- Whinning noise from Engine/Tranny
- just installed boost gauge on stock evo...10 psi!?!?!?!
- disconnecting stock boost controller?
- Question about APS Bov!!!
- boost gauge tubing?
- IX Head on a VIII
- Can't locate a DSM ignitor for a MSD DIS-2
- Boost After Cams & Head Studs?
- Why don't stroked motors last?
- OK, so doesnt seem to be rear main seal, but input shaft seal on tranny instead
- Car holds 7000RPM
- Shearer's new turbo kit...check it out
- Intake Manifolds?
- Flashers/Tuners/Gurus/Racers - 11s on a flash w/o cams
- Flashers/Tuners/Gurus - Pump gas boost opinions
- Center Differential
- Forge Unos 1.4 to 1.22 boost taper
- recirculated SSQV
- Devo Tuning Intercooler
- Question
- Peakboost A-spec Intercooler install pics and small review
- Boost Problem, need some help
- exhaust touching driveshaft
- turboback?
- *Stainless Steel Header*
- will this cause exhaust rattling
- Fried ECU? How to check?
- Oil thread
- Case study # 107 - Another MR with big pump power
- I've got CRANKWALK!!??? where's the Tums?!
- helix 3" dp help
- *Next MOD*
- Transmission Problems?
- turbo kit plus ?
- true 3" downpipe and exhaust?
- Idle Drops Car Stalls
- Another Evo tuned by Precision Dyno (Dynos inside)
- dryad001's MAF-less excursion
- clutch masters ... anyone ever used?
- AMS vs Buschur Alky kit
- Who's got a Front LSD
- freeze plug problem
- To All HKS Exhaust Owners ............ !
- 5th gear grind
- clutch install..throwout bearing fix???
- Ebay Tsudo exhaust?
- Mr Bpv
- Calculation for Hz (MAF) into g/sec or similair please!
- ?s changing Fluids on TC for 05's
- Which 1st?
- Cams idling
- Backfire ? ! ? Car feels much slower...
- Exedy clutch installation instructions...
- Vishnu XFlash = Outstanding
- ARP studs
- Can we use slightly missmatched tire circumferences, frt & rr
- Top Speed Clutch Install
- when alky fails which part of engine blows up?
- 91 Octane max boost consensus?
- Does the HKS Twin DLI II Power add any HP?
- Evo Block Pics
- oil feed for gt turbos???
- shooting flames and a big bang
- External Wastegate to alleviate some of the twin scroll design bottle neck?
- Stock BPV/BOV
- New to turbo's, interpreting the boost gauge
- stuck on 14 psi
- ACT or Exedy organic single
- Zeitronix Wideband Users....
- How do i test for a boost leak??
- After turbo back- Flame during decel
- Some Odd Questions
- Boost question/HKS/MBC
- Does Anyone Know!
- coolant question..
- Po300 questions for people who have had it, or have it now???
- Car broke at the track
- Question about Bushur stages
- Head stud install, some cool tips for your install
- EVO's transmission #$%^$
- Professional SHOP in GA?
- RWD conversion?
- Over-Revved
- Best turbo for 45 mph to 140 mph highway runs???
- HKS SSQV BOV problem...
- injector question
- rpms "stick"
- power loss
- Whats ur Opinion
- So I have a GT35R w/ 0.82back end.Should I put a smaller one?
- Case Study # 106 - Good ole Buschur Stage 1
- Help! Is my timing off ?????
- Turbo question
- When is it time for a new clutch?
- alky kit low level light.. got questions
- Please Help! Issue with stock cam!
- Standalone VS. Flash
- what next?
- EVO mems, brag a lil', post your mods if your over 350awhp...
- boost too much?
- Blitz Turbo Timmer DC2..HELP!!
- Mivec ?
- *rpm Dropping Question*
- Tansmission Problem
- driveshaft ? awnsered
- Evodave's gt35r spoolup.... want big power with fast spoolup...come on in!
- Transfer case question
- boosting at 13 psi with intercooler pipes??
- Swapped out BOV for gen1 BOV quick question
- Limitations of the EVO 6.5 RS TME Turbo
- rpms seem to hang...
- Ralliart Plug Wires
- Question For People w/ Exedy Twin Plate
- Rear Main Seal , anyone
- 10000RPM Inc. clutch experience
- 1st Gear Engagement Stutter
- Transfer Case SHOT???
- Boost leak? Please Help.
- stock internal and gt30r?
- Will this filter work with a GT35R?
- Who hase the lowest price on a new 4G63 block?
- Test pipe = Lower Boost?
- Stroker Engine Reliability?
- The most HP Turbo
- More and more car woes help needed
- how to tell if its too much boost???
- Injen kit...is it worth it..
- Helix IC pipes installed....
