- Interesting BOV issue
- Vehicle start with turbo timer
- Clunk in Drivetrain
- HKS VBC anyone using this?
- Rear 02 Sensor with after market exhaust
- Evo engine or clutch problem???
- Mobil 1 10w30 installed ?
- Who makes the best High Flow Cat.....
- Time for a new clutch
- Applied REDLINE 75-90 and BG SyncroShift & Redline HeavyWeight ShockProof
- Is it safe to run 24psi with stock turbo?
- Turbo minus Backpressure = 0 boost?
- Aftermarket exhaust pipe diameter
- aem or k&n?
- Added some new mods!!!!!
- Hks Evc
- Does anyone else HATE the Profec B 2...?
- Mines Super Turbo Outlet??
- Any fix for Turboxs exhaust burning your rear bumper?
- Stupid Check Engine Light!!!!
- Arc Intercooler installed
- question for people with intake
- ecu question
- does this sound fishy to u guys?
- Aftermarket Power Steering Fluid
- Is Mobil 1 oil fully synthentic?
- Cold Evo shakes
- Magnaflow Ti exahust for EVO
- Over Rev Question
- psi engine compression
- will a dsm clutch disc fit
- High Flow Cat Question
- ~$1k to spend
- wierd feeling from 1st to 2nd
- HKS Exhaust question
- Self Draining Oil Plug
- RnR carbon ti exhaust
- Pruven FMIC Install
- Just installed Cusco twin carbon clutch
- ECU+ web site now up
- milltek exhaust
- Best ways to avoid running lean?
- Mitsubishi Clutch Recall!!
- Downpipe thread
- narrow band A/F Gauge
- does HKS Hi Power hang low?
- B&B cat-back to Greddy Ti cat-back
- Will a K&N panel filter reduce boost
- Big Scare - Oil Leak
- Ultra Shift Transmission Fluid
- How much fuel to take out with 255HP?
- did bad thing (reved the piss out of it)
- Bye Bye Clutch!!!
- greddy type R ?
- short shifters for the Evo 8
- 5Zigen Miracle Catback VS. HKS Hi-Power Catback Exhaust
- Yet another exhaust question
- Oil Catch Can question
- mixing different cams
- Bc
- Clutch Install - Where To Start?
- Squeaking Gear Stick
- egt guage install?
- Best boost controller?
- after boost controler install
- stock ic inlet/outlet size?
- You know how you take a spinning class to lose weight??????
- Lets see those shifter lights!
- ATS twin carbon clutch
- Po401 Egr Valve
- Need help fuel cut at 18-19psi
- Gauge help --- please
- Those with Buschur Stage 4, which cams do you recommend?
- Any ECU reflashes offered in CA?
- Helix
- Clutch check... (pic included)
- AFC vs DynoFlash
- what are the synchro's made out of?
- Details on Sigma engine architecture
- Info plz
- Interesting ECU tuning program
- propain
- Trick Exhaust Mod Done
- Boost Control
- Quick parts question
- RNR Racing question!
- RMR or ACT six puck disk
- Looking for proper wires for air/fuel gauge and shift light?
- Down Pipes that clear Conrtol arms...
- Po401???
- Evo 1 Intercooler Help, Please!!!!
- Mod suggestions?
- JDM Exhaust Manifold Triva
- Does the Buschur Stage 1 Power Package give the best gains for your $$$?
- Evo burning oil?
- which mbc works?
- MBC problem?
- Final Verdict on GReddy Profec B SPec II?
- Helix 3" DP
- Bypassing the A/C
- Slipped the clutch too long...WOW what a smell
- Reccomendations on turbo timers?
- Question about resonated exhausts.
- Detonation?
- need help!!!!
- What do you think of this??
- Evo VIII backfire with aftermarket exhaust
- Spark Plug Failure at 5000 miles
- Gonna pull the tranny myself
- CEL on after turboback?
- Anyone using UR downpipe
- ordered a turboxs fuel cut defender...
- Something wrong with my Evo...
- Amsoil gear lube 75w-90 for tranny/diff
- Stupid question. Where can I get these plastic pins?
- boost problems after uninstalled mbc
- Intercooler Silicone Elbows?
- Can this super lightweight battery work in the EVO?
- Loud BANG from EVO today under full boost...
- boost question....
- Turbo Timer
- will it work
- What is the MAX horsepower out of an EVO?
- SAFCII knock on warm days = more??
