PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 [119] 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Apexi Power Fc D Jetro intake manifold question
  2. 2.3 Stroker W/50trim On Pump Meth.
  3. Po403????????????help Please How Do I Fix These Code
  4. Fix my leaking TB seals...still leaking (vid inside)
  5. Update (Includes MAF Translator Review) **Photos**
  6. best plugs for fp green/alchy
  7. test page
  8. Transmission, and clutch pedal problems
  9. output shaft
  10. Exedy twin install... help? Phoenix
  11. Board of the green
  12. P0401 EGR Flow Insufficient fix?
  13. Idle???????
  14. cam gear settings
  15. Need info on 5 speed swap
  16. Dyno tuning tricks
  17. Short Runners Vs. Long Runners
  18. 4th gear grinding
  19. My new AMS goody......Bling...Bling...
  20. highest boost i can safely run
  21. is it ok to drive with a blown exhaust manifold gasket?
  22. can anyone tell me exactly what kind of bov this is?
  23. Starter issue?
  24. Problems with the Evo
  25. new clutch installed into 6spd, hard to get into reverse
  26. stock cam lift?
  27. please help! underhood shifter bushings
  28. Warning/Cam gears w/o cover
  29. Found tooth on magnetic plug when draining tranny...
  30. Stroker rod clearance
  31. FP Green+ Iveytune= power
  32. Clutch sticking
  33. Clutch problem, need help fast
  34. valve tap, bad lifters?
  35. Balance shaft bearing question
  36. ACD Warranty question
  37. Car won't start, randomly.
  38. throw out bearing removal
  39. Injen Intake Question
  40. 1G BOV on Evo
  41. Walbro question...should i be worried?
  42. Exhaust Manifold to Turbo Gasket
  43. got my evo red today!
  44. no spark no fuel....
  45. Throttle hang (again)
  46. mbc choices
  47. ETS quality work!
  48. Need help solving boost problem
  49. help help
  50. upgrade to Forge WGA on stock turbo + meth?
  51. Make your own balance shaft eliminator kits
  52. just got car bac
  53. HEAD and CAM GEAR TORQUE SPEC?!?!?
  54. help rev limiter!!
  55. Questions for Quartermasters Twin Disc Clutch Users???!!!
  56. What race fuel to use?
  57. Titanium exhaust tip covers
  58. Car setup Advice needed!!!
  59. interesting question about quarter master twin
  60. walbro fuel pump install
  61. Time to replace a clutch
  62. *ams Product Release* Evo Viii/ix Jdm Bumper Catback Exhuast!
  63. Low Boost - help
  64. Tapping Valve? Parts Advice Needed!
  65. quick bov question
  66. Gizzmo MS-IBC
  67. Clutch got stuck engaged
  68. lean idle
  69. Confused
  70. db exhaust evo!
  71. Turbo XS MBC info
  72. Camshafts for Evo red... idle, revlimit, power
  73. Clutch/Flywheel Rotational Weight (Pics): Exedy Triple VS. Quartermaster Twin.
  74. 3" Downpipe Problems
  75. 9K miles Service Engine Soon light ON
  76. 2nd Time took the tranny off in 3 weeks...Exedy clutch clip broke again!
  77. Tuning Technologies performs magical tune!
  78. coming in HOT...Spark Tech!!
  79. Motul 300V vs German Castrol
  80. Anyone Using Spec Clutch?
  81. If your ARP Headstuds were Installed 1x1 Please Vote!
  82. Should I get an aftermarket Intercooler?
  83. Need help with Fluids! (Tranny, Diff, etc)
  84. Does invidia downpipe fit skunk2 testpipe?
  85. Who's Turbo Kit is this?
  86. Turbo IX GSR vs Turbo IX RS Mag. (Power-Spool up)
  87. Need Help - Oil Pressure Low
  88. Tial wastegate...need help
  89. My Exedy Twin SD is gone. Rebuild,Up to HD, or ACT combo???
  90. How long did your clutch last after it started slipping?
  91. DSM Shootout Prep - 800 whp Gt37
  92. How high can you REV on these Beehive valve springs? (9K+ fine?)
  93. Colo & Monroig FP RED EVO Video
  94. A full day of work
  95. clutch questions??
  96. rhd evo 5 white smoke(compression test +
  97. Driven Innovations Intake Manifold "Black Magic!"
  98. Buschur POWER!
  99. my arp headstuds, headgasket, and me Questions
  100. Deceptor BOV and Works Exhaust...removing Mitsu logo
  101. Backfire at redline???
  102. Kelford 272 and stock ECU
  103. Exhuast manifold
  104. FP Green
  105. My TB seals are out!
  106. fp3065 Vs. HTA3076 Vs. RED
  107. 1st and 2nd gear soft, neutral is first, wont go into gear WTH!
  108. Which headgasket?
  109. Who else has a 2.4 stroker???
  110. Stock Exhaust Bolt Pitch (test pipe)
  111. misfire 4k limp mode
  112. new intercooler, did i lose power?
  113. HKS Cam Gears
  114. Idle
  115. Time to buy an intercooler?
  116. Your Opinion...
  117. what timing belt for a dohc 4G64?
  118. Meth kit install/advice
  119. With my supporting mods in my signature is the exedy twin disc a good idea with an MR
  120. Back in the shop :(
  121. Have Syncro Problems? - FILE A COMPLAINT
  122. I need immediate help please
  123. knock in first gear?
