PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 [209] 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Break in period for new turbo
  2. ACT it the greatest!!!
  3. Pretty sure I figured out my "transfer case" problem!
  4. engine terminology question ??
  5. want to get an evo 8 but should i get an 03 or new 04-05? due to ACD
  6. Does anyone sell the o-rings for the stock injectors?
  7. Need advice on my car being "safe"
  8. Which turbo for the next evo turbo buildup? gt35r , gt3040 , gt30r?
  9. Modification advice needed...
  10. Just installed Ebay DP, HKS hiper, Test Pipe..
  11. who has delete pipe for daily driver?
  12. Loudest BOV
  13. Stock MAF flow
  14. Question: why use a clutch type front LSD on the street
  15. New Flywheel or aftermarket??
  16. SBR 2.3 GT35R Dyno results
  17. Timing Belt Tensioner Tool. Where to Buy
  18. AVC-R Owners...need help.
  19. anyone here have alky kit with mail in flash
  20. Should I make Ti IC pipes?
  21. Help here, new project
  22. Aquamist Water Injection
  23. megan catback installed I LOVE LANCERSHOP!
  24. Blow Off Valve
  25. Monitoring tranny fluids?
  26. Car Dead. IC Sprayer Always On???
  27. TRE is as good as gold
  28. alternator
  29. mobile 1 extended life oils
  30. 02 sensor wire?
  31. Idle Issues, stock BOV
  32. Exhaust Cutouts...whos got one and where you get it?
  33. Pics My New Toys!! Full-Race & Innovative
  34. Exedy Racing Clutch Stg 2 Fidanza Flywheel
  35. Random ses light
  36. tranny swap
  37. Car feels funny, boost kicks in weird...
  38. Boost Solenoid Capping
  39. Diverter valve or blow off valve
  40. Question about Perrin Oil Catch Can
  41. Greddy TT Error help...
  42. new turbo kit coming soon!!!!!
  43. Welded Viscous Coupling Question
  44. humid weather
  45. Higher Elevation and Boost Levels...Flash Related
  46. Best intake kit?
  47. service engine soon light issue
  48. Keep my S-AFC and Flash, or just Flash???
  49. Boost controller hookup
  50. Help with Apexi GT down pipe.
  51. What Exuast is this!!
  52. Dejontool 1G BOV "Leak Stop Kit"
  53. bad boost creep, need help!
  54. What's wrong with my car?
  55. Trying to pass inspection...
  56. EBC can sound like preignition at low settings
  57. are ACT clutches stiffer than the stock?
  58. Piecing together your own kit??
  59. evo turbo into the ralliart
  60. cam gear cover
  61. good shop to replace clutch in bay area
  62. fuel pump
  63. 10.5 hotside install question
  64. Injen Air Filters
  65. My Helix HF cat failed emissions.. why?
  66. Flashing service w/ a core exchange?
  67. Those with Helix IC piping
  68. Arp Head stud
  69. Tomei Blow Off Valve
  70. ACT clutch disk swap
  71. Help! Clutch problems
  72. Question about boost gauge reading?
  73. Have 750$ to spend, what should I get next ?
  74. rpm not rising but is my clutch about to go???
  75. AEM Short Ram installed last night!
  76. A-Pillar Pod "Dual"
  77. Lifter cleaning tips, tricks
  78. Can anyone explain cold startup to me?
  79. QUESTION: HKS SSQV version 2 with upper IC pipe
  80. sound of exhaust after dp??
  81. Better powerband
  82. crank pulley damage due to over-rev.
  83. Steady idle with 750cc/SAFC combo??
  84. What Royal Purple TC, tranny, diff oil should i use?
  85. TME turbo sources
  86. At what HP level is a LSD needed???
  87. egt normal temps.
  88. Dual Charger Setup!!
  89. TRE rebuilding Car & Driver Evo?
  90. Has anyone overheated a Walbro fuel pump yet?
  91. Upgraded fuel rail
  92. Anyone running a KnockLink?
  93. 264/272 cam gear settings
  94. EGT gauge Install prices
  95. BOV Question (yes another one..)
  96. Piston tech question for venders!
  97. Misfire diagnosis (plugs or coils?)
  98. Can u get 600WHP On GT35R Turbo?!
  99. Exhaust and O2 sensor question
  100. fuel cut and boost cut
  101. Whats the best air filter?
  102. myths about cams and questions
  103. Hallman Evolution Pro or RX Users... Mounting question
  104. How long does your Stock Clutch last?
  105. ngk iridium one step colder spark plugs
  106. Wont go into Gear, Tranny, Clutch???
  107. Injector size question
  108. Ignition power amplifiers - HKS Twin power, XS engineering Power Pack, etc
  109. Stock clutch done at 28K...need advice for new clutch!
  110. Screaming turbo?
  111. clutch malfunction
  112. ***Downpipe question****
  113. turbo back for $195.00 any thoughts?
  114. Is there splicing of wires involved in Profec b
  115. having problem with my car.. please help
  116. ported head - what kind of gains?
  117. Noob? On Boost
  118. EvoMoto - HowTos - If you hvae them, let me know...
  119. Is anyone a Clutchmasters reseller?
  120. Which coating to choose
  121. relocating mini battery under passenger seat
  122. Question about a certain cat-back exhaust
  123. question on jetcoating the manif.
  124. Pressure Plate Spring
  125. does your MR BOV hold over 26 psi?
