- Trouble Removing Oil Filter
- now that the X is on the way, time to start modding the IX, exhaust Q
- What are the best clamps for Diverter Valve?
- Turbo kit install
- Big Oil Leak Problem!!! Help!
- Quick Fix?? P401 Error Code, EGR?
- test pipe question
- Which stock BCS port goes where?
- F1 Racing flywheels
- flywheel bolts
- 35R WHP record?
- *Wastegate debate*
- 10k miles on my IX and the clutch seems to be going
- New TB gasket & still leaking?
- 560cc injectos
- 35R WHP record?
- Cat-bolt dimensions
- car is back together, tuning done with video
- oem transmission parts?
- new turbo time
- Wait time on IX to Green?
- evo9 10.5 turbo
- 4th gear issue
- Anyone use Quartermaster clutch?
- strange noise when taking off in 1st
- mbc hook up for ams turbo kit ?
- Installed my 3" QTP Electric Cutout - Pics & Video
- Hey Guys, please help w/ mods gone wrong...
- 4" intercoolers, ETS or Buschur?
- help newbie in ny
- unequal or equal lenth manifolds ??
- GSC Stage 1 cams installed, wow!
- whıch slım fan can ı use
- Start up precautions after long down time?
- FPgreen and 05' differenes
- Tale from the Dyno: ETS 'Super Value' Ball Bearing 58 Trim on VP MS109...
- Diagnose this sound - Video Included
- notchy shifting, goodbye OEM clutch??
- NEW Pump gas record on MD....603WHP
- HTA35r setup, do I need anything else?
- 35hta vs 35r vs Evo green vs 37hta
- What's the maximum Reliable RPM Limit on the 4G63 Head
- STOCK Evo 8 Turbo ????'s Bumping her up to 9 turbo..
- BF 272 Cams STOCK ECU!!! Video Clips
- AMS 2.3RR 42R car from Denmark
- Injen intake with stock upper pipe???
- The evo is alive!!!!! VIDEO
- Solid or 6 puck clutch?
- post your PSI drop for you LICP
- Idle after ported intake manifold and 65mm TB
- Quick Question on Air bypass Hose
- All put together 3065,780's,AEM,etc
- some boost Q
- AYC ACD problem
- cone filter or drop in?? please help!!
- question about open downpipe
- Mustang dyno load = street load?
- Pump gas turbo choice
- Tcase bad or something else?
- Best engine OIL for IX
- Fluidampr on light modded evo?
- 03 EVO 8 spark plugs
- The baddest EVO 9 pump gas we've built.
- Cobb stage 2 with manifold and 02??
- Flywheel suggestions and feedback please
- Test pipe question
- GT30r OR GT35r
- 5 speed trans X 6 speed trans
- Light weight pulley question
- Ix Rs Finale:) 410whp/437tq
- safe oil temps?
- What ignition for 700-800hp
- GSC S1s on GT35R??
- Stock EVO9 turbo, most power we've seen yet.
- Clutch Setup Question
- ported stock exhaust manifold
- SRS light (airbag warning)
- Autolite XP3924 spark plugs for a IX?
- Evo 5 with 6speed tranny?
- HKS Blow off valve help
- EVO 4 transfer case (Centre diff)
- Stock boost on GSR 260?
- AWD Motorsports Stock Turbo RS.. 427whp/423tq!!!
- 400WHP+ or BUST
- throttle issue need help
- P0171 Cause?
- medalion touring exhaust on evo 9 rear bumper.
- Big cams little Turbo
- deceleration rattle from engine bay
- lower front strut bar
- quick wastegate question
- spark plug rings leaking
- Ported my Exhaust Manifold
- Where can i found Quaife LSD?
- Is my clutch going out or do I just need a tune?
- Some serious bad luck...
- porting titek o2?
- Pulstar Spark Plugs
- cams or turbo????
- STOCK IX turbo Dyno (374.26WHP and 314.91TQ)
- Hallman MBC leaking boost?
- bad mbc or bad wastegate???
- fuel pump???
- For those of you with an Exedy Twin Disc Clutch
- Drive Shaft Grinding exhaust down
- FP or Forge wga
- Need help... RPM hunting at idling
- Clutch question
- What turbo with stock mani. ???
- In the market for a turbo kit!
- clutch is almost 100% gone.. i got questions.
- Magnus intake manifold.... good bad?
- 6 speed shift cable?
- Turbo Lines Question
- AEM Water Injection Help
- 506whp Stock IX turbo E85
- best cams for fp green
- C16 Maxing out PTE 780's
- Garrett GT 32 series
- Stock Intake Mods
- Pumpgas, 35r-ish guys....
- just picked these up
- Shepard trans
- Oil light on
- Spun a rod bearing...what's the worst that could of happen ?
- MD031805 oil filter
- ???????????? Is full-race going to produce a 37r upgrade????