  124. My Evo is shooting out smoke
  125. Dsm Shootout Racers
  126. Separate Ignitor/Coil system working on stock ECU :)
  127. p300 after installing
  128. noisy clutch
  129. Fp red on e85 525hp and 462tq
  130. EVO8 low boost (11psi)
  131. Teaser pictures of the new RPS billet twin plate carbon clutch
  132. Boost Spike With Built Evo9!
  133. Boost Spike Problem
  134. Stock Clutch power
  135. What is this for??? **PICTURE**
  136. 1.2-1.3 Bar on stock 8? Not Right?
  137. Buying a car that hasn't been started for 3 yrs! what to do?
  138. Just did my Walbro
  139. Wierd surge at full throttle
  140. Borg or Garett
  141. Borla Headers?
  142. Wiring 2 fans up?
  143. broken crank:S?
  144. Will intercooler piping size affect throttle response.
  145. need clutch.suggestions???
  146. Anyone know what this thing is?
  147. FP Red......565awhp/557awtq on E 85!!!!!!!!!!!!!
  148. hard to shift, especially when hot
  149. cylinder matching/cylinder compression
  150. Just finished installing my LICP and....
  151. Jdm Map Sensor
  152. Will the IX buschur licp work w/ the VIII?
  153. If you have a Synchronic BOV try this
  154. Tial Wastegate Issue
  155. Impressions on my precision 6262
  156. Dnp Evo Polished Ss Manifold
  157. Aem + Anti Lag Launch Control Kills Motor (evo9)
  158. amsoil series 2000 for transmission ???
  159. need help diagnosing my timeslips!
  160. Blown Engine, Changhe Oil Cooler?
  161. My Evo 9 600+whp on pump gas 700+whp on race gas
  162. first gear whine, any ideas?
  163. Dc Sports Dp Rubbing?
  164. Perrin Boost tube. Who has it?
  165. FP RED vs 35R
  166. What do you guys think of this Intercooler?
  167. Cam Settings; Road Racing, Time Trials
  168. IX bov
  169. need help p0403 code???how can i fix or ddelete this code??????
  170. HKS Hi Power Silencer
  171. Ran outta fuel :(
  172. Need help: Lower Control Arm
  173. Exhaust Stud Broke
  174. Exhaust Bolts
  175. Rubbing Noise When Taking Off
  176. What header is this??
  177. Exedy twin disk question
  178. Tranny Fluid Changed
  179. Shifter Linkage Popped Off ...
  180. Meth Line Broke (Misfire & Knock ... Help!)
  181. To Stroke or Not to Stroke
  182. Blown Head Gasket?
  183. Anyone got Stealth Perrin Exhaust?
  184. 500 to 600whp drop in setup.
  185. Wilson Manifolds V2 w/ 65mm Throttlebody.. Pics Inside!!
  186. old EGT sensor...
  187. What Valve Springs?
  188. My neutral is stiff as a rock hard to move, but my 1-5 is fine?
  189. Need some technical answers,,2.0L vs 2.3L
  190. Cam Install
  191. Car cuts out under full boost
  192. 02 Sensor Question
  193. Power Fc, HKS 280s, crappiest idle ever...
  194. power problems on evo 8
  195. URGENT: My JDM Evo IX Goes dead @ 5,800 RPM
  196. tranny question?
  197. Injen LICP
  198. evo gear
  199. OK, need some help for a change.
  200. 37R W/stock internals
  201. oem crank hp???
  202. The rear motor mount
  203. question guys can i still use my old headstuds on my new engine??????
  204. looking for info on revolver cams
  205. cam timing question/problem
  206. TBE Exhaust...
  207. porting on 10.5 housing
  208. couplers size for stock intake
  209. too much heat for carbon fiber hood vent?
  210. Lets Compile the data
  211. help understanding a basic PSI question
  212. Vac/Boost Problem?
  213. Snow meth Kit $150 good deal
  214. Race fuel?
  215. mitsubishi GDI engine?
  216. Couple knock questions
  217. FP EVORed 470whp on 26psi with 100oct UL fuel
  218. ETS 42R Turbo PrOn
  219. Post cam instal idle questions
  220. GT35RL Kit and supporting mods
  221. my precision 6262 has arrived
  222. Tune necessary with aftermarket o2 housing?
  223. Evo gear help!!!
  224. header
  225. Spark plugs...5-600whp...
  226. My Evo 9 made popping sound w/ black smoke and oil leaking from o2 housing.
  227. Need Help HKS 272's Stock Valve Springs
  228. Quick Question about TurboXS intercooler
  229. Metal against metal on start up...
  230. Estimated Power Numbers from Set up
  231. shaft play?
  232. ETS or Turboxs
  233. How is everyone getting manifold and dp bolts loose?
  234. Need opinionon Turbo upgrade
  235. hta35, cast vs tubular??
  236. HTA GT35R Spool Data
  237. Need info on 4g64 motor
  238. Clutch experience!
  239. Evo MR Full Fluid Change.
  240. Whose fault is it???
  241. Help, me find the best turbo for my Evo IX MR?
  242. Need recipes for 550awhp
  243. Cusco=Exedy?
  244. Custom airbox
  245. This was a first....
  246. quaife lsd
  247. ACT Hdss Clutch question
  248. manifold and turbo bolt ?
  249. JIC Spartan DE ( Titanium Canister )
  250. Got some new personal bests........but now have lots of decisions to make! HELP.
