- ATS Clutch
- N/A 4G63 head info.
- Lightened Crank Pulley Perrin
- 4G63 forged motor?
- Weirdest Problem Ever Eoncountered...
- transfer case leaking oil
- royal purple trans fluid?
- which lower intercoller pipes....
- evo 3 4G93T drivetrain viabration
- P0011 code on evo 9?
- Evo abbreviation help
- upgraded cam gains????
- The Tuning Technologies Dynojet Database Project is ready for viewing - see link
- Aftermarket Intake Manifold Gasket
- boost leak?
- B&M Adjustable SS doesnt fit IX
- 350+whp on stock turbo? CA 91 octane
- revolver springs and retainers from buschur racing
- installed new plugs and it got worse
- Anyone re-torqued stock head bolts.
- cams
- Megan Header Cracked!!!
- 780cc on gt35r?
- How much power do I have ??????
- Is my clutch going?
- A'pexi Isamu dyno graphs?
- Converting 9.8T to Evo IX 10.5T the Mitsubishi way?
- obx cams?
- WHAT??!! Stock turbo/inj/Ecu 374 AWHP on Dynodynamics?
- Turbo Smart BOV...hopefully a good buy
- Found leak between turbo & hotside but...
- evo 9 mr part out sale !!!!!!!
- evo 9mr part out
- Clutch upgrade needed?!
- blown head gasket
- Lots of vibrations thru clutch pedal...just had exedy twin installed
- Cheapest place to buy a front LSD?
- got my head back from being ported
- Does fujitsubo legalis fit ix mr?
- replacing cams on a 9
- Engine ticking
- TurbTrix Cams on IX?
- wierd noise?
- "cosworth Cams On Ix" By The Shop And Dynoflash!!!
- Synchronic Blow Off Valve
- Case Study - Evo IX Stage II with Alky - stock vs Cosworth Cams
- stock Turbo Q
- What kind of weld wire on exhaust?
- What do I need to put stock exhaust back on?
- upgrading to revolver cams???
- Help! Wedge collar will not click onto TOB
- APR 3.5" DR Exhaust....anyone try one yet?
- stock valve question?????
- Stock IX with compressor surge???
- 2 step?
- Rattle coming from the eng. bay
- Comparison GT3037S 52T and GT3071R (-23 CHRA) ?
- 24 psi on stock 8 MR turbo
- what can i expect with 35R and meth?
- Size and pitch of downpipe bolts
- MR Downpipe clearance?
- M-85
- HKS 272 cam kit on HRA9.8T?
- Just dropping in pistons and rods
- Snaped manifold bolts...
- Hmm...Interesting observations after electronical boost gauge install
- Looking for some help!
- cranks, LONG rods, and stroker pistons
- i need suggestions....my car's NOT boosting....
- popped out of 5th gear while driving
- Question on GT35R
- misfireing after spark plug change
- Any Truth to this? "Two Step on Stock ECU is BAD."
- Gear dependant signal?
- Help Required
- Attention all Cosworth or GSC EVO IX cam owners
- response time of a wideband sensor
- Nisei intercooler + piping?
- Need new clutch
- Loosening/Tightning of timing belt
- hks rs intake causeing car to stall?
- map or maf? dby or cable?Mc Pherson or double wishbone?
- 650 to spend
- Tial BOV w/ stock turbo/maf but at @28psi. Who has it? Problems?
- * best cams to put on EVO IX?*
- alternator / battery question....
- mitsu gear oil ?????
- cosworth 8 cams
- 2.4 Stroker with 35r dyno graph
- Will Evo 8 Manifold covers fit Evo 9's?
- engine oil question?
- problem installing greddy bov
- Cosworth or GSC
- O2 Housing Gaskets
- Electronic boost controller
- Drivetrain noise, need help diagnosing
- Engine Removal: Plz Help!!!!
- Comments Required!
- Zeitronix ZT2
- CD5W Liberoz 93t Wagon
- Trouble Going into reverse
- Stock Evo 8 injector hold current spec?
- Where can I get custom IC pipe hoses?
- What DP would fit well with the Invidia o2 housing?
- Anyone using the Saiken Michi co. DC3 Catch Can?
- Engine not idling properly........EVO 7
- HKS cams for evo 9
- boost leak results..vid
- quick help tap!?
- 50 shot on evo 9?
- Who makes a good Alky Kit?
- odd boosting problems
- Having Problems with my 4th gear
- Manual Boost Controller vs. Electronic Boost Controller
- spark plugs?
- Did I Screw Up On My Boost Controller Install??
- K&N oil filters
- When to change coolant and brake fluid?
- Cosworth IX Cams RULE ! My test
- Help needed on reinstall of Tranny
- Where Can I buy a throwout Bearing?
- Scary Noise Coming From????
- more torque???
- What Gear lube do I buy?
