Uicp
  108. Cam Question
  109. VCU vs. ACD - need input
  110. RMR Clutch Disc Question
  111. egt tapping into manifold????????
  112. hey when swaping o2 housing's??
  113. tial bov spring
  114. will it fit?
  115. tranny rebuild part prices.
  116. 3567r???? 37r ect...
  117. What Grease to Use For Clutch Install
  118. Tial leaded or unleaded fuel WG?
  119. Has anybody seen these new evo coils???
  120. Evo boost levels?
  121. What clutch to buy???
  122. Megan Racing Exhaust ??????
  123. Reducing Wheelhop
  124. Would like some help with re-occuring p0300 code
  125. Just installed my motor mount...
  126. what if i put stock intake back on
  127. Question about 03 and 05 T CASE
  128. leakage!
  129. stiffer rear end mounts
  130. ACT clutch = ruined tranny
  131. evo IX clutch chatter at idle
  132. Problem with car starting
  133. ebay 02 housing best for the money???
  134. Dyno'ed my stock turbo :)
  135. Things to check on if you made low hp numbers?
  136. great location for MBC
  137. clutch questions: carbonetics/ATS????
  138. OIL PRESSURE where should it be??
  139. clutch install???
  140. Pin Out Walbro TDD MIJ 600 AA
  141. After licp install boost drop?
  142. alternator going out
  143. HELP!!...why does my evo keep spiking?
  144. just dynoed ATP 3071 443 whp/393wtq
  145. RNR GT3076R kit issue help please.
  146. Dumb(?) oil catch question
  147. Problems P0170 fuel trim in Evo7
  148. MAF 03-06 all the same
  149. Spun rod bearing??
  150. another problem.. please help!!
  151. BOV flutter with a BIG turbo
  152. Hallman MBC questions
  153. Walbro GSS317 questions
  154. Coil on plug questions
  155. Evo 9 TME Turbo 6 Blade Dyno #'s
  156. Help with o2 sensor on cat delete!!
  157. Nelp Help!!! Lines On Intake Manifold!!!
  158. alky boost taper
  159. duralast clutches lol.....
  160. RNR 30r kit dyno #'s
  161. Intake Question
  162. how to clock 35r?
  163. what are the differences in a mivec vs. non-mivec cam install???
  164. Smoke at WOT?
  165. Stroker cam gear setting suggestions?
  166. Forge MBC tapering...
  167. ams 3076 question
  168. OEM tranny t-case and rear diff
  169. sporadic engine vibration/start-up
  170. hks cams and cam gear questions
  171. alky vs. cams
  172. T-case Whine
  173. what is the best bolt on turbo for the evo 8
  174. carrier bearing.
  175. post pics of your licp installed, please.
  176. boost hitting 23-24 psi?
  177. 3.5" inch O2 Housing?
  178. HKS O2 housing
  179. Forge MBC Question
  180. Cosworth/GSC cams IX
  181. Please HELP!!! Overboosting!!!!!
  182. STOCK EVO9 volunteer needed at Buschur Racing
  183. loud whining coming from front of car???
  184. Please help me diagnose my problem!
  185. Vendors: 2.1 longblocks?
  186. What lower intercooler pipe is everyone using with their ARC Intercooler?
  187. 208kw atw & 93% duty cycle on injectors ... why?
  188. LM-1 Rpm voltage?
  189. Engine louder after cam install??
  190. Need Opinions: Injen Ic pipe kit
  191. noob boost flash question
  192. Running oil pump / oil through before starting new engine.
  193. Stock exhaust (axelback) flange?? Where to buy?
  194. My car "Grenaded"!! What let go??
  195. Which Intake Mani
  196. Off throttle flutter/rattle
  197. List of Parts Needed for Timing Belt Change ?
  198. 5 bolt turbine housings
  199. A little help if you please...
  200. Deleting AC
  201. Need help with a 75mm throttle body and linkage
  202. Bad Decel Noise - have questions
  203. Need help quick.....cant get o2 sensor out
  204. Front end problem
  205. Fs Ix Turbo
  206. Air intake....
  207. Boost Level
  208. Greddy Informeter??
  209. Diverter Valve Recirculation Hose - Size/Dimmensions Anyone?!?
  210. Strange Issues with my EVO 8 MR
  211. What exhausts are louder than the Greddy Ti?
  212. 20g-9-5
  213. Oil where it shouldn't be (PICS)
  214. evo newbie needing some advice
  215. battery check lite lit up on cluster
  216. engine oil/oil filter?
  217. Clutch question
  218. upgrade my daily driver
  219. EVO IX: MIVEC and adjustable cam gears
  220. Time for a new clutch
  221. Is a T3/T4 the limit on hybrid?
  222. poppin noise
  223. Engine Decel Whine, Not Tranny or TC
  224. RMR Catback
  225. LSD Oil Help
  226. Need Advice on Ignition (Bad Misfire)
  227. Exhaust cam on IX, anybody with good results??
  228. 4 EVO IX's + Tune from Alfred @ Tuning Technologies = Simply Amazing Results
  229. Exhaust leaks HELP!!!!
  230. slickmotorsports 2.3 gt40 build "sneak peak"
  231. Ses P0507
  232. Confusion with race gas ....
  233. launching.
  234. noise when shifting faster in rear diff.
  235. Broke something....What is it?
  236. forge wga....
  237. stage vi head. (56k no way)
  238. Clips of JDM evos launching
  239. does the APS fmic come with ic piping or just by itself?
  240. ATS vs HKS twin carbon clutch
  241. What to do?
  242. Which Exhaust Manifold???
  243. valve springs
  244. Has anybody in this forum broked there transfer case with the stock clutch?
  245. Has anyone used this boost controller?
  246. ams vs buschur
  247. Good Exhaust Manifod for evo 9 mr
  248. 2003 no lsd issue?
  249. custom turbo possibility for evo9s
  250. stock oil pump efficiencies