  126. Cylinder pressure, whats your number..
  127. GFB bov, who has one?
  128. Which Exedy multiplate for daily driver?
  129. Tomei Poncam 260 10.7/10.2
  130. 522 Awhp, Stock Intake, Stock Exhaust Manifold, Stock Block
  131. Difference off 272/272 264/272 ?
  132. TBE exhaust with MBC
  133. P0243 I know the definition, what does it mean
  134. To people with Helix Catbacks
  135. Boost Creep with MBC???
  136. Oil feed line fitting that goes to the oil filter location??
  137. Defi BF EGT Temps
  138. moving throttle cable
  139. heard of direct hits spark plugs?
  140. catch can...should I get one?
  141. Can't Shift nearly impossible Please help.
  142. do I need bigger injectors for alky kit?
  143. Question about peice i found in bellhousing while doing clutch install
  144. Where can I buy exhaust gaskets???
  145. Octane Boosters
  146. Questions on dead spark plugs.
  147. first mod
  148. How many using injection (H2O, Alcohol)?
  149. broken front diff?
  150. for those using LAUNCH CONTROL
  151. Buschur Racing Car & Driver Super Four Challenge!
  152. Need help with fitting size!!
  153. SES P0128 and Ralliart thermostat
  154. Went to the track. Numbers inside
  155. Injector duty cycle w/ HKS 272 Cams?
  156. octane changing...what to do?
  157. Spark plugs and wires
  158. problem with my car
  159. 2003 EVO Transmission common Transmission Problem?
  160. Ball and Spring MBC questions......
  161. CONTINUE: LOudest Exhaust Result POSTING
  162. Injector Question
  163. Oil blowing from oil cap/dipstick
  164. VTA BOV w/20g turbo?
  165. Another o2 Housing
  166. Super charger/ Turbo pics
  167. BPR7IEX plugs, ??
  168. hks vs greddy
  169. Is there any reason I shouldn't buy this clutch?
  170. Ne1 have a picture of a lifter?
  171. Valve Springs
  172. Seemingly common Evo problem..
  173. Fluid Leaking
  174. Would displacement increase by using oversized pistons?
  175. Doing my first oil change, dino or synthetic?
  176. Tackling the clutch install tommorow, any last words of wisdom.??
  177. Help me to choose the LOUDEST exhaust
  178. MR Clutch Differences
  179. Problem: Car Smells
  180. how do you know if TC goes out?
  181. Problem: CEL flashing @ high rpm's in 4th gear?
  182. help, my whole gauge cluster doesn't work!!
  183. Q on turbo inlet pipe/hose
  184. Q on used hks cams
  185. How much PSI r u runnin?
  186. 3" Electronic Dump Valve - Pics & Video!
  187. Stroking worth it?
  188. 10,000 mile maintenance ?s
  189. New Stock Turbo Record !!!!! 435 awhp 436tq!!!! STOCK ECU, STOCK BLOCK
  190. Can't decide on cam choice for Buschur Stg 4/BR440
  191. Help with my stutter problem?
  192. intercooler question
  193. EVC 5 offset setting & install qns
  194. Question about strange brand of T case oil i found
  195. Simple way to tell if your clutch is dying
  196. 280's on stock ECU and turbo
  197. APS BOV adjustments?
  198. possible leak?
  199. noob question - re: MBC, SAFC
  200. ACT Installed Today By RRE
  201. Modding in a month.. questions
  202. BR UIC + Greddy Type S BOV
  203. Fixed 17psi Taper-> 22psi at redline
  204. Anyone have Buschur FMIC and electronic boost controller?
  205. HElp!! Hallman Pro or RX!
  206. Yet, another Walboro 255 Fuel Pump Install Question
  207. 10.5 turbine housing part number?
  208. Boost problem
  209. Engine Management w/ GT35r
  210. boost leak need help
  211. p0300 Cure? EMS which will fix it?
  212. Breaking Dip Stick Tube Brackect
  213. Please Help...shifting Problem
  214. Which is more effective, methanol or denatured alcohol?
  215. couple quick high revving questions
  216. Next Mod?
  217. Where to get Evo Tuned In WA
  218. Evo clutch only bad on 03? or also 04/05
  219. MR BLOW OFF vs. STOCK BLOW OFF
  220. Lifter Tick Video and Question
  221. apex'i with hks harness help needed
  222. Transfer Case?
  223. Stock flywheels, signs they are no good?
  224. Best clutch for DAILY driver, but will have high HP
  225. Buzzing Sound Help!
  226. ?? About Alkohol Injection
  227. Funny smell, smoke outta engine?
  228. Car slow on warm 60% day?
  229. Lifters: hydraulic vs. solid
  230. Does anyone use the Microtech EMS?
  231. SS clutch line - how much of a PITA?
  232. Defi Gauge Cluster - Evo 8
  233. New exhuast system going in, few questions
  234. Stock flywheel pic request
  235. Coolant is low...
  236. Has Any One Installed A Fuel Presure Guage???
  237. IC pipe size question?
  238. any1 have a ebc
  239. Valve Springs!! Transfer Case!!
  240. What EVO Clutch to get? or.. Evo 9
  241. lightweight flywheels
  242. My track experience with GT35r
  243. Evo 9 questions and can u swap stuff form it to the 8?
  244. Act Hdss Feedback
  245. Curious question?> some1 help me out
  246. ***Evo clutches
  247. Anyone notice that after "spirited" driving that the oil..
  248. video of my 272's idle without tune
  249. How much hp is a pound of boost worth...
  250. question about cams