- Understanding ACD influence on real world daily driving
- Engine Bulit help
- My new Injen Intercooler
- SCAT or Eagle ESP rods?
- Need a good mechanic for clutch install in So Cal!
- question about tranny's
- 2006 Mr Tranny Installed In 2006 Evo 9 With Ssl... Pics Inside...
- Forge MBC Part #FMCB051
- Help needed Tranny Removal
- Downpipes with flex sections. A question.
- Custom turbo kit idea cheap....does it look like a nice setup?
- Help!
- BAD lag after parts install
- hi flow kizzzat
- BPR7 OR 8 ES'S For my setup
- Stuck Clutch in 3rd Gear
- carbon tripple question
- Zeitronics Users!
- dc3 catch can or rre catch can???
- 4G64 crank or aftermarket
- My 2.0 Build Up 56k come back in a Week!
- Add on resonators
- Mine and a buds FP20gLT dyno results.
- EVO IX boost issues?
- All the small things
- Loud popping noise and smoke out the hood vent
- ACD equiped Clutch install
- HKS Filter Question
- catch can importance?
- Great deal on HKS Pistons
- EVO 9 Specific test pipe
- Santa Came 5 Days Early!
- Greddy upper ic piping question??
- HKS 280 Cams and WR-8 turbo
- evo 8 20g???
- AEM ECU installed on evo 9...
- Hallman PRO or Forge?
- Buschur's Turbo Choices
- Exedy TD HD engagement dead spot?
- whats required to get into the 350-380awhp league?
- Cusco Oil Catch Can Installation
- !!! Intercooler Piping Pictures!!!
- What is the correct oil for transfer case ? I got two part codes
- Should I get ARP rod bolts and main studs 4 Stock 2.0L block???
- greddy profec b spec 2 ?'s
- wastespark system
- LICP: Buschur or Nisei?
- How many different model HKS downpipes are there?
- Anyone with JIC Exhaust..
- Can acceleration with low fuel cause engine skip?
- air flow meter probs
- fuel pump question
- ACT Extreme duty 6 puck sprung
- Just Installed Clutch and Flywheel:
- I hit 24 psi On Stock Setup
- Proper break-in for EXEDY HD TWIN clutch? Need input on procedures/methods
- Evo Ix Bov
- 418awhp on pump gas
- Boost goes to 29psi in the 2-step!!
- Buschur's FP3065
- Quick question...
- PeakBoost Topmount GT35R pumpgas #'s
- UIP Question
- Code 0420
- Car RPMS weres still at 6K at the light
- kakimoto regu r 06 exhaust
- AFI Turbo Kit Installed
- !!! star a second after i turn the switch !!!
- Boosting problem
- Crank/Cam timing marks
- Is it o-k to overfill the Transfer case fluid?
- evo 9 CLUTCH problems!!!
- Which clutch
- idle problem when car is cold
- buschur ic's
- Question about HFC
- Injen SES cat-back exhaust installed (pics)
- New Cosworth 2.0L and 2.2L Block 4/S at Lancershop
- Rebuilding the 2.3L more then a 2.0L? Bearings?
- Looking for information on "missing fire system" !
- noob Jack point question
- N2O Question. Please help!
- TURBOS GT42R Vs T51R KAI PLUS FUEL
- Exhaust Manifold worth it?
- boost and going to the track
- EVO Green/20gLT information and new dyno charts.
- Finally going to mod
- 1mm oversized valves: Whats the effect on power and torque?
- Tranny Problems
- Which Clutch
- bad vibration with ac on
- Help anti freeze everywhere!
- Really starting to piss me off
- Anyone Have This Tranny Problem?
- greddy headder
- ignitions for the IX
- Pics of total destruction...(no 56k)
- ***Upper intercooler Pipe...
- Any 280e cams on IX's
- Need help quick!
- What should i do for engine management???
- Modifacations to the block to fit 2.3 crank
- Warped Clutch?!?!
- is it the throw-out bearing?
- Hey Guys, I finally registered under the name for work. Im Here to help
- oil leaks
- Is this a good pump gas combination?
- jackson?
- 50 trim?
- Installed Greddy IC...
- Normal Tranny Build Up? Pic Included
- Why you should not buy a Megan DP.
- Evo IX stroker kit?
- Cosworth M2 CAM VID
- Perrin/Espelier 3" DP fitment on a IX?
- just got an 03 evo , want like 350 hp?
- cams worth it??
- Downpipe bolt spec?
- Ball Bearing Turbos Hks-sos!!!!
- New Fluid Crank Pulley Released ?
- Injen intercooler piping fit Nisei intercooler?
- Which valve springs and retainers???
- Full-Race Turbo Kits Are They The Best?
- help my exhaust is so loud !!!
- spec clutch???????
- Is my Clutch Messed up? Or Tranny problems? HELP!