- Intakes???
- Turbosmart E-Boost EBC
- Piston with offset pin from Ross for EVO
- HighFlow cat fitment?
- World One Performance
- Is there an easy way to check the tranny fluid?
- Connections for stock boost solenoid... Need help (removing boost controller)
- which boost controller is the best
- Does RPS plan on making their Billet segmented flywheel for the Evo?
- Oil filter spacer
- Installed Hliex DP today
- Boost.... Boost.... Boost.......
- Oil Catch Can for $5
- Jun cam idle fix
- Boost Controllers
- i need some cams
- blitz spark performer
- help with top speed
- What Is Cheapest Way To Get Rid Of Rev Limiter And Fuel Cut
- Shep Racing Rebuild
- NHSTA findings on clutch, 5th sync,wing,vac lines
- RRE No Name Clutch Kit???
- Rating not found for Pennzoil and GM Synchromesh Tranny Fluid
- Precision Turbos for Evo
- Ralliart Ecu And Superchip
- Best Clutch for 300WHP EVO?
- Dyno testing of head/FMIC temps..
- Modding Questions
- Does this part exist?
- AFC Pinouts
- Question about gauge wires and locations
- ACD/AYC Conversion?
- Attention EVO with knock problems
- test pipe
- Strange EGT Gauge Readings
- Best Aftermarket exhaust?
- Is having a high flow cat a must w/catback and dp?
- Bought Turbo XS DP (pics)
- Can someone clear something up for me please?
- dyno numbers
- What should i expect to pay for a clutch install???
- how do I turn my evo into a 2.3 or 2.4 motor?
- turbo back setup??
- Internals Comparison
- Ultimate Racing Downpipe...installed, but rattles for anyone else??
- Need Help!
- US Evo 8 to UK FQ-330 Evo 8
- Don't know what it is but I WANT ONE!
- on idle my vaccum fluctuates a bit
- hks 272 powerband..
- My New Exhaust
- Was 494 now 424.X on Vishnu's Dyno
- More Tranny Problems
- intercooler piping size
- Installed my TB B&B exhaust today
- Ideal motor for 5g mirage evo conversion???
- Datalogger Question
- Studs instead of blots for the cam caps???
- Walbro fuel pump whine
- Crank cost?
- Low Boost with EBC
- How Difficult to Change Radiator?
- Where to get a turbo xs downpipe?
- safe to remove catback completely?
- Rear diff/drivetrain vibration
- 4G63 Similarities?
- Quick shifting problem?
- Rod Knock??
- 1G DSM BOV holding til redline?
- quietest aftermarket exhaust with hp gains
- HKS pressure vein converter
- Question about boost & MBC/EBC
- What is more important with the following mods?
- AEM intake completely sucks. never buy it
- BIG PROBLEM. My Evo is making a horrible clicking noise.
- New Clutch is in!!
- Help! what's this!
- Achieving 300whp
- Is anyone running an aftermarket O2 housing with the stock turbo?
- clutch websites
- Exedy/Cusco Clutch Noise ???
- Evo hesitates in 5th gear around 4000-5000rpm
- valve noise
- anyone know what this noise is?
- Boost gauge questions
- Injen intake for EVO VIII
- Best clutch for non moddified car
- Install day today!
- What is the best Intake?
- Parking Brake Light
- Boost lag?
- Tomei 2.2 liter stroker kit question
- Coolant in spark plug well
- crappy stock intercooler piping
- Magnetic drain plug
- Turbo whirl noise when cold.
- where to buy o2 simulator?
- Clutch install shortcuts
- help please! cars slow
- help... asap
- Swoosh sound
- Buddy Club Spec III
- 5 speed Dog Box
- Water Injection System?
- converting to fwd for dyno use
- HKS 264 and 272 mix setup
- New to the EVO club, couple of moding theories
- Which downpipe to get with Greddy Titanium catback?
- Exhaust system newbie question
- what t3-t4 turbo would match up good to the EVO?
- Clutch Slippage, time for a new one again!
- which cam is good
- change oil after cam install??
- 272 noise
- for ams
- For those still having issues with their Profec B - Spec II...
- Redish black plugs
- Calculating Injector Size
- can anyone hit this?
- K&N Filter
- S-AFC2 wiring diagram
- Does anyone have the HKS supersequential recirv BOV?
- Greddy type S and VTAing.
- bov
- WOT Surge
- What downpipe mounts to the stock cat?