- HELP! Car wont SHIFT into any gears!
- newbie cam question
- Dual springs = smoke under load :(
- loud knocking on engine acceleration
- Boost issues?
- how high can crower valve springs rev
- Official HTA EVOGREEN thread by FP
- Urgent HELP! Cam install S2
- Avoiding ACD issues when doing clutch?
- Bad boost creep
- Ams 1130awhp Video!!!!!
- Can/should I use these cams?
- Anyone running the HTA35r with Buschur Cast Mani kit?
- Walbro wine!!
- what is wrong in this picture?
- Where to buy rear 02 Sensor?
- New 8 T-case Better Than Old???
- Intermittent miss on a IX...advice???
- evo 8/9 6-speed trans Q.
- 12.0 @ 119.8mph
- Stolen thoughts from Simon Norris on T04Z
- oil change + o2 sensor
- Funny idleing
- Boost problem
- used act clutch?
- car issue
- cosworth head + revolver cams compatible?
- burn smell
- p0106 problem... I've searched
- ACD Help!
- ams gt35 r turbo gasket/sealant questions.
- Unknown boost leak
- stage 3 clutch problems?
- where to buy stainless studs & nuts?
- Meth Or Intercooler
- Need your help Identifying this part!!
- cams installed!
- My fuel pressure??
- Help - Clutch Problem
- What is the latest on DynoFlash Evo?
- 2.3l + BR Stage3 Head + 20g Build
- Greddy Full Auto Turbo Timer
- 5th Gear Harmonics and P0300 - Does it Get Worse over Time?
- Built Head Questions
- Used turbo kit what manifold is this?
- Can 2 in-tank GSS342HP pumps supply enough fuel for a 2.2l / GT42R?
- Advice needed on setting fuel pressure
- I need your help!!! any mitsu mechanics here?
- royal purple 75-90
- T Case question.
- Suman's Revenge - 685 whp on BR cast kit with FP GT37HTA (I was wrong)
- 2 part question
- were the HELL is the hole in the fire wall to run wires through
- HKS DLI II Issues????
- Fabled injectors it seems.
- Disconnected the batterie, now evo wont idle???
- mitsu part numbers for evo 9 turbo into evo 8
- differential cooler
- O2 housing =compressor surge?
- Drag Car... Start To Finish!
- IveyTune is BEST (for me at least!)
- Clutch install question Evo 8
- SS flange for FP Green
- Potential power w/ 91 oct
- Vacuum Manifold ***Pics***
- Max power with evo 9 with stock turbo with mods on pump gas only?
- Car is acting up. PART 2, please help!
- White Stock Exhaust Manifold, Cracked?
- Power loss through drivetrain
- Boomslang harness compatibility?
- Rebuild stock turbo?
- How much boost in stock form?
- Should I use Loctite when installing my cams?
- difference in evo 8 and 9 throttle body?
- slipping clutch
- Tranny?
- Intake questions?? i know i know.......
- Looking to buy a manifold w/external dump
- best 3in angled catback with jdm bumper
- Another IVEYTUNE 690hp
- Biggest turbo for street
- Race gas +2 psi advice
- Oil pressure too high...possibly?
- oem wga or fp hp wga
- Modification Math (stock turbo)
- dyno question
- Retaining Clip...?
- fuel injector installation issues
- 406WHP/373WTRQ, bolt-ons and meth on Evo IX, DD dyno
- ebay 70MM trottle body. plug and play. anyone have this or tryed it out????
- Best cams for the EVO 9
- Help! Im getting sick of asking for help but i could use some.
- 2005 T-case problems...
- maximum oil working temp?
- Fp green lag
- Where's that elusive Ebay cone filter?
- ets 3' or 3.5'?
- Lift off, car wants to stall.
- How Much HP?????????
- More power with response wanted!
- radiator fan noise
- HTA 35R VS 35R Twin Scroll Pump Gas on both
- Can someone tell me what's causing this? (video inside)
- Red line 75w90 Safe in the TC for 100 miles?
- Bigger turbo stock applications
- Best camshaft for evo 8
- Clutch Clutch Clutch
- BOV Backwards
- Anyone running HTA 35R in a .82 "5 bolt" housing?
- FULL-RACE TWIN SCROLL 35R test results and data
- Ams Liquid To Air Intercooler !
- Info - Looking at the 400 whp question from a different perspective
- which front LSD? - Cusco, kaaz, Carbonetics
- Norris Designs - 830 ft/lb @ 5700 RPM (Shearer Manifold)
- Help!!!!!! Pelase!!!
- which piston for 2.4 ??
- OFFICIAL: Tanabe Super Medalion Hyper Exhaust for EVO 8 & 9
- P0134 and P0125 help
- tilton questions?
- Has anyone tryed ACT MB7-XTG6 clutch kit
- type s fluttering bad help!!!!
- injector question