- Low temp thermostat?
- Need A Mbc With A Dynoflash?
- need cheap t4 flange manifold
- downpipe for 05
- Stumbling VIII
- How much boost?
- tranny problem
- turbo noob question
- Extrude Hone EVO Intake Manifolds??
- 22 psi
- 4" Turbo Back Exhaust
- how much did your MPG change??
- Vacuum Line Filter?
- fuel and boost cut for noobs?
- Boost leak on stock MR?!
- intercooler leak
- hacked airbox ?
- Intercooler pipe upgrade for now, which?
- Which Spools Faster/Which makes more pwr?
- fuel cut or boost cut?
- rear diff question
- Post-Installs Boost Cut: Actuator?
- Anyone's Forge MBC do this too
- Case Study # 104 - 2005 MR makes mega TQ!
- why?
- Underhood shift bushing for 6sp?
- Greddy Type RS question (i searched!)
- 20g upgrade worth it?
- Boosing only 11psi...please help!
- Electric Water Pump
- Extreme Duty Oil Pump
- Two turbos two results.....
- Dashboard/Race ECU
- Reflash
- Some advice please...
- Which coils do I need for a MSD DIS-2
- Dyno Tested Buschur Racing's 20g
- Any benefit to upgrading valves?
- Almost stock IX and Qpexi N1?
- Evolution Engine into A Normal Everyday CC Lancer
- how do i go about cleaning an alcohol injector?
- short Video of Buddy Club SpecIII Pro exhaust
- exedy vs rps cluth(twin plate)
- So how does 6,000 feet affect your Evo's performance?
- **hks Ssqv**
- Hallman mbc not boosting to 21
- Exhaust fit on a IX question
- Idol control malfunction?
- Name These Exhausts..
- need help for greddy type rs bov
- spark plug change messed up!
- Pro Street Motorsports Cam Gears - Product Release
- MeganRacing O2 housing and Exhaust Manifold
- best angled exhaust out there? (yes im a noob lol)
- Limp Mode???
- Greddy Type-RS
- R cam gears beneficial with a 264/264 combo
- Stripped the threads on the trans!
- Anyone have pics of the Injen SES cat back installed?
- Very impressed with the EVO IX! Comparison of VIII vs. IX
- oil smell?
- Best gauges to have?
- HKS BOV Question
- Something really wierd with my EVO IX and a friends EVO IX..
- Problems fitting my ATP GT35R .
- How many headstuds??
- Looking for a 4" Cold Air Intake
- Anyone have the ECU Pin Out Diagram for an EVO 9?
- Precision Dyno...EVO IX #2
- Turbo Trix Dyno Reflash!!
- wht noises should I expect on an EVO???
- On your Buschur intake what did you do with the crank case hose?
- how do i make my doors stay locked when my turbo timer shuts off
- 03 evo8 vs 04 and up evo 8 exhaust diff??
- I want to increase my rev limt but by how much?
- Stock lifters... where to get em?
- 264/272 >>> 280/280
- Garrett GT3050 Ball Bearing Turbo on a 4G63
- Greddy RS Acting Weird...help
- What boost pressure requires head stud upgrade?
- How to disable / disconnect / remove the 5k rev limiter
- clutch smell
- Need to clock my turbo and other q's
- HELP, Transfer case fluid leak!
- Are aftermarket IC pipe kits worth it??
- water temp gauge, sensor location solutions
- clutch adjustments?
- Fantastic 900 mile trip, two BR EVO's...
- Turbo Choices?!
- gt35
- Help!!!! Clutch Pedal Stuck!!
- ACT clutch/Fidenza Flywheel problem
- Is my head gasket blown?
- Any thoughts on TurboXS Knocklite
- IM gaskets necessary with phenolic spacer?
- Metal burning smell after 10.5 hotside and tubular 02 install
- 20g and injectors?
- Good Porting Shop on the Eastcoast?
- Build a new motor, 4G63 or 4G64? 2.1, 2.3 or 2.4l?
- hallman boost controller setting
- Shredded Serpintine belt #4!!!!!!!!!
- Question about BOV
- HELP!!! evo problems....
- Amsoil
- po401 question...
- 50 Trim vs. Gt 3076r???
- most hp gain from cold air intake
- Jun vs.HKS
- worth fixing?
- More dyno plots/ stock turbo+c16 vs. w/r+meth!
- Q for alky owner?
- 22 psi on stock turbo
- Angled Muffler, Straight Tip, Help
- Hallman MBC gear differences
- Evo gearboxes
- Cooling Performer
- Healthy plugs?
- Having Serious Timing Belt Problem With My Car - Need Help!!
- Greddy radiator
- 2003 evo 8 injectors
- Most TQ on stock turbo and ECU
- t3/t4 50 trim??
